crown wheel drive
tecdroid
crown wheel drive
Сообщение tecdroid »
hello,
i want to create a crown gear drive so that my motor lies orthogonally to my wheel (which will also be the bog crown wheel)
something like the one on the right side of this picture but i want to mill the bumps using a second layer.
All has to be small since my big wheel must not be bigger than 3-4cm, my normal bit is of 1mm size.
inkscape gears aren't made for milling. when i lose 1mm on the edges, I fear that it won't fit anymore.
did anybody ever try this?
narvf
Re: crown wheel drive
Сообщение narvf »
Try with this, maybe result will be good for you :)
gears-tutotial.svg
(230.02 КБ) 1026 скачиваний
tecdroid
hi, thanks :) this helped me building some interesting gears- even if i fear they won't last very long since they're made of wood.
narvf
Сообщение narvf »
would be nice to see some photos :)
Вернуться в «English forum»
