Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/max/linuxcnc/configs/5i25_prob_rfx2'
Machine configuration file is '5i25_prob_rfx2.ini'
INIFILE=/home/max/linuxcnc/configs/5i25_prob_rfx2/5i25_prob_rfx2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./5i25_prob_rfx2.hal
hm2: loading Mesa HostMot2 driver version 0.15
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:00:3a
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): IOPort
hm2/hm2_7i92.0: IO Pin 006 (P2-04): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): IOPort
hm2/hm2_7i92.0: IO Pin 008 (P2-05): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): IOPort
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Encoder #0, pin A (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Encoder #0, pin B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Encoder #0, pin Index (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0: IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0: IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0: IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0: IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0: IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0: IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0: IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0: IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0: IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0: IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): Encoder #1, pin A (Input)
hm2/hm2_7i92.0: IO Pin 032 (P1-12): Encoder #1, pin B (Input)
hm2/hm2_7i92.0: IO Pin 033 (P1-13): Encoder #1, pin Index (Input)
hm2/hm2_7i92.0: registered
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=7962
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
Note: Using POSIX realtime
sched_setaffinity: Invalid argument
./5i25_prob_rfx2.hal:61: Ini variable '[AXIS_0]STEPGEN_MAXVEL' not found.
7962
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-4-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT RT Debian 3.2.89-2
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d000 (usable)
[ 0.000000] BIOS-e820: 000000000009d000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bf681000 (usable)
[ 0.000000] BIOS-e820: 00000000bf681000 - 00000000bf6bf000 (reserved)
[ 0.000000] BIOS-e820: 00000000bf6bf000 - 00000000bf74d000 (usable)
[ 0.000000] BIOS-e820: 00000000bf74d000 - 00000000bf7bf000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bf7bf000 - 00000000bf7e3000 (usable)
[ 0.000000] BIOS-e820: 00000000bf7e3000 - 00000000bf7ff000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bf7ff000 - 00000000bf800000 (usable)
[ 0.000000] BIOS-e820: 00000000bf800000 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f8000000 (reserved)
[ 0.000000] BIOS-e820: 00000000feb00000 - 00000000feb04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed10000 - 00000000fed14000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed18000 - 00000000fed1a000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1b000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000017c000000 (usable)
[ 0.000000] BIOS-e820: 000000017c000000 - 0000000180000000 (reserved)
[ 0.000000] BIOS-e820: 0000000180000000 - 00000001bc000000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: eMachines eME732G/HM55_CP, BIOS V1.11 05/27/2011
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1bc000 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-combining
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 0FFE00000 mask FFFE00000 write-protect
[ 0.000000] 2 base 080000000 mask FC0000000 write-back
[ 0.000000] 3 base 0BF800000 mask FFF800000 uncachable
[ 0.000000] 4 base 100000000 mask F00000000 write-back
[ 0.000000] 5 base 1BC000000 mask FFC000000 uncachable
[ 0.000000] 6 base 1C0000000 mask FC0000000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 365c6000 - 372db000
[ 0.000000] ACPI: RSDP 0x00000000000FE020 00024 (v02 ACRSYS)
[ 0.000000] ACPI: XSDT 0x00000000BF7FE120 00074 (v01 ACRSYS ACRPRDCT 00000001 01000013)
[ 0.000000] ACPI: FACP 0x00000000BF7FC000 000F4 (v04 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: DSDT 0x00000000BF7ED000 0B073 (v02 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: FACS 0x00000000BF75F000 00040
[ 0.000000] ACPI: ASF! 0x00000000BF7FD000 000A5 (v32 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: HPET 0x00000000BF7FB000 00038 (v01 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: APIC 0x00000000BF7FA000 0008C (v02 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: MCFG 0x00000000BF7F9000 0003C (v01 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: SLIC 0x00000000BF7EC000 00176 (v01 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: BOOT 0x00000000BF7E9000 00028 (v01 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: ASPT 0x00000000BF7E5000 00034 (v04 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: WDAT 0x00000000BF7E4000 00224 (v01 ACRSYS ACRPRDCT 00000001 1025 01000013)
[ 0.000000] ACPI: SSDT 0x00000000BF7E3000 009F1 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 6214MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x001bc000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[7] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000bf681
[ 0.000000] 0: 0x000bf6bf -> 0x000bf74d
[ 0.000000] 0: 0x000bf7bf -> 0x000bf7e3
[ 0.000000] 0: 0x000bf7ff -> 0x000bf800
[ 0.000000] 0: 0x00100000 -> 0x0017c000
[ 0.000000] 0: 0x00180000 -> 0x001bc000
[ 0.000000] On node 0 totalpages: 1537729
[ 0.000000] free_area_init_node: node 0, pgdat c1415480, node_mem_map f2e46200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 12429 pages used for memmap
[ 0.000000] HighMem zone: 1297577 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x05] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x00] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:30000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 93 pages/cpu @f76e9000 s360192 r0 d20736 u380928
[ 0.000000] pcpu-alloc: s360192 r0 d20736 u380928 alloc=93*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1523520
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-rt-686-pae root=UUID=0682ec85-3b6d-4d11-9c12-e5f79c8e6da5 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 isolcpus=1 acpi_irq_nobalance noirqbalance
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:001bc000)
[ 0.000000] Memory: 6070664k/7274496k available (2867k kernel code, 80252k reserved, 1343k data, 728k init, 5240024k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc141d000 - 0xc14d3000 ( 728 kB)
[ 0.000000] .data : 0xc12ccde0 - 0xc141cb40 (1343 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12ccde0 (2867 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f2808000 soft=f280a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2393.906 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 4787.81 BogoMIPS (lpj=9575624)
[ 0.000005] pid_max: default: 32768 minimum: 301
[ 0.000045] Security Framework initialized
[ 0.000050] AppArmor: AppArmor disabled by boot time parameter
[ 0.000066] Mount-cache hash table entries: 512
[ 0.000180] Initializing cgroup subsys cpuacct
[ 0.000185] Initializing cgroup subsys memory
[ 0.000193] Initializing cgroup subsys devices
[ 0.000195] Initializing cgroup subsys freezer
[ 0.000197] Initializing cgroup subsys net_cls
[ 0.000199] Initializing cgroup subsys blkio
[ 0.000203] Initializing cgroup subsys perf_event
[ 0.000231] CPU: Physical Processor ID: 0
[ 0.000232] CPU: Processor Core ID: 0
[ 0.000237] mce: CPU supports 9 MCE banks
[ 0.000247] CPU0: Thermal monitoring enabled (TM1)
[ 0.000254] using mwait in idle threads.
