В общем через Pncconf создал конфигурацию, но чтото пошло не так...
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/red/linuxcnc/configs/зеленый_фрезер'
Machine configuration file is 'зеленый_фрезер.ini'
INIFILE=/home/red/linuxcnc/configs/зеленый_фрезер/зеленый_фрезер.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./зеленый_фрезер.hal
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=3617
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
./зеленый_фрезер.hal:81: Signal 'x-pos-fb' can not add OUT pin 'hm2_5i25.0.encoder.00.position', it already has OUT pin 'hm2_5i25.0.stepgen.00.position-fb'
3617
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001dfc0000 (usable)
[ 0.000000] BIOS-e820: 000000001dfc0000 - 000000001dfce000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001dfce000 - 000000001dff0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001dff0000 - 000000001e000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: ECS P4M800PRO-M2/P4M800PRO-M2, BIOS 080012 10/04/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x1dfc0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 010000000 mask FF8000000 write-back
[ 0.000000] 2 base 018000000 mask FFC000000 write-back
[ 0.000000] 3 base 01C000000 mask FFE000000 write-back
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-000000001dfc0000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001dc00000 page 2M
[ 0.000000] 001dc00000 - 001dfc0000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x1dfbffff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 1c9e7000 - 1d749000
[ 0.000000] ACPI: RSDP 000f8730 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 1dfc0000 00030 (v01 A M I OEMRSDT 10000604 MSFT 00000097)
[ 0.000000] ACPI: FACP 1dfc0200 00084 (v02 A M I OEMFACP 10000604 MSFT 00000097)
[ 0.000000] ACPI: DSDT 1dfc0400 03CA3 (v01 12345 12345123 00000123 INTL 20051117)
[ 0.000000] ACPI: FACS 1dfce000 00040
[ 0.000000] ACPI: APIC 1dfc0390 0006C (v01 A M I OEMAPIC 10000604 MSFT 00000097)
[ 0.000000] ACPI: OEMB 1dfce040 00060 (v01 A M I AMI_OEM 10000604 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 479MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1dfc0000
[ 0.000000] low ram: 0 - 1dfc0000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001dfc0
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001dfc0
[ 0.000000] On node 0 totalpages: 122703
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map ddbff200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 928 pages used for memmap
[ 0.000000] Normal zone: 117792 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e6000
[ 0.000000] PM: Registered nosave memory: 00000000000e6000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 1e000000 (gap: 1e000000:e0c00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ddbb7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121743
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e28b9af0-e06f-4382-bb3b-b55d20b47cc6 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 982400 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 465752k/491264k available (3495k kernel code, 25060k reserved, 1237k data, 416k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xde7c0000 - 0xff7fe000 ( 528 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xddfc0000 ( 479 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=dc408000 soft=dc40a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2666.522 MHz processor.
[ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 5333.04 BogoMIPS (lpj=10666088)
[ 0.004014] pid_max: default: 32768 minimum: 301
[ 0.004121] Security Framework initialized
[ 0.004134] AppArmor: AppArmor disabled by boot time parameter
[ 0.004173] Mount-cache hash table entries: 512
[ 0.004578] Initializing cgroup subsys cpuacct
[ 0.004585] Initializing cgroup subsys memory
[ 0.004605] Initializing cgroup subsys devices
[ 0.004609] Initializing cgroup subsys freezer
[ 0.004613] Initializing cgroup subsys net_cls
[ 0.004617] Initializing cgroup subsys blkio
[ 0.004634] Initializing cgroup subsys perf_event
[ 0.004707] CPU0: Hyper-Threading is disabled
[ 0.004715] mce: CPU supports 4 MCE banks
[ 0.004732] CPU0: Thermal monitoring enabled (TM1)
[ 0.008070] SMP alternatives: switching to UP code
[ 0.014261] ACPI: Core revision 20120320
[ 0.020137] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.021478] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.061572] CPU0: Intel(R) Celeron(R) CPU 2.66GHz stepping 09
[ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.064003] ... version: 0
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 18
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 0000007fffffffff
[ 0.064003] ... fixed-purpose events: 0
[ 0.064003] ... event mask: 000000000003ffff
[ 0.072051] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.072141] Brought up 1 CPUs
[ 0.072147] Total of 1 processors activated (5333.04 BogoMIPS).
