Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/233'
Machine configuration file is '233.ini'
INIFILE=/home/cnc/linuxcnc/configs/233/233.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=7935
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
233.hal:10: exit value: 1
233.hal:10: insmod failed, returned -1
See the output of 'dmesg' for more information.
7935
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
4318] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1078.564444] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1078.564461] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 1078.564474] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 1078.564483] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1078.576762] RTAI[math]: loaded.
[ 1078.779467] hm2: loading Mesa HostMot2 driver version 0.15
[ 1078.784065] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1078.784146] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1078.786360] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1078.843458] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 1078.846174] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 1078.848437] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 1078.852594] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 1078.857919] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1078.953079] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 1078.955657] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 1079.057369] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1079.057378] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1079.057385] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1079.057391] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1079.057399] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 1079.057408] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 1079.057416] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 1079.057424] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 1079.057431] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1079.057437] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1079.057443] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1079.057449] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1079.057455] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1079.057461] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1079.057467] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1079.057474] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1079.057480] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1079.057486] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1079.057492] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1079.057498] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1079.057504] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1079.057510] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1079.057517] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1079.057523] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1079.057529] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1079.057536] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1079.057544] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1079.057552] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1079.057560] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1079.057570] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1079.057578] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1079.057585] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1079.057593] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1079.057601] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1079.057609] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1079.057772] hm2/hm2_5i25.0: registered
[ 1079.057779] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 1079.070535] creating ladder-state
[ 1573.461701] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 1573.461720] hm2/hm2_5i25.0: unregistered
[ 1573.461843] hm2_pci: driver unloaded
[ 1573.466222] hm2: unloading
[ 1575.709065] RTAI[math]: unloaded.
[ 1575.713716] SCHED releases registered named ALIEN PEDV$D
[ 1575.723988] RTAI[malloc]: unloaded.
[ 1575.824040] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1575.828297] I-pipe: head domain RTAI unregistered.
[ 1575.828480] RTAI[hal]: unmounted.
[ 1578.079561] I-pipe: head domain RTAI registered.
[ 1578.079580] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1578.079755] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1578.079768] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 1578.079778] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1578.079790] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12394000
[ 1578.093848] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1578.093967] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1578.093985] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 1578.093998] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 1578.094007] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1578.107508] RTAI[math]: loaded.
[ 1585.675501] trivkins: Unknown parameter `\'
[ 1795.902311] hm2: loading Mesa HostMot2 driver version 0.15
[ 1802.812104] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1802.812168] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1802.814417] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1802.872177] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1802.872187] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1802.872194] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1802.872200] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1802.872206] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 1802.872212] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 1802.872218] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 1802.872225] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1802.872232] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
[ 1802.872240] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #3, pin Muxed A (Input)
[ 1802.872248] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #3, pin Muxed B (Input)
[ 1802.872256] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #3, pin Muxed Index (Input)
[ 1802.872263] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1802.872269] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1802.872275] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1802.872281] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1802.872287] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1802.872294] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1802.872300] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1802.872306] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1802.872312] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1802.872318] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1802.872324] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1802.872331] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1802.872337] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1802.872344] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1802.872352] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1802.872359] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1802.872367] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1802.872375] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1802.872382] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1802.872390] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1802.872398] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1802.872406] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1802.872413] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1802.872550] hm2/hm2_5i25.0: registered
[ 1802.872556] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 1847.418113] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 1847.418127] hm2/hm2_5i25.0: unregistered
[ 1847.418227] hm2_pci: driver unloaded
[ 1856.891383] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1856.891458] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1856.892845] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1856.950091] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1856.950102] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1856.950109] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1856.950115] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1856.950121] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 1856.950127] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 1856.950133] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 1856.950139] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1856.950145] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1856.950151] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1856.950157] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1856.950163] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1856.950170] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1856.950176] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1856.950182] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1856.950188] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1856.950194] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1856.950200] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1856.950206] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1856.950213] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1856.950219] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1856.950225] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1856.950231] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1856.950237] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1856.950243] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1856.950251] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1856.950259] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1856.950267] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1856.950274] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1856.950282] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1856.950290] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1856.950298] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1856.950305] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1856.950313] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1856.950321] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1856.950446] hm2/hm2_5i25.0: registered
[ 1856.950453] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 1868.439497] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 1868.439510] hm2/hm2_5i25.0: unregistered
[ 1868.439609] hm2_pci: driver unloaded
[ 1876.553076] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1876.553141] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1876.554223] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1876.609787] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 1876.611179] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 1876.674389] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1876.674398] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1876.674405] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1876.674411] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1876.674419] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 1876.674427] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 1876.674434] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 1876.674440] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1876.674447] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1876.674453] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1876.674459] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1876.674465] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1876.674471] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1876.674477] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1876.674483] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1876.674489] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1876.674496] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1876.674502] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1876.674508] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1876.674514] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1876.674520] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1876.674526] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1876.674532] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1876.674538] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1876.674545] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1876.674552] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1876.674560] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1876.674568] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1876.674575] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1876.674583] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1876.674591] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1876.674598] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1876.674606] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1876.674614] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1876.674622] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1876.674768] hm2/hm2_5i25.0: registered