[ 0.000570] ACPI: Core revision 20110623
[ 0.029892] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.030380] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.069995] CPU0: Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz stepping 05
[ 0.174928] Performance Events: PEBS fmt1+, Westmere events, Intel PMU driver.
[ 0.174941] ... version: 3
[ 0.174943] ... bit width: 48
[ 0.174945] ... generic registers: 4
[ 0.174946] ... value mask: 0000ffffffffffff
[ 0.174948] ... max period: 000000007fffffff
[ 0.174950] ... fixed-purpose events: 3
[ 0.174951] ... event mask: 000000070000000f
[ 0.195190] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.214912] CPU 1 irqstacks, hard=f2970000 soft=f2972000
[ 0.214919] Booting Node 0, Processors #1
[ 0.214926] smpboot cpu 1: start_ip = 99000
[ 0.225318] Initializing CPU#1
[ 0.322824] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.338713] CPU 2 irqstacks, hard=f2988000 soft=f298a000
[ 0.338719] #2
[ 0.338722] smpboot cpu 2: start_ip = 99000
[ 0.348864] Initializing CPU#2
[ 0.446538] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.462504] CPU 3 irqstacks, hard=f29be000 soft=f29c0000
[ 0.462510] #3
[ 0.462514] smpboot cpu 3: start_ip = 99000
[ 0.472655] Initializing CPU#3
[ 0.570320] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.574248] Brought up 4 CPUs
[ 0.574254] Total of 4 processors activated (19151.50 BogoMIPS).
[ 0.577356] devtmpfs: initialized
[ 0.577645] PM: Registering ACPI NVS region at bf74d000 (466944 bytes)
[ 0.577890] print_constraints: dummy:
[ 0.577977] NET: Registered protocol family 16
[ 0.578138] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.578141] ACPI: bus type pci registered
[ 0.578242] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.578246] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.578248] PCI: Using MMCONFIG for extended config space
[ 0.578250] PCI: Using configuration type 1 for base access
[ 0.579289] bio: create slab <bio-0> at 0
[ 0.579424] ACPI: Added _OSI(Module Device)
[ 0.579427] ACPI: Added _OSI(Processor Device)
[ 0.579430] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.579432] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.582017] ACPI: EC: Look up EC in DSDT
[ 0.610272] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.626940] ACPI: SSDT 0x00000000BF691918 00432 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.627601] ACPI: Dynamic OEM Table Load:
[ 0.627605] ACPI: SSDT 0x0000000000000000 00432 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.627882] ACPI: SSDT 0x00000000BF68F018 00891 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.628492] ACPI: Dynamic OEM Table Load:
[ 0.628495] ACPI: SSDT 0x0000000000000000 00891 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.662718] ACPI: SSDT 0x00000000BF690A98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.663518] ACPI: Dynamic OEM Table Load:
[ 0.663521] ACPI: SSDT 0x0000000000000000 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.678377] ACPI: SSDT 0x00000000BF68ED98 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.679062] ACPI: Dynamic OEM Table Load:
[ 0.679066] ACPI: SSDT 0x0000000000000000 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.695452] ACPI: Interpreter enabled
[ 0.695460] ACPI: (supports S0 S3 S4 S5)
[ 0.695506] ACPI: Using IOAPIC for interrupt routing
[ 0.703772] ACPI: EC: GPE = 0x16, I/O: command/status = 0x66, data = 0x62
[ 0.704046] ACPI: No dock devices found.
[ 0.704048] HEST: Table not found.
