Страница 6 из 8
Re: Модернизация фрезерного станка 6720вф2+EMC2 + MESA 5i20+
Добавлено: 12 ноя 2013, 11:22
Vova_3000
# Generated by PNCconf at Wed Nov 21 13:23:12 2012
# Все изменения в этом файле будут перезаписаны
# overwritten when you run PNCconf again
[EMC]
MACHINE = CNC_final
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.0500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/vova/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 40
MAX_LINEAR_VELOCITY = 40
MIN_LINEAR_VELOCITY = 1
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i20
[HAL]
HALUI = halui
HALFILE = CNC_final.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 40
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.1
MAX_VELOCITY = 40
MAX_ACCELERATION = 100
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
ENCODER_SCALE = -6545.359
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 300.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = -0.250000
HOME_FINAL_VEL = 0.083333
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.1
MAX_VELOCITY = 40
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 300.0
FERROR =
MIN_FERROR = 0.1
MAX_VELOCITY = 40
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
ENCODER_SCALE = 6545.359
OUTPUT_SCALE = -10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 300.0
HOME_OFFSET = 300.0
HOME_SEARCH_VEL = 0.60000
HOME_LATCH_VEL = 0.250000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
Добавлено: 12 ноя 2013, 13:04
Надо scale для pwmgen настроить...
После
net spindle-vel-cmd => hm2_5i20.0.pwmgen.01.value
напиши:
Вместо XXX значение, должно получиться от -1 до 1. Т.е. value / scale от -1 до 1, т.е. скажем максимальные обороты 1000 об/мин, то надо ставить 1000, вроде как
, в общем подбери значение.
Добавлено: 12 ноя 2013, 16:41
Vova_3000
огромное СПАСИБО!!!
все в порядке!!!
осталось дело за малым.
не отображаются обороты,а только линейка с процентами.
необходимо чтобы приложение запускалось вместе с системой.
Добавлено: 12 ноя 2013, 16:45
Vova_3000
и еще не понятно. как на другом компьютере запустить то что я там наваял?
я установил систему, скопировал папку linuxcnc Со станка, запускаю а там ошибка.
Добавлено: 12 ноя 2013, 16:46
Vova_3000
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.3
Machine configuration directory is '/home/vova/linuxcnc/configs/CNC_final'
Machine configuration file is 'CNC_final.ini'
INIFILE=/home/vova/linuxcnc/configs/CNC_final/CNC_final.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1897
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 No such device
CNC_final.hal:9: exit value: 1
CNC_final.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
1897
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 494.485374] I-pipe: Domain RTAI registered.
[ 494.485378] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 494.485379] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 494.485422] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 494.485423] PIPELINE layers:
[ 494.485425] f8815e20 9ac15d93 RTAI 200
[ 494.485426] c085cb20 0 Linux 100
[ 494.495266] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 494.495370] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 494.495373] RTAI[sched]: hard timer type/freq = APIC/6437477(Hz); default timing: periodic; linear timed lists.
[ 494.495375] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3296571000 hz.
[ 494.495377] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 494.495409] RTAI[usi]: enabled.
[ 494.505805] RTAI[math]: loaded.
[ 494.601347] hm2: loading Mesa HostMot2 driver version 0.15
[ 494.603114] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 494.814084] hm2: unloading
[ 494.874777] RTAI[math]: unloaded.
[ 494.880562] SCHED releases registered named ALIEN RTGLBH
[ 494.942544] RTAI[malloc]: unloaded.
[ 495.042201] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 495.043234] I-pipe: Domain RTAI unregistered.
[ 495.043280] RTAI[hal]: unmounted.
Добавлено: 13 ноя 2013, 00:16
Vova_3000 писал(а):insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 No such device
А там меса вставлена?
Vova_3000 писал(а):необходимо чтобы приложение запускалось вместе с системой.
Или в ./etc/rc.local прописать linuxcnc + путь до конфига. Или через Система - Параметры - Автозапуск.
Vova_3000 писал(а):не отображаются обороты,а только линейка с процентами.
Хм... тоже на днях искал обороты... можно сделать панельку pyvcp - можно даже со стрелкой...
Добавлено: 13 ноя 2013, 00:46
Vova_3000, у нас за хороший ответ ставят плюсик, рядом с цитата
Добавлено: 13 ноя 2013, 11:49
Vova_3000
понял Спасибо!!
Добавлено: 13 ноя 2013, 11:54
Vova_3000
Я панельку делать пытаюсь, да только она не работает.
висит просто как картинка и все тут.
вроде все по учебнику а чет не идет.
Добавлено: 13 ноя 2013, 12:16
Vova_3000 писал(а):Я панельку делать пытаюсь, да только она не работает.
