[ 0.000000] BIOS-e820: 000000000be00000 - 0000000010000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] DMI present.
[ 0.000000] last_pfn = 0xbdf0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 00BE00000 mask FFFE00000 uncachable
[ 0.000000] 2 base 00C000000 mask FFC000000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009f400 (usable)
[ 0.000000] modified: 000000000009f400 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000dc000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000000bdf0000 (usable)
[ 0.000000] modified: 000000000bdf0000 - 000000000bdfa000 (ACPI data)
[ 0.000000] modified: 000000000bdfa000 - 000000000be00000 (ACPI NVS)
[ 0.000000] modified: 000000000be00000 - 0000000010000000 (reserved)
[ 0.000000] modified: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000000bdf0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 000bc00000 page 2M
[ 0.000000] 000bc00000 - 000bdf0000 page 4k
[ 0.000000] kernel direct mapping tables up to bdf0000 @ 7000-c000
[ 0.000000] RAMDISK: 0822b000 - 08eb351f
[ 0.000000] ACPI: RSDP 000f8150 00014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 0bdf6482 00030 (v01 PTLTD RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 0bdf9f3c 00074 (v01 SiS 661MX 06040000 PTL 00000001)
[ 0.000000] ACPI: DSDT 0bdf66ad 0388F (v01 PTLTD 661MX 06040000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 0bdfafc0 00040
[ 0.000000] ACPI: APIC 0bdf9fb0 00050 (v01 PTLTD ? APIC 06040000 LTP 00000000)
[ 0.000000] ACPI: SSDT 0bdf64b2 001FB (v01 PmRef CpuPm 00003000 INTL 20030224)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 189MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 0bdf0000
[ 0.000000] low ram: 0 - 0bdf0000
[ 0.000000] node 0 low ram: 00000000 - 0bdf0000
[ 0.000000] node 0 bootmap 00008000 - 000097c0
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 000bdf0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000822b000 - 0008eb351f] RAMDISK ==> [000822b000 - 0008eb351f]
[ 0.000000] #5 [000009f400 - 0000100000] BIOS reserved ==> [000009f400 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4190] BRK ==> [00008b1000 - 00008b4190]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000a000] BOOTMAP ==> [0000008000 - 000000a000]
[ 0.000000] found SMP MP-table at [c00f8180] f8180
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0000bdf0
[ 0.000000] HighMem 0x0000bdf0 -> 0x0000bdf0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0000bdf0
[ 0.000000] On node 0 totalpages: 48523
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 348 pages used for memmap
[ 0.000000] Normal zone: 44180 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x8008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ11 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] Allocating PCI resources starting at 10000000 (gap: 10000000:eec00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48143
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=3ee30cf3-502f-454e-8555-ecf02f8aef83 ro quiet splash
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 972480 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 170388k/194496k available (4539k kernel code, 23544k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xcc5f0000 - 0xff7fe000 ( 818 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xcbdf0000 ( 189 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1500.051 MHz processor.
[ 0.004007] Calibrating delay loop (skipped), value calculated using timer frequency.. 3000.10 BogoMIPS (lpj=6000204)
[ 0.004033] Security Framework initialized
[ 0.004069] AppArmor: AppArmor initialized
[ 0.004080] Mount-cache hash table entries: 512
[ 0.004265] Initializing cgroup subsys ns
[ 0.004272] Initializing cgroup subsys cpuacct
[ 0.004278] Initializing cgroup subsys memory
[ 0.004293] Initializing cgroup subsys devices
[ 0.004297] Initializing cgroup subsys freezer
[ 0.004301] Initializing cgroup subsys net_cls
[ 0.004331] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.004336] CPU: L2 cache: 1024K
[ 0.004342] mce: CPU supports 5 MCE banks
[ 0.004354] CPU0: Thermal monitoring enabled (TM1)
[ 0.004368] Performance Events: p6 PMU driver.
