(для просмотра содержимого нажмите на ссылку)/********************************************************************
* Description: keystick.cc
* Curses-based keyboard control panel
* Derived from a work by Fred Proctor & Will Shackleford
* Author:
* License: GPL Version 2
* System: Linux
* Copyright (c) 2004 All rights reserved.
* Last change:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <ctype.h>
#include <signal.h>
#include <errno.h>
#include <sys/time.h> // struct itimerval
#include <sys/ioctl.h> // ioctl(), TIOCGWINSZ, struct winsize
#include <unistd.h> // STDIN_FILENO
#include "rcs.hh" // rcs_print_error(), esleep()
#include "emc.hh" // EMC NML
#include "emc_nml.hh"
#include "emcglb.h" // EMC_NMLFILE, TRAJ_MAX_VELOCITY
#include "emccfg.h" // DEFAULT_TRAJ_MAX_VELOCITY
#include "inifile.hh" // INIFILE
#include "rcs_print.hh"
#include "nml_oi.hh"
#include "timer.hh"
#include <ncurses.h>
#define ESC 27
#define TAB 9
#define RETURN 13
#define ALT(ch) ((ch) + 128)
#define CTL(ch) ((ch) - 64)
// paths to awk and xgraph, using to plot logs
// fill these in for your system, if these are not in user's path
#define AWK_PATH "awk"
#define XGRAPH_PATH "xgraph"
#define SYSTEM_STRING_LEN 1024
// the NML channels to the EMC task
static RCS_CMD_CHANNEL *emcCommandBuffer = 0;
static RCS_STAT_CHANNEL *emcStatusBuffer = 0;
EMC_STAT *emcStatus = 0;
// the NML channel for errors
static NML *emcErrorBuffer = 0;
static char error_string[NML_ERROR_LEN] = "";
// the current command numbers, set up updateStatus(), used in main()
static int emcCommandSerialNumber = 0;
// NML messages
static EMC_AXIS_HOME emc_axis_home_msg;
static EMC_AXIS_ABORT emc_axis_abort_msg;
static EMC_AXIS_JOG emc_axis_jog_msg;
static EMC_AXIS_INCR_JOG emc_axis_incr_jog_msg;
static EMC_TRAJ_SET_SCALE emc_traj_set_scale_msg;
static EMC_TRAJ_ABORT emc_traj_abort_msg;
static EMC_SPINDLE_ON emc_spindle_on_msg;
static EMC_SPINDLE_OFF emc_spindle_off_msg;
static EMC_SPINDLE_INCREASE emc_spindle_increase_msg;
static EMC_SPINDLE_DECREASE emc_spindle_decrease_msg;
static EMC_SPINDLE_CONSTANT emc_spindle_constant_msg;
static EMC_SPINDLE_BRAKE_RELEASE emc_spindle_brake_release_msg;
static EMC_SPINDLE_BRAKE_ENGAGE emc_spindle_brake_engage_msg;
static EMC_COOLANT_MIST_ON emc_coolant_mist_on_msg;
static EMC_COOLANT_MIST_OFF emc_coolant_mist_off_msg;
static EMC_COOLANT_FLOOD_ON emc_coolant_flood_on_msg;
static EMC_COOLANT_FLOOD_OFF emc_coolant_flood_off_msg;
static EMC_LUBE_ON emc_lube_on_msg;
static EMC_LUBE_OFF emc_lube_off_msg;
static EMC_TOOL_LOAD_TOOL_TABLE emc_tool_load_tool_table_msg;
static EMC_TASK_SET_MODE mode_msg;
static EMC_TASK_SET_STATE state_msg;
static EMC_TASK_ABORT task_abort_msg;
static EMC_TASK_PLAN_INIT task_plan_init_msg;
static EMC_TASK_PLAN_OPEN task_plan_open_msg;
static EMC_TASK_PLAN_RUN task_plan_run_msg;
static EMC_TASK_PLAN_EXECUTE task_plan_execute_msg;
static EMC_TASK_PLAN_PAUSE task_plan_pause_msg;
static EMC_TASK_PLAN_RESUME task_plan_resume_msg;
static EMC_TASK_PLAN_STEP task_plan_step_msg;
// critical section flag-- set to non-zero to prevent sig handler
// from interrupting your window printing
static unsigned char critFlag = 0;
// the program path prefix
static char programPrefix[LINELEN] = "";
// the saved program name
static char programFile[LINELEN] = "";
static int programOpened = 0;
static FILE * programFp = 0;
static int programFpLine = 0;
static int programActiveLine = 0;
static char programLineText[LINELEN] = "";
// error log file
static FILE *errorFp = NULL;
#define ERROR_FILE "keystick.err"
typedef enum {
JOG_CONTINUOUS = 1,
JOG_INCREMENTAL
} JOG_MODE;
static JOG_MODE jogMode
= JOG_CONTINUOUS;
static double jogIncrement = 0.001;
static double jogSpeed = 60.0;
static int xJogPol = 1;
static int yJogPol = 1;
static int zJogPol = 1;
static int aJogPol = 1;
typedef enum {
AXIS_NONE = 1,
AXIS_X,
AXIS_Y,
AXIS_Z,
AXIS_A,
} AXIS_TYPE;
static AXIS_TYPE axisSelected = AXIS_X;
static AXIS_TYPE axisJogging = AXIS_NONE;
static const char * axisString(AXIS_TYPE a)
switch (a)
case AXIS_X:
return " X SELECTED ";
case AXIS_Y:
return " Y SELECTED ";
case AXIS_Z:
return " Z SELECTED ";
case AXIS_A:
return " A SELECTED ";
default:
return " ? SELECTED ";
static int axisIndex(AXIS_TYPE a)
if (a == AXIS_X)
return 0;
if (a == AXIS_Y)
return 1;
if (a == AXIS_Z)
return 2;
if (a == AXIS_A)
return 3;
return 0;
typedef enum {
COORD_RELATIVE = 1,
COORD_ABSOLUTE
} COORD_TYPE;
static COORD_TYPE coords = COORD_RELATIVE;
typedef enum {
POS_DISPLAY_ACT = 1,
POS_DISPLAY_CMD
} POS_DISPLAY_TYPE;
static POS_DISPLAY_TYPE posDisplay = POS_DISPLAY_ACT;
static int spindleChanging = 0;
#define INTERRUPT_USECS 50000
static int usecs = INTERRUPT_USECS;
static chtype ch = 0, oldch = 0;
#define ASCLINELEN 80
static char line_blank[ASCLINELEN + 1];
static char scratch_string[ASCLINELEN] = "";
static char state_string[ASCLINELEN] = "";
static char mode_string[ASCLINELEN] = "";
static char spindle_string[ASCLINELEN] = "";
static char brake_string[ASCLINELEN] = "";
static char mist_string[ASCLINELEN] = "";
static char flood_string[ASCLINELEN] = "";
static char lube_on_string[ASCLINELEN] = "";
static char lube_level_string[ASCLINELEN] = "";
static char home_string[ASCLINELEN] = "";
static char pos_string[ASCLINELEN] = "";
static char origin_string[ASCLINELEN] = "";
static char speed_string[ASCLINELEN] = "";
static char incr_string[ASCLINELEN] = "";
static char prog_string[ASCLINELEN] = "";
static char line_string[ASCLINELEN] = "";
static char interp_string[ASCLINELEN] = "";
static char active_g_codes_string[ASCLINELEN] = "";
static char active_m_codes_string[ASCLINELEN] = "";
// bottom string gill be set to "---Machine Version---"
static char bottom_string[ASCLINELEN + 1] = "";
// key repeat delays, in microseconds
#define DEFAULT_FIRST_KEYUP_DELAY 300000 // works w/ 50000 alarm
static int FIRST_KEYUP_DELAY = DEFAULT_FIRST_KEYUP_DELAY;
#define DEFAULT_NEXT_KEYUP_DELAY 100000 // works w/ 50000 alarm