то есть :
панель видна ,кнопочки нажимаются и все отстальное визуально срабатывает, пины панели скоммутированны в
файле postgui_call_list.hal ,а реально пины не отрабатывают?
и ошибки никакой нет?
Добавлено: 13 ноя 2013, 12:18
Покажи свои все hal, ini и саму панельку.
Добавлено: 13 ноя 2013, 16:31
Vova_3000
hal
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i20/SV12IM_2X7I48_72.BIT num_encoders=6 num_pwmgens=6 num_3pwmgens=0 num_stepgens=0 "
setp hm2_5i20.0.pwmgen.pwm_frequency 24000
setp hm2_5i20.0.pwmgen.pdm_frequency 24000
setp hm2_5i20.0.watchdog.timeout_ns 10000000
loadrt pid names=pid.x,pid.y,pid.z
addf hm2_5i20.0.read servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf hm2_5i20.0.write servo-thread
addf hm2_5i20.0.pet_watchdog servo-thread
#------- Limits
# --- MIN-HOME-X ---
net min-home-x <= hm2_5i20.0.gpio.024.in
# --- MAX-X ---
net max-x <= hm2_5i20.0.gpio.025.in
# --- MIN-HOME-Y ---
net min-home-y <= hm2_5i20.0.gpio.026.in
# --- MAX-Y ---
net max-y <= hm2_5i20.0.gpio.027.in
# --- MAX-HOME-Z ---
net max-home-z <= hm2_5i20.0.gpio.028.in
# --- MIN-Z ---
net min-z <= hm2_5i20.0.gpio.029.in
#------- Limits
# ---setup home / limit switch signals---
net min-home-x => axis.0.home-sw-in
net min-home-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
net min-home-y => axis.1.home-sw-in
net min-home-y => axis.1.neg-lim-sw-in
net max-y => axis.1.pos-lim-sw-in
net max-home-z => axis.2.home-sw-in
net min-z => axis.2.neg-lim-sw-in
net max-home-z => axis.2.pos-lim-sw-in
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-output => pid.x.output
net x-pos-cmd => pid.x.command
net x-vel-fb => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
# ---PWM Generator signals/setup---
setp hm2_5i20.0.pwmgen.00.output-type 2
setp hm2_5i20.0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE
net x-output => hm2_5i20.0.pwmgen.00.value
net x-pos-cmd axis.0.motor-pos-cmd
net x-enable axis.0.amp-enable-out => hm2_5i20.0.pwmgen.00.enable
# ---Encoder feedback signals/setup---
setp hm2_5i20.0.encoder.00.counter-mode 0
setp hm2_5i20.0.encoder.00.filter 1
setp hm2_5i20.0.encoder.00.index-invert 0
setp hm2_5i20.0.encoder.00.index-mask 0
setp hm2_5i20.0.encoder.00.index-mask-invert 0
setp hm2_5i20.0.encoder.00.scale [AXIS_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i20.0.encoder.00.position
net x-vel-fb <= hm2_5i20.0.encoder.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_5i20.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i20.0.encoder.00.rawcounts
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-output => pid.y.output
net y-pos-cmd => pid.y.command
net y-vel-fb => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
setp hm2_5i20.0.pwmgen.02.output-type 2
setp hm2_5i20.0.pwmgen.02.scale [AXIS_1]OUTPUT_SCALE
net y-output => hm2_5i20.0.pwmgen.02.value
net y-pos-cmd axis.1.motor-pos-cmd
net y-enable axis.1.amp-enable-out => hm2_5i20.0.pwmgen.02.enable
setp hm2_5i20.0.encoder.02.counter-mode 0
setp hm2_5i20.0.encoder.02.filter 1
setp hm2_5i20.0.encoder.02.index-invert 0
setp hm2_5i20.0.encoder.02.index-mask 0
setp hm2_5i20.0.encoder.02.index-mask-invert 0
setp hm2_5i20.0.encoder.02.scale [AXIS_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i20.0.encoder.02.position
net y-vel-fb <= hm2_5i20.0.encoder.02.velocity
net y-pos-fb => axis.1.motor-pos-fb
net y-index-enable axis.1.index-enable <=> hm2_5i20.0.encoder.02.index-enable
net y-pos-rawcounts <= hm2_5i20.0.encoder.02.rawcounts
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-output => pid.z.output
net z-pos-cmd => pid.z.command
net z-vel-fb => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
setp hm2_5i20.0.pwmgen.04.output-type 2
setp hm2_5i20.0.pwmgen.04.scale [AXIS_2]OUTPUT_SCALE
net z-output => hm2_5i20.0.pwmgen.04.value
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out => hm2_5i20.0.pwmgen.04.enable
setp hm2_5i20.0.encoder.04.counter-mode 0
setp hm2_5i20.0.encoder.04.filter 1
setp hm2_5i20.0.encoder.04.index-invert 0
setp hm2_5i20.0.encoder.04.index-mask 0
setp hm2_5i20.0.encoder.04.index-mask-invert 0
setp hm2_5i20.0.encoder.04.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i20.0.encoder.04.position