[ 0.004402] ... version: 0
[ 0.004405] ... bit width: 32
[ 0.004408] ... generic registers: 2
[ 0.004411] ... value mask: 00000000ffffffff
[ 0.004414] ... max period: 000000007fffffff
[ 0.004418] ... fixed-purpose events: 0
[ 0.004420] ... event mask: 0000000000000003
[ 0.004427] Checking 'hlt' instruction... OK.
[ 0.021218] SMP alternatives: switching to UP code
[ 0.031123] Freeing SMP alternatives: 31k freed
[ 0.031139] ACPI: Core revision 20090903
[ 0.040037] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.040052] ftrace: allocating 21003 entries in 42 pages
[ 0.051757] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.052001] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.052001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.052001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.052001] ..... (found apic 0 pin 2) ...
[ 0.097834] ....... works.
[ 0.097837] CPU0: Intel(R) Celeron(R) M processor 1.50GHz stepping 08
[ 0.100001] Brought up 1 CPUs
[ 0.100001] Total of 1 processors activated (3000.10 BogoMIPS).
[ 0.100001] CPU0 attaching NULL sched-domain.
[ 0.100001] devtmpfs: initialized
[ 0.100001] regulator: core version 0.5
[ 0.100001] NET: Registered protocol family 16
[ 0.100001] EISA bus registered
[ 0.100001] ACPI: bus type pci registered
[ 0.100001] PCI: PCI BIOS revision 2.10 entry at 0xfd786, last bus=1
[ 0.100001] PCI: Using configuration type 1 for base access
[ 0.100001] bio: create slab <bio-0> at 0
[ 0.100426] ACPI: EC: Look up EC in DSDT
[ 0.120083] ACPI: Interpreter enabled
[ 0.120088] ACPI: (supports S0 S5)
[ 0.120101] ACPI: Using IOAPIC for interrupt routing
[ 0.123390] ACPI: EC: GPE = 0x19, I/O: command/status = 0x66, data = 0x62
[ 0.123562] ACPI: No dock devices found.
[ 0.124877] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.124937] pci 0000:00:00.0: reg 10 32bit mmio: [0xe0000000-0xe1ffffff]
[ 0.125096] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.125147] pci 0000:00:02.1: reg 20 io port: [0x8100-0x811f]
[ 0.125192] pci 0000:00:02.5: reg 10 io port: [0x1f0-0x1f7]
[ 0.125200] pci 0000:00:02.5: reg 14 io port: [0x3f4-0x3f7]
[ 0.125209] pci 0000:00:02.5: reg 18 io port: [0x170-0x177]
[ 0.125217] pci 0000:00:02.5: reg 1c io port: [0x374-0x377]
[ 0.125226] pci 0000:00:02.5: reg 20 io port: [0x1000-0x100f]
[ 0.125279] pci 0000:00:02.6: reg 10 io port: [0x1400-0x14ff]
[ 0.125288] pci 0000:00:02.6: reg 14 io port: [0x1080-0x10ff]
[ 0.125337] pci 0000:00:02.6: supports D1 D2
[ 0.125340] pci 0000:00:02.6: PME# supported from D3hot D3cold
[ 0.125346] pci 0000:00:02.6: PME# disabled
[ 0.125385] pci 0000:00:02.7: reg 10 io port: [0x1c00-0x1cff]
[ 0.125394] pci 0000:00:02.7: reg 14 io port: [0x1800-0x187f]
[ 0.125442] pci 0000:00:02.7: supports D1 D2
[ 0.125445] pci 0000:00:02.7: PME# supported from D3hot D3cold
[ 0.125451] pci 0000:00:02.7: PME# disabled
[ 0.125480] pci 0000:00:03.0: reg 10 32bit mmio: [0xe2000000-0xe2000fff]
[ 0.125539] pci 0000:00:03.1: reg 10 32bit mmio: [0xe2001000-0xe2001fff]
[ 0.125611] pci 0000:00:03.3: reg 10 32bit mmio: [0xe2002000-0xe2002fff]
[ 0.125663] pci 0000:00:03.3: PME# supported from D0 D3hot D3cold
[ 0.125668] pci 0000:00:03.3: PME# disabled
[ 0.125713] pci 0000:00:04.0: reg 10 io port: [0x2000-0x20ff]
[ 0.125722] pci 0000:00:04.0: reg 14 32bit mmio: [0xe2003000-0xe2003fff]
[ 0.125752] pci 0000:00:04.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.125774] pci 0000:00:04.0: supports D1 D2