[ 1876.674774] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 1877.579712] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 1877.579726] hm2/hm2_5i25.0: unregistered
[ 1877.579827] hm2_pci: driver unloaded
[ 1880.590868] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1880.590932] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1880.592123] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1880.648204] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 1880.649597] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 1880.712592] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1880.712601] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1880.712608] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1880.712614] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1880.712622] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 1880.712631] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 1880.712638] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 1880.712644] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1880.712650] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1880.712656] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1880.712662] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1880.712668] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1880.712674] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1880.712680] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1880.712686] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1880.712693] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1880.712699] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1880.712705] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1880.712711] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1880.712717] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1880.712723] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1880.712729] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1880.712735] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1880.712742] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1880.712748] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1880.712755] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1880.712763] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1880.712771] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1880.712778] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1880.712786] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1880.712794] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1880.712802] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1880.712809] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1880.712817] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1880.712825] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1880.712970] hm2/hm2_5i25.0: registered
[ 1880.712976] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 1934.564210] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 1934.564227] hm2/hm2_5i25.0: unregistered
[ 1934.564328] hm2_pci: driver unloaded
[ 1939.772430] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1939.772494] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 1939.773586] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1939.830935] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1939.830945] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1939.830952] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1939.830958] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1939.830964] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 1939.830970] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 1939.830976] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 1939.830983] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 1939.830989] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 1939.830995] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 1939.831001] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 1939.831007] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 1939.831013] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 1939.831019] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 1939.831025] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 1939.831032] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 1939.831038] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 1939.831044] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 1939.831050] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1939.831056] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1939.831062] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1939.831068] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1939.831075] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1939.831081] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1939.831087] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1939.831095] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1939.831103] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1939.831110] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1939.831118] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1939.831126] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1939.831133] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1939.831141] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1939.831149] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1939.831157] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1939.831164] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1939.831290] hm2/hm2_5i25.0: registered
[ 1939.831296] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2098.990861] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2098.990875] hm2/hm2_5i25.0: unregistered
[ 2098.990974] hm2_pci: driver unloaded
[ 2105.005013] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2105.005076] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2105.006156] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2105.061752] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2105.063151] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2105.126357] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2105.126366] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2105.126372] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2105.126378] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2105.126387] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2105.126395] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2105.126402] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2105.126408] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2105.126414] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2105.126420] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2105.126426] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2105.126432] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2105.126438] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2105.126445] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2105.126451] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2105.126457] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2105.126463] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2105.126469] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2105.126475] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2105.126481] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2105.126488] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2105.126494] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2105.126500] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2105.126506] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2105.126512] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2105.126520] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2105.126528] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2105.126535] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2105.126543] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2105.126551] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2105.126558] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2105.126566] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2105.126574] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2105.126582] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2105.126589] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2105.126735] hm2/hm2_5i25.0: registered
[ 2105.126741] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2121.174476] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2121.174490] hm2/hm2_5i25.0: unregistered
[ 2121.174590] hm2_pci: driver unloaded
[ 2126.701402] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2126.701467] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2126.702547] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2126.758764] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 2126.760571] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 2126.762105] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 2126.764825] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 2126.768263] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 2126.829747] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2126.831137] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2126.895389] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2126.895398] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2126.895405] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2126.895411] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2126.895419] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2126.895427] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2126.895435] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 2126.895443] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 2126.895450] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2126.895456] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2126.895462] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2126.895468] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2126.895475] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2126.895481] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2126.895487] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2126.895493] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2126.895499] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2126.895505] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2126.895511] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2126.895518] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2126.895524] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2126.895530] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2126.895536] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2126.895542] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2126.895548] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2126.895556] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2126.895564] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2126.895571] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2126.895579] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2126.895587] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2126.895594] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2126.895602] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2126.895610] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2126.895617] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2126.895625] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2126.895787] hm2/hm2_5i25.0: registered