static int NEXT_KEYUP_DELAY = DEFAULT_NEXT_KEYUP_DELAY;
static int keyup_count = 0;
static enum {DIAG_USECS = 1, DIAG_FIRST_KEYUP_DELAY, DIAG_NEXT_KEYUP_DELAY} diagtab = DIAG_USECS;
static WINDOW * window = 0;
static WINDOW * helpwin = 0;
static WINDOW * diagwin = 0;
static WINDOW * toolwin = 0;
static WINDOW * logwin = 0;
static WINDOW * progwin = 0;
static int wbegy, wbegx;
static int wmaxy, wmaxx;
static void printFkeys()
{ wattrset(window, A_BOLD);
mvwaddstr(window, 0, 1, "F1 ");
mvwaddstr(window, 1, 1, "F2 ");
mvwaddstr(window, 2, 1, "F3 ");
mvwaddstr(window, 3, 1, "F4 ");
mvwaddstr(window, 0, 21, "F5 ");
mvwaddstr(window, 1, 21, "F6 ");
mvwaddstr(window, 2, 21, "F7 ");
mvwaddstr(window, 3, 21, "F8 ");
mvwaddstr(window, 0, 41, "F9 ");
mvwaddstr(window, 1, 41, "F10");
mvwaddstr(window, 2, 41, "F11");
mvwaddstr(window, 3, 41, "F12");
mvwaddstr(window, 0, 61, "ESC");
mvwaddstr(window, 1, 61, "TAB");
mvwaddstr(window, 2, 61, "END");
mvwaddstr(window, 3, 61, " ? ");
wattrset(window, 0);
mvwaddstr(window, 0, 5, "Estop On/Off ");
mvwaddstr(window, 1, 5, "Machine On/Off");
mvwaddstr(window, 2, 5, "Manual Mode ");
mvwaddstr(window, 3, 5, "Auto Mode ");
mvwaddstr(window, 0, 25, "MDI Mode ");
mvwaddstr(window, 1, 25, "Reset Interp ");
mvwaddstr(window, 2, 25, "Mist On/Off ");
mvwaddstr(window, 3, 25, "Flood On/Off ");
mvwaddstr(window, 0, 45, "Spndl Fwd/Off ");
mvwaddstr(window, 1, 45, "Spndl Rev/Off ");
mvwaddstr(window, 2, 45, "Spndl Decrease");
mvwaddstr(window, 3, 45, "Spndl Increase");
mvwaddstr(window, 0, 65, "Aborts Actions");
mvwaddstr(window, 1, 65, "Selects Params");
mvwaddstr(window, 2, 65, "Quits Display ");
mvwaddstr(window, 3, 65, "Toggles Help ");
#define ERR_Y ((wmaxy) - 2)
#define ERR_X (wbegx)
static void clearWindow()
int t;
critFlag = 1;
for (t = wbegy; t <= wmaxy; t++)
mvwaddstr(window, t, 0, line_blank);
wrefresh(window);
wmove(window, wmaxy, wbegx);
wrefresh(window);
critFlag = 0;
static void printError(const char * errstring)
int savey, savex;
chtype saveattr;
// log to error file
if (errorFp)
fprintf(errorFp, "%f\t%s\n", etime(), errstring);
if (0 == window)
// no window yet
return;
critFlag = 1;
getyx(window, savey, savex);
saveattr = getattrs(window);
mvwaddstr(window, ERR_Y, ERR_X, line_blank);
mvwaddstr(window, ERR_Y, ERR_X, errstring);
(void)wattrset(window, (int) saveattr);
wmove(window, savey, savex);
wrefresh(window);
critFlag = 0;
static void printStatus()
//Кое что надо пораскрашивать
int savey, savex;
int t;
int line;
int override;
int len;
int code;
if (window == helpwin)
printFkeys();
mvwaddstr(window, 5, 1, "x/X y/Y z/Z a/A");
mvwaddstr(window, 6, 1, "HOME");
mvwaddstr(window, 7, 1, "< > or , .");
mvwaddstr(window, 8, 1, "1-9, 0");
mvwaddstr(window, 9, 1, "<- arrow keys ->");
mvwaddstr(window, 10, 1, "^ arrow keys V");
mvwaddstr(window, 11, 1, "PageUp/PageDown");
mvwaddstr(window, 12, 1, " + / - ");
mvwaddstr(window, 13, 1, "c/C");
mvwaddstr(window, 14, 1, "i/I");
mvwaddstr(window, 15, 1, "#");
mvwaddstr(window, 16, 1, "@");
wattrset(window, A_UNDERLINE);
mvwaddstr(window, 5, 19, "selects axis");
mvwaddstr(window, 6, 19, "homes selected axis");
mvwaddstr(window, 7, 19, "change jog speed");
mvwaddstr(window, 8, 19, "10%-90%, 100% feed");
mvwaddstr(window, 9, 19, "jog X");
mvwaddstr(window, 10, 19, "jog Y");
mvwaddstr(window, 11, 19, "jog Z");
mvwaddstr(window, 12, 19, "jog A");
mvwaddstr(window, 13, 19, "sets continuous jog");
mvwaddstr(window, 14, 19, "toggles incr jog");
mvwaddstr(window, 15, 19, "toggles abs/rel");
mvwaddstr(window, 16, 19, "toggles cmd/act");
mvwaddstr(window, 5, 41, "B");
mvwaddstr(window, 6, 41, "b");
mvwaddstr(window, 7, 41, "o/O");
mvwaddstr(window, 8, 41, "r/R");
mvwaddstr(window, 9, 41, "p/P");
mvwaddstr(window, 10, 41, "s/S");
mvwaddstr(window, 11, 41, "quote/XYZAGM");
mvwaddstr(window, 12, 41, "l/L");
mvwaddstr(window, 13, 41, "u/U");
mvwaddstr(window, 5, 54, "turns spindle brake on");
mvwaddstr(window, 6, 54, "turns spindle brake off");
mvwaddstr(window, 7, 54, "prompts for program");
mvwaddstr(window, 8, 54, "runs selected program");
mvwaddstr(window, 9, 54, "pauses motion");
mvwaddstr(window, 10, 54, "starts motion again");
mvwaddstr(window, 11, 54, "prompts for MDI command");
mvwaddstr(window, 12, 54, "prompts for tool table");
mvwaddstr(window, 13, 54, "turns lube off/on");
if (error_string[0])
printError(error_string);
wattrset(window, A_REVERSE);
mvwaddstr(window, wmaxy - 1, wbegx, bottom_string);
// restore cursor position
wrefresh(window);
else if (window == diagwin)
mvwaddstr(window, 0, 34, "Diagnostics");
mvwaddstr(window, 2, 1, "Task Heartbeat/Cmd:");
mvwaddstr(window, 3, 1, "IO Heartbeat/Cmd:");
mvwaddstr(window, 4, 1, "Motion Heartbeat/Cmd:");
if (diagtab == DIAG_USECS)
mvwaddstr(window, 6, 1, "Polling Period (usecs):");
if (diagtab == DIAG_FIRST_KEYUP_DELAY)
mvwaddstr(window, 7, 1, "Kbd Delay Until Repeat:");
if (diagtab == DIAG_NEXT_KEYUP_DELAY)
mvwaddstr(window, 8, 1, "Kbd Delay Between Repeats:");
mvwaddstr(window, 10, 1, "Task Execution State:");
mvwaddstr(window, 12, 1, "Traj Scale:");
mvwaddstr(window, 13, 1, "X Scale:");
mvwaddstr(window, 14, 1, "Y Scale:");
mvwaddstr(window, 15, 1, "Z Scale:");
mvwaddstr(window, 15, 1, "A Scale:");
mvwaddstr(window, 17, 1, "V/Max V:");
mvwaddstr(window, 18, 1, "A/Max A:");
sprintf(scratch_string, "%10ld %10d %10d", emcStatus->task.heartbeat,
emcStatus->echo_serial_number,
emcStatus->status);
mvwaddstr(window, 2, 28, scratch_string);
sprintf(scratch_string, "%10ld %10d", emcStatus->io.heartbeat,
emcStatus->io.echo_serial_number);
mvwaddstr(window, 3, 28, scratch_string);
sprintf(scratch_string, "%10ld %10d", emcStatus->motion.heartbeat,
emcStatus->motion.echo_serial_number);
mvwaddstr(window, 4, 28, scratch_string);
sprintf(scratch_string, "%10d", usecs);
mvwaddstr(window, 6, 28, scratch_string);
sprintf(scratch_string, "%10d", FIRST_KEYUP_DELAY);
mvwaddstr(window, 7, 28, scratch_string);