[ 0.125778] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.125783] pci 0000:00:04.0: PME# disabled
[ 0.125825] pci 0000:00:06.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.125847] pci 0000:00:06.0: supports D1 D2
[ 0.125850] pci 0000:00:06.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.125856] pci 0000:00:06.0: PME# disabled
[ 0.125938] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.125946] pci 0000:01:00.0: reg 14 32bit mmio: [0xe2100000-0xe211ffff]
[ 0.125953] pci 0000:01:00.0: reg 18 io port: [0x9000-0x907f]
[ 0.125989] pci 0000:01:00.0: supports D1 D2
[ 0.126032] pci 0000:00:01.0: bridge io port: [0x9000-0x9fff]
[ 0.126038] pci 0000:00:01.0: bridge 32bit mmio: [0xe2100000-0xe21fffff]
[ 0.126044] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.126073] pci_bus 0000:00: on NUMA node 0
[ 0.126078] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.133895] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 *7 9 10 11)
[ 0.134030] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11) *0, disabled.
[ 0.134160] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 11) *0, disabled.
[ 0.134296] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 11) *0, disabled.
[ 0.134458] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 *9 10 11)
[ 0.134589] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 *11)
[ 0.134717] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11) *0, disabled.
[ 0.134846] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 *10 11)
[ 0.135017] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.135021] vgaarb: loaded
[ 0.135204] SCSI subsystem initialized
[ 0.135287] libata version 3.00 loaded.
[ 0.135383] usbcore: registered new interface driver usbfs
[ 0.135405] usbcore: registered new interface driver hub
[ 0.135440] usbcore: registered new device driver usb
[ 0.135610] ACPI: WMI: Mapper loaded
[ 0.135613] PCI: Using ACPI for IRQ routing
[ 0.135791] NetLabel: Initializing
[ 0.135794] NetLabel: domain hash size = 128
[ 0.135796] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.135816] NetLabel: unlabeled traffic allowed by default
[ 0.135863] Switching to clocksource tsc
[ 0.136000] AppArmor: AppArmor Filesystem Enabled
[ 0.136000] pnp: PnP ACPI init
[ 0.136000] ACPI: bus type pnp registered
[ 0.136961] pnp: PnP ACPI: found 9 devices
[ 0.136964] ACPI: ACPI bus type pnp unregistered
[ 0.136970] PnPBIOS: Disabled by ACPI PNP
[ 0.136989] system 00:04: ioport range 0x8000-0x807f has been reserved
[ 0.136994] system 00:04: ioport range 0x8080-0x80ff has been reserved
[ 0.136998] system 00:04: ioport range 0x8100-0x811f has been reserved
[ 0.137002] system 00:04: ioport range 0x4d0-0x4d1 has been reserved
[ 0.137006] system 00:04: ioport range 0xfe00-0xfe00 has been reserved
[ 0.137011] system 00:04: ioport range 0x3f0-0x3f1 has been reserved
[ 0.137017] system 00:04: iomem range 0xfec00000-0xfecfffff could not be reserved
[ 0.137022] system 00:04: iomem range 0xfee00000-0xfeefffff could not be reserved
[ 0.137026] system 00:04: iomem range 0xffc00000-0xffc00fff has been reserved
[ 0.137031] system 00:04: iomem range 0xffe00000-0xffe00fff has been reserved
[ 0.137035] system 00:04: iomem range 0xffe80000-0xffefffff has been reserved
[ 0.137039] system 00:04: iomem range 0xd0000-0xd7fff has been reserved
[ 0.171809] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.171815] pci 0000:00:01.0: IO window: 0x9000-0x9fff
