Бесплатные CAD CAM CNC программы Free CAD CAM CNN Software
xentaur
Сообщение xentaur »
Вот такой списочек попался - думаю многим интересно посмотреть.
Free CAD Software
A9 CAD CAD http://www.a9tech.com/products/a9cad/
Blender CAD https://www.blender.org/
eCabinet: CAD for custom cabinet makers CAD http://www.ecabinetsystems.com/
gCAD3d CAD http://www.cadcam.co.at/freiter/gCAD3D_en.htm
Google Sketchup CAD https://sketchup.google.com/
GraphiteOne CAD CAD https://www.graphiteone-cad.com/
Minos CAD http://www.le-boite.com/minos.htm
Solid Edge Free 2D Drafting CAD http://www.solidedge.com/free2d/
Wings 3D CAD https://www.wings3d.com/
Free CAM Software
Free Mill: 3D Milling from the makers of Visual Mill * CAM http://www.mecsoft.com/freemill.shtml
HSMExpress CAM http://www.hsmworks.com/hsmxpress/
G-Simple CAM https://www.gsimple.eu/
Heeks CAD/CAM CAM https://www.heeks.net/
* = Mecsoft are thoroughly legit and partners of ours. This freeware will not contain malware!
Other Free CNC Software
EMC2 CNC Controller https://www.linuxcnc.org/
Jedicut CNC Foam Cutting http://www.aeropassion.net/index-en.php
GenGCode Conversational G-Code http://home.inter.net/mthomas/Download.htm
Jon Elson's Free Programs to Write G-Code Conversational G-Code http://jelinux.pico-systems.com/gcode.html
Ace Converter DXF to G-Code http://www.dakeng.com/ace.html
2linc Engraving Software: Light Version Engraving Software http://www.2linc.com/cnc_programming_software.htm
DeskEngrave Engraving Software http://www.deskam.com/download.html
PCB-GCODE G-Code for Eagle PCB https://groups.yahoo.com/group/pcb-gcode/
Auto-trace Image or bitmap to g-code http://autotrace.sourceforge.net/
Image to G-Code Image or bitmap to g-code http://www.imagetogcode.com/
Scan2CNC Image or bitmap to g-code http://www.gravomaster.com/Tristan_Dean/scan2cnc.html
MaxCut Nesting http://www.maxcut.co.za/
Навеяно темой про использование CAD. Gcodetools не хватает. :cry:
Re: Бесплатные CAD CAM CNC программы Free CAD CAM CNN Softwa
Сообщение nkp »
может кто даст ссылочку на русиф SheetCam ?
Развивающая продукт компания Dassault Systèmes находится на рынке систем 3D/2D-моделирования с 1981 года. По задумке создателей, продукт DraftSight должен стать первой профессиональной бесплатной системой 2D-проектирования, предоставляющей набор инструментов на уровне AutoCAD и способной просматривать и редактировать проекты, созданные в AutoCAD.
http://www.3ds.com/products/draftsight/ ... -software/
Под линукс есть!
aegis
Настоящее имя: Михайло
Сообщение aegis »
UAVpilot, пытались нас на работе на драфтсайт перевести...
Г редкостное. функционал на уровне 2004 акада
нікому нічого не нав'язую.
sandman
Сообщение sandman »
Dassault Systèmes и CATIA сделали, хорошая система...
Сообщение nkp »
Небольшой вводный видеоурок FreeCAD и Heeks CAD/CAM:
https://www.youtube.com/watch?v=NP9YZwHbBE4
nkp писал(а):Небольшой вводный видеоурок FreeCAD и Heeks CAD/CAM:
А может ну нафик эти Inkscape и Gcodetools?.. :hehehe:
SNC00286.jpg (103186 просмотров) <a class='original' href='./download/file.php?id=7414&sid=ae60a9ae536e0837fee0e470050de329&mode=view' target=_blank>Загрузить оригинал (282.95 КБ)</a>
Всё сделано исключительно в линуксе.
nkp писал(а):HeeksCNC
Если кому надо, то выложу HeeksCAD+HeeksCNC+прибамбасы собранные в RPM для Fedora16/17.