sprintf(scratch_string, "%10d", NEXT_KEYUP_DELAY);
mvwaddstr(window, 8, 28, scratch_string);
sprintf(scratch_string, "%10d", emcStatus->task.execState);
mvwaddstr(window, 10, 28, scratch_string);
sprintf(scratch_string, "%10.3f", emcStatus->motion.traj.scale);
mvwaddstr(window, 12, 28, scratch_string);
sprintf(scratch_string, "%10.3f%10.3f",
emcStatus->motion.traj.velocity, emcStatus->motion.traj.maxVelocity);
mvwaddstr(window, 17, 28, scratch_string);
emcStatus->motion.traj.acceleration, emcStatus->motion.traj.maxAcceleration);
mvwaddstr(window, 18, 28, scratch_string);
wrefresh(window);
else if (window == toolwin)
mvwaddstr(window, 0, 34, "Tool Table");
mvwaddstr(window, 2, 1, "Pocket ToolNo Length Diameter");
line = 4;
for (t = 0; t < CANON_POCKETS_MAX; t++)
/* if (emcStatus->io.tool.toolTable[t].toolno)*/
if (emcStatus->io.tool.toolTable[t].toolno != -1) /* AIKE */
//sprintf(scratch_string, "%4d%10d%10.4f%10.4f",
sprintf(scratch_string, "%2d%8d%11.4f%10.4f%13d%12.4f%12.4f",
t,
emcStatus->io.tool.toolTable[t].toolno,
emcStatus->io.tool.toolTable[t].offset.tran.z,
emcStatus->io.tool.toolTable[t].diameter,
//add nev
emcStatus->io.tool.toolTable[t].orientation,
emcStatus->io.tool.toolTable[t].frontangle,
emcStatus->io.tool.toolTable[t].backangle);
//end nev
mvwaddstr(window, line++, 3, scratch_string);
wrefresh(window);
else if (window == progwin)
// start_color();
// init_pair(1, COLOR_YELLOW, COLOR_BLACK);
// init_pair(2, COLOR_WHITE, COLOR_GREEN);
// init_pair(3, COLOR_BLACK, COLOR_RED);
mvwaddstr(window, 0, 0, line_blank);
if (emcStatus->task.file[0] == 0)
mvwaddstr(window, 0, 36, "(no program)");
else
mvwaddstr(window, 0, 36, emcStatus->task.file);
if (emcStatus->task.currentLine > 0)
if (emcStatus->task.motionLine > 0 &&
emcStatus->task.motionLine < emcStatus->task.currentLine)
programActiveLine = emcStatus->task.motionLine;
else
programActiveLine = emcStatus->task.currentLine;
if (programFp)
if (programFpLine > programActiveLine)
rewind(programFp);
programFpLine = 0;
programLineText[0] = 0;
// fast forward over past lines
while (programFpLine < programActiveLine)
if (fgets(programLineText, LINELEN, programFp) != NULL)
programFpLine++;
// now we have the current line
for (t = 0; t < 20; t++)
// knock off CR, LF
len = strlen(programLineText) - 1;
while (len >= 0)
if (isspace(programLineText[len]))
programLineText[len] = 0;
len--;
else
break;
// print this line
mvwaddstr(window, t+2, wbegx, line_blank);
mvwaddstr(window, t+2, wbegx, programLineText);
// get the next line
if (fgets(programLineText, LINELEN, programFp))
programFpLine++;
else
// make it a blank line to clear any old stuff
strcpy(programLineText, line_blank);
else
else
line_string[0] = 0;
wrefresh(window);
else // if (window == stdscr)
// print the function key labels
printFkeys();
// print the status labels
mvwaddstr(window, 6, 1, "Override:");
mvwaddstr(window, 7, 1, "Tool:");
mvwaddstr(window, 8, 1, "Offset:");
mvwaddstr(window, 7, 61, "Speed:");
mvwaddstr(window, 8, 61, "Incr: ");
strcpy(scratch_string, "--X--");
if (emcStatus->motion.axis[0].minHardLimit)
scratch_string[0] = '*';
if (emcStatus->motion.axis[0].minSoftLimit)
scratch_string[1] = '*';
if (emcStatus->motion.axis[0].maxSoftLimit)
scratch_string[3] = '*';
if (emcStatus->motion.axis[0].maxHardLimit)
scratch_string[4] = '*';
mvwaddstr(window, 10, 23, scratch_string);
strcpy(scratch_string, "--Y--");
if (emcStatus->motion.axis[1].minHardLimit)
if (emcStatus->motion.axis[1].minSoftLimit)
if (emcStatus->motion.axis[1].maxSoftLimit)
if (emcStatus->motion.axis[1].maxHardLimit)
mvwaddstr(window, 10, 39, scratch_string);
strcpy(scratch_string, "--Z--");
if (emcStatus->motion.axis[2].minHardLimit)
if (emcStatus->motion.axis[2].minSoftLimit)
if (emcStatus->motion.axis[2].maxSoftLimit)
if (emcStatus->motion.axis[2].maxHardLimit)
mvwaddstr(window, 10, 55, scratch_string);
strcpy(scratch_string, "--A--");
if (emcStatus->motion.axis[3].minHardLimit)
if (emcStatus->motion.axis[3].minSoftLimit)
if (emcStatus->motion.axis[3].maxSoftLimit)
if (emcStatus->motion.axis[3].maxHardLimit)
mvwaddstr(window, 10, 70, scratch_string);
if (coords == COORD_ABSOLUTE)
if (posDisplay == POS_DISPLAY_CMD)
mvwaddstr(window, 11, 1, "Absolute Cmd Pos:");
else
mvwaddstr(window, 11, 1, "Absolute Act Pos:");
mvwaddstr(window, 12, 0, line_blank);
else
mvwaddstr(window, 11, 1, "Relative Cmd Pos:");
else
mvwaddstr(window, 11, 1, "Relative Act Pos:");
mvwaddstr(window, 14, 0, line_blank);
mvwaddstr(window, 15, 0, line_blank);
mvwaddstr(window, 16, 0, line_blank);
mvwaddstr(window, 17, 0, line_blank);
mvwaddstr(window, 18, 0, line_blank);
mvwaddstr(window, 19, 0, line_blank);
if (emcStatus->task.mode == EMC_TASK_MODE_AUTO)
mvwaddstr(window, 14, 1, "Program:");
mvwaddstr(window, 15, 1, "Line:");
mvwaddstr(window, 16, 1, "Command:");
mvwaddstr(window, 17, 1, "Interpreter:");
mvwaddstr(window, 18, 1, "Modal G Codes:");
mvwaddstr(window, 19, 1, "Modal M Codes:");
else if (emcStatus->task.mode == EMC_TASK_MODE_MDI)
// end of labels
// fill the status strings in
switch(emcStatus->task.state)
case EMC_TASK_STATE_OFF:
sprintf(state_string, " OFF ");
break;
case EMC_TASK_STATE_ON:
wattrset(window, COLOR_PAIR(2));
sprintf(state_string, " ON ");
break;
case EMC_TASK_STATE_ESTOP:
sprintf(state_string, " ESTOP ");
break;
//Сделать красным мигающим
case EMC_TASK_STATE_ESTOP_RESET:
sprintf(state_string, " ESTOP RESET ");
break;
default:
sprintf(state_string, " ? ");
break;
switch(emcStatus->task.mode)
case EMC_TASK_MODE_MANUAL:
sprintf(mode_string, " MANUAL ");
break;
case EMC_TASK_MODE_AUTO:
sprintf(mode_string, " AUTO ");
break;
case EMC_TASK_MODE_MDI:
sprintf(mode_string, " MDI ");
break;
default:
sprintf(mode_string, " ? ");
break;
if (emcStatus->motion.spindle.increasing > 0)
sprintf(spindle_string, " SPINDLE INCREASE ");
else if (emcStatus->motion.spindle.increasing < 0)
sprintf(spindle_string, " SPINDLE DECREASE ");
else if (emcStatus->motion.spindle.direction > 0)