[ 0.171822] pci 0000:00:01.0: MEM window: 0xe2100000-0xe21fffff
[ 0.171828] pci 0000:00:01.0: PREFETCH window: 0xe8000000-0xefffffff
[ 0.171837] pci 0000:00:06.0: CardBus bridge, secondary bus 0000:02
[ 0.171841] pci 0000:00:06.0: IO window: 0x002400-0x0024ff
[ 0.171847] pci 0000:00:06.0: IO window: 0x002800-0x0028ff
[ 0.171853] pci 0000:00:06.0: PREFETCH window: 0x10000000-0x13ffffff
[ 0.171859] pci 0000:00:06.0: MEM window: 0x14000000-0x17ffffff
[ 0.171883] pci 0000:00:06.0: enabling device (0000 -> 0003)
[ 0.171890] alloc irq_desc for 19 on node -1
[ 0.171894] alloc kstat_irqs on node -1
[ 0.171902] pci 0000:00:06.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 0.171912] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.171916] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.171920] pci_bus 0000:01: resource 0 io: [0x9000-0x9fff]
[ 0.171924] pci_bus 0000:01: resource 1 mem: [0xe2100000-0xe21fffff]
[ 0.171928] pci_bus 0000:01: resource 2 pref mem [0xe8000000-0xefffffff]
[ 0.171932] pci_bus 0000:02: resource 0 io: [0x2400-0x24ff]
[ 0.171936] pci_bus 0000:02: resource 1 io: [0x2800-0x28ff]
[ 0.171940] pci_bus 0000:02: resource 2 pref mem [0x10000000-0x13ffffff]
[ 0.171944] pci_bus 0000:02: resource 3 mem: [0x14000000-0x17ffffff]
[ 0.171997] NET: Registered protocol family 2
[ 0.172139] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.172487] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.172565] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.172646] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.172649] TCP reno registered
[ 0.172743] NET: Registered protocol family 1
[ 0.612125] pci 0000:01:00.0: Boot video device
[ 0.612338] Scanning for low memory corruption every 60 seconds
[ 0.612501] audit: initializing netlink socket (disabled)
[ 0.612524] type=2000 audit(1307790398.612:1): initialized
[ 0.624369] Trying to unpack rootfs image as initramfs...
[ 0.636394] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.642756] VFS: Disk quotas dquot_6.5.2
[ 0.642847] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.643674] fuse init (API version 7.13)
[ 0.643805] msgmni has been set to 333
[ 0.648426] alg: No test for stdrng (krng)
[ 0.648561] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.648565] io scheduler noop registered
[ 0.648568] io scheduler anticipatory registered
[ 0.648571] io scheduler deadline registered
[ 0.648629] io scheduler cfq registered (default)
[ 0.648779] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.648812] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.648947] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.650768] ACPI: Lid Switch [LID]
[ 0.650852] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.650856] ACPI: Power Button [PWRB]
[ 0.650920] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 0.650924] ACPI: Sleep Button [SLPB]
[ 0.650993] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 0.650997] ACPI: Power Button [PWRF]
[ 0.653057] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.653516] serial 0000:00:02.6: enabling device (0000 -> 0001)
[ 0.653528] alloc irq_desc for 18 on node -1
[ 0.653532] alloc kstat_irqs on node -1
[ 0.653542] serial 0000:00:02.6: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.653550] serial 0000:00:02.6: PCI INT C disabled
[ 0.656790] brd: module loaded
[ 0.657342] isapnp: Scanning for PnP cards...