net z-vel-fb <= hm2_5i20.0.encoder.04.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i20.0.encoder.04.index-enable
net z-pos-rawcounts <= hm2_5i20.0.encoder.04.rawcounts
# SPINDLE S
setp hm2_5i20.0.pwmgen.01.scale 6000
net machine-is-enabled => hm2_5i20.0.pwmgen.01.enable
# ---setup spindle control signals---
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-on <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
# ---Setup spindle at speed signals---
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
#net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out <= iocontrol.0.user-enable-out
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
loadusr -W hal_manualtoolchange
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
Добавлено: 13 ноя 2013, 16:33
Vova_3000
custom
# ---classicladder---
loadrt classicladder_rt
addf classicladder.0.refresh servo-thread
loadusr -w classicladder --nogui classicladder_as.clp
# zashim-otshim
net zashim-sig classicladder.0.in-00 <= hm2_5i20.0.gpio.036.in
net zashim-sig-out classicladder.0.out-00 => hm2_5i20.0.gpio.044.out
net otshim-sig classicladder.0.in-02 <= hm2_5i20.0.gpio.035.in
net otshim-sig-out classicladder.0.out-01 => hm2_5i20.0.gpio.045.out
net machine-is-enabled => classicladder.0.in-01
# lube-cycle
net lube-sig classicladder.0.in-03 <= hm2_5i20.0.gpio.033.in
net lube-sig-out classicladder.0.out-02 => hm2_5i20.0.gpio.043.out
net lube iocontrol.0.lube => classicladder.0.in-04
setp hm2_5i20.0.gpio.043.is_output true
setp hm2_5i20.0.gpio.043.is_opendrain true
setp hm2_5i20.0.gpio.043.invert_output true
setp hm2_5i20.0.gpio.044.is_output true
setp hm2_5i20.0.gpio.044.is_opendrain true
setp hm2_5i20.0.gpio.044.invert_output true
setp hm2_5i20.0.gpio.045.is_output true
setp hm2_5i20.0.gpio.045.is_opendrain true
setp hm2_5i20.0.gpio.045.invert_output true
# external output signals
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled hm2_5i20.0.gpio.040.out
setp hm2_5i20.0.gpio.040.is_output true
setp hm2_5i20.0.gpio.040.is_opendrain true
setp hm2_5i20.0.gpio.040.invert_output true
# --- SPINDLE-ON ---
net spindle-on hm2_5i20.0.gpio.041.out
setp hm2_5i20.0.gpio.041.is_output true
setp hm2_5i20.0.gpio.041.is_opendrain true
setp hm2_5i20.0.gpio.041.invert_output true
# --- SOH-OUT ---
net coolant-flood hm2_5i20.0.gpio.042.out
setp hm2_5i20.0.gpio.042.is_output true
setp hm2_5i20.0.gpio.042.is_opendrain true
setp hm2_5i20.0.gpio.042.invert_output true
# --- E-stop ---
#net e-stop <= hm2_5i20.0.gpio.030.in
# --- SPINDLE ---
net spindle <= hm2_5i20.0.gpio.031.in
Добавлено: 13 ноя 2013, 16:36
Vova_3000
ini
[EMC]
MACHINE = CNC_final
DEBUG = 0
[DISPLAY]
DISPLAY = axis
INTRO_TIME = 5
EDITOR = gedit
GEOMETRY = xyz
PYVCP = custompanel.xml
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HOSTMOT2]
# DRIVER0=hm2_pci
# BOARD0=5i20
[HAL]
HALUI = halui
POSTGUI_HALFILE = spindle_to_pyvcp.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.1
MAX_VELOCITY = 40
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 300.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 1
MIN_FERROR = 0.1
MAX_VELOCITY = 40
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
OUTPUT_SCALE = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 300.0
FERROR =
MIN_FERROR = 0.1
MAX_VELOCITY = 40
P = 7.8
I = 120.0
D = 0.0
FF0 = 0.0005
FF1 = 0.0402
FF2 = 0.0001
BIAS = 0.0
DEADBAND = 0.0003
MAX_OUTPUT = 10.0
MIN_LIMIT = -0.01
MAX_LIMIT = 300.0
HOME_OFFSET = 300.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
Добавлено: 13 ноя 2013, 16:39
Vova_3000
сама картинка
<?xml version='1.0' encoding='UTF-8'?>
<pyvcp>
<vbox>
<relief>RIDGE</relief>
<bd>6</bd>
<label>
<text>"Spindle Speed:"</text>
<font>("Helvetica",20)</font>
</label>
<bar>
<halpin>"spindle-speed"</halpin>
<max_>3000</max_>
</bar>
<label>
<text>"Spindle-At-Speed:"</text>
</label>
<hbox>
<label>
<text>" "</text>
</label>
<led>
<halpin>"spindle-at-speed-led"</halpin>
<size>30</size>
<on_color>"green"</on_color>
<off_color>"red"</off_color>
</led>
</hbox>
</vbox>
</pyvcp>
Добавлено: 13 ноя 2013, 16:42
Vova_3000
и вот так а когда в хал прописываю net spindle-rpm-filtered => pyvcp.spindle-speed то emc не запускается.