[ 0.073093] devtmpfs: initialized
[ 0.073626] PM: Registering ACPI NVS region [mem 0x1dfce000-0x1dfeffff] (139264 bytes)
[ 0.073873] dummy:
[ 0.074013] NET: Registered protocol family 16
[ 0.074292] ACPI: bus type pci registered
[ 0.074669] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=1
[ 0.074675] PCI: Using configuration type 1 for base access
[ 0.075957] bio: create slab <bio-0> at 0
[ 0.076226] ACPI: Added _OSI(Module Device)
[ 0.076233] ACPI: Added _OSI(Processor Device)
[ 0.076238] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.076243] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.078570] ACPI: EC: Look up EC in DSDT
[ 0.084192] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.092476] ACPI: Interpreter enabled
[ 0.092491] ACPI: (supports S0 S3 S4 S5)
[ 0.092550] ACPI: Using IOAPIC for interrupt routing
[ 0.115859] ACPI: No dock devices found.
[ 0.115874] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.116121] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.116411] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.116418] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.116423] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.116428] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
[ 0.116433] pci_root PNP0A03:00: host bridge window [mem 0x1e000000-0xff37ffff] (ignored)
[ 0.116439] PCI: root bus 00: using default resources
[ 0.116526] PCI host bridge to bus 0000:00
[ 0.116533] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.116538] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.116568] pci 0000:00:00.0: [1106:0314] type 00 class 0x060000
[ 0.116587] pci 0000:00:00.0: reg 10: [mem 0xf8000000-0xfbffffff pref]
[ 0.116688] pci 0000:00:00.1: [1106:1314] type 00 class 0x060000
[ 0.116757] pci 0000:00:00.2: [1106:2314] type 00 class 0x060000
[ 0.116830] pci 0000:00:00.3: [1106:3208] type 00 class 0x060000
[ 0.116901] pci 0000:00:00.4: [1106:4314] type 00 class 0x060000
[ 0.116977] pci 0000:00:00.7: [1106:7314] type 00 class 0x060000
[ 0.117052] pci 0000:00:01.0: [1106:b198] type 01 class 0x060400
[ 0.117122] pci 0000:00:01.0: supports D1
[ 0.117157] pci 0000:00:08.0: [2718:5125] type 00 class 0x110000
[ 0.117179] pci 0000:00:08.0: reg 10: [mem 0xfebf0000-0xfebfffff]
[ 0.117288] pci 0000:00:0f.0: [1106:3149] type 00 class 0x01018f
[ 0.117315] pci 0000:00:0f.0: reg 10: [io 0xec00-0xec07]
[ 0.117332] pci 0000:00:0f.0: reg 14: [io 0xe880-0xe883]
[ 0.117348] pci 0000:00:0f.0: reg 18: [io 0xe800-0xe807]
[ 0.117364] pci 0000:00:0f.0: reg 1c: [io 0xe480-0xe483]
[ 0.117380] pci 0000:00:0f.0: reg 20: [io 0xe400-0xe40f]
[ 0.117396] pci 0000:00:0f.0: reg 24: [io 0xe000-0xe0ff]
[ 0.117465] pci 0000:00:0f.1: [1106:0571] type 00 class 0x01018a
[ 0.117538] pci 0000:00:0f.1: reg 20: [io 0xfc00-0xfc0f]
[ 0.117626] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 0.117696] pci 0000:00:10.0: reg 20: [io 0xdc00-0xdc1f]
[ 0.117747] pci 0000:00:10.0: supports D1 D2
[ 0.117752] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.117785] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 0.117856] pci 0000:00:10.1: reg 20: [io 0xd880-0xd89f]
[ 0.117907] pci 0000:00:10.1: supports D1 D2
[ 0.117911] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.117941] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 0.118012] pci 0000:00:10.2: reg 20: [io 0xd800-0xd81f]
[ 0.118063] pci 0000:00:10.2: supports D1 D2
[ 0.118067] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118099] pci 0000:00:10.3: [1106:3038] type 00 class 0x0c0300
[ 0.118170] pci 0000:00:10.3: reg 20: [io 0xd480-0xd49f]
[ 0.118221] pci 0000:00:10.3: supports D1 D2
[ 0.118225] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118256] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 0.118282] pci 0000:00:10.4: reg 10: [mem 0xfebefc00-0xfebefcff]
[ 0.118377] pci 0000:00:10.4: supports D1 D2
[ 0.118382] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118420] pci 0000:00:11.0: [1106:3227] type 00 class 0x060100
[ 0.118517] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.118576] pci 0000:00:11.5: [1106:3059] type 00 class 0x040100