sprintf(spindle_string, " SPINDLE FORWARD ");
else if (emcStatus->motion.spindle.direction < 0)
sprintf(spindle_string, " SPINDLE REVERSE ");
else
sprintf(spindle_string, " SPINDLE STOPPED ");
if (emcStatus->motion.spindle.brake)
sprintf(brake_string, " BRAKE ON ");
else
sprintf(brake_string, " BRAKE OFF ");
if (emcStatus->io.coolant.mist)
sprintf(mist_string, " MIST ON ");
else
sprintf(mist_string, " MIST OFF ");
if (emcStatus->io.coolant.flood)
sprintf(flood_string, " FLOOD ON ");
else
sprintf(flood_string, " FLOOD OFF ");
if (emcStatus->io.lube.on)
sprintf(lube_on_string, " LUBE ON ");
else
sprintf(lube_on_string, " LUBE OFF ");
if (! emcStatus->io.lube.level)
sprintf(lube_level_string, " LUBE OK ");
else
sprintf(lube_level_string, " LUBE LOW ");
sprintf(home_string, " ---- HOMED ");
if (emcStatus->motion.axis[0].homed)
home_string[4] = 'X';
if (emcStatus->motion.axis[1].homed)
home_string[5] = 'Y';
if (emcStatus->motion.axis[2].homed)
home_string[6] = 'Z';
if (emcStatus->motion.axis[3].homed)
home_string[7] = 'A';
/* if (emcStatus->motion.axis[2].homed)
home_string[6] = 'A';
} здесь надо основательно повозиться*/
if (posDisplay == POS_DISPLAY_ACT)
sprintf(pos_string, "%9.4f %14.4f %14.4f %14.4f",
emcStatus->motion.traj.actualPosition.tran.x,
emcStatus->motion.traj.actualPosition.tran.y,
emcStatus->motion.traj.actualPosition.tran.z,
emcStatus->motion.traj.actualPosition.a);
else
emcStatus->motion.traj.position.tran.x,
emcStatus->motion.traj.position.tran.y,
emcStatus->motion.traj.position.tran.z,
emcStatus->motion.traj.position.a);
else
emcStatus->motion.traj.actualPosition.tran.x - emcStatus->task.g5x_offset.tran.x - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.x,
emcStatus->motion.traj.actualPosition.tran.y - emcStatus->task.g5x_offset.tran.y - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.y,
emcStatus->motion.traj.actualPosition.tran.z - emcStatus->task.g5x_offset.tran.z - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.z,
emcStatus->motion.traj.actualPosition.a - emcStatus->task.g5x_offset.a - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.a);
else
emcStatus->motion.traj.position.tran.x - emcStatus->task.g5x_offset.tran.x - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.x,
emcStatus->motion.traj.position.tran.y - emcStatus->task.g5x_offset.tran.y - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.y,
emcStatus->motion.traj.position.tran.z - emcStatus->task.g5x_offset.tran.z - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.tran.z,
emcStatus->motion.traj.position.a - emcStatus->task.g5x_offset.a - emcStatus->task.g92_offset.tran.x - emcStatus->task.toolOffset.a);
sprintf(origin_string, "%9.4f %14.4f %14.4f %14.4f",
emcStatus->task.g5x_offset.tran.x + emcStatus->task.g92_offset.tran.x,
emcStatus->task.g5x_offset.tran.y + emcStatus->task.g92_offset.tran.y,
emcStatus->task.g5x_offset.tran.z + emcStatus->task.g92_offset.tran.z,
emcStatus->task.g5x_offset.a + emcStatus->task.g92_offset.a);
sprintf(speed_string, "%10.1f", jogSpeed);
if (jogMode == JOG_INCREMENTAL)
sprintf(incr_string, "%10.4f", jogIncrement);
else
sprintf(incr_string, "continuous");
if (! programOpened)
// print the last one opened, since we'll send this by default
strcpy(prog_string, programFile);
else
// print the one the controller knows about
strcpy(prog_string, emcStatus->task.file);
else
sprintf(line_string, "%d", programActiveLine);
if (programFp)
rewind(programFp);
programFpLine = 0;
programFpLine++;
// knock off CR, LF
while (len >= 0)
len--;
else
break;
else
else
line_string[0] = 0;
switch (emcStatus->task.interpState)
// Надо раскрасить
case EMC_TASK_INTERP_IDLE:
sprintf(interp_string, "%s", "IDLE ");
break;
case EMC_TASK_INTERP_READING:
sprintf(interp_string, "%s", "RUNNING ");
break;
case EMC_TASK_INTERP_PAUSED:
sprintf(interp_string, "%s", "PAUSED ");
break;
case EMC_TASK_INTERP_WAITING:
break;
default:
sprintf(interp_string, "%s", "? ");
break;
// fill in the active G codes
active_g_codes_string[0] = 0;
for (t = 1; t < ACTIVE_G_CODES; t++)
code = emcStatus->task.activeGCodes[t];
if (code == -1)
continue;
if (code % 10)
sprintf(scratch_string, "G%.1f ", (double) code / 10.0);
else
sprintf(scratch_string, "G%d ", code / 10);
strcat(active_g_codes_string, scratch_string);
// fill in the active M codes, settings too
active_m_codes_string[0] = 0;
for (t = 1; t < ACTIVE_M_CODES; t++)
code = emcStatus->task.activeMCodes[t];
if (code == -1)
continue;
sprintf(scratch_string, "M%d ", code);
strcat(active_m_codes_string, scratch_string);
sprintf(scratch_string, "F%.0f ", emcStatus->task.activeSettings[1]);
sprintf(scratch_string, "S%.0f ", emcStatus->task.activeSettings[2]);
// fill the screen in
override = (int) (emcStatus->motion.traj.scale * 100.0 + 0.5);
sprintf(scratch_string, "%4d%%", override);
if (override < 100)
else
start_color();
mvwaddstr(window, 6, 14, scratch_string);
sprintf(scratch_string, "%8d", emcStatus->io.tool.toolInSpindle);
mvwaddstr(window, 7, 11, scratch_string);
sprintf(scratch_string, "%8.4f", emcStatus->task.toolOffset.tran.z);
mvwaddstr(window, 8, 11, scratch_string);
mvwaddstr(window, 5, 1, state_string);
mvwaddstr(window, 5, 21, mode_string);
mvwaddstr(window, 6, 21, lube_on_string);
mvwaddstr(window, 7, 21, lube_level_string);
mvwaddstr(window, 5, 41, spindle_string);
mvwaddstr(window, 6, 41, brake_string);
mvwaddstr(window, 7, 41, mist_string);
mvwaddstr(window, 8, 41, flood_string);
mvwaddstr(window, 5, 61, home_string);
mvwaddstr(window, 6, 61, axisString(axisSelected));
mvwaddstr(window, 11, 21, pos_string);
if (coords == COORD_RELATIVE)
mvwaddstr(window, 12, 21, origin_string);
mvwaddstr(window, 7, 69, speed_string);
mvwaddstr(window, 8, 69, incr_string);
mvwaddstr(window, 14, 21, prog_string);
mvwaddstr(window, 15, 21, line_string);
if (emcStatus->task.interpState == EMC_TASK_INTERP_PAUSED)
mvwaddstr(window, 16, 21, programLineText);
mvwaddstr(window, 17, 21, interp_string);