[ 0.704051] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.704956] \_SB_.PCI0:_OSC invalid UUID
[ 0.704959] _OSC request data:1 8 0
[ 0.704964] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[ 0.706350] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.706353] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.706355] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.706359] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xfeafffff]
[ 0.706375] pci 0000:00:00.0: [8086:0044] type 0 class 0x000600
[ 0.706417] pci 0000:00:01.0: [8086:0045] type 1 class 0x000604
[ 0.706454] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.706508] pci 0000:00:16.0: [8086:3b64] type 0 class 0x000780
[ 0.706539] pci 0000:00:16.0: reg 10: [mem 0xd4106100-0xd410610f 64bit]
[ 0.706640] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.706686] pci 0000:00:1a.0: [8086:3b3c] type 0 class 0x000c03
[ 0.707083] pci 0000:00:1a.0: reg 10: [mem 0xd4105c00-0xd4105fff]
[ 0.709384] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.709422] pci 0000:00:1b.0: [8086:3b56] type 0 class 0x000403
[ 0.709445] pci 0000:00:1b.0: reg 10: [mem 0xd4100000-0xd4103fff 64bit]
[ 0.709545] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.709578] pci 0000:00:1c.0: [8086:3b42] type 1 class 0x000604
[ 0.709683] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.709723] pci 0000:00:1c.5: [8086:3b4c] type 1 class 0x000604
[ 0.709829] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.709869] pci 0000:00:1d.0: [8086:3b34] type 0 class 0x000c03
[ 0.710267] pci 0000:00:1d.0: reg 10: [mem 0xd4105800-0xd4105bff]
[ 0.712556] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.712587] pci 0000:00:1e.0: [8086:2448] type 1 class 0x000604
[ 0.712677] pci 0000:00:1f.0: [8086:3b09] type 0 class 0x000601
[ 0.712813] pci 0000:00:1f.2: [8086:3b29] type 0 class 0x000106
[ 0.712840] pci 0000:00:1f.2: reg 10: [io 0x4048-0x404f]
[ 0.712852] pci 0000:00:1f.2: reg 14: [io 0x4054-0x4057]
[ 0.712865] pci 0000:00:1f.2: reg 18: [io 0x4040-0x4047]
[ 0.712876] pci 0000:00:1f.2: reg 1c: [io 0x4050-0x4053]
[ 0.712888] pci 0000:00:1f.2: reg 20: [io 0x4020-0x403f]
[ 0.712900] pci 0000:00:1f.2: reg 24: [mem 0xd4105000-0xd41057ff]
[ 0.712969] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.712996] pci 0000:00:1f.3: [8086:3b30] type 0 class 0x000c05
[ 0.713018] pci 0000:00:1f.3: reg 10: [mem 0xd4106000-0xd41060ff 64bit]
[ 0.713049] pci 0000:00:1f.3: reg 20: [io 0x4000-0x401f]
[ 0.713124] pci 0000:01:00.0: [1002:68c1] type 0 class 0x000300
[ 0.713144] pci 0000:01:00.0: reg 10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.713160] pci 0000:01:00.0: reg 18: [mem 0xd4000000-0xd401ffff 64bit]
[ 0.713171] pci 0000:01:00.0: reg 20: [io 0x3000-0x30ff]
[ 0.713190] pci 0000:01:00.0: reg 30: [mem 0xfffe0000-0xffffffff pref]
[ 0.713232] pci 0000:01:00.0: supports D1 D2
[ 0.713260] pci 0000:01:00.1: [1002:aa60] type 0 class 0x000403
[ 0.713280] pci 0000:01:00.1: reg 10: [mem 0xd4020000-0xd4023fff 64bit]
[ 0.713365] pci 0000:01:00.1: supports D1 D2
[ 0.713403] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.713407] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.713410] pci 0000:00:01.0: bridge window [mem 0xd4000000-0xd40fffff]
[ 0.713414] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.713531] pci 0000:02:00.0: [14e4:1692] type 0 class 0x000200
[ 0.713563] pci 0000:02:00.0: reg 10: [mem 0xd3000000-0xd300ffff 64bit]
[ 0.713729] pci 0000:02:00.0: PME# supported from D3hot D3cold
[ 0.718104] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.718112] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.718118] pci 0000:00:1c.0: bridge window [mem 0xd3000000-0xd3ffffff]
[ 0.718126] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd0ffffff 64bit pref]
[ 0.718246] pci 0000:03:00.0: [14e4:4358] type 0 class 0x000280
[ 0.718279] pci 0000:03:00.0: reg 10: [mem 0xd2000000-0xd2003fff 64bit]
[ 0.718447] pci 0000:03:00.0: supports D1 D2
[ 0.718449] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.726051] pci 0000:00:1c.5: PCI bridge to [bus 03-03]
[ 0.726063] pci 0000:00:1c.5: bridge window [io 0x1000-0x1fff]
[ 0.726067] pci 0000:00:1c.5: bridge window [mem 0xd2000000-0xd2ffffff]
[ 0.726075] pci 0000:00:1c.5: bridge window [mem 0xd1000000-0xd1ffffff 64bit pref]
[ 0.726153] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.726167] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.726170] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.726173] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.726176] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xfeafffff] (subtractive decode)
[ 0.726198] pci_bus 0000:00: on NUMA node 0
[ 0.726202] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.726723] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
[ 0.726839] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.727026] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.727251] \_SB_.PCI0:_OSC invalid UUID
[ 0.727253] _OSC request data:1 1f 0
[ 0.727259] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.727333] \_SB_.PCI0:_OSC invalid UUID
[ 0.727335] _OSC request data:1 0 1d
[ 0.727340] pci0000:00: ACPI _OSC request failed (AE_ERROR), returned control mask: 0x1d
[ 0.727342] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.736434] ACPI: PCI Root Bridge [CPBG] (domain 0000 [bus 7f])
[ 0.736565] pci 0000:7f:00.0: [8086:2c62] type 0 class 0x000600
[ 0.736590] pci 0000:7f:00.1: [8086:2d01] type 0 class 0x000600
[ 0.736613] pci 0000:7f:02.0: [8086:2d10] type 0 class 0x000600
[ 0.736634] pci 0000:7f:02.1: [8086:2d11] type 0 class 0x000600
[ 0.736654] pci 0000:7f:02.2: [8086:2d12] type 0 class 0x000600
[ 0.736676] pci 0000:7f:02.3: [8086:2d13] type 0 class 0x000600
[ 0.736705] pci_bus 0000:7f: on NUMA node 0
[ 0.736716] pci0000:7f: Requesting ACPI _OSC control (0x1d)
[ 0.736720] pci0000:7f: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.736722] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.737147] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.737236] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 *5 6 7 11 12 14 15)
[ 0.737323] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.737411] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *10
[ 0.737499] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
[ 0.737589] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 *7 11 12 14 15)
[ 0.737679] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *11
[ 0.737766] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 *11 12 14 15)
[ 0.737897] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.737909] vgaarb: loaded
[ 0.737911] vgaarb: bridge control possible 0000:01:00.0
[ 0.737971] PCI: Using ACPI for IRQ routing
[ 0.742826] PCI: pci_cache_line_size set to 64 bytes
[ 0.743030] reserve RAM buffer: 000000000009d000 - 000000000009ffff
[ 0.743033] reserve RAM buffer: 00000000bf681000 - 00000000bfffffff
[ 0.743036] reserve RAM buffer: 00000000bf74d000 - 00000000bfffffff
[ 0.743039] reserve RAM buffer: 00000000bf7e3000 - 00000000bfffffff
[ 0.743042] reserve RAM buffer: 00000000bf800000 - 00000000bfffffff
[ 0.743202] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.743210] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.745242] AMD NB: Cannot enumerate AMD northbridges.