[ 0.664254] loop: module loaded
[ 0.664406] input: Macintosh mouse button emulation as /devices/virtual/input/input4
[ 0.664601] pata_sis 0000:00:02.5: version 0.5.2
[ 0.664619] alloc irq_desc for 16 on node -1
[ 0.664622] alloc kstat_irqs on node -1
[ 0.664633] pata_sis 0000:00:02.5: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.668500] scsi0 : pata_sis
[ 0.668679] scsi1 : pata_sis
[ 0.668960] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0x1000 irq 14
[ 0.668964] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0x1008 irq 15
[ 0.669453] Fixed MDIO Bus: probed
[ 0.669508] PPP generic driver version 2.4.2
[ 0.669586] tun: Universal TUN/TAP device driver, 1.6
[ 0.669589] tun: (C) 1999-2004 Max Krasnyansky <
maxk@qualcomm.com>
[ 0.669723] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.669757] alloc irq_desc for 23 on node -1
[ 0.669760] alloc kstat_irqs on node -1
[ 0.669772] ehci_hcd 0000:00:03.3: PCI INT D -> GSI 23 (level, low) -> IRQ 23
[ 0.669796] ehci_hcd 0000:00:03.3: EHCI Host Controller
[ 0.669839] ehci_hcd 0000:00:03.3: new USB bus registered, assigned bus number 1
[ 0.669907] ehci_hcd 0000:00:03.3: irq 23, io mem 0xe2002000
[ 0.715691] ehci_hcd 0000:00:03.3: USB 2.0 started, EHCI 1.00
[ 0.715844] usb usb1: configuration #1 chosen from 1 choice
[ 0.715886] hub 1-0:1.0: USB hub found
[ 0.715900] hub 1-0:1.0: 6 ports detected
[ 0.715976] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.716002] alloc irq_desc for 20 on node -1
[ 0.716005] alloc kstat_irqs on node -1
[ 0.716012] ohci_hcd 0000:00:03.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 0.716026] ohci_hcd 0000:00:03.0: OHCI Host Controller
[ 0.716078] ohci_hcd 0000:00:03.0: new USB bus registered, assigned bus number 2
[ 0.716120] ohci_hcd 0000:00:03.0: irq 20, io mem 0xe2000000
[ 0.804047] usb usb2: configuration #1 chosen from 1 choice
[ 0.804096] hub 2-0:1.0: USB hub found
[ 0.804134] hub 2-0:1.0: 3 ports detected
[ 0.804221] alloc irq_desc for 21 on node -1
[ 0.804225] alloc kstat_irqs on node -1
[ 0.804237] ohci_hcd 0000:00:03.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21
[ 0.804264] ohci_hcd 0000:00:03.1: OHCI Host Controller
[ 0.804329] ohci_hcd 0000:00:03.1: new USB bus registered, assigned bus number 3
[ 0.804366] ohci_hcd 0000:00:03.1: irq 21, io mem 0xe2001000
[ 0.833056] ata1.00: ATA-6: HTS424040M9AT00, MA2OA71A, max UDMA/100
[ 0.833063] ata1.00: 78140160 sectors, multi 16: LBA48
[ 0.892013] ata1.00: configured for UDMA/100
[ 0.892279] usb usb3: configuration #1 chosen from 1 choice
[ 0.892324] hub 3-0:1.0: USB hub found
[ 0.892342] hub 3-0:1.0: 3 ports detected
[ 0.892423] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.892589] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.895394] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.895404] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.895603] mice: PS/2 mouse device common for all mice
[ 0.895873] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.895899] rtc0: alarms up to one year, y3k, 114 bytes nvram
[ 0.896062] device-mapper: uevent: version 1.0.3
[ 0.898829] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised:
dm-devel@redhat.com
[ 0.904384] device-mapper: multipath: version 1.1.0 loaded
[ 0.904391] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.904673] EISA: Probing bus 0 at eisa.0
[ 0.904684] Cannot allocate resource for EISA slot 1
[ 0.904688] Cannot allocate resource for EISA slot 2
[ 0.904710] Cannot allocate resource for EISA slot 8
[ 0.904713] EISA: Detected 0 cards.