mvwaddstr(window, 18, 21, active_g_codes_string);
mvwaddstr(window, 19, 21, active_m_codes_string);
mvwaddstr(window, 16, 21, emcStatus->task.command);
wrefresh(window);
static int catchErrors = 1;
static int updateStatus()
NMLTYPE type;
if (0 == emcStatus ||
0 == emcStatusBuffer ||
! emcStatusBuffer->valid())
return -1;
if (catchErrors)
if (0 == emcErrorBuffer ||
! emcErrorBuffer->valid())
return -1;
switch (type = emcStatusBuffer->peek())
case -1:
// error on CMS channel
return -1;
break;
case 0: // no new data
case EMC_STAT_TYPE: // new data
// new data
break;
default:
return -1;
break;
if (catchErrors)
switch (type = emcErrorBuffer->read())
case -1:
// error reading channel
break;
case 0:
// nothing new
error_string[0] = 0;
break;
case EMC_OPERATOR_ERROR_TYPE:
strncpy(error_string,
((EMC_OPERATOR_ERROR *) (emcErrorBuffer->get_address()))->error,
LINELEN - 1);
error_string[LINELEN - 1] = 0;
break;
case EMC_OPERATOR_TEXT_TYPE:
((EMC_OPERATOR_TEXT *) (emcErrorBuffer->get_address()))->text,
LINELEN - 1);
break;
case EMC_OPERATOR_DISPLAY_TYPE:
((EMC_OPERATOR_DISPLAY *) (emcErrorBuffer->get_address()))->display,
LINELEN - 1);
break;
case NML_ERROR_TYPE:
((NML_ERROR *) (emcErrorBuffer->get_address()))->error,
NML_ERROR_LEN - 1);
error_string[NML_ERROR_LEN - 1] = 0;
break;
case NML_TEXT_TYPE:
((NML_TEXT *) (emcErrorBuffer->get_address()))->text,
NML_ERROR_LEN - 1);
break;
case NML_DISPLAY_TYPE:
((NML_DISPLAY *) (emcErrorBuffer->get_address()))->display,
NML_ERROR_LEN - 1);
break;
default:
strcpy(error_string, "unrecognized error");
break;
return 0;
waits until the EMC reports that it's got the command with the
indicated serial_number. Sleeps between queries.
#define EMC_COMMAND_TIMEOUT 1.0 // how long to wait until timeout
#define EMC_COMMAND_DELAY 0.1 // how long to sleep between checks
static int emcCommandWait(int serial_number)
double start = etime();
while (etime() - start < EMC_COMMAND_TIMEOUT)
updateStatus();
if (emcStatus->echo_serial_number == serial_number)
return 0;
esleep(EMC_COMMAND_DELAY);
printError("timeout sending command");
return -1;
startTimer starts the timer to generate SIGALRM events, or stops the timer
if 'us' is 0. Enable a signal handler for SIGALRM before you call this.
void startTimer(int us)
timeout(us < 1000 ? 1 : us/1000);
idleHandler is called when no key is received after timeout and handles the
reading of NML status, the update of the status window, and key-up simulation
and handling
static void idleHandler()
// read NML status
updateStatus();
// only print if main is not printing, so we don't clobber in the middle
if (! critFlag)
printStatus();
// simulate key-up event, as per comment below
keyup_count -= usecs;
if (keyup_count < 0)
keyup_count = 0;
/* oldch = 0;*/
ch = 0;
Key-up events are simulated as follows: each time a key is received,
keyup_count is loaded. If it's a new key, FIRST_KEYUP_DELAY is
loaded. If it's the same as the last key, NEXT_KEYUP_DELAY is loaded.
This is to handle the different delay between the first and subsequent
repeats.
Each time through this handler, keyup_count is decremented. If it
reaches 0, it means no key has been pressed before the delay expires,
and we see this as a key-up event.
If you have code that needs to respond to a key-up event, set a flag
when you do your key-down stuff, and put the key-up code in here,
like this:
if (myFlag && keyup_count == 0)
// do stuff for key up here
// and clear your flag
myFlag = 0;
// key up for jogs
if (axisJogging != AXIS_NONE && keyup_count == 0)
emc_axis_abort_msg.axis = axisIndex(axisJogging);
emc_axis_abort_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_axis_abort_msg);
emcCommandWait(emcCommandSerialNumber);
// key up for spindle speed changes
if (spindleChanging && keyup_count == 0)
emc_spindle_constant_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_constant_msg);
return;
static int done = 0;
static void quit(int sig)
// clean up curses windows
delwin(progwin);
progwin = 0;
delwin(logwin);
logwin = 0;
delwin(toolwin);
toolwin = 0;
delwin(diagwin);
diagwin = 0;
delwin(helpwin);
helpwin = 0;
endwin();
// clean up NML buffers
if (emcErrorBuffer)
delete emcErrorBuffer;
emcErrorBuffer = 0;
if (emcStatusBuffer)
delete emcStatusBuffer;
emcStatus = 0;
if (emcCommandBuffer)
delete emcCommandBuffer;
// close program file
if (programFp)
fclose(programFp);
programFp = 0;
// close error log file
if (errorFp)
fclose(errorFp);
errorFp = NULL;
// reset signal handlers to default
signal(SIGINT, SIG_DFL);
exit(0);
static int emcTaskNmlGet()
int retval = 0;
// try to connect to EMC cmd
if (emcCommandBuffer == 0)
emcCommandBuffer = new RCS_CMD_CHANNEL(emcFormat, "emcCommand", "keystick", EMC_NMLFILE);
if (! emcCommandBuffer->valid())
rcs_print_error("emcCommand buffer not available\n");
retval = -1;
// try to connect to EMC status
if (emcStatusBuffer == 0)
emcStatusBuffer = new RCS_STAT_CHANNEL(emcFormat, "emcStatus", "keystick", EMC_NMLFILE);
if (! emcStatusBuffer->valid() ||
EMC_STAT_TYPE != emcStatusBuffer->peek())
rcs_print_error("emcStatus buffer not available\n");
emcStatus = 0;
retval = -1;
else
emcStatus = (EMC_STAT *) emcStatusBuffer->get_address();
return retval;
static int emcErrorNmlGet()
int retval = 0;
if (emcErrorBuffer == 0)
emcErrorBuffer = new NML(nmlErrorFormat, "emcError", "keystick", EMC_NMLFILE);
if (! emcErrorBuffer->valid())
rcs_print_error("emcError buffer not available\n");
emcErrorBuffer = 0;
retval = -1;
return retval;
// string for ini file version num
static char version_string[LINELEN] = "";
// destructively converts string to its uppercase counterpart
static char *upcase(char *string)
char *ptr = string;
while (*ptr)
*ptr = toupper(*ptr);
ptr++;
return string;
static int iniLoad(const char *filename)
IniFile inifile;
const char *inistring;
char machine[LINELEN] = "";
char version[LINELEN] = "";
char displayString[LINELEN] = "";
int jogPol;
// open it
if (-1 == inifile.Open(filename))
return -1;