Добавлено: 13 ноя 2013, 17:35
А что говорит? Пина нет? В какой hal прописываешь?
Надо в
А у тебя наверное в нем есть...
Добавлено: 14 ноя 2013, 12:42
Vova_3000
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.1
Machine configuration directory is '/home/cnc01/linuxcnc/configs/CNC_final'
INIFILE=/home/cnc01/linuxcnc/configs/CNC_final/CNC_final.ini
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=3069
Cleanup done
CNC_final.hal:226: Pin 'pyvcp.spindle-speed' does not exist
3069
[ 7032.398316] I-pipe: Domain RTAI registered.
[ 7032.398340] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 7032.398345] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 7032.398360] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7032.398365] PIPELINE layers:
[ 7032.398371] e116fe20 9ac15d93 RTAI 200
[ 7032.398375] c085cb20 0 Linux 100
[ 7032.454237] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7032.454640] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 7032.454651] RTAI[sched]: hard timer type/freq = APIC/6264148(Hz); default timing: periodic; linear timed lists.
[ 7032.454658] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2004577000 hz.
[ 7032.454662] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 7032.454870] RTAI[usi]: enabled.
[ 7032.692505] RTAI[math]: loaded.
[ 7032.883684] hm2: loading Mesa HostMot2 driver version 0.15
[ 7032.893704] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 7032.893771] hm2_pci: discovered 5i20 at 0000:03:03.0
[ 7032.893908] hm2_5i20.0: firmware: requesting hm2/5i20/SV12IM_2X7I48_72.BIT
[ 7033.035796] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 7033.035806] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 7033.035810] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 7033.047940] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 7033.047953] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 7033.047959] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 7033.047965] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 7033.047971] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 7033.047976] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 7033.047982] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 7033.047987] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 7033.047993] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 7033.047999] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 7033.048004] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 7033.048010] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 7033.048016] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 7033.048022] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 7033.048028] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 7033.048034] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 7033.048110] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 7033.048121] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 7033.048126] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 7033.048132] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 7033.048137] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 7033.048143] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 7033.048148] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 7033.048153] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 7033.048158] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 7033.048163] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 7033.048167] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 7033.048171] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 7033.048176] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 7033.048180] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 7033.048184] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 7033.048188] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 7033.048192] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 7033.048196] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 7033.048200] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 7033.048206] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 7033.048210] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 7033.048215] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 7033.048219] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 7033.048223] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 7033.048227] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 7033.048231] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 7033.048235] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 7033.048239] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 7033.048244] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 7033.048248] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 7033.048252] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 7033.048256] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 7033.048260] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 7033.048265] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 7033.048271] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 7033.048276] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 7033.048281] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 7033.048285] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 7033.048289] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 7033.048293] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 7033.048297] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 7033.048301] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 7033.048305] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 7033.048309] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 7033.048313] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 7033.048318] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 7033.048322] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 7033.048326] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 7033.048330] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 7033.048334] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 7033.048338] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 7033.048342] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 7033.048346] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 7033.048350] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 7033.048354] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 7033.048359] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 7033.048363] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 7033.048583] hm2/hm2_5i20.0: registered
[ 7033.048589] hm2_5i20.0: initialized AnyIO board at 0000:03:03.0
[ 7034.058782] hm2_5i20.0: dropping AnyIO board at 0000:03:03.0
[ 7034.058802] hm2/hm2_5i20.0: unregistered
[ 7034.062427] hm2_pci: driver unloaded
[ 7034.071441] hm2: unloading
[ 7034.203552] RTAI[math]: unloaded.
[ 7034.374330] SCHED releases registered named ALIEN RTGLBH
[ 7034.388666] RTAI[malloc]: unloaded.
[ 7034.488045] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7034.497181] I-pipe: Domain RTAI unregistered.
[ 7034.497205] RTAI[hal]: unmounted.
Добавлено: 14 ноя 2013, 12:46
Vova_3000
Не пойму где нужно прописать , и что
Добавлено: 14 ноя 2013, 12:47
попробуй просто в ини HALFILE = CNC_final.hal
заменить на POSTGUI_HALFILE = CNC_final.hal