[ 2126.895793] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2263.459080] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2263.459094] hm2/hm2_5i25.0: unregistered
[ 2263.459195] hm2_pci: driver unloaded
[ 2297.227018] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2297.227083] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2297.227669] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2297.284796] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2297.284806] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2297.284813] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2297.284819] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2297.284825] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 2297.284831] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 2297.284837] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2297.284843] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2297.284849] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2297.284855] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2297.284861] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2297.284868] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2297.284874] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2297.284880] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2297.284886] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2297.284892] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2297.284898] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2297.284904] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2297.284911] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2297.284917] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2297.284923] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2297.284929] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2297.284935] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2297.284941] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2297.284947] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2297.284955] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2297.284963] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2297.284971] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2297.284979] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2297.284986] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2297.284994] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2297.285002] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2297.285009] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 2297.285015] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 2297.285021] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 2297.285141] hm2/hm2_5i25.0: registered
[ 2297.285147] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2493.750993] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2493.751008] hm2/hm2_5i25.0: unregistered
[ 2493.751111] hm2_pci: driver unloaded
[ 2493.755478] hm2: unloading
[ 2493.909560] RTAI[math]: unloaded.
[ 2493.914658] SCHED releases registered named ALIEN PEDV$D
[ 2493.924900] RTAI[malloc]: unloaded.
[ 2494.024050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2494.028357] I-pipe: head domain RTAI unregistered.
[ 2494.028555] RTAI[hal]: unmounted.
[ 2506.062110] I-pipe: head domain RTAI registered.
[ 2506.062124] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2506.062283] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2506.062293] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 2506.062301] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2506.062309] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12362000
[ 2506.076554] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2506.076648] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2506.076660] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 2506.076669] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 2506.076675] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2506.092579] RTAI[math]: loaded.
[ 2506.276170] hm2: loading Mesa HostMot2 driver version 0.15
[ 2506.280508] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2506.280585] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2506.281206] hm2/hm2_5i25.0: IDRom:
[ 2506.281220] hm2/hm2_5i25.0: IDRom Type: 0x00000003
[ 2506.281230] hm2/hm2_5i25.0: Offset to Modules: 0x00000040
[ 2506.281239] hm2/hm2_5i25.0: Offset to Pin Description: 0x000001C0
[ 2506.281248] hm2/hm2_5i25.0: Board Name: MESA5I25
[ 2506.281256] hm2/hm2_5i25.0: FPGA Size: 9
[ 2506.281264] hm2/hm2_5i25.0: FPGA Pins: 144
[ 2506.281272] hm2/hm2_5i25.0: Port Width: 17
[ 2506.281279] hm2/hm2_5i25.0: IO Ports: 2
[ 2506.281287] hm2/hm2_5i25.0: IO Width: 34
[ 2506.281296] hm2/hm2_5i25.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
[ 2506.281307] hm2/hm2_5i25.0: Clock High: 200000000 Hz (200000 KHz, 200 MHz)
[ 2506.281316] hm2/hm2_5i25.0: Instance Stride 0: 0x00000004
[ 2506.281324] hm2/hm2_5i25.0: Instance Stride 1: 0x00000040
[ 2506.281333] hm2/hm2_5i25.0: Register Stride 0: 0x00000100
[ 2506.281342] hm2/hm2_5i25.0: Register Stride 1: 0x00000100
[ 2506.281381] hm2/hm2_5i25.0: 34 HM2 Pin Descriptors:
[ 2506.281387] hm2/hm2_5i25.0: pin 0:
[ 2506.281393] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281400] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281406] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281413] hm2/hm2_5i25.0: Secondary Pin: 0x96 (TxEn5 , Output)
[ 2506.281419] hm2/hm2_5i25.0: pin 1:
[ 2506.281425] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281431] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281437] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281444] hm2/hm2_5i25.0: Secondary Pin: 0x86 (TxData5, Output)
[ 2506.281449] hm2/hm2_5i25.0: pin 2:
[ 2506.281455] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281461] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281468] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281474] hm2/hm2_5i25.0: Secondary Pin: 0x06 (RxData5, Input)
[ 2506.281479] hm2/hm2_5i25.0: pin 3:
[ 2506.281485] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281491] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281498] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281504] hm2/hm2_5i25.0: Secondary Pin: 0x85 (TxData4, Output)
[ 2506.281510] hm2/hm2_5i25.0: pin 4:
[ 2506.281515] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281521] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281528] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281534] hm2/hm2_5i25.0: Secondary Pin: 0x05 (RxData4, Input)
[ 2506.281539] hm2/hm2_5i25.0: pin 5:
[ 2506.281545] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281551] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281557] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281564] hm2/hm2_5i25.0: Secondary Pin: 0x84 (TxData3, Output)
[ 2506.281569] hm2/hm2_5i25.0: pin 6:
[ 2506.281575] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281581] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281587] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281594] hm2/hm2_5i25.0: Secondary Pin: 0x04 (RxData3, Input)
[ 2506.281599] hm2/hm2_5i25.0: pin 7:
[ 2506.281605] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281611] hm2/hm2_5i25.0: Secondary Tag: 0x0D (Muxed Encoder Select)
[ 2506.281617] hm2/hm2_5i25.0: Secondary Unit: 0x06
[ 2506.281624] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Mux Select 0, Output)
[ 2506.281630] hm2/hm2_5i25.0: pin 8:
[ 2506.281635] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281641] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281647] hm2/hm2_5i25.0: Secondary Unit: 0x03
[ 2506.281662] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.281670] hm2/hm2_5i25.0: pin 9:
[ 2506.281675] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281682] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281688] hm2/hm2_5i25.0: Secondary Unit: 0x03
[ 2506.281694] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.281700] hm2/hm2_5i25.0: pin 10:
[ 2506.281705] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281711] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281717] hm2/hm2_5i25.0: Secondary Unit: 0x03
[ 2506.281723] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.281729] hm2/hm2_5i25.0: pin 11:
[ 2506.281735] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281741] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281747] hm2/hm2_5i25.0: Secondary Unit: 0x04
[ 2506.281753] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.281759] hm2/hm2_5i25.0: pin 12:
[ 2506.281765] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281771] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281777] hm2/hm2_5i25.0: Secondary Unit: 0x04
[ 2506.281783] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.281789] hm2/hm2_5i25.0: pin 13:
[ 2506.281794] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281800] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281806] hm2/hm2_5i25.0: Secondary Unit: 0x04
[ 2506.281812] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.281818] hm2/hm2_5i25.0: pin 14:
[ 2506.281824] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281830] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281836] hm2/hm2_5i25.0: Secondary Unit: 0x05
[ 2506.281842] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.281848] hm2/hm2_5i25.0: pin 15:
[ 2506.281853] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281860] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281866] hm2/hm2_5i25.0: Secondary Unit: 0x05
[ 2506.281872] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.281877] hm2/hm2_5i25.0: pin 16:
[ 2506.281883] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281889] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.281895] hm2/hm2_5i25.0: Secondary Unit: 0x05
[ 2506.281901] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.281907] hm2/hm2_5i25.0: pin 17:
[ 2506.281913] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281919] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281925] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281931] hm2/hm2_5i25.0: Secondary Pin: 0x93 (TxEn2 , Output)
[ 2506.281937] hm2/hm2_5i25.0: pin 18:
[ 2506.281943] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281949] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281955] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281961] hm2/hm2_5i25.0: Secondary Pin: 0x83 (TxData2, Output)
[ 2506.281967] hm2/hm2_5i25.0: pin 19:
[ 2506.281973] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.281979] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.281985] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.281991] hm2/hm2_5i25.0: Secondary Pin: 0x03 (RxData2, Input)
[ 2506.281997] hm2/hm2_5i25.0: pin 20:
[ 2506.282003] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282009] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.282015] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282021] hm2/hm2_5i25.0: Secondary Pin: 0x82 (TxData1, Output)
[ 2506.282027] hm2/hm2_5i25.0: pin 21:
[ 2506.282033] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282039] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.282045] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282051] hm2/hm2_5i25.0: Secondary Pin: 0x02 (RxData1, Input)
[ 2506.282057] hm2/hm2_5i25.0: pin 22:
[ 2506.282063] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282069] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.282075] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282081] hm2/hm2_5i25.0: Secondary Pin: 0x81 (TxData0, Output)
[ 2506.282087] hm2/hm2_5i25.0: pin 23:
[ 2506.282093] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282099] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[ 2506.282105] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282111] hm2/hm2_5i25.0: Secondary Pin: 0x01 (RxData0, Input)
[ 2506.282117] hm2/hm2_5i25.0: pin 24:
[ 2506.282123] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282129] hm2/hm2_5i25.0: Secondary Tag: 0x0D (Muxed Encoder Select)
[ 2506.282135] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282141] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Mux Select 0, Output)
[ 2506.282147] hm2/hm2_5i25.0: pin 25:
[ 2506.282153] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282159] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282165] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282171] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.282177] hm2/hm2_5i25.0: pin 26:
[ 2506.282182] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282188] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282194] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282201] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.282206] hm2/hm2_5i25.0: pin 27:
[ 2506.282212] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282218] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282224] hm2/hm2_5i25.0: Secondary Unit: 0x00
[ 2506.282230] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.282236] hm2/hm2_5i25.0: pin 28:
[ 2506.282242] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282248] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282254] hm2/hm2_5i25.0: Secondary Unit: 0x01
[ 2506.282260] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.282266] hm2/hm2_5i25.0: pin 29:
[ 2506.282271] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282277] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282283] hm2/hm2_5i25.0: Secondary Unit: 0x01
[ 2506.282289] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.282295] hm2/hm2_5i25.0: pin 30:
[ 2506.282301] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282307] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282313] hm2/hm2_5i25.0: Secondary Unit: 0x01
[ 2506.282319] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.282325] hm2/hm2_5i25.0: pin 31:
[ 2506.282330] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282337] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282343] hm2/hm2_5i25.0: Secondary Unit: 0x02
[ 2506.282349] hm2/hm2_5i25.0: Secondary Pin: 0x01 (Muxed A, Input)
[ 2506.282354] hm2/hm2_5i25.0: pin 32:
[ 2506.282360] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282366] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282372] hm2/hm2_5i25.0: Secondary Unit: 0x02
[ 2506.282378] hm2/hm2_5i25.0: Secondary Pin: 0x02 (Muxed B, Input)
[ 2506.282384] hm2/hm2_5i25.0: pin 33:
[ 2506.282390] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[ 2506.282396] hm2/hm2_5i25.0: Secondary Tag: 0x0C (Muxed Encoder)
[ 2506.282402] hm2/hm2_5i25.0: Secondary Unit: 0x02
[ 2506.282408] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Muxed Index, Input)
[ 2506.282417] hm2/hm2_5i25.0: Module Descriptor 0 at 0x0440:
[ 2506.282423] hm2/hm2_5i25.0: General Function Tag: 2 (Watchdog)
[ 2506.282429] hm2/hm2_5i25.0: Version: 0
[ 2506.282436] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282441] hm2/hm2_5i25.0: Instances: 1
[ 2506.282447] hm2/hm2_5i25.0: Base Address: 0x0C00
[ 2506.282452] hm2/hm2_5i25.0: -- Num Registers: 3
[ 2506.282458] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282464] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[ 2506.282470] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000000
[ 2506.282478] hm2/hm2_5i25.0: Module Descriptor 1 at 0x044C:
[ 2506.282484] hm2/hm2_5i25.0: General Function Tag: 3 (IOPort)
[ 2506.282489] hm2/hm2_5i25.0: Version: 0
[ 2506.282496] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282501] hm2/hm2_5i25.0: Instances: 2
[ 2506.282507] hm2/hm2_5i25.0: Base Address: 0x1000
[ 2506.282512] hm2/hm2_5i25.0: -- Num Registers: 5
[ 2506.282518] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282524] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[ 2506.282530] hm2/hm2_5i25.0: -- Multiple Registers: 0x0000001F
[ 2506.282538] hm2/hm2_5i25.0: Module Descriptor 2 at 0x0458:
[ 2506.282544] hm2/hm2_5i25.0: General Function Tag: 12 (Muxed Encoder)
[ 2506.282550] hm2/hm2_5i25.0: Version: 3
[ 2506.282556] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282562] hm2/hm2_5i25.0: Instances: 12
[ 2506.282567] hm2/hm2_5i25.0: Base Address: 0x3500
[ 2506.282573] hm2/hm2_5i25.0: -- Num Registers: 5
[ 2506.282578] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282584] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[ 2506.282590] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000003
[ 2506.282598] hm2/hm2_5i25.0: Module Descriptor 3 at 0x0464:
[ 2506.282605] hm2/hm2_5i25.0: General Function Tag: 13 (Muxed Encoder Select)
[ 2506.282611] hm2/hm2_5i25.0: Version: 0
[ 2506.282617] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282622] hm2/hm2_5i25.0: Instances: 1
[ 2506.282628] hm2/hm2_5i25.0: Base Address: 0x0000
[ 2506.282633] hm2/hm2_5i25.0: -- Num Registers: 0
[ 2506.282639] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282645] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[ 2506.282653] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000000
[ 2506.282662] hm2/hm2_5i25.0: Module Descriptor 4 at 0x0470:
[ 2506.282670] hm2/hm2_5i25.0: General Function Tag: 193 (Smart Serial Interface)
[ 2506.282676] hm2/hm2_5i25.0: Version: 0
[ 2506.282682] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282687] hm2/hm2_5i25.0: Instances: 1
[ 2506.282693] hm2/hm2_5i25.0: Base Address: 0x5A00
[ 2506.282698] hm2/hm2_5i25.0: -- Num Registers: 6
[ 2506.282704] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282710] hm2/hm2_5i25.0: -- Instance Stride: 0x00000040
[ 2506.282716] hm2/hm2_5i25.0: -- Multiple Registers: 0x0000003C
[ 2506.282724] hm2/hm2_5i25.0: Module Descriptor 5 at 0x047C:
[ 2506.282730] hm2/hm2_5i25.0: General Function Tag: 128 (LED)
[ 2506.282736] hm2/hm2_5i25.0: Version: 0
[ 2506.282742] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[ 2506.282748] hm2/hm2_5i25.0: Instances: 1
[ 2506.282753] hm2/hm2_5i25.0: Base Address: 0x0200
[ 2506.282758] hm2/hm2_5i25.0: -- Num Registers: 1
[ 2506.282764] hm2/hm2_5i25.0: Register Stride: 0x00000100
[ 2506.282770] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[ 2506.282776] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000000
[ 2506.284283] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2506.341957] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2506.341967] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2506.341974] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2506.341980] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2506.341986] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 2506.341992] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 2506.341998] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2506.342004] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2506.342011] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2506.342017] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2506.342023] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2506.342029] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2506.342035] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2506.342041] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2506.342048] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2506.342054] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2506.342060] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2506.342066] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2506.342072] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2506.342079] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2506.342085] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2506.342091] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2506.342097] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2506.342103] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2506.342110] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2506.342117] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2506.342125] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2506.342133] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2506.342141] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2506.342148] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2506.342156] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2506.342164] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2506.342172] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2506.342179] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2506.342187] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2506.342194] hm2/hm2_5i25.0: HM2 Modules used:
[ 2506.342199] hm2/hm2_5i25.0: Encoders: 6
[ 2506.342206] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 2506.342212] hm2/hm2_5i25.0: version: 3
[ 2506.342217] hm2/hm2_5i25.0: counter_addr: 0x3500
[ 2506.342223] hm2/hm2_5i25.0: latch_control_addr: 0x3600
[ 2506.342229] hm2/hm2_5i25.0: timestamp_div_addr: 0x3700
[ 2506.342235] hm2/hm2_5i25.0: timestamp_count_addr: 0x3800
[ 2506.342241] hm2/hm2_5i25.0: filter_rate_addr: 0x3900
[ 2506.342247] hm2/hm2_5i25.0: timestamp_div: 0x001F
[ 2506.342252] hm2/hm2_5i25.0: instance 0:
[ 2506.342257] hm2/hm2_5i25.0: hw:
[ 2506.342262] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342269] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342275] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342280] hm2/hm2_5i25.0: instance 1:
[ 2506.342285] hm2/hm2_5i25.0: hw:
[ 2506.342291] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342297] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342303] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342309] hm2/hm2_5i25.0: instance 2:
[ 2506.342313] hm2/hm2_5i25.0: hw:
[ 2506.342319] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342325] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342331] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342337] hm2/hm2_5i25.0: instance 3:
[ 2506.342342] hm2/hm2_5i25.0: hw:
[ 2506.342347] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342353] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342359] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342365] hm2/hm2_5i25.0: instance 4:
[ 2506.342370] hm2/hm2_5i25.0: hw:
[ 2506.342375] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342381] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342387] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342393] hm2/hm2_5i25.0: instance 5:
[ 2506.342398] hm2/hm2_5i25.0: hw:
[ 2506.342403] hm2/hm2_5i25.0: counter = 0000.0000
[ 2506.342409] hm2/hm2_5i25.0: latch/control = 0000.0800
[ 2506.342415] hm2/hm2_5i25.0: prev_control = 0000.0800
[ 2506.342421] hm2/hm2_5i25.0: Absolute Encoder (Generic): 0
[ 2506.342427] hm2/hm2_5i25.0: resolvers: 0
[ 2506.342432] hm2/hm2_5i25.0: PWMGen: 0
[ 2506.342438] hm2/hm2_5i25.0: 3-phase PWMGen: 0
[ 2506.342443] hm2/hm2_5i25.0: SSerial: 0
[ 2506.342448] hm2/hm2_5i25.0: version 43
[ 2506.342454] hm2/hm2_5i25.0: StepGen: 0
[ 2506.342460] hm2/hm2_5i25.0: Buffered SPI: 0
[ 2506.342465] hm2/hm2_5i25.0: IO Ports: 2
[ 2506.342472] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 2506.342478] hm2/hm2_5i25.0: version: 0
[ 2506.342483] hm2/hm2_5i25.0: data_addr: 0x1000
[ 2506.342489] hm2/hm2_5i25.0: ddr_addr: 0x1100
[ 2506.342494] hm2/hm2_5i25.0: alt_source_addr: 0x1200
[ 2506.342500] hm2/hm2_5i25.0: open_drain_addr: 0x1300
[ 2506.342506] hm2/hm2_5i25.0: output_invert_addr: 0x1400
[ 2506.342511] hm2/hm2_5i25.0: instance 0:
[ 2506.342517] hm2/hm2_5i25.0: data_read = 0x0041FF
[ 2506.342522] hm2/hm2_5i25.0: data_write = 0x000000
[ 2506.342528] hm2/hm2_5i25.0: ddr = 0x000000
[ 2506.342533] hm2/hm2_5i25.0: alt_source = 0x000000
[ 2506.342539] hm2/hm2_5i25.0: open_drain = 0x000000
[ 2506.342545] hm2/hm2_5i25.0: output_invert = 0x000000
[ 2506.342550] hm2/hm2_5i25.0: instance 1:
[ 2506.342556] hm2/hm2_5i25.0: data_read = 0x01FF7F
[ 2506.342562] hm2/hm2_5i25.0: data_write = 0x000000
[ 2506.342567] hm2/hm2_5i25.0: ddr = 0x000080
[ 2506.342573] hm2/hm2_5i25.0: alt_source = 0x01FF80
[ 2506.342579] hm2/hm2_5i25.0: open_drain = 0x000000
[ 2506.342584] hm2/hm2_5i25.0: output_invert = 0x000000
[ 2506.342590] hm2/hm2_5i25.0: Watchdog: 1
[ 2506.342597] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[ 2506.342602] hm2/hm2_5i25.0: version: 0
[ 2506.342608] hm2/hm2_5i25.0: timer_addr: 0x0C00
[ 2506.342613] hm2/hm2_5i25.0: status_addr: 0x0D00
[ 2506.342619] hm2/hm2_5i25.0: reset_addr: 0x0E00
[ 2506.342625] hm2/hm2_5i25.0: instance 0:
[ 2506.342631] hm2/hm2_5i25.0: param timeout_ns = 5000000
[ 2506.342636] hm2/hm2_5i25.0: pin has_bit = 0
[ 2506.342645] hm2/hm2_5i25.0: reg timer = 0x80000000
[ 2506.342778] hm2/hm2_5i25.0: registered
[ 2506.342785] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2506.893826] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2506.893840] hm2/hm2_5i25.0: unregistered
[ 2506.893942] hm2_pci: driver unloaded
[ 2506.898387] hm2: unloading
[ 2507.052340] RTAI[math]: unloaded.