if ((inistring = inifile.Find("MACHINE", "EMC")))
strcpy(machine, inistring);
if ((inistring = inifile.Find("VERSION", "EMC")))
sscanf(inistring, "$Revision: %s", version);
sprintf(version_string, "%s EMC Version %s", machine, version);
if ((inistring = inifile.Find("MAX_VELOCITY", "TRAJ")))
if (1 != sscanf(inistring, "%lf", &TRAJ_MAX_VELOCITY))
TRAJ_MAX_VELOCITY = DEFAULT_TRAJ_MAX_VELOCITY;
else
if ((inistring = inifile.Find("PROGRAM_PREFIX", "DISPLAY")))
if (1 != sscanf(inistring, "%s", programPrefix))
programPrefix[0] = 0;
else
if ((inistring = inifile.Find("POSITION_OFFSET", "DISPLAY")))
if (1 == sscanf(inistring, "%s", displayString))
upcase(displayString);
if (! strcmp(displayString, "ABSOLUTE"))
coords = COORD_ABSOLUTE;
else if (! strcmp(displayString, "RELATIVE"))
else
// error-- invalid value
// ignore
else
// error-- no value provided
// ignore
else
// no line at all
// ignore
if ((inistring = inifile.Find("POSITION_FEEDBACK", "DISPLAY")))
if (! strcmp(displayString, "ACTUAL"))
else if (! strcmp(displayString, "COMMANDED"))
posDisplay = POS_DISPLAY_CMD;
else
// ignore
else
// ignore
else
// no line at all
// ignore
xJogPol = 1; // set to default
if ((inistring = inifile.Find("JOGGING_POLARITY", "AXIS_0")) &&
1 == sscanf(inistring, "%d", &jogPol) &&
jogPol == 0)
// it read as 0, so override default
xJogPol = 0;
yJogPol = 1; // set to default
if ((inistring = inifile.Find("JOGGING_POLARITY", "AXIS_1")) &&
jogPol == 0)
yJogPol = 0;
zJogPol = 1; // set to default
if ((inistring = inifile.Find("JOGGING_POLARITY", "AXIS_2")) &&
jogPol == 0)
zJogPol = 0;
//надо добавить
aJogPol = 1; // set to default
if ((inistring = inifile.Find("JOGGING_POLARITY", "AXIS_3")) &&
jogPol == 0)
aJogPol = 0;
// close it
inifile.Close();
return 0;;
int tryNml()
double end;
int good;
#define RETRY_TIME 10.0 // seconds to wait for subsystems to come up
#define RETRY_INTERVAL 1.0 // seconds between wait tries for a subsystem
if ((EMC_DEBUG & EMC_DEBUG_NML) == 0) {
set_rcs_print_destination(RCS_PRINT_TO_NULL); // inhibit diag
// messages
end = RETRY_TIME;
good = 0;
do {
if (0 == emcTaskNmlGet()) {
good = 1;
break;
esleep(RETRY_INTERVAL);
end -= RETRY_INTERVAL;
} while (end > 0.0);
set_rcs_print_destination(RCS_PRINT_TO_STDOUT); // inhibit diag
// messages
if (!good) {
return -1;
// messages
end = RETRY_TIME;
good = 0;
do {
if (0 == emcErrorNmlGet()) {
good = 1;
break;
// messages
if (!good) {
return -1;
return 0;
#undef RETRY_TIME
#undef RETRY_INTERVAL
int main(int argc, char *argv[])
int dump = 0;
struct winsize size;
int curx, cury;
int t;
int typing = 0;
#define TYPEBUFFERSIZE ASCLINELEN
char typebuffer[TYPEBUFFERSIZE];
char lastmdi[TYPEBUFFERSIZE] = "";
int typeindex = 0;
enum {IACT_NONE = 1, IACT_OPEN, IACT_MDI, IACT_LOAD_TOOL, IACT_OPEN_LOG,
IACT_END} interactive = IACT_NONE;
//char keystick[] = "keystick";
int charHandled;
// process command line args, indexing argv[] from [1]
for (t = 1; t < argc; t++)
// try -dump
if (!strcmp(argv[t], "-dump"))
dump = 1;
continue;
// try -nml
if (!strcmp(argv[t], "-nml"))
if (t == argc - 1) // if last, can't read past it
printf("syntax: -nml <nmlfile>\n");
exit(1);
else
strcpy(EMC_NMLFILE, argv[t+1]);
t++; // step over nmlfile
continue;
// try -ini
if (!strcmp(argv[t], "-ini"))
if (t == argc - 1)
printf("syntax: -ini <inifile\n");
exit(1);
else
strcpy(EMC_INIFILE, argv[t+1]);
t++; // step over inifile
continue;
// try -noerror
if (!strcmp(argv[t], "-noerror"))
catchErrors = 0;
continue;
// try -usecs for cycle time in microseconds
if (!strcmp(argv[t], "-usecs"))
if (t == argc - 1 ||
1 != sscanf(argv[t + 1], "%d", &usecs) ||
usecs <= 0 ||
usecs >= 1000000)
printf("syntax: -usecs <1..999999 microsecond polling period>\n");
exit(1);
else
t++;
continue;
// try -dur for delay until repeat
if (!strcmp(argv[t], "-dur"))
1 != sscanf(argv[t + 1], "%d", &FIRST_KEYUP_DELAY) ||
FIRST_KEYUP_DELAY < 0)
printf("syntax: -dur <usecs delay until first repeat>\n");
exit(1);
else
t++;
continue;
// try -dbr for delay between repeats
if (!strcmp(argv[t], "-dbr"))
1 != sscanf(argv[t + 1], "%d", &NEXT_KEYUP_DELAY) ||
NEXT_KEYUP_DELAY < 0)
printf("syntax: -dbr <usecs delay between repeats>\n");
exit(1);
else
t++;
continue;
// read INI file
iniLoad(EMC_INIFILE);
// trap SIGINT
signal(SIGINT, quit);
#ifdef LOG
errorFp = fopen(ERROR_FILE, "w");
// failure here just disables logging
#endif
// init NML
if (! dump)
if(tryNml())
exit(1);
// set up curses
initscr();
cbreak();
noecho();
nonl();
intrflush(stdscr, FALSE);
keypad(stdscr, TRUE);
helpwin = newwin(0, 0, 0, 0);
diagwin = newwin(0, 0, 0, 0);
toolwin = newwin(0, 0, 0, 0);
logwin = newwin(0, 0, 0, 0);
progwin = newwin(0, 0, 0, 0);
window = stdscr;
// fill in strings
for (t = 0; t < ASCLINELEN; t++)
line_blank[t] = ' ';
line_blank[ASCLINELEN] = 0;
bottom_string[t] = '-';
bottom_string[ASCLINELEN] = 0;
t = (ASCLINELEN - strlen(version_string)) / 2;
if (t >= 0)
memcpy(&bottom_string[t], version_string, strlen(version_string));
// get screen width and height
wbegy = 0;
wbegx = 0;
if (ioctl(STDIN_FILENO, TIOCGWINSZ, &size) < 0)
// use 80x24 as default
wmaxy = 23;
wmaxx = 79;
else
wmaxy = size.ws_row - 1;
wmaxx = size.ws_col - 1;
// and set them here
cury = wmaxy;
curx = wbegx;
wmove(window, cury, curx);
wrefresh(window);
// set up interval timer
if (!dump)
startTimer(usecs);
while (! done)
oldch = ch;
int keypress = getch();
if(keypress == ERR)
idleHandler();
continue;
ch = (chtype) keypress;
// check for ^C that may happen during blocking read
if (done)
break;
if (dump)
mvwaddstr(window, wmaxy, wbegx, line_blank);
sprintf(scratch_string, "%12o", (int) ch);
mvwaddstr(window, wmaxy, wbegx, scratch_string);
wrefresh(window);
if (ch == 'q')
break;
else
continue;
if (ch != oldch)
keyup_count = FIRST_KEYUP_DELAY;
else
keyup_count = NEXT_KEYUP_DELAY;
// read NML status */
updateStatus();
printStatus();
// set up a first switch on ch, for those characters that
// are to be looked at before the interactive typing string.
