G64 vs G61
Добавлено: 12 ноя 2014, 15:14
Can someone explain difference? When to use G64? From what i've observed in my machine, should I always use G61? When using high speed and G64 -i think this is default, the path of tool is different on corners and etc... Are there different ways to avoid G61? The main reason is when i try to engrave on plexi, when machine stops after each "path", it can bee seen on plexiglass and it's not looking good. With G64 recatangle for example will have rounded corners...