[ 2507.056826] SCHED releases registered named ALIEN PEDV$D
[ 2507.065434] RTAI[malloc]: unloaded.
[ 2507.164065] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2507.168256] I-pipe: head domain RTAI unregistered.
[ 2507.168513] RTAI[hal]: unmounted.
[ 2523.536574] I-pipe: head domain RTAI registered.
[ 2523.536593] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 2523.536770] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2523.536782] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 2523.536793] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 2523.536805] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12371000
[ 2523.550501] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2523.550602] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 2523.550619] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 2523.550629] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 2523.550637] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2523.562679] RTAI[math]: loaded.
[ 2732.492041] hm2: loading Mesa HostMot2 driver version 0.15
[ 2738.105041] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2738.105120] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2738.110246] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2738.166537] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 2738.168520] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 2738.170059] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 2738.173096] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 2738.176709] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 2738.238541] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2738.239933] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2738.305747] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2738.305762] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2738.305771] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2738.305779] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2738.305790] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2738.305802] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2738.305813] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 2738.305825] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 2738.305836] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
[ 2738.305847] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #3, pin Muxed A (Input)
[ 2738.305857] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #3, pin Muxed B (Input)
[ 2738.305868] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #3, pin Muxed Index (Input)
[ 2738.305878] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #4, pin Muxed A (Input)
[ 2738.305888] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #4, pin Muxed B (Input)
[ 2738.305899] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #4, pin Muxed Index (Input)
[ 2738.305909] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #5, pin Muxed A (Input)
[ 2738.305920] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #5, pin Muxed B (Input)
[ 2738.305930] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #5, pin Muxed Index (Input)
[ 2738.305940] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2738.305948] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2738.305957] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2738.305966] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2738.305974] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2738.305983] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2738.305991] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2738.306001] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2738.306011] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2738.306022] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2738.306032] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2738.306042] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2738.306053] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2738.306063] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2738.306074] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2738.306085] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2738.306096] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2738.306329] hm2/hm2_5i25.0: registered
[ 2738.306338] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2781.926767] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2781.926781] hm2/hm2_5i25.0: unregistered
[ 2781.926882] hm2_pci: driver unloaded
[ 2784.753884] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2784.753960] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2784.754740] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2784.810927] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 2784.812741] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 2784.814275] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 2784.816996] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 2784.820427] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 2784.881988] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2784.883379] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2784.947222] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2784.947230] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2784.947237] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2784.947243] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2784.947251] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2784.947259] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2784.947267] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 2784.947275] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 2784.947282] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2784.947288] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2784.947294] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2784.947300] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2784.947306] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2784.947312] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2784.947318] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2784.947325] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2784.947331] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2784.947337] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2784.947343] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2784.947349] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2784.947355] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2784.947361] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2784.947367] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2784.947373] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2784.947379] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2784.947387] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2784.947395] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2784.947402] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2784.947410] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2784.947417] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 2784.947423] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 2784.947429] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 2784.947435] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 2784.947441] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 2784.947447] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 2784.947600] hm2/hm2_5i25.0: registered
[ 2784.947606] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2852.421711] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2852.421725] hm2/hm2_5i25.0: unregistered
[ 2852.421829] hm2_pci: driver unloaded
[ 2888.107850] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2888.107926] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2888.109343] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2888.166694] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2888.166705] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2888.166712] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2888.166718] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2888.166724] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 2888.166730] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 2888.166736] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2888.166742] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2888.166748] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2888.166754] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2888.166760] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2888.166766] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2888.166772] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2888.166778] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2888.166785] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2888.166791] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2888.166797] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2888.166803] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2888.166809] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2888.166815] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2888.166821] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2888.166827] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2888.166834] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2888.166840] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2888.166846] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2888.166854] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2888.166862] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2888.166869] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2888.166877] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2888.166885] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2888.166892] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2888.166900] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2888.166908] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2888.166915] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2888.166923] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2888.167049] hm2/hm2_5i25.0: registered
[ 2888.167055] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2926.483329] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2926.483343] hm2/hm2_5i25.0: unregistered
[ 2926.483444] hm2_pci: driver unloaded
[ 2934.399705] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2934.399781] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2934.401072] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2934.456732] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2934.458124] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2934.521302] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2934.521310] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2934.521317] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2934.521323] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2934.521331] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2934.521339] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2934.521346] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2934.521352] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2934.521358] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2934.521364] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2934.521370] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2934.521376] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2934.521382] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2934.521389] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2934.521395] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2934.521401] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2934.521407] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2934.521413] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2934.521419] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2934.521425] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2934.521431] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2934.521437] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2934.521444] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2934.521450] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2934.521456] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2934.521463] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2934.521471] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2934.521479] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2934.521486] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2934.521494] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2934.521502] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2934.521509] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2934.521517] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2934.521525] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2934.521532] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2934.521678] hm2/hm2_5i25.0: registered
[ 2934.521684] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2971.812829] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2971.812847] hm2/hm2_5i25.0: unregistered
[ 2971.812954] hm2_pci: driver unloaded
[ 2991.871394] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2991.871469] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2991.873183] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2991.928922] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2991.930316] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2991.993546] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2991.993554] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2991.993561] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2991.993567] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2991.993575] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2991.993583] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2991.993590] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2991.993596] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2991.993603] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2991.993609] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2991.993615] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2991.993621] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2991.993627] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2991.993633] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2991.993639] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2991.993645] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2991.993651] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2991.993657] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2991.993664] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2991.993670] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2991.993676] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2991.993682] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2991.993688] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2991.993694] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2991.993700] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2991.993708] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2991.993716] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2991.993723] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2991.993731] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2991.993739] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2991.993746] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2991.993754] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2991.993762] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2991.993769] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2991.993777] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2991.993922] hm2/hm2_5i25.0: registered
[ 2991.993928] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 2993.116697] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 2993.116711] hm2/hm2_5i25.0: unregistered
[ 2993.116814] hm2_pci: driver unloaded
[ 2994.922221] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2994.922294] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 2994.923828] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2994.979551] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 2994.980982] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 2995.044117] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2995.044125] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2995.044132] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2995.044138] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2995.044146] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 2995.044154] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 2995.044161] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2995.044167] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2995.044173] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 2995.044179] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 2995.044185] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 2995.044191] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 2995.044197] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2995.044204] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2995.044210] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2995.044216] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2995.044222] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2995.044228] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2995.044234] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2995.044240] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2995.044246] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2995.044252] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2995.044258] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2995.044264] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2995.044270] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2995.044278] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2995.044286] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2995.044293] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2995.044301] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2995.044308] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 2995.044316] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 2995.044324] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 2995.044331] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 2995.044339] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 2995.044347] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 2995.044493] hm2/hm2_5i25.0: registered
[ 2995.044499] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 3004.815573] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 3004.815588] hm2/hm2_5i25.0: unregistered
[ 3004.815691] hm2_pci: driver unloaded
[ 3009.773303] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3009.773378] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 3009.774626] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3009.830854] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 3009.832669] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 3009.834202] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 3009.836917] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 3009.840356] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 3009.901915] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 3009.903305] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 3009.967478] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3009.967486] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3009.967493] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3009.967499] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3009.967507] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 3009.967515] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 3009.967523] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 3009.967531] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 3009.967538] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3009.967544] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3009.967550] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3009.967556] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3009.967563] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3009.967569] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3009.967575] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3009.967581] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3009.967587] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3009.967593] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3009.967599] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3009.967605] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3009.967611] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3009.967618] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3009.967624] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3009.967630] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3009.967636] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3009.967643] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3009.967651] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3009.967659] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3009.967666] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3009.967674] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3009.967682] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3009.967689] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3009.967697] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3009.967705] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3009.967712] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3009.967874] hm2/hm2_5i25.0: registered