// set flag signifying the char has been handled, which will
// be reset in the default (not handled) case
charHandled = 1;
switch (ch)
To implement a "repeated key," whose actions are done
during the first and every repeated key, do this:
case MY_REPEATED_KEY:
// do action
// you need do nothing else
break;
To implement a "single key," whose actions are done
once and not repeated if the key repeats, do this:
case MY_SINGLE_KEY:
if (oldch != ch)
// do action
break;
The simulated key-up event and setting of oldch is done
automatically elsewhere.
case ESC: // task abort (abort everything)
task_abort_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_abort_msg);
break;
case TAB: // toggle highlight
// toggle dianostics highlight
diagtab = DIAG_FIRST_KEYUP_DELAY;
else if (diagtab == DIAG_FIRST_KEYUP_DELAY)
diagtab = DIAG_NEXT_KEYUP_DELAY;
else
break;
case ALT('o'): // open log
case ALT('O'):
if (oldch != ch)
typing = 1;
typeindex = 0;
interactive = IACT_OPEN_LOG;
critFlag = 1;
mvwaddstr(window, wmaxy, wbegx, "log file to open: ");
wrefresh(window);
critFlag = 0;
break;
case CTL('L'): // redraw current window
clearWindow();
printStatus();
break;
case KEY_F(1): // toggle estop
if (oldch != ch)
if (emcStatus->task.state == EMC_TASK_STATE_ESTOP)
state_msg.state = EMC_TASK_STATE_ESTOP_RESET;
else
state_msg.state = EMC_TASK_STATE_ESTOP;
state_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(state_msg);
break;
case KEY_F(2): // toggle servos
if (oldch != ch)
if (emcStatus->task.state == EMC_TASK_STATE_ESTOP_RESET)
state_msg.state = EMC_TASK_STATE_ON;
else
state_msg.state = EMC_TASK_STATE_OFF;
break;
case KEY_F(3): // to into manual mode
if (oldch != ch)
mode_msg.mode = EMC_TASK_MODE_MANUAL;
mode_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(mode_msg);
break;
case KEY_F(4): // go into auto mode
if (oldch != ch)
mode_msg.mode = EMC_TASK_MODE_AUTO;
break;
case KEY_F(5): // go into mdi mode
if (oldch != ch)
mode_msg.mode = EMC_TASK_MODE_MDI;
break;
case KEY_F(6): // reset interpreter
if (oldch != ch)
task_plan_init_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_init_msg);
break;
case KEY_F(7): // toggle mist
if (oldch != ch)
emc_coolant_mist_off_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_coolant_mist_off_msg);
else
emc_coolant_mist_on_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_coolant_mist_on_msg);
break;
case KEY_F(8): // toggle flood
if (oldch != ch)
emc_coolant_flood_off_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_coolant_flood_off_msg);
else
emc_coolant_flood_on_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_coolant_flood_on_msg);
break;
case KEY_F(9): // toggle spindle forward/off
if (oldch != ch)
if (emcStatus->motion.spindle.direction == 0)
// it's off, so turn forward
emc_spindle_on_msg.speed = 1;
emc_spindle_on_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_on_msg);
else
// it's not off, so turn off
emc_spindle_off_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_off_msg);
break;
case KEY_F(10): // toggle spindle reverse/off
if (oldch != ch)
// it's off, so turn reverse
emc_spindle_on_msg.speed = -1;
else
break;
case KEY_F(11): // spindle speed decrease
if (oldch != ch)
// check for running first
break;
emc_spindle_decrease_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_decrease_msg);
spindleChanging = 1;
break;
case KEY_F(12): // spindle speed increase
if (oldch != ch)
break;
emc_spindle_increase_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_increase_msg);
break;
case KEY_RIGHT:
if (oldch != ch &&
axisJogging == AXIS_NONE)
emc_axis_incr_jog_msg.serial_number = ++emcCommandSerialNumber;
emc_axis_incr_jog_msg.axis = axisIndex(AXIS_X);
if (xJogPol)
emc_axis_incr_jog_msg.vel = jogSpeed / 60.0;
else
emc_axis_incr_jog_msg.vel = - jogSpeed / 60.0;
emc_axis_incr_jog_msg.incr = jogIncrement;
emcCommandBuffer->write(emc_axis_incr_jog_msg);
// don't set axisJogging, since key up will abort
else
jogMode = JOG_CONTINUOUS;
emc_axis_jog_msg.serial_number = ++emcCommandSerialNumber;
emc_axis_jog_msg.axis = axisIndex(AXIS_X);
if (xJogPol)
emc_axis_jog_msg.vel = jogSpeed / 60.0;
else
emc_axis_jog_msg.vel = - jogSpeed / 60.0;
emcCommandBuffer->write(emc_axis_jog_msg);
axisJogging = AXIS_X;
break;
case KEY_LEFT:
if (oldch != ch &&
if (xJogPol)
else
else
if (xJogPol)
else
break;
case KEY_UP:
if (oldch != ch &&
emc_axis_incr_jog_msg.axis = axisIndex(AXIS_Y);
if (yJogPol)
else
else
emc_axis_jog_msg.axis = axisIndex(AXIS_Y);
if (yJogPol)
else
axisJogging = AXIS_Y;
axisSelected = AXIS_Y;
break;
case KEY_DOWN:
if (oldch != ch &&
if (yJogPol)
else
else
if (yJogPol)
else
break;
case KEY_PPAGE:
if (oldch != ch &&
emc_axis_incr_jog_msg.axis = axisIndex(AXIS_Z);
if (zJogPol)
else
else
emc_axis_jog_msg.axis = axisIndex(AXIS_Z);
if (zJogPol)
else
axisJogging = AXIS_Z;
axisSelected = AXIS_Z;
break;
case KEY_NPAGE:
if (oldch != ch &&
if (zJogPol)
else
else
if (zJogPol)
else
break;
//и сюда кое чего дописать**********************************************/
case '+':
if (oldch != ch &&
emc_axis_incr_jog_msg.axis = axisIndex(AXIS_A);
if (aJogPol)
else
else
emc_axis_jog_msg.axis = axisIndex(AXIS_A);
if (aJogPol)
else
if (aJogPol)
else
axisJogging = AXIS_A;
axisSelected = AXIS_A;
break;
case '-':
if (oldch != ch &&
if (aJogPol)
else
else
if (aJogPol)
else
break;
case KEY_HOME: // home selected axis
if (oldch != ch)
emc_axis_home_msg.axis = axisIndex(axisSelected);
emc_axis_home_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_axis_home_msg);
break;
case KEY_END: // end this program
if (oldch != ch)
typing = 1;
typeindex = 0;
interactive = IACT_END;
critFlag = 1;
mvwaddstr(window, wmaxy, wbegx, "really quit? (y/n): ");
wrefresh(window);
critFlag = 0;
break;
default:
charHandled = 0;
break;
} // end of first switch (ch)
// now handle interactive typing, since immediate chars have
// just been handled
if (typing &&
! charHandled)
if (ch == RETURN)
typing = 0;
typebuffer[typeindex] = 0;
typeindex = 0;
critFlag = 1;
wrefresh(window);
critFlag = 0;
// now handle typed string
switch (interactive)
case IACT_OPEN:
strcpy(task_plan_open_msg.file, typebuffer);
task_plan_open_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_open_msg);
strcpy(programFile, task_plan_open_msg.file);
programOpened = 1;
if (programFp)
fclose(programFp);
programFp = fopen(programFile, "r");
programFpLine = 0;
break;
case IACT_MDI:
if (typebuffer[0] == 0)
break; // ignore blank lines
strcpy(lastmdi, typebuffer); // save it
strcpy(task_plan_execute_msg.command, typebuffer);