[ 0.118603] pci 0000:00:11.5: reg 10: [io 0xd000-0xd0ff]
[ 0.118701] pci 0000:00:11.5: supports D1 D2
[ 0.118736] pci 0000:00:12.0: [1106:3065] type 00 class 0x020000
[ 0.118763] pci 0000:00:12.0: reg 10: [io 0xee00-0xeeff]
[ 0.118779] pci 0000:00:12.0: reg 14: [mem 0xfebef800-0xfebef8ff]
[ 0.118865] pci 0000:00:12.0: supports D1 D2
[ 0.118869] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.118959] pci 0000:01:00.0: [1106:3344] type 00 class 0x030000
[ 0.118986] pci 0000:01:00.0: reg 10: [mem 0xf0000000-0xf3ffffff pref]
[ 0.119001] pci 0000:01:00.0: reg 14: [mem 0xfd000000-0xfdffffff]
[ 0.119052] pci 0000:01:00.0: reg 30: [mem 0xfeaf0000-0xfeafffff pref]
[ 0.119082] pci 0000:01:00.0: supports D1 D2
[ 0.119139] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.119151] pci 0000:00:01.0: bridge window [mem 0xfca00000-0xfeafffff]
[ 0.119159] pci 0000:00:01.0: bridge window [mem 0xeff00000-0xf7efffff pref]
[ 0.119173] pci_bus 0000:00: on NUMA node 0
[ 0.119182] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.119809] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.120069] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.141295] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.141449] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.141591] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.141730] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.141874] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142020] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142163] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142306] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.142567] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.142574] vgaarb: loaded
[ 0.142577] vgaarb: bridge control possible 0000:01:00.0
[ 0.142646] PCI: Using ACPI for IRQ routing
[ 0.142654] PCI: pci_cache_line_size set to 64 bytes
[ 0.142781] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.142787] reserve RAM buffer: 000000001dfc0000 - 000000001fffffff
[ 0.143230] pnp: PnP ACPI init
[ 0.143259] ACPI: bus type pnp registered
[ 0.143482] pnp 00:00: [bus 00-ff]
[ 0.143489] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.143495] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.143500] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.143505] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.143510] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.143515] pnp 00:00: [mem 0x1e000000-0xff37ffff window]
[ 0.143647] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.143723] pnp 00:01: [dma 4]
[ 0.143728] pnp 00:01: [io 0x0000-0x000f]
[ 0.143733] pnp 00:01: [io 0x0081-0x0083]
[ 0.143737] pnp 00:01: [io 0x0087]
[ 0.143741] pnp 00:01: [io 0x0089-0x008b]
[ 0.143745] pnp 00:01: [io 0x008f]
[ 0.143749] pnp 00:01: [io 0x00c0-0x00df]
[ 0.143807] pnp 00:01: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.143845] pnp 00:02: [io 0x0070-0x0071]
[ 0.143870] pnp 00:02: [irq 8]
[ 0.143932] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.144065] pnp 00:03: [io 0x0060]
[ 0.144071] pnp 00:03: [io 0x0064]
[ 0.144086] pnp 00:03: [irq 1]
[ 0.144170] pnp 00:03: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.144282] pnp 00:04: [irq 12]
[ 0.144352] pnp 00:04: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.144382] pnp 00:05: [io 0x0061]
[ 0.144438] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.144471] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.144484] pnp 00:06: [irq 13]
[ 0.144551] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.146542] pnp 00:07: [io 0x03f8-0x03ff]
[ 0.146559] pnp 00:07: [irq 4]
[ 0.146564] pnp 00:07: [dma 0 disabled]
[ 0.146785] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.148782] pnp 00:08: [io 0x02f8-0x02ff]
[ 0.148800] pnp 00:08: [irq 3]
[ 0.148806] pnp 00:08: [dma 0 disabled]
[ 0.149019] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.153784] pnp 00:09: [io 0x0378-0x037f]
[ 0.153791] pnp 00:09: [io 0x0778-0x077f]
[ 0.153807] pnp 00:09: [irq 7]
[ 0.153812] pnp 00:09: [dma 3]
[ 0.154839] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.155253] pnp 00:0a: [io 0x0000-0xffffffff disabled]