[ 0.745244] Switching to clocksource hpet
[ 0.748437] pnp: PnP ACPI init
[ 0.748455] ACPI: bus type pnp registered
[ 0.749155] pnp 00:00: [bus 00-7e]
[ 0.749159] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.749161] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.749163] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.749166] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.749168] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.749171] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.749175] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.749178] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.749180] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.749183] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.749185] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.749187] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.749190] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.749192] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.749195] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.749197] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.749199] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.749202] pnp 00:00: [mem 0xc0000000-0xfeafffff window]
[ 0.749204] pnp 00:00: [mem 0xfed40000-0xfed44fff window]
[ 0.749292] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.749376] pnp 00:01: [io 0x0000-0x001f]
[ 0.749379] pnp 00:01: [io 0x0081-0x0091]
[ 0.749381] pnp 00:01: [io 0x0093-0x009f]
[ 0.749383] pnp 00:01: [io 0x00c0-0x00df]
[ 0.749386] pnp 00:01: [dma 4]
[ 0.749429] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.749443] pnp 00:02: [mem 0xff000000-0xffffffff]
[ 0.749480] pnp 00:02: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.749607] pnp 00:03: [mem 0xfed00000-0xfed003ff]
[ 0.749648] pnp 00:03: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.749664] pnp 00:04: [io 0x00f0]
[ 0.749672] pnp 00:04: [irq 13]
[ 0.749713] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.749730] pnp 00:05: [io 0x002e-0x002f]
[ 0.749732] pnp 00:05: [io 0x004e-0x004f]
[ 0.749735] pnp 00:05: [io 0x0061]
[ 0.749737] pnp 00:05: [io 0x0063]
[ 0.749738] pnp 00:05: [io 0x0065]
[ 0.749740] pnp 00:05: [io 0x0067]
[ 0.749742] pnp 00:05: [io 0x0070]
[ 0.749744] pnp 00:05: [io 0x0080]
[ 0.749746] pnp 00:05: [io 0x0092]
[ 0.749748] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.749750] pnp 00:05: [io 0x0680-0x069f]
[ 0.749752] pnp 00:05: [io 0x0800-0x080f]
[ 0.749754] pnp 00:05: [io 0xffff]
[ 0.749756] pnp 00:05: [io 0xffff]
[ 0.749758] pnp 00:05: [io 0x0400-0x047f]
[ 0.749761] pnp 00:05: [io 0x0500-0x057f]
[ 0.749763] pnp 00:05: [io 0x164e-0x164f]
[ 0.749778] pnp 00:05: disabling [io 0x164e-0x164f] because it overlaps 0000:00:1c.5 BAR 13 [io 0x1000-0x1fff]
[ 0.749844] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.749848] system 00:05: [io 0x0800-0x080f] has been reserved
[ 0.749851] system 00:05: [io 0xffff] has been reserved
[ 0.749854] system 00:05: [io 0xffff] has been reserved
[ 0.749857] system 00:05: [io 0x0400-0x047f] could not be reserved
[ 0.749861] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.749864] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.749877] pnp 00:06: [io 0x0070-0x0077]
[ 0.749883] pnp 00:06: [irq 8]
[ 0.749925] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.749941] pnp 00:07: [io 0x0060]
[ 0.749943] pnp 00:07: [io 0x0064]
[ 0.749949] pnp 00:07: [irq 1]
[ 0.749991] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.750007] pnp 00:08: [irq 12]
[ 0.750049] pnp 00:08: Plug and Play ACPI device, IDs SYN1b20 SYN1b00 SYN0002 PNP0f13 (active)
[ 0.750629] pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
[ 0.750632] pnp 00:09: [mem 0xfed10000-0xfed13fff]
[ 0.750634] pnp 00:09: [mem 0xfed18000-0xfed18fff]
[ 0.750637] pnp 00:09: [mem 0xfed19000-0xfed19fff]
[ 0.750640] pnp 00:09: [mem 0xf0000000-0xf1ffffff]
[ 0.750643] pnp 00:09: [mem 0xfed20000-0xfed3ffff]
[ 0.750645] pnp 00:09: [mem 0xfed90000-0xfed8ffff disabled]
[ 0.750647] pnp 00:09: [mem 0xfed45000-0xfed8ffff]
[ 0.750650] pnp 00:09: [mem 0xff000000-0xffffffff]
[ 0.750652] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 0.750654] pnp 00:09: [mem 0xd4200000-0xd4200fff]
[ 0.750755] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.750759] system 00:09: [mem 0xfed10000-0xfed13fff] has been reserved
[ 0.750762] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.750765] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.750769] system 00:09: [mem 0xf0000000-0xf1ffffff] has been reserved
[ 0.750772] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.750775] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.750779] system 00:09: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.750783] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.750786] system 00:09: [mem 0xd4200000-0xd4200fff] has been reserved
[ 0.750790] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.751063] pnp 00:0a: [bus 7f]
[ 0.751124] pnp 00:0a: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.751142] pnp: PnP ACPI: found 11 devices
[ 0.751144] ACPI: ACPI bus type pnp unregistered
[ 0.751146] PnPBIOS: Disabled by ACPI PNP
[ 0.789269] pci 0000:01:00.0: no compatible bridge window for [mem 0xfffe0000-0xffffffff pref]
[ 0.789283] PCI: max bus depth: 1 pci_try_num: 2
[ 0.789321] pci 0000:01:00.0: BAR 6: assigned [mem 0xd4040000-0xd405ffff pref]
[ 0.789324] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.789327] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff]
[ 0.789331] pci 0000:00:01.0: bridge window [mem 0xd4000000-0xd40fffff]
[ 0.789334] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.789339] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.789343] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.789349] pci 0000:00:1c.0: bridge window [mem 0xd3000000-0xd3ffffff]
