Продам детали гравировального станка,
gantry (steel) 283 USD
side boards for gentry 170USD
frame for Y The height of the frame for Y if possible should be lower, approximately 18-26 sm (for easy transportation from Urumchi to Uzbekistan, as cubic metre cost 850 USD+in the Territory of China+the distance to my workshop) 850USD
100мм spindle Fixture 1pc 54USD
Gear rack 1meter 58USD
pinion shaft 43USD
HIWIN Linear guidway 25mm. (ForY) 82USD
HIWIN Linear guidway 20mm. (For X&Z) 74USD
big pulley 3 71USD
smaller pulley 5 51USD
timing belt 3 25USD
small timing belt 1 7.5USD
plate forZ h=450mm 1 99USD
посмотрите на картины!