[ 0.155259] pnp 00:0a: [io 0x0a00-0x0a0f]
[ 0.155264] pnp 00:0a: [io 0x0290-0x029f]
[ 0.155268] pnp 00:0a: [io 0x0a20-0x0a2f]
[ 0.155273] pnp 00:0a: [io 0x0a30-0x0a3f]
[ 0.155402] system 00:0a: [io 0x0a00-0x0a0f] has been reserved
[ 0.155410] system 00:0a: [io 0x0290-0x029f] has been reserved
[ 0.155415] system 00:0a: [io 0x0a20-0x0a2f] has been reserved
[ 0.155420] system 00:0a: [io 0x0a30-0x0a3f] has been reserved
[ 0.155427] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.155660] pnp 00:0b: [io 0x0010-0x001f]
[ 0.155666] pnp 00:0b: [io 0x0022-0x003f]
[ 0.155670] pnp 00:0b: [io 0x0044-0x005f]
[ 0.155674] pnp 00:0b: [io 0x0062-0x0063]
[ 0.155679] pnp 00:0b: [io 0x0065-0x006f]
[ 0.155683] pnp 00:0b: [io 0x0072-0x007f]
[ 0.155687] pnp 00:0b: [io 0x0080]
[ 0.155691] pnp 00:0b: [io 0x0084-0x0086]
[ 0.155696] pnp 00:0b: [io 0x0088]
[ 0.155700] pnp 00:0b: [io 0x008c-0x008e]
[ 0.155704] pnp 00:0b: [io 0x0090-0x009f]
[ 0.155708] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.155713] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.155717] pnp 00:0b: [io 0x03e0-0x03e7]
[ 0.155721] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.155726] pnp 00:0b: [io 0x0800-0x087f]
[ 0.155730] pnp 00:0b: [io 0x0400-0x041f]
[ 0.155735] pnp 00:0b: [io 0x0000-0xffffffff disabled]
[ 0.155867] system 00:0b: [io 0x03e0-0x03e7] has been reserved
[ 0.155873] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.155879] system 00:0b: [io 0x0800-0x087f] has been reserved
[ 0.155884] system 00:0b: [io 0x0400-0x041f] has been reserved
[ 0.155891] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.156072] pnp 00:0c: [mem 0xfec00000-0xfec00fff]
[ 0.156078] pnp 00:0c: [mem 0xfee00000-0xfee00fff]
[ 0.156214] system 00:0c: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.156222] system 00:0c: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.156229] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.156798] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 0.156805] pnp 00:0d: [mem 0x000c0000-0x000cffff]
[ 0.156809] pnp 00:0d: [mem 0x000e0000-0x000fffff]
[ 0.156817] pnp 00:0d: [mem 0x00100000-0x1dffffff]
[ 0.156822] pnp 00:0d: [mem 0xff380000-0xffffffff]
[ 0.156978] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.156986] system 00:0d: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.156992] system 00:0d: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.156998] system 00:0d: [mem 0x00100000-0x1dffffff] could not be reserved
[ 0.157005] system 00:0d: [mem 0xff380000-0xffffffff] has been reserved
[ 0.157011] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.157422] pnp: PnP ACPI: found 14 devices
[ 0.157428] ACPI: ACPI bus type pnp unregistered
[ 0.157435] PnPBIOS: Disabled by ACPI PNP
[ 0.195914] Switching to clocksource acpi_pm
[ 0.195999] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.195999] pci 0000:00:01.0: bridge window [mem 0xfca00000-0xfeafffff]
[ 0.195999] pci 0000:00:01.0: bridge window [mem 0xeff00000-0xf7efffff pref]
[ 0.195999] pci 0000:00:01.0: setting latency timer to 64
[ 0.195999] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.195999] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.195999] pci_bus 0000:01: resource 1 [mem 0xfca00000-0xfeafffff]
[ 0.195999] pci_bus 0000:01: resource 2 [mem 0xeff00000-0xf7efffff pref]
[ 0.195999] NET: Registered protocol family 2
[ 0.195999] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.195999] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.195999] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.195999] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.195999] TCP: reno registered
[ 0.195999] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.195999] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.195999] NET: Registered protocol family 1
[ 0.195999] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.195999] pci 0000:00:11.0: Bypassing VIA 8237 APIC De-Assert Message
[ 0.195999] pci 0000:01:00.0: Boot video device
[ 0.195999] PCI: CLS 32 bytes, default 64
[ 0.195999] Unpacking initramfs...