[ 0.789354] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd0ffffff 64bit pref]
[ 0.789363] pci 0000:00:1c.5: PCI bridge to [bus 03-03]
[ 0.789367] pci 0000:00:1c.5: bridge window [io 0x1000-0x1fff]
[ 0.789373] pci 0000:00:1c.5: bridge window [mem 0xd2000000-0xd2ffffff]
[ 0.789379] pci 0000:00:1c.5: bridge window [mem 0xd1000000-0xd1ffffff 64bit pref]
[ 0.789387] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 0.789415] pci 0000:00:01.0: setting latency timer to 64
[ 0.789434] pci 0000:00:1c.0: setting latency timer to 64
[ 0.789446] pci 0000:00:1c.5: setting latency timer to 64
[ 0.789456] pci 0000:00:1e.0: setting latency timer to 64
[ 0.789460] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.789463] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.789465] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.789467] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfeafffff]
[ 0.789470] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.789472] pci_bus 0000:01: resource 1 [mem 0xd4000000-0xd40fffff]
[ 0.789474] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.789477] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.789479] pci_bus 0000:02: resource 1 [mem 0xd3000000-0xd3ffffff]
[ 0.789481] pci_bus 0000:02: resource 2 [mem 0xd0000000-0xd0ffffff 64bit pref]
[ 0.789484] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.789486] pci_bus 0000:03: resource 1 [mem 0xd2000000-0xd2ffffff]
[ 0.789489] pci_bus 0000:03: resource 2 [mem 0xd1000000-0xd1ffffff 64bit pref]
[ 0.789491] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 0.789493] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 0.789496] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.789498] pci_bus 0000:04: resource 7 [mem 0xc0000000-0xfeafffff]
[ 0.789569] NET: Registered protocol family 2
[ 0.791705] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.792065] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.792369] TCP bind hash table entries: 65536 (order: 8, 1835008 bytes)
[ 0.793253] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.793256] TCP reno registered
[ 0.793262] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.793280] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.793440] NET: Registered protocol family 1
[ 0.825199] pci 0000:01:00.0: Boot video device
[ 0.825287] PCI: CLS 64 bytes, default 64
[ 0.825364] Unpacking initramfs...
[ 1.124792] Freeing initrd memory: 13396k freed
[ 1.128492] Simple Boot Flag at 0x44 set to 0x1
[ 1.129266] audit: initializing netlink socket (disabled)
[ 1.129282] type=2000 audit(1516353721.956:1): initialized
[ 1.143914] highmem bounce pool size: 64 pages
[ 1.143920] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.144150] VFS: Disk quotas dquot_6.5.2
[ 1.144201] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.144296] msgmni has been set to 1648
[ 1.144517] alg: No test for stdrng (krng)
[ 1.144578] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.144582] io scheduler noop registered
[ 1.144584] io scheduler deadline registered
[ 1.144605] io scheduler cfq registered (default)
[ 1.144741] pcieport 0000:00:01.0: setting latency timer to 64
[ 1.144774] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X
[ 1.144986] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.145016] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.145018] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.145618] intel_idle: MWAIT substates: 0x1120
[ 1.145620] intel_idle: v0.4 model 0x25
[ 1.145622] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.145677] ERST: Table is not found!
[ 1.145679] GHES: HEST is not enabled!
[ 1.145697] isapnp: Scanning for PnP cards...
[ 1.499370] isapnp: No Plug & Play device found
[ 1.499457] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.640137] Linux agpgart interface v0.103
[ 1.640602] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.647466] i8042: Detected active multiplexing controller, rev 1.1
[ 1.651156] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.651209] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.651248] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.651289] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.651327] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.651470] mousedev: PS/2 mouse device common for all mice
[ 1.651540] rtc_cmos 00:06: RTC can wake from S4
[ 1.651695] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 1.651772] rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
[ 1.651902] cpuidle: using governor ladder
[ 1.652082] cpuidle: using governor menu
[ 1.652454] TCP cubic registered
[ 1.652512] NET: Registered protocol family 10
[ 1.653367] Mobile IPv6
[ 1.653371] NET: Registered protocol family 17
[ 1.653376] Registering the dns_resolver key type
[ 1.653401] Using IPI No-Shortcut mode
[ 1.653560] PM: Hibernation image not present or could not be loaded.
[ 1.653573] registered taskstats version 1
[ 1.654065] rtc_cmos 00:06: setting system clock to 2018-01-19 09:22:03 UTC (1516353723)
[ 1.654429] Initializing network drop monitor service
[ 1.654923] Freeing unused kernel memory: 728k freed
[ 1.655435] Write protecting the kernel text: 2868k
[ 1.655582] Write protecting the kernel read-only data: 1076k
[ 1.655588] NX-protecting the kernel data: 3276k
[ 1.672680] udevd[75]: starting version 175
[ 1.672732] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.735579] SCSI subsystem initialized
[ 1.737257] usbcore: registered new interface driver usbfs
[ 1.739770] usbcore: registered new interface driver hub
[ 1.740249] tg3.c:v3.121 (November 2, 2011)
[ 1.740309] tg3 0000:02:00.0: setting latency timer to 64
[ 1.740579] usbcore: registered new device driver usb
[ 1.743016] libata version 3.00 loaded.