[ 3009.967880] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 3770.728538] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 3770.728552] hm2/hm2_5i25.0: unregistered
[ 3770.728654] hm2_pci: driver unloaded
[ 3778.892365] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3778.892441] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 3778.896213] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3778.896225] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3778.896234] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3778.896243] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3778.896252] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3778.896262] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3778.896271] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3778.896281] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3778.896290] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3778.896299] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3778.896309] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3778.896318] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3778.896327] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3778.896337] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3778.896346] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3778.896356] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3778.896365] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3778.896374] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3778.896383] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3778.896391] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3778.896400] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3778.896409] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3778.896418] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3778.896427] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3778.896436] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3778.896448] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3778.896460] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3778.896471] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3778.896482] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3778.896494] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3778.896505] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3778.896517] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3778.896529] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3778.896541] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3778.896552] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3778.896690] hm2/hm2_5i25.0: registered
[ 3778.896697] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 3800.373860] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 3800.373875] hm2/hm2_5i25.0: unregistered
[ 3800.373976] hm2_pci: driver unloaded
[ 3807.207123] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3807.207210] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 3807.208996] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3807.266369] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3807.266379] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3807.266386] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3807.266392] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3807.266398] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3807.266404] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3807.266410] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3807.266416] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3807.266422] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3807.266428] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3807.266434] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3807.266441] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3807.266447] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3807.266453] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3807.266459] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3807.266465] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3807.266471] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3807.266477] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3807.266483] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3807.266490] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3807.266496] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3807.266502] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3807.266508] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3807.266514] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3807.266520] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3807.266528] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3807.266536] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3807.266544] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3807.266551] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3807.266559] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3807.266567] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3807.266574] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3807.266582] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3807.266590] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3807.266597] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3807.266723] hm2/hm2_5i25.0: registered
[ 3807.266729] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 3821.225766] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 3821.225780] hm2/hm2_5i25.0: unregistered
[ 3821.225882] hm2_pci: driver unloaded
[ 3827.266566] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3827.266642] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 3827.267889] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3827.324070] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 3827.325880] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 3827.327413] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 3827.330125] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 3827.333569] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 3827.395090] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 3827.396493] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 3827.460850] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3827.460859] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3827.460865] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3827.460872] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3827.460880] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 3827.460888] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 3827.460896] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 3827.460904] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 3827.460911] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 3827.460917] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 3827.460923] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 3827.460929] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 3827.460935] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3827.460941] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3827.460948] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3827.460954] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3827.460960] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3827.460966] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3827.460972] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3827.460978] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3827.460984] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3827.460990] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3827.460997] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3827.461003] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3827.461009] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3827.461016] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3827.461024] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3827.461032] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3827.461039] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3827.461047] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3827.461055] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3827.461062] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3827.461070] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 3827.461078] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 3827.461085] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 3827.461248] hm2/hm2_5i25.0: registered
[ 3827.461254] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4153.335002] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4153.335016] hm2/hm2_5i25.0: unregistered
[ 4153.335120] hm2_pci: driver unloaded
[ 4155.837522] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4155.837584] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4155.839135] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4155.896788] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4155.896798] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4155.896805] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4155.896811] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4155.896817] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 4155.896823] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 4155.896829] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 4155.896835] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 4155.896841] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4155.896847] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4155.896854] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4155.896860] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4155.896866] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4155.896872] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4155.896878] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4155.896884] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4155.896890] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4155.896896] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4155.896903] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4155.896909] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4155.896915] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4155.896921] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4155.896927] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4155.896933] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4155.896939] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4155.896947] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4155.896955] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4155.896963] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4155.896970] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4155.896978] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4155.896986] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4155.896993] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4155.897001] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4155.897009] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4155.897016] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4155.897149] hm2/hm2_5i25.0: registered
[ 4155.897155] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4177.671449] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4177.671463] hm2/hm2_5i25.0: unregistered
[ 4177.671560] hm2_pci: driver unloaded
[ 4187.356955] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4187.357031] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4187.361318] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4187.361328] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4187.361334] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4187.361341] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4187.361347] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 4187.361353] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 4187.361359] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 4187.361365] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 4187.361371] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4187.361377] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4187.361383] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4187.361389] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4187.361395] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4187.361401] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4187.361408] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4187.361414] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4187.361420] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4187.361426] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4187.361432] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4187.361438] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4187.361444] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4187.361450] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4187.361456] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4187.361463] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4187.361469] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4187.361477] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4187.361485] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4187.361492] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4187.361500] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4187.361507] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4187.361515] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4187.361523] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4187.361531] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4187.361538] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4187.361546] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4187.361678] hm2/hm2_5i25.0: registered
[ 4187.361684] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4208.963022] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4208.963036] hm2/hm2_5i25.0: unregistered
[ 4208.963136] hm2_pci: driver unloaded
[ 4213.917603] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4213.917678] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4213.919188] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4213.975340] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 4213.977145] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 4213.978679] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 4213.981393] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 4213.984839] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 4214.046398] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 4214.047789] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 4214.112388] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4214.112396] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4214.112403] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4214.112409] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4214.112417] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 4214.112425] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 4214.112433] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 4214.112441] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 4214.112448] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4214.112454] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4214.112460] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4214.112466] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4214.112472] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4214.112479] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4214.112485] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4214.112491] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4214.112497] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4214.112503] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4214.112509] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4214.112515] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4214.112521] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4214.112528] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4214.112534] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4214.112540] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4214.112546] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4214.112553] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4214.112561] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4214.112569] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4214.112576] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4214.112584] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4214.112592] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4214.112599] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4214.112607] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4214.112615] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4214.112622] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4214.112792] hm2/hm2_5i25.0: registered
[ 4214.112798] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4215.755857] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4215.755871] hm2/hm2_5i25.0: unregistered
[ 4215.755972] hm2_pci: driver unloaded
[ 4219.157351] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4219.157417] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4219.158827] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4219.215059] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 4219.216868] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 4219.218402] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 4219.221114] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 4219.224558] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 4219.286121] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 4219.287511] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 4219.352098] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4219.352108] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4219.352115] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4219.352121] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4219.352130] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 4219.352138] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 4219.352146] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 4219.352154] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 4219.352161] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4219.352167] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4219.352173] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4219.352179] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4219.352185] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4219.352191] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4219.352197] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4219.352204] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4219.352210] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4219.352216] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4219.352222] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4219.352228] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4219.352234] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4219.352240] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4219.352246] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4219.352253] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4219.352259] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4219.352266] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4219.352274] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4219.352282] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4219.352289] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4219.352297] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4219.352305] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4219.352312] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4219.352320] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4219.352328] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4219.352335] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4219.352504] hm2/hm2_5i25.0: registered
[ 4219.352510] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4255.445725] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4255.445739] hm2/hm2_5i25.0: unregistered
[ 4255.445844] hm2_pci: driver unloaded
[ 4255.454611] hm2: unloading
[ 4255.584654] RTAI[math]: unloaded.