[ 0.699678] Freeing initrd memory: 13704k freed
[ 0.720876] audit: initializing netlink socket (disabled)
[ 0.720919] type=2000 audit(1481494620.720:1): initialized
[ 0.738416] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.738736] VFS: Disk quotas dquot_6.5.2
[ 0.738789] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.738947] msgmni has been set to 936
[ 0.739323] alg: No test for stdrng (krng)
[ 0.739406] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.739414] io scheduler noop registered
[ 0.739418] io scheduler deadline registered
[ 0.739447] io scheduler cfq registered (default)
[ 0.739644] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.739681] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.739686] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.740554] GHES: HEST is not enabled!
[ 0.740583] isapnp: Scanning for PnP cards...
[ 1.094986] isapnp: No Plug & Play device found
[ 1.095108] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.115530] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.135988] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.156834] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.177376] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.177725] Linux agpgart interface v0.103
[ 1.177919] agpgart: Detected VIA VT3314 chipset
[ 1.183044] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 1.183247] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.183837] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.183905] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.184157] mousedev: PS/2 mouse device common for all mice
[ 1.184263] rtc_cmos 00:02: RTC can wake from S4
[ 1.184538] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.184607] rtc0: alarms up to one year, y3k, 114 bytes nvram
[ 1.184845] TCP: cubic registered
[ 1.184932] NET: Registered protocol family 10
[ 1.185349] Mobile IPv6
[ 1.185359] NET: Registered protocol family 17
[ 1.185372] Registering the dns_resolver key type
[ 1.185480] Using IPI No-Shortcut mode
[ 1.185712] PM: Hibernation image not present or could not be loaded.
[ 1.185750] registered taskstats version 1
[ 1.186427] rtc_cmos 00:02: setting system clock to 2016-12-11 22:17:01 UTC (1481494621)
[ 1.186614] Freeing unused kernel memory: 416k freed
[ 1.187268] Write protecting the kernel text: 3496k
[ 1.187297] Write protecting the kernel read-only data: 984k
[ 1.203579] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.224494] udevd[45]: starting version 175
[ 1.486346] usbcore: registered new interface driver usbfs
[ 1.486422] usbcore: registered new interface driver hub
[ 1.496591] SCSI subsystem initialized
[ 1.501101] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[ 1.519538] usbcore: registered new device driver usb
[ 1.527805] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.530951] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.541541] libata version 3.00 loaded.
[ 1.546851] via-rhine 0000:00:12.0: eth0: VIA Rhine II at 0x1ee00, 00:19:21:4d:37:e6, IRQ 23
[ 1.547659] via-rhine 0000:00:12.0: eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link cde1
[ 1.551747] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 1.551814] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 1.551931] ehci_hcd 0000:00:10.4: irq 21, io mem 0xfebefc00
[ 1.560109] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 1.560218] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.560225] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.560230] usb usb1: Product: EHCI Host Controller
[ 1.560234] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.560238] usb usb1: SerialNumber: 0000:00:10.4
[ 1.560520] hub 1-0:1.0: USB hub found
[ 1.560534] hub 1-0:1.0: 8 ports detected
[ 1.561165] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 1.561199] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.561247] uhci_hcd 0000:00:10.0: irq 21, io base 0x0000dc00
[ 1.561330] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.561337] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.561342] usb usb2: Product: UHCI Host Controller
[ 1.561346] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.561350] usb usb2: SerialNumber: 0000:00:10.0
[ 1.561931] hub 2-0:1.0: USB hub found
[ 1.561950] hub 2-0:1.0: 2 ports detected
[ 1.562185] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 1.562212] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 1.562256] uhci_hcd 0000:00:10.1: irq 21, io base 0x0000d880
[ 1.562334] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.562340] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.562345] usb usb3: Product: UHCI Host Controller
[ 1.562349] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.562353] usb usb3: SerialNumber: 0000:00:10.1
[ 1.562629] hub 3-0:1.0: USB hub found
[ 1.562642] hub 3-0:1.0: 2 ports detected