[ 1.743394] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.743614] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.743619] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.743854] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.743885] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.747810] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.747907] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xd4105c00
[ 1.763507] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.763654] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.763659] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.763663] usb usb1: Product: EHCI Host Controller
[ 1.763667] usb usb1: Manufacturer: Linux 3.2.0-4-rt-686-pae ehci_hcd
[ 1.763670] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.768860] hub 1-0:1.0: USB hub found
[ 1.768873] hub 1-0:1.0: 3 ports detected
[ 1.770796] ahci 0000:00:1f.2: version 3.0
[ 1.770904] ahci 0000:00:1f.2: irq 41 for MSI/MSI-X
[ 1.771003] ahci: SSS flag set, parallel bus scan disabled
[ 1.771063] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[ 1.771067] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems apst
[ 1.771073] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.783051] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.783055] ACPI: Thermal Zone [THRM] (40 C)
[ 1.792618] tg3 mdio bus: probed
[ 1.797146] scsi0 : ahci
[ 1.799060] scsi1 : ahci
[ 1.804543] scsi2 : ahci
[ 1.807271] scsi3 : ahci
[ 1.809014] tg3 0000:02:00.0: eth0: Tigon3 [partno(BCM57780) rev 57780001] (PCI Express) MAC address e8:9a:8f:b3:43:7f
[ 1.809020] tg3 0000:02:00.0: eth0: attached PHY driver [Broadcom BCM57780] (mii_bus:phy_addr=200:01)
[ 1.809025] tg3 0000:02:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.809030] tg3 0000:02:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.810043] ata1: SATA max UDMA/133 abar m2048@0xd4105000 port 0xd4105100 irq 41
[ 1.810048] ata2: SATA max UDMA/133 abar m2048@0xd4105000 port 0xd4105180 irq 41
[ 1.810051] ata3: DUMMY
[ 1.810053] ata4: DUMMY
[ 1.810173] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.810179] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.810216] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.810248] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.814196] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.814375] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd4105800
[ 1.827390] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.827525] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.827529] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.827532] usb usb2: Product: EHCI Host Controller
[ 1.827534] usb usb2: Manufacturer: Linux 3.2.0-4-rt-686-pae ehci_hcd
[ 1.827536] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.829570] hub 2-0:1.0: USB hub found
[ 1.829583] hub 2-0:1.0: 3 ports detected
[ 2.079045] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 2.126968] Refined TSC clocksource calibration: 2393.999 MHz.
[ 2.126976] Switching to clocksource tsc
[ 2.127029] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.193807] ata1.00: ATA-8: WDC WD3200BEVT-22ZCT0, 11.01A11, max UDMA/133
[ 2.193817] ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.197097] ata1.00: configured for UDMA/133
[ 2.197280] scsi 0:0:0:0: Direct-Access ATA WDC WD3200BEVT-2 11.0 PQ: 0 ANSI: 5
[ 2.211627] usb 1-1: New USB device found, idVendor=8087, idProduct=0020
[ 2.211633] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.212182] hub 1-1:1.0: USB hub found
[ 2.212376] hub 1-1:1.0: 6 ports detected
[ 2.322647] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 2.455235] usb 2-1: New USB device found, idVendor=8087, idProduct=0020
[ 2.455241] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.455702] hub 2-1:1.0: USB hub found
[ 2.455828] hub 2-1:1.0: 8 ports detected
[ 2.514321] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.516057] ata2.00: ATAPI: MATSHITADVD-RAM UJ8A0AS, 1.00, max UDMA/100
[ 2.518740] ata2.00: configured for UDMA/100
[ 2.524741] scsi 1:0:0:0: CD-ROM MATSHITA DVD-RAM UJ8A0AS 1.00 PQ: 0 ANSI: 5
[ 2.530176] usb 1-1.1: new high-speed USB device number 3 using ehci_hcd
[ 2.536744] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.536810] sd 0:0:0:0: [sda] Write Protect is off
[ 2.536813] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.536839] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.538218] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.538227] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.538738] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.626589] sda: sda1 sda2 sda3 < sda5 sda6 > sda4
[ 2.628519] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.631315] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.631380] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.728759] usb 1-1.1: New USB device found, idVendor=0402, idProduct=9665
[ 2.728765] usb 1-1.1: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 2.728770] usb 1-1.1: Product: 1.3M WebCam
[ 2.728773] usb 1-1.1: Manufacturer: XPB5P0DTH
[ 4.506927] usb 1-1.4: new low-speed USB device number 4 using ehci_hcd
[ 4.604502] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=0044
[ 4.604508] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.604513] usb 1-1.4: Product: Usb Mouse
[ 4.604516] usb 1-1.4: Manufacturer: SIGMACHIP
[ 4.611203] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input1
[ 4.611417] generic-usb 0003:1A2C:0044.0001: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:1a.0-1.4/input0
[ 4.611465] usbcore: registered new interface driver usbhid
[ 4.611470] usbhid: USB HID core driver
[ 5.842727] usb 1-1.4: USB disconnect, device number 4
[ 6.112115] usb 1-1.4: new low-speed USB device number 5 using ehci_hcd
[ 6.209873] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=0044
[ 6.209882] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.209888] usb 1-1.4: Product: Usb Mouse
[ 6.209893] usb 1-1.4: Manufacturer: SIGMACHIP
[ 6.213689] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2
[ 6.213842] generic-usb 0003:1A2C:0044.0002: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:1a.0-1.4/input0
[ 7.376091] usb 1-1.4: USB disconnect, device number 5
[ 7.641475] usb 1-1.4: new low-speed USB device number 6 using ehci_hcd
[ 7.739158] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=0044
[ 7.739164] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.739168] usb 1-1.4: Product: Usb Mouse
[ 7.739171] usb 1-1.4: Manufacturer: SIGMACHIP
[ 7.742660] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input3
[ 7.742944] generic-usb 0003:1A2C:0044.0003: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:1a.0-1.4/input0
[ 8.660115] microcode: CPU0 sig=0x20655, pf=0x10, revision=0x2
[ 8.663128] platform microcode: firmware: agent loaded intel-ucode/06-25-05 into memory
[ 8.663606] microcode: CPU0 updated to revision 0x4, date = 2013-06-28
[ 8.663634] microcode: CPU1 sig=0x20655, pf=0x10, revision=0x2
[ 8.666590] platform microcode: firmware: agent loaded intel-ucode/06-25-05 into memory
[ 8.666808] microcode: CPU1 updated to revision 0x4, date = 2013-06-28
[ 8.666819] microcode: CPU2 sig=0x20655, pf=0x10, revision=0x2
[ 8.669657] platform microcode: firmware: agent loaded intel-ucode/06-25-05 into memory
[ 8.669860] microcode: CPU2 updated to revision 0x4, date = 2013-06-28
[ 8.669889] microcode: CPU3 sig=0x20655, pf=0x10, revision=0x2
[ 8.673195] platform microcode: firmware: agent loaded intel-ucode/06-25-05 into memory
[ 8.673402] microcode: CPU3 updated to revision 0x4, date = 2013-06-28
[ 8.673527] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 8.818471] PM: Starting manual resume from disk
[ 8.818474] PM: Hibernation image partition 8:6 present
[ 8.818476] PM: Looking for hibernation image.