[ 4255.589157] SCHED releases registered named ALIEN PEDV$D
[ 4255.599594] RTAI[malloc]: unloaded.
[ 4255.684100] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4273.810751] halcmd[6678]: segfault at 8 ip b7730899 sp bf91fb50 error 6 in liblinuxcnchal.so.0[b772c000+9000]
[ 4273.815894] halcmd[6679]: segfault at 8 ip b76d2899 sp bfda9950 error 6 in liblinuxcnchal.so.0[b76ce000+9000]
[ 4273.868621] I-pipe: head domain RTAI unregistered.
[ 4273.868857] RTAI[hal]: unmounted.
[ 4277.169906] I-pipe: head domain RTAI registered.
[ 4277.169921] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4277.170087] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4277.170099] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4277.170107] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4277.170117] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12345250
[ 4277.184333] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4277.184427] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4277.184439] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4277.184448] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4277.184454] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4277.207242] RTAI[math]: loaded.
[ 4280.036639] RTAI[math]: unloaded.
[ 4280.041041] SCHED releases registered named ALIEN PEDV$D
[ 4280.049141] RTAI[malloc]: unloaded.
[ 4280.148051] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4280.152442] I-pipe: head domain RTAI unregistered.
[ 4280.152635] RTAI[hal]: unmounted.
[ 4281.414523] halcmd[6763]: segfault at 8 ip b76c4899 sp bf931090 error 6 in liblinuxcnchal.so.0[b76c0000+9000]
[ 4281.419789] halcmd[6764]: segfault at 8 ip b7707899 sp bfb7aa70 error 6 in liblinuxcnchal.so.0[b7703000+9000]
[ 4285.242088] I-pipe: head domain RTAI registered.
[ 4285.242104] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4285.242266] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4285.242275] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4285.242283] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4285.242291] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12353000
[ 4285.256465] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4285.256559] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4285.256572] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4285.256581] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4285.256587] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4285.269372] RTAI[math]: loaded.
[ 4285.465751] hm2: loading Mesa HostMot2 driver version 0.15
[ 4285.470135] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4285.470227] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4285.472271] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4285.529408] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 4285.532139] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 4285.534510] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 4285.538672] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 4285.543979] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 4285.639045] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 4285.641620] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 4285.743247] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4285.743256] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4285.743262] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4285.743269] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4285.743277] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 4285.743285] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 4285.743293] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 4285.743301] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 4285.743308] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4285.743314] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4285.743320] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4285.743326] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4285.743332] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4285.743338] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4285.743345] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4285.743351] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4285.743357] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4285.743363] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4285.743369] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4285.743375] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4285.743382] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4285.743388] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4285.743394] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4285.743400] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4285.743406] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4285.743414] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4285.743422] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4285.743429] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4285.743437] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4285.743445] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4285.743453] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4285.743460] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4285.743468] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4285.743476] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4285.743483] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4285.743646] hm2/hm2_5i25.0: registered
[ 4285.743652] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4285.755992] creating ladder-state
[ 4325.248457] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4325.248476] hm2/hm2_5i25.0: unregistered
[ 4325.248677] hm2_pci: driver unloaded
[ 4325.258511] hm2: unloading
[ 4327.533554] RTAI[math]: unloaded.
[ 4327.538081] SCHED releases registered named ALIEN PEDV$D
[ 4327.548618] RTAI[malloc]: unloaded.
[ 4327.648047] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4327.652414] I-pipe: head domain RTAI unregistered.
[ 4327.652598] RTAI[hal]: unmounted.
[ 4369.602284] I-pipe: head domain RTAI registered.
[ 4369.602303] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4369.602476] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4369.602489] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4369.602501] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4369.602512] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12353000
[ 4369.616663] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4369.616759] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4369.616772] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4369.616780] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4369.616786] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4369.636733] RTAI[math]: loaded.
[ 4369.736343] hm2: loading Mesa HostMot2 driver version 0.15
[ 4369.740787] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4369.740864] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4369.740968] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=000xx"
[ 4369.740985] hm2_5i25.0: board fails HM2 registration
[ 4369.741033] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4370.314000] hm2: unloading
[ 4370.469301] RTAI[math]: unloaded.
[ 4370.473910] SCHED releases registered named ALIEN PEDV$D
[ 4370.479987] RTAI[malloc]: unloaded.
[ 4370.580046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4370.584193] I-pipe: head domain RTAI unregistered.
[ 4370.584486] RTAI[hal]: unmounted.
[ 4383.170895] I-pipe: head domain RTAI registered.
[ 4383.170910] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4383.171067] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4383.171079] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4383.171086] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4383.171095] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12389500
[ 4383.184752] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4383.184847] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4383.184860] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4383.184869] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4383.184875] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4383.198537] RTAI[math]: loaded.
[ 4383.400120] hm2: loading Mesa HostMot2 driver version 0.15
[ 4383.404292] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4383.404371] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4383.404841] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=000xxx"
[ 4383.404859] hm2_5i25.0: board fails HM2 registration
[ 4383.404917] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4383.965202] hm2: unloading
[ 4384.118988] RTAI[math]: unloaded.
