Tabs or bridges
Добавлено: 22 фев 2013, 19:31
Hi,
Is there any possibility in Gcodetools (maybe in dev version) which I can use to prevent flying/jumping out parts after they are fully cut out/around?
They are called "tabs" or "bridges" in other CAM tools and G code generators.
Or perhaps the current voting "Live bridges while cutting [export]" is all about it?
If there is no such functionality implemented right now, can you advice some tricks, which can be used instead?
Regards:
James
Regards:
James
