Is there a new link to "Engraving tutorial by Dormouse" http://kalyaev.com/2010/20100402/tut01/tut01.html
I get a lookup error for this one
Richard
Is there a new link
- Nick
- Заслуга: Developer
Re: Is there a new link
I've just checked it's working.
Newer the less here's a achieved copy:
- Вложения
- tut01.mht.tar.gz
- (11.41 МБ) 1635 скачиваний
From here, southern US, I get
$ dig http://kalyaev.com
; <<>> DiG 9.3.6-P1-RedHat-9.3.6-4.P1.el5_4.2 <<>> http://kalyaev.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 57798
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;http://kalyaev.com. IN A
;; AUTHORITY SECTION:
com. 900 IN SOA a.gtld-servers.net. nstld.verisign-grs.com. 1301428046 1800 900 604800 86400
;; Query time: 79 msec
;; SERVER: 172.17.32.45#53(172.17.32.45)
;; WHEN: Tue Mar 29 14:48:09 2011
;; MSG SIZE rcvd: 109
;; Got answer:
- Nick
Probably there are some problems with the server and your location...
Have you checked the attached file? Is it fine?
I can not make heads nor tails of the attached file
- Nick
I've got an idea try to use anonymouse it should work:
http://anonymouse.org/cgi-bin/anon-www. ... tut01.html
By the way what is your task? May be I can help you with it .
this works ok but is over my headroot писал(а):I've got an idea try to use anonymouse it should work:
http://anonymouse.org/cgi-bin/anon-www. ... tut01.html.
i was looking at your engraving extension and for the life of me i can not figure what i would use it forroot писал(а):By the way what is your task? May be I can help you with it .
i tried it on a few things and have not gotten good results
i am sure it is just me
i attached an example of one design i tried it on
richard
- Вложения
- design_1.svg
- (11.58 КБ) 1415 скачиваний
- Nick
What kind of mill bit are you going to use? Shape, diameter?
You are right, engraving function is a kind of strange one . We've developed it with one of the members of cnc-club. So his problem was to cut the thing places.
For example if we have ornament with smooth edges we can cut it's internal using only large cylindrical mill (for example 1/2" ).
But how to cut sharp corners or thin places that are less than 1/4"? We can try to cut it with the cone mill bit.
So we've developed engraving function to to that job.
And later it appeared that it the whole ornament is thing enough to be cut from the first pass you can use only engraving function to create the Gcode.
It appeared to be very useful while cutting texts.
I'll try to make a tutorial using your svg...
PS sorry for my "English"
