Radius to end arc diffemrs from start - Inkscape 0.91 error
Добавлено: 30 мар 2015, 07:26
Good afternoon all,
I'm very excited about this plugin for Inkscape, but I'm having troubles getting the gcode to function.
I'm running Inkscape's new stable 0.91 version, and the code has worked just fine in a couple of online test programs, but it fails in Mach3 at line 131 with the above error.
From other forums it looks like a problem of I/J coordinates; are they absolute or incremental? Unfortunately I have no idea. Is the Inkscape extension producing them as Incremental or Absolute? Do I need G90.1 or G91.1 code to specify what it is? Does anyone know what Mach3 is assuming they are?
Thanks so much everyone.
