Tabs or bridges
James628
Tabs or bridges
Сообщение James628 »
Hi,
Is there any possibility in Gcodetools (maybe in dev version) which I can use to prevent flying/jumping out parts after they are fully cut out/around?
They are called "tabs" or "bridges" in other CAM tools and G code generators.
Or perhaps the current voting "Live bridges while cutting [export]" is all about it?
If there is no such functionality implemented right now, can you advice some tricks, which can be used instead?
Regards:
James
Re: Tabs or bridges
It's not implemented yet. :(
But there's a trick... the trick is to use custom depth function and split a path. There's a video on youtube about it, but it's in Russian.
http://www.youtube.com/watch?feature=pl ... VgXx-HKXVs
Hmmm... yousually youtube sujests me to translate the video I'm watching, but now I can not find that button...
Вернуться в «English forum»
