EMC2 problem
Добавлено: 14 июн 2011, 05:39
Hello
I've been trying to get my Ubuntu 10.04 EMC2 Live cd installation to work but no luck... Ubuntu works fine, EMC2 runs fine, but my motors don't move. I've used stepconf but when I try to test the axis nothing happens. I tested the parallel port output, and this is where it gets strange... I get a constant +5.26vdc from pins 2-7 no matter what I do. I mean it stays constant if i'm not running EMC2. I tried parport port tester but I get the same result. Can someone please help. I've been trying for a month with no luck..... I'm going crazy