[ 8.818805] PM: Image not found (code -22)
[ 8.818812] PM: Hibernation image not present or could not be loaded.
[ 8.875445] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 10.894233] udevd[415]: starting version 175
[ 11.402735] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0C:00/input/input4
[ 11.402744] ACPI: Power Button [PWRB]
[ 11.422509] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0D:00/input/input5
[ 11.422585] ACPI: Lid Switch [LID0]
[ 11.426379] ACPI: Requesting acpi_cpufreq
[ 11.444435] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/PNP0C0E:00/input/input6
[ 11.444444] ACPI: Sleep Button [SLPB]
[ 11.457343] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[ 11.457352] ACPI: Power Button [PWRF]
[ 11.744620] acpi device:0b: registered as cooling_device4
[ 11.744709] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:08/LNXVIDEO:01/input/input8
[ 11.744717] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 11.798335] ACPI: resource 0000:00:1f.3 [io 0x4000-0x401f] conflicts with ACPI region SMBI [io 0x4000-0x400f]
[ 11.798339] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 11.822850] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 11.920396] wmi: Mapper loaded
[ 12.072283] [drm] Initialized drm 1.1.0 20060810
[ 12.102853] iTCO_vendor_support: vendor-support=0
[ 12.103672] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 12.103788] iTCO_wdt: Found a HM55 TCO device (Version=2, TCOBASE=0x0460)
[ 12.104080] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.513530] ACPI: AC Adapter [ACAD] (on-line)
[ 12.513906] ACPI: Battery Slot [BAT1] (battery absent)
[ 12.544795] acer_wmi: Acer Laptop ACPI-WMI Extras
[ 12.544829] acer_wmi: Function bitmap for Communication Button: 0x1
[ 12.544834] acer_wmi: Brightness must be controlled by generic video driver
[ 12.546507] input: Acer WMI hotkeys as /devices/virtual/input/input10
[ 12.722294] Linux media interface: v0.10
[ 12.732888] Linux video capture interface: v2.00
[ 12.737509] uvcvideo: Found UVC 1.00 device 1.3M WebCam (0402:9665)
[ 12.740382] input: 1.3M WebCam as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input11
[ 12.740463] usbcore: registered new interface driver uvcvideo
[ 12.740465] USB Video Class driver (1.1.1)
[ 12.756443] psmouse serio2: synaptics: Touchpad model: 1, fw: 7.2, id: 0x1c0b1, caps: 0xd04733/0xa44000/0xa0000
[ 12.788555] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 12.788685] snd_hda_intel 0000:00:1b.0: irq 42 for MSI/MSI-X
[ 12.788913] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 12.802458] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio2/input/input12
[ 12.902477] [drm] radeon kernel modesetting enabled.
[ 12.958815] radeon 0000:01:00.0: setting latency timer to 64
[ 12.958839] [drm] initializing kernel modesetting (REDWOOD 0x1002:0x68C1 0x1025:0x051A).
[ 12.958898] [drm] register mmio base: 0xD4000000
[ 12.958901] [drm] register mmio size: 131072
[ 12.959108] ATOM BIOS: Acer
[ 12.959144] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 12.959149] radeon 0000:01:00.0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
[ 12.961087] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 12.961093] [drm] RAM width 128bits DDR
[ 12.961234] [TTM] Zone kernel: Available graphics memory: 422382 kiB
[ 12.961242] [TTM] Zone highmem: Available graphics memory: 3042394 kiB
[ 12.961247] [TTM] Initializing pool allocator
[ 12.961310] [drm] radeon: 1024M of VRAM memory ready
[ 12.961316] [drm] radeon: 512M of GTT memory ready.
[ 12.961374] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 12.962423] [drm] radeon: ib pool ready.
[ 12.967077] [drm] Loading REDWOOD Microcode
[ 13.017425] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input13
[ 13.021854] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 13.022811] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 13.062552] platform radeon_cp.0: firmware: agent loaded radeon/REDWOOD_pfp.bin into memory
[ 13.162204] platform radeon_cp.0: firmware: agent loaded radeon/REDWOOD_me.bin into memory
[ 13.284290] platform radeon_cp.0: firmware: agent loaded radeon/REDWOOD_rlc.bin into memory
[ 13.287154] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 13.287364] radeon 0000:01:00.0: WB enabled
[ 13.287371] [drm] fence driver on ring 0 use gpu addr 0x40000c00 and cpu addr 0xffbb2c00
[ 13.287381] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 13.287385] [drm] Driver supports precise vblank timestamp query.
[ 13.287460] radeon 0000:01:00.0: irq 43 for MSI/MSI-X
[ 13.287483] radeon 0000:01:00.0: radeon: using MSI.
[ 13.287696] [drm] radeon: irq initialized.