[ 1.562837] pata_via 0000:00:0f.1: version 0.3.4
[ 1.567389] microcode: CPU0 sig=0xf49, pf=0x10, revision=0x3
[ 1.567497] scsi0 : pata_via
[ 1.571079] scsi1 : pata_via
[ 1.585463] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 1.585472] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 1.585759] sata_via 0000:00:0f.0: version 2.6
[ 1.585856] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 1.589631] scsi2 : sata_via
[ 1.593279] scsi3 : sata_via
[ 1.599265] ata3: SATA max UDMA/133 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 20
[ 1.599275] ata4: SATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 20
[ 1.608407] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 1.608443] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 1.608493] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 1.608578] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.608584] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.608589] usb usb4: Product: UHCI Host Controller
[ 1.608593] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.608597] usb usb4: SerialNumber: 0000:00:10.2
[ 1.608877] hub 4-0:1.0: USB hub found
[ 1.608890] hub 4-0:1.0: 2 ports detected
[ 1.609077] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 1.609098] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 1.609146] uhci_hcd 0000:00:10.3: irq 21, io base 0x0000d480
[ 1.609220] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.609226] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.609230] usb usb5: Product: UHCI Host Controller
[ 1.609234] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.609238] usb usb5: SerialNumber: 0000:00:10.3
[ 1.609492] hub 5-0:1.0: USB hub found
[ 1.609503] hub 5-0:1.0: 2 ports detected
[ 1.707884] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.728054] Refined TSC clocksource calibration: 2666.667 MHz.
[ 1.728068] Switching to clocksource tsc
[ 1.800037] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.006938] ata3.00: ATA-7: ST3500630AS, 3.AAE, max UDMA/133
[ 2.006945] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.056034] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[ 2.073568] ata3.00: configured for UDMA/133
[ 2.073827] scsi 2:0:0:0: Direct-Access ATA ST3500630AS 3.AA PQ: 0 ANSI: 5
[ 2.239334] usb 2-2: New USB device found, idVendor=0518, idProduct=0001
[ 2.239342] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.239348] usb 2-2: Product: USB-compliant keyboard
[ 2.239352] usb 2-2: Manufacturer: Plus More Enterprise LTD.
[ 2.272511] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.0/input/input1
[ 2.272824] generic-usb 0003:0518:0001.0001: input,hidraw0: USB HID v1.10 Keyboard [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:10.0-2/input0
[ 2.276051] ata4: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 2.318342] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/pci0000:00/0000:00:10.0/usb2/2-2/2-2:1.1/input/input2
[ 2.319193] generic-usb 0003:0518:0001.0002: input,hidraw1: USB HID v1.10 Mouse [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:10.0-2/input1
[ 2.319828] usbcore: registered new interface driver usbhid
[ 2.319835] usbhid: USB HID core driver
[ 2.351998] sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 2.352369] sd 2:0:0:0: [sda] Write Protect is off
[ 2.352377] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.352452] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.392028] sda: sda1 sda2 < sda5 >
[ 2.392910] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.398456] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 7.692910] PM: Starting manual resume from disk
[ 7.692921] PM: Hibernation image partition 8:5 present
[ 7.692924] PM: Looking for hibernation image.
[ 7.693365] PM: Image not found (code -22)
[ 7.693372] PM: Hibernation image not present or could not be loaded.
[ 7.821469] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.684438] udevd[334]: starting version 175
[ 10.045128] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 10.045146] ACPI: Sleep Button [SLPB]
[ 10.045290] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4
[ 10.045302] ACPI: Power Button [PWRB]
[ 10.045419] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 10.045428] ACPI: Power Button [PWRF]
[ 10.207664] parport_pc 00:09: reported by Plug and Play ACPI
[ 10.207776] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 10.228007] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.135695] snd_via82xx 0000:00:11.5: setting latency timer to 64
[ 11.367761] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[ 13.274627] Adding 978940k swap on /dev/sda5. Priority:-1 extents:1 across:978940k
[ 13.312603] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.603974] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.766980] loop: module loaded
[ 16.421319] RPC: Registered named UNIX socket transport module.