[ 0.904717] cpuidle: using governor ladder
[ 0.904719] cpuidle: using governor menu
[ 0.905282] TCP cubic registered
[ 0.905515] NET: Registered protocol family 10
[ 0.906097] lo: Disabled Privacy Extensions
[ 0.906471] NET: Registered protocol family 17
[ 0.906524] Using IPI No-Shortcut mode
[ 0.906666] registered taskstats version 1
[ 0.906933] rtc_cmos 00:02: setting system clock to 2011-06-11 11:06:39 UTC (1307790399)
[ 0.906938] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.906941] EDD information not available.
[ 0.927206] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
[ 1.336009] isapnp: No Plug & Play device found
[ 1.336282] scsi 0:0:0:0: Direct-Access ATA HTS424040M9AT00 MA2O PQ: 0 ANSI: 5
[ 1.336546] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.336796] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.336869] sd 0:0:0:0: [sda] Write Protect is off
[ 1.336873] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.336910] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.337119] sda: sda1 sda2 < sda5 >
[ 1.397237] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.470436] Freeing initrd memory: 12833k freed
[ 1.494591] ata2.01: NODEV after polling detection
[ 1.500546] ata2.00: ATAPI: PHILIPS DVD+/-RW SDVD8441, P646, max UDMA/33
[ 1.516501] ata2.00: configured for UDMA/33
[ 1.520269] scsi 1:0:0:0: CD-ROM PHILIPS DVD+-RW SDVD8441 P646 PQ: 0 ANSI: 5
[ 1.522623] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 1.522628] Uniform CD-ROM driver Revision: 3.20
[ 1.522818] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.522918] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.522993] Freeing unused kernel memory: 620k freed
[ 1.523799] Write protecting the kernel text: 4540k
[ 1.523838] Write protecting the kernel read-only data: 1668k
[ 1.548949] udev: starting version 151
[ 1.798201] vga16fb: initializing
[ 1.798208] vga16fb: mapped to 0xc00a0000
[ 1.798305] fb0: VGA16 VGA frame buffer device
[ 1.803855] sis900.c: v1.08.10 Apr. 2 2006
[ 1.803907] sis900 0000:00:04.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.810439] Linux agpgart interface v0.103
[ 1.823893] 0000:00:04.0: Realtek RTL8201 PHY transceiver found at address 13.
[ 1.830090] 0000:00:04.0: Using transceiver found at address 13 as default
[ 1.859557] eth0: SiS 900 PCI Fast Ethernet at 0x2000, IRQ 19, 00:16:36:32:70:f7
[ 1.859595] agpgart-sis 0000:00:00.0: SiS chipset [1039/0661]
[ 1.862733] agpgart-sis 0000:00:00.0: AGP aperture is 32M @ 0xe0000000
[ 1.922675] Console: switching to colour frame buffer device 80x30
[ 2.482531] xor: automatically using best checksumming function: pIII_sse
[ 2.500006] pIII_sse : 4013.000 MB/sec
[ 2.500009] xor: using function: pIII_sse (4013.000 MB/sec)
[ 2.528507] device-mapper: dm-raid45: initialized v0.2594b
[ 2.754996] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 2.755005] EXT4-fs (sda1): write access will be enabled during recovery
[ 4.273971] EXT4-fs (sda1): recovery complete
[ 4.274608] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 11.157046] Adding 538616k swap on /dev/sda5. Priority:-1 extents:1 across:538616k
[ 12.350055] udev: starting version 151
[ 14.312225] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x8100
[ 14.511854] type=1505 audit(1307790413.103:2): operation="profile_load" pid=465 name="/sbin/dhclient3"
[ 14.512719] type=1505 audit(1307790413.105:3): operation="profile_load" pid=465 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 14.513194] type=1505 audit(1307790413.105:4): operation="profile_load" pid=465 name="/usr/lib/connman/scripts/dhclient-script"