[ 4384.123343] SCHED releases registered named ALIEN PEDV$D
[ 4384.134061] RTAI[malloc]: unloaded.
[ 4384.232050] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4384.236199] I-pipe: head domain RTAI unregistered.
[ 4384.236470] RTAI[hal]: unmounted.
[ 4407.604447] I-pipe: head domain RTAI registered.
[ 4407.604466] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4407.604665] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4407.604677] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4407.604684] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4407.604694] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12407000
[ 4407.618593] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4407.618683] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4407.618695] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4407.618704] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4407.618710] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4407.634676] RTAI[math]: loaded.
[ 4407.832986] hm2: loading Mesa HostMot2 driver version 0.15
[ 4407.837310] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4407.837404] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4407.839348] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4407.896429] Board hm2_5i25.0.7i77.0.3 Hardware Mode 0 = standard
[ 4407.899266] Board hm2_5i25.0.7i77.0.3 Software Mode 0 = input_output
[ 4407.901637] Board hm2_5i25.0.7i77.0.3 Software Mode 1 = io_analog
[ 4407.905799] Board hm2_5i25.0.7i77.0.3 Software Mode 2 = io_analog_fieldvoltage
[ 4407.911204] Board hm2_5i25.0.7i77.0.3 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 4408.006135] Board hm2_5i25.0.7i77.0.4 Hardware Mode 0 = standard
[ 4408.008710] Board hm2_5i25.0.7i77.0.4 Software Mode 0 = analogout_enables
[ 4408.110334] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4408.110342] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4408.110349] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4408.110355] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4408.110363] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData4 (Output)
[ 4408.110371] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData4 (Input)
[ 4408.110379] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData3 (Output)
[ 4408.110387] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData3 (Input)
[ 4408.110394] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 4408.110400] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 4408.110406] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 4408.110413] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 4408.110419] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4408.110425] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4408.110431] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4408.110437] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4408.110443] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4408.110450] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4408.110456] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4408.110462] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4408.110468] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4408.110474] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4408.110480] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4408.110487] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4408.110493] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4408.110500] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4408.110508] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4408.110516] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4408.110523] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4408.110531] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 4408.110539] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 4408.110547] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 4408.110554] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 4408.110562] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 4408.110570] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 4408.110732] hm2/hm2_5i25.0: registered
[ 4408.110738] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 4408.122866] creating ladder-state
[ 4449.788050] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 4449.788070] hm2/hm2_5i25.0: unregistered
[ 4449.788194] hm2_pci: driver unloaded
[ 4449.792293] hm2: unloading
[ 4452.045782] RTAI[math]: unloaded.
[ 4452.050168] SCHED releases registered named ALIEN PEDV$D
[ 4452.059189] RTAI[malloc]: unloaded.
[ 4452.156058] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4452.160538] I-pipe: head domain RTAI unregistered.
[ 4452.160721] RTAI[hal]: unmounted.
[ 4469.289493] I-pipe: head domain RTAI registered.
[ 4469.289508] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4469.289672] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4469.289683] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4469.289692] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4469.289703] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12350000
[ 4469.303467] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4469.303556] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4469.303568] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4469.303577] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4469.303583] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4469.320357] RTAI[math]: loaded.
[ 4469.521056] hm2: loading Mesa HostMot2 driver version 0.15
[ 4469.525385] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4469.525475] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4469.525575] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=0123xx"
[ 4469.525591] hm2_5i25.0: board fails HM2 registration
[ 4469.525628] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4470.084513] hm2: unloading
[ 4470.238125] RTAI[math]: unloaded.
[ 4470.242429] SCHED releases registered named ALIEN PEDV$D
[ 4470.251835] RTAI[malloc]: unloaded.
[ 4470.348053] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4470.352336] I-pipe: head domain RTAI unregistered.
[ 4470.352515] RTAI[hal]: unmounted.
[ 4486.890642] I-pipe: head domain RTAI registered.
[ 4486.890660] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4486.890834] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4486.890847] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4486.890857] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4486.890868] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12362500
[ 4486.904764] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4486.904871] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4486.904884] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4486.904893] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4486.904899] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4486.922935] RTAI[math]: loaded.
[ 4487.122831] hm2: loading Mesa HostMot2 driver version 0.15
[ 4487.127220] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4487.127284] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4487.127368] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=xx"
[ 4487.127383] hm2_5i25.0: board fails HM2 registration
[ 4487.127427] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4487.694639] hm2: unloading
[ 4487.849537] RTAI[math]: unloaded.
[ 4487.853777] SCHED releases registered named ALIEN PEDV$D
[ 4487.863768] RTAI[malloc]: unloaded.
[ 4487.960041] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4487.964341] I-pipe: head domain RTAI unregistered.
[ 4487.964561] RTAI[hal]: unmounted.
[ 4522.325566] I-pipe: head domain RTAI registered.
[ 4522.325580] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4522.325740] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4522.325751] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4522.325761] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4522.325772] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12383000
[ 4522.342380] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4522.342467] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4522.342479] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4522.342488] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4522.342494] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4522.356849] RTAI[math]: loaded.
[ 4522.554713] hm2: loading Mesa HostMot2 driver version 0.15
[ 4522.559074] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4522.559138] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4522.559225] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=xxxxxx"
[ 4522.559240] hm2_5i25.0: board fails HM2 registration
[ 4522.559285] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4523.106953] hm2: unloading
[ 4523.261008] RTAI[math]: unloaded.
[ 4523.265434] SCHED releases registered named ALIEN PEDV$D
[ 4523.273718] RTAI[malloc]: unloaded.
[ 4523.372055] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4523.376304] I-pipe: head domain RTAI unregistered.
[ 4523.376504] RTAI[hal]: unmounted.
[ 4631.206084] I-pipe: head domain RTAI registered.
[ 4631.206099] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4631.206270] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4631.206280] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 12498768, CLK_FREQ 1799890000, CPU_FREQ 1799890000
[ 4631.206292] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4631.206304] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12498768, 12498768, 12371750
[ 4631.224732] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4631.224829] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4631.224841] RTAI[sched]: hard timer type/freq = APIC/12498768(Hz); default timing: oneshot; linear timed lists.
[ 4631.224850] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799890000 hz.
[ 4631.224856] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4631.243193] RTAI[math]: loaded.
[ 4631.458205] hm2: loading Mesa HostMot2 driver version 0.15
[ 4631.462740] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4631.462826] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 4631.463303] hm2/hm2_5i25.0: invalid token in config string: "serial_port_0=xxxxxx"
[ 4631.463321] hm2_5i25.0: board fails HM2 registration
[ 4631.463379] hm2_pci: probe of 0000:02:00.0 failed with error -22
[ 4632.127783] hm2: unloading
[ 4632.281660] spurious APIC interrupt on CPU#3, should never happen.
[ 4632.290621] RTAI[math]: unloaded.
[ 4632.295237] SCHED releases registered named ALIEN PEDV$D
[ 4632.302645] RTAI[malloc]: unloaded.
[ 4632.400082] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4632.404549] I-pipe: head domain RTAI unregistered.
[ 4632.404721] RTAI[hal]: unmounted.
