G64 vs G61
narvf
G64 vs G61
Сообщение narvf »
Can someone explain difference? When to use G64? From what i've observed in my machine, should I always use G61? When using high speed and G64 -i think this is default, the path of tool is different on corners and etc... Are there different ways to avoid G61? The main reason is when i try to engrave on plexi, when machine stops after each "path", it can bee seen on plexiglass and it's not looking good. With G64 recatangle for example will have rounded corners...
Re: G64 vs G61
G64 P0.1 can be an option - P defines distance from the path that machine can go off.
narvf
Re: G64 vs G61
Сообщение narvf »
Ok, will try this. Thank you.
But I'm curious how other people are using in projects :)
Re: G64 vs G61
That really "depends" :)
Вернуться в «English forum»
