Gears extension improvements
Gears extensions improvements
We've made some improvements of Gears extension. It adds holes to the gear.
Here's an example:
gears extension gcode tools.png (27477 просмотров) <a class='original' href='./download/file.php?id=1090&sid=1d0bd72e153953c7f2f3e08cdd9f22d1&mode=view' target=_blank>Загрузить оригинал (99.13 КБ)</a>
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart Inkscape.
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart Inkscape.
Latest version
gears-dev.tar.gz
(3.4 КБ) 3147 скачиваний
rray
Re: Gears extension improvements
Сообщение rray »
Cool
I have units set to inch
Under advanced options -> mount hole diameter I set to 0.250
I switch to gears tab and back to advanced option and mount hole diameter has changed to 0.2
It seems that I can not set more than 1 decimal place
Richard
Fixed that. 5 digits is enough, or not?
gears-dev.tar.gz
(3.42 КБ) 2508 скачиваний
Thanks for the report :)!
When will I start to write the code without bugs :roll:?
PS have you seen Unordinare gears extension? http://www.cnc-club.ru/forum/viewtopic.php?f=33&t=433
rray
Сообщение rray »
I have seen your Unordinary gears extension but not tried it, YET
I plan to
I think no app has ever been written without bugs
That is what killed Multics
Richard
juewei
Сообщение juewei »
Nick, all!
I've made some small improvements on your great gears-dev extension.
Please have a look at https://github.com/jnweiger/inkscape-gears-dev
- one can now switch from cyclic pitch to metric module, which is more common in europe.
- one can now lower the nodes count per tooth, which is helpful with large numbers of teeth.
- raised the limit on the number of teeth above 1000
- added an option to define some clearance at the inner tooth diameter
- fixed the rotation center.
I've also taken the liberty to send it upstream to be eventually included in official inkscape releases.
https://bugs.launchpad.net/inkscape/+bug/1295641
Awesome!
Hopefully we'll see it soon in official Inkscape release :)
Вернуться в «English forum»