task_plan_execute_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_execute_msg);
break;
case IACT_LOAD_TOOL:
strcpy(emc_tool_load_tool_table_msg.file, typebuffer);
emc_tool_load_tool_table_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_tool_load_tool_table_msg);
break;
case IACT_END:
if (typebuffer[0] == 'y' ||
typebuffer[0] == 'Y')
done = 1;
break;
default: // ignore
break;
else if (ch == KEY_BACKSPACE || // try all the backspace chars
ch == 8 ||
ch == 127)
if (typeindex == 0)
// we're at first spot-- ignore
continue;
--typeindex;
critFlag = 1;
getyx(window, cury, curx);
--curx;
mvwaddch(window, cury, curx, ' ');
wrefresh(window);
critFlag = 0;
else
if (typeindex >= TYPEBUFFERSIZE - 1)
// we're at last spot, which we need for null-- ignore
continue;
typebuffer[typeindex++] = ch;
critFlag = 1;
waddch(window, ch);
wrefresh(window);
critFlag = 0;
// continue with while (! done), so we skip over the normal
// handling of alphanumeric chars
continue;
} // end of if (typing)
// set up a second switch on ch, for those alphanumeric chars that
// can be part of an interactive string
switch (ch)
case RETURN:
if (oldch != ch)
// clear all error buffers
critFlag = 1;
mvwaddstr(stdscr, ERR_Y, ERR_X, line_blank);
mvwaddstr(helpwin, ERR_Y, ERR_X, line_blank);
mvwaddstr(diagwin, ERR_Y, ERR_X, line_blank);
mvwaddstr(toolwin, ERR_Y, ERR_X, line_blank);
mvwaddstr(logwin, ERR_Y, ERR_X, line_blank);
mvwaddstr(progwin, ERR_Y, ERR_X, line_blank);
wrefresh(window);
critFlag = 0;
break;
case '?': // toggle help screen
critFlag = 1;
window = helpwin;
else if (window == helpwin)
window = toolwin;
window = logwin;
else if (window == logwin)
window = diagwin;
window = progwin;
window = stdscr;
else
window = stdscr;
critFlag = 0;
clearWindow();
printStatus();
break;
case '#': // toggle abs/rel mode
if (oldch != ch)
switch (coords)
case COORD_RELATIVE:
break;
case COORD_ABSOLUTE:
break;
default:
break;
break;
case '@': // toggle cmd/act mode
if (oldch != ch)
switch (posDisplay)
case POS_DISPLAY_ACT:
break;
case POS_DISPLAY_CMD:
break;
default:
break;
break;
case 'x':
case 'X':
if (oldch != ch)
typing = 1;
typeindex = 1;
typebuffer[0] = ch;
typebuffer[1] = 0;
interactive = IACT_MDI;
critFlag = 1;
mvwaddstr(window, wmaxy, wbegx, "mdi command: ");
waddch(window, ch);
wrefresh(window);
critFlag = 0;
else
break;
case 'y':
case 'Y':
if (oldch != ch)
typing = 1;
typeindex = 1;
typebuffer[0] = ch;
typebuffer[1] = 0;
critFlag = 1;
waddch(window, ch);
wrefresh(window);
critFlag = 0;
else
break;
case 'z':
case 'Z':
if (oldch != ch)
typing = 1;
typeindex = 1;
typebuffer[0] = ch;
typebuffer[1] = 0;
critFlag = 1;
waddch(window, ch);
wrefresh(window);
critFlag = 0;
else
break;
/* сюда дописать про А*/
case 'a':
case 'A':
if (oldch != ch)
typing = 1;
typeindex = 1;
typebuffer[0] = ch;
typebuffer[1] = 0;
critFlag = 1;
waddch(window, ch);
wrefresh(window);
critFlag = 0;
else
break;
case 'i': // incremental jog toggle
case 'I':
jogIncrement *= 10.0;
if (jogIncrement >= 0.9)
jogIncrement = 0.0001;
jogMode = JOG_INCREMENTAL;
break;
case 'c': // continuous jog
case 'C':
if (oldch != ch)
break;
case '<':
case ',':
usecs -= 10000;
if (usecs < 10000)
usecs = 10000;
startTimer(usecs);
FIRST_KEYUP_DELAY -= 10000;
if (FIRST_KEYUP_DELAY <= 0)
FIRST_KEYUP_DELAY = 0;
else
NEXT_KEYUP_DELAY -= 10000;
if (NEXT_KEYUP_DELAY <= 0)
NEXT_KEYUP_DELAY = 0;
else
jogSpeed -= 1;
if (jogSpeed < 1)
jogSpeed = 1;
break;
case '>':
case '.':
usecs += 10000;
if (usecs > 900000)
usecs = 900000;
startTimer(usecs);
FIRST_KEYUP_DELAY += 10000;
else
NEXT_KEYUP_DELAY += 10000;
else
jogSpeed += 1;
if (jogSpeed > TRAJ_MAX_VELOCITY * 60.0)
jogSpeed = TRAJ_MAX_VELOCITY * 60.0;
break;
//надо по другому распределить скорости до 150%
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
// feed override
if (oldch != ch)
if (ch == '0')
emc_traj_set_scale_msg.scale = 1.0;
else
emc_traj_set_scale_msg.scale = double (ch - '1' + 1) / 10.0;
emc_traj_set_scale_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_traj_set_scale_msg);
break;
case 'b': // spindle brake off
if (oldch != ch)
emc_spindle_brake_release_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_brake_release_msg);
break;
case 'B': // spindle brake on
if (oldch != ch)
emc_spindle_brake_engage_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_spindle_brake_engage_msg);
break;
case 'o':
case 'O':
if (oldch != ch)
if (emcStatus->task.mode != EMC_TASK_MODE_AUTO)
break;
typing = 1;
strcpy(typebuffer, programPrefix);
typeindex = strlen(programPrefix);
interactive = IACT_OPEN;
critFlag = 1;
mvwaddstr(window, wmaxy, wbegx, "program to open: ");
waddstr(window, typebuffer);
wrefresh(window);
critFlag = 0;
break;
case 'r':
case 'R':
if (oldch != ch)
break;
// send a request to open the last one
strcpy(task_plan_open_msg.file, programFile);
task_plan_run_msg.serial_number = ++emcCommandSerialNumber;
task_plan_run_msg.line = 0;
emcCommandBuffer->write(task_plan_run_msg);
programOpened = 0;
break;
case 'p':
case 'P':
if (oldch != ch)
task_plan_pause_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_pause_msg);
break;
case 's':
case 'S':
if (oldch != ch)
task_plan_resume_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_resume_msg);
break;
/* И что удивительно в хелпе про это по другому
надо по другому переделать потому, что перекекаются хоткеи */
// case 'a':
// case 'A':
case 'f':
case 'F':
if (oldch != ch)
task_plan_step_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(task_plan_step_msg);
break;
case 'u':
if (oldch != ch)
emc_lube_off_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_lube_off_msg);
break;
case 'U':
if (oldch != ch)
emc_lube_on_msg.serial_number = ++emcCommandSerialNumber;
emcCommandBuffer->write(emc_lube_on_msg);
break;
case '\'':
case '\"':
if (oldch != ch)
if (emcStatus->task.mode != EMC_TASK_MODE_MDI)
break;
typing = 1;
// stuff last command
strcpy(typebuffer, lastmdi);
typeindex = strlen(typebuffer);
critFlag = 1;
wrefresh(window);
critFlag = 0;
break;
case 'm':
case 'M':
case 'g':
case 'G':
if (oldch != ch)
break;
typing = 1;
typeindex = 1;
typebuffer[0] = ch;
typebuffer[1] = 0;
critFlag = 1;
waddch(window, ch);
wrefresh(window);
critFlag = 0;
break;
case 'l':
case 'L':
if (oldch != ch)
typing = 1;
typeindex = 0;
interactive = IACT_LOAD_TOOL;
critFlag = 1;
mvwaddstr(window, wmaxy, wbegx, "tool file to load: ");
wrefresh(window);
critFlag = 0;
break;
default:
break;
} // end of second switch (ch)
} // end of while (! done)
// call ^C signal handler directly to terminate cleanly
quit(0);
return 0;
