Tangential knife lifts
Добавлено: 31 окт 2017, 01:59
Hello
So far I have had good success with the software, but I have one problem.
I need gcode with few arcs, because arduino / RAMPS doesn't handle arcs well. This I can do by setting the arc angle to a very high value.
I would like to have lifts between moves for the tangential knife, but so far can only make it lift every time via the parameters.
I would like to have it lift only when the angle is greater than a certain value, so that it does not lift between segments of a circle.
I am willing to make changes to the code if it's not supported. Any suggestions?
Thanks for the great software.