Сообщение nkp »
а что за прибамбасы?
nkp писал(а):а что за прибамбасы?
Пара модулей для питона: libarea и libactp, без них работать будет, но G-код генерить не сможет и те зелёные линии-траектории тоже не будет рисовать.
Сообщение nkp »
Тогда давай -нам без зеленых линий никак ;)
А серьезно-если конвертнуть рпм в деб - установиться?Или там по другому надо(в убунту )?
Так по твоей-же ссылке есть готовые .deb. Да и в исходниках есть всё, что нужно для сбора в виде deb, это для rpm пришлось руки прикладывать.
Сообщение nkp »
Так я ж подумал там чтой-то еще эксклюзивное включено!
UAVpilot писал(а): Да и в исходниках есть всё, что нужно для сбора в виде deb, это для rpm пришлось руки прикладывать.
А всякие там alien не работают?
UAVpilot писал(а):А может ну нафик эти Inkscape и Gcodetools?..
Я только за! Мне же меньше работы :hehehe:
Но наверное не всем это подойдет. Как-то пытался на фрикаде порисовать, у меня от него моск свернулся. Я понимаю, что это не обычная рисовалка, а скорее интерфейс к каскаду, но все же тяжело с ним разобраться. Он больше подходит для технических деталей, в отличие от Gcodetools который больше по художественным обработкам...
Кстати, в нем есть импорт svg? Интересно проверить эти зеленые траектории на сложных контурах :)...
nkp, пока нет, хотя доработка не помешает. Например оно в начале g-кода вставляет
O123(Test Program)
а linuxcnc пугается этого O1234.
Собственно я просто собрал всё это в работоспособную кучку, а то эти lib* существуют отдельно и при сборке не проверяется их наличие и соотв. зависимости не строятся.
Nick, я считаю применение этих alien и им подобных некошерным методом.
Я после видеоурока на украинском вроде разобрался как в нём рисовать. Попробую по этой технологии сделать "щетку" от стружки на шпиндель.
Inkscape конечно попонятнее будет, но из-за того, что в нём объекты нельзя позиционировать относительно их центров просто нереально делать чертежи посложней, приходится сидеть с калькулятором и помнить все поправки и смещения.
SVG поддерживает.
FreeCAD умеет читать форматы:
freecad-imp.png (103154 просмотра) <a class='original' href='./download/file.php?id=7423&sid=ae60a9ae536e0837fee0e470050de329&mode=view' target=_blank>Загрузить оригинал (16.38 КБ)</a>
Умеет экспортировать в форматы:
HeeksCAD понимает форматы:
heekscad-imp.png (103154 просмотра) <a class='original' href='./download/file.php?id=7425&sid=ae60a9ae536e0837fee0e470050de329&mode=view' target=_blank>Загрузить оригинал (17.41 КБ)</a>
Сообщение nkp »
UAVpilot писал(а):Я после видеоурока на украинском
Вообще то на польском :hehehe:
Жесть! А я по украински слушал. :hehehe:
Steel.ne
Сообщение Steel.ne »
А этот HeeksCNC умеет гравировку с подрезкой углов?
А то посмотрел - как-то простенько. Карманы, отверстия.
В принципе все то, что умеет gcodetools. Но наглядно, ничего не скажешь.
Steel.ne писал(а):А этот HeeksCNC умеет гравировку с подрезкой углов?
Если пояснишь что это за гравировка такая (я гравировку даж не пробовал никогда), то попробую.
Чертежи из других CADом в g-код переводить попроще будет.
Оно ещё G-код получше генерит, само правильные подходы-отходы делает и траектории оптимизит.
Может и ещё чего хорошего - я пока изучаю. У меня задача - обходится без винды.