[ 14.513862] type=1505 audit(1307790413.105:5): operation="profile_replace" pid=463 name="/sbin/dhclient3"
[ 14.514707] type=1505 audit(1307790413.105:6): operation="profile_replace" pid=463 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 14.515184] type=1505 audit(1307790413.105:7): operation="profile_replace" pid=463 name="/usr/lib/connman/scripts/dhclient-script"
[ 14.639202] acer-wmi: Acer Laptop ACPI-WMI Extras
[ 14.639226] acer-wmi: No or unsupported WMI interface, unable to load
[ 14.839607] lp: driver loaded but no devices found
[ 14.863309] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 14.871342] yenta_cardbus 0000:00:06.0: CardBus bridge found [1025:0082]
[ 14.871367] yenta_cardbus 0000:00:06.0: Using CSCINT to route CSC interrupts to PCI
[ 14.871371] yenta_cardbus 0000:00:06.0: Routing CardBus interrupts to PCI
[ 14.871378] yenta_cardbus 0000:00:06.0: TI: mfunc 0x00001002, devctl 0x44
[ 15.100778] yenta_cardbus 0000:00:06.0: ISA IRQ mask 0x06f8, PCI irq 19
[ 15.100785] yenta_cardbus 0000:00:06.0: Socket status: 30000006
[ 15.718488] Synaptics Touchpad, model: 1, fw: 6.2, id: 0x12a0b1, caps: 0xa04713/0x204000
[ 15.755664] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
[ 15.964140] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 15.965848] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x480-0x48f
[ 15.966548] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 15.967154] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 15.967944] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 16.743599] Intel ICH 0000:00:02.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 17.568036] intel8x0_measure_ac97_clock: measured 55443 usecs (2667 samples)
[ 17.568042] intel8x0: clocking to 48000
[ 17.753559] type=1505 audit(1307790416.345:8): operation="profile_load" pid=675 name="/usr/share/gdm/guest-session/Xsession"
[ 17.757682] type=1505 audit(1307790416.349:9): operation="profile_replace" pid=681 name="/sbin/dhclient3"
[ 17.761240] type=1505 audit(1307790416.353:10): operation="profile_replace" pid=681 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 17.761735] type=1505 audit(1307790416.353:11): operation="profile_replace" pid=681 name="/usr/lib/connman/scripts/dhclient-script"
[ 20.584983] eth0: Media Link On 100mbps full-duplex
[ 22.750521] ppdev: user-space parallel port driver
[ 28.924013] eth0: no IPv6 routers present
[ 48.105955] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 48.394805] ISOFS: changing to secondary root
[ 290.404028] pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
[ 290.404068] pci 0000:02:00.0: reg 10 io port: [0x00-0x07]
[ 290.404078] pci 0000:02:00.0: reg 14 io port: [0x00-0x07]
[ 290.404153] yenta_cardbus 0000:00:06.0: EnE: chaning testregister 0xC9, 06 -> 04
[ 290.404270] serial 0000:02:00.0: enabling device (0000 -> 0001)
[ 290.404282] serial 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 290.404462] 0000:02:00.0: ttyS0 at I/O 0x2400 (irq = 19) is a XScale
[ 1498.084115] pcmcia_socket pcmcia_socket0: pccard: card ejected from slot 0
[ 1498.120411] serial 0000:02:00.0: PCI INT A disabled
[ 5289.352032] pcmcia_socket pcmcia_socket0: pccard: CardBus card inserted into slot 0
[ 5289.352075] pci 0000:02:00.0: reg 10 io port: [0x00-0x07]
[ 5289.352086] pci 0000:02:00.0: reg 14 io port: [0x00-0x07]
[ 5289.352160] yenta_cardbus 0000:00:06.0: EnE: chaning testregister 0xC9, 04 -> 04
[ 5289.352269] serial 0000:02:00.0: enabling device (0000 -> 0001)
[ 5289.352281] serial 0000:02:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
aft@cnc:~$