[ 13.304843] [drm] ring test on 0 succeeded in 1 usecs
[ 13.305439] [drm] ib test on ring 0 succeeded in 0 usecs
[ 13.306182] [drm] Radeon Display Connectors
[ 13.306186] [drm] Connector 0:
[ 13.306189] [drm] LVDS
[ 13.306192] [drm] DDC: 0x6470 0x6470 0x6474 0x6474 0x6478 0x6478 0x647c 0x647c
[ 13.306195] [drm] Encoders:
[ 13.306197] [drm] LCD1: INTERNAL_UNIPHY
[ 13.306199] [drm] Connector 1:
[ 13.306201] [drm] HDMI-A
[ 13.306203] [drm] HPD1
[ 13.306206] [drm] DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[ 13.306209] [drm] Encoders:
[ 13.306211] [drm] DFP1: INTERNAL_UNIPHY1
[ 13.306213] [drm] Connector 2:
[ 13.306215] [drm] VGA
[ 13.306218] [drm] DDC: 0x64d8 0x64d8 0x64dc 0x64dc 0x64e0 0x64e0 0x64e4 0x64e4
[ 13.306220] [drm] Encoders:
[ 13.306222] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 13.306280] [drm] Internal thermal controller without fan control
[ 13.306371] [drm] radeon: power management initialized
[ 13.725169] [drm] fb mappable at 0xC0142000
[ 13.725172] [drm] vram apper at 0xC0000000
[ 13.725174] [drm] size 4325376
[ 13.725175] [drm] fb depth is 24
[ 13.725176] [drm] pitch is 5632
[ 13.725459] fbcon: radeondrmfb (fb0) is primary device
[ 14.303050] Console: switching to colour frame buffer device 170x48
[ 14.307042] fb0: radeondrmfb frame buffer device
[ 14.307044] drm: registered panic notifier
[ 14.307051] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 14.307236] snd_hda_intel 0000:01:00.1: irq 44 for MSI/MSI-X
[ 14.307325] snd_hda_intel 0000:01:00.1: setting latency timer to 64
[ 14.360412] HDMI status: Codec=0 Pin=3 Presence_Detect=0 ELD_Valid=0
[ 14.360594] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 15.586974] Adding 2749436k swap on /dev/sda6. Priority:-1 extents:1 across:2749436k
[ 15.620500] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 15.821296] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 15.965887] loop: module loaded
[ 17.283302] tg3 0000:02:00.0: irq 45 for MSI/MSI-X
[ 17.310251] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.772958] tg3 0000:02:00.0: eth0: Link is down
[ 17.900519] RPC: Registered named UNIX socket transport module.
[ 17.900527] RPC: Registered udp transport module.
[ 17.900532] RPC: Registered tcp transport module.
[ 17.900536] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.969000] FS-Cache: Loaded
[ 18.010495] FS-Cache: Netfs 'nfs' registered for caching
[ 18.026051] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 20.332172] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input17
[ 21.202256] Bluetooth: Core ver 2.16
[ 21.202277] NET: Registered protocol family 31
[ 21.202279] Bluetooth: HCI device and connection manager initialized
[ 21.202282] Bluetooth: HCI socket layer initialized
[ 21.202284] Bluetooth: L2CAP socket layer initialized
[ 21.202292] Bluetooth: SCO socket layer initialized
[ 21.236785] Bluetooth: RFCOMM TTY layer initialized
[ 21.236800] Bluetooth: RFCOMM socket layer initialized
[ 21.236805] Bluetooth: RFCOMM ver 1.11
[ 21.461137] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.461145] Bluetooth: BNEP filters: protocol multicast
[ 22.121816] lp: driver loaded but no devices found
[ 22.177681] ppdev: user-space parallel port driver
[ 636.721817] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 636.721823] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 636.721947] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 646.783440] eth0: no IPv6 routers present
[ 658.835872] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 876.308762] tg3 0000:02:00.0: eth0: Link is down
[ 3250.425603] hub 1-1:1.0: port 4 disabled by hub (EMI?), re-enabling...
[ 3250.425790] usb 1-1.4: USB disconnect, device number 6
[ 3250.666057] usb 1-1.4: new low-speed USB device number 7 using ehci_hcd
[ 3250.764151] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=0044
[ 3250.764160] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3250.764167] usb 1-1.4: Product: Usb Mouse
[ 3250.764172] usb 1-1.4: Manufacturer: SIGMACHIP
[ 3250.768327] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input18
[ 3250.768829] generic-usb 0003:1A2C:0044.0004: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:1a.0-1.4/input0
[ 3251.959172] usb 1-1.4: USB disconnect, device number 7
[ 3252.303196] usb 1-1.4: new low-speed USB device number 8 using ehci_hcd
[ 3252.401510] usb 1-1.4: New USB device found, idVendor=1a2c, idProduct=0044
[ 3252.401520] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3252.401526] usb 1-1.4: Product: Usb Mouse
[ 3252.401531] usb 1-1.4: Manufacturer: SIGMACHIP
[ 3252.404979] input: SIGMACHIP Usb Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input19
[ 3252.405469] generic-usb 0003:1A2C:0044.0005: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-0000:00:1a.0-1.4/input0
[ 3463.871417] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 3463.871423] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 3463.871550] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 3849.239020] tg3 0000:02:00.0: eth0: Link is down
[ 3851.235545] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 3851.235551] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 3855.228675] tg3 0000:02:00.0: eth0: Link is down
[ 3858.223450] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 3858.223456] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 3872.199418] tg3 0000:02:00.0: eth0: Link is down
[ 3900.151216] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 3900.151222] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 3997.998520] tg3 0000:02:00.0: eth0: Link is down
[ 4050.907284] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 4050.907290] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
[ 4146.746097] tg3 0000:02:00.0: eth0: Link is down
[ 4170.704739] tg3 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex
[ 4170.704745] tg3 0000:02:00.0: eth0: Flow control is on for TX and on for RX