[ 16.421328] RPC: Registered udp transport module.
[ 16.421332] RPC: Registered tcp transport module.
[ 16.421335] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.455973] FS-Cache: Loaded
[ 16.501825] NFS: Registering the id_resolver key type
[ 16.501876] FS-Cache: Netfs 'nfs' registered for caching
[ 16.513605] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 18.952193] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[ 20.221728] Bluetooth: Core ver 2.16
[ 20.222545] NET: Registered protocol family 31
[ 20.222553] Bluetooth: HCI device and connection manager initialized
[ 20.222559] Bluetooth: HCI socket layer initialized
[ 20.222563] Bluetooth: L2CAP socket layer initialized
[ 20.222582] Bluetooth: SCO socket layer initialized
[ 20.248512] Bluetooth: RFCOMM TTY layer initialized
[ 20.248527] Bluetooth: RFCOMM socket layer initialized
[ 20.248533] Bluetooth: RFCOMM ver 1.11
[ 20.279684] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.279694] Bluetooth: BNEP filters: protocol multicast
[ 20.355728] lp0: using parport0 (interrupt-driven).
[ 20.479107] ppdev: user-space parallel port driver
[ 25.309569] [drm] Initialized drm 1.1.0 20060810
[ 25.323949] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 25.323959] [drm] No driver support for vblank timestamp query.
[ 25.323967] [drm] Initialized via 2.11.1 20070202 for 0000:01:00.0 on minor 0
[ 25.408504] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[ 25.408548] agpgart-via 0000:00:00.0: putting AGP V3 device into 8x mode
[ 25.408663] pci 0000:01:00.0: putting AGP V3 device into 8x mode
[ 665.818402] I-pipe: head domain RTAI registered.
[ 665.818418] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 665.818430] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 665.818437] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8333249, CLK_FREQ 2666522000, CPU_FREQ 2666522000
[ 665.818442] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 665.818449] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8333249, 8333249, 7406000
[ 665.889185] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 665.889309] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 665.889320] RTAI[sched]: hard timer type/freq = APIC/8333249(Hz); default timing: oneshot; linear timed lists.
[ 665.889327] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2666522000 hz.
[ 665.889331] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 665.919579] RTAI[math]: loaded.
[ 666.304144] hm2: loading Mesa HostMot2 driver version 0.15
[ 666.317340] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 666.317422] hm2_pci: discovered 5i25 at 0000:00:08.0
[ 666.319317] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 666.375840] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 666.378731] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 666.481046] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 666.481056] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 666.481061] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 666.481065] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 666.481071] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 666.481077] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 666.481081] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 666.481085] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 666.481090] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 666.481095] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 666.481100] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 666.481105] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 666.481110] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 666.481115] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 666.481120] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 666.481124] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 666.481129] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 666.481134] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 666.481140] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #0, pin Direction (Output)
[ 666.481144] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #0, pin Step (Output)
[ 666.481149] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #1, pin Direction (Output)
[ 666.481154] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #1, pin Step (Output)
[ 666.481158] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #2, pin Direction (Output)
[ 666.481163] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #2, pin Step (Output)
[ 666.481168] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #3, pin Direction (Output)
[ 666.481172] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #3, pin Step (Output)
[ 666.481177] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #4, pin Direction (Output)
[ 666.481182] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #4, pin Step (Output)
[ 666.481186] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 666.481190] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 666.481194] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 666.481198] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 666.481202] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 666.481206] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 666.481209] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 666.481563] hm2/hm2_5i25.0: registered
[ 666.481571] hm2_5i25.0: initialized AnyIO board at 0000:00:08.0
[ 667.131089] hm2_5i25.0: dropping AnyIO board at 0000:00:08.0
[ 667.131104] hm2/hm2_5i25.0: unregistered
[ 667.132017] hm2_pci: driver unloaded
[ 667.137792] hm2: unloading
[ 669.412751] RTAI[math]: unloaded.
[ 669.418715] SCHED releases registered named ALIEN PEDV$D
[ 669.430983] RTAI[malloc]: unloaded.
[ 669.528028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 669.534953] I-pipe: head domain RTAI unregistered.
[ 669.534973] RTAI[hal]: unmounted.
