Потекли у меня электролиты на матери, отдал мать в ремон. Перепаяли, всё ок.
Сейчас стартую EMC2 и получаю такое вот сообщение (даже с дэфолтными конфигами).
Кто знает, в чём дело?
Ошибка:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/os8lvr/emc2/configs/мой-станок'
Machine configuration file is 'мой-станок.ini'
INIFILE=/home/os8lvr/emc2/configs/мой-станок/мой-станок.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1758
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1758
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
[ 0.000000] BIOS-e820: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000001fff3000 - 0000000020000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] Phoenix BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x1fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FE0000000 write-back
[ 0.000000] 1 base 0E8000000 mask FFE000000 write-combining
[ 0.000000] 2 base 0E8000000 mask FFE000000 write-combining
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001fff0000 (usable)
[ 0.000000] modified: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
[ 0.000000] modified: 000000001fff3000 - 0000000020000000 (ACPI data)
[ 0.000000] modified: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001fff0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001fc00000 page 2M
[ 0.000000] 001fc00000 - 001fff0000 page 4k
[ 0.000000] kernel direct mapping tables up to 1fff0000 @ 10000-15000
[ 0.000000] RAMDISK: 173b4000 - 1803341c
[ 0.000000] ACPI: RSDP 000f7350 00014 (v00 VIA694)
[ 0.000000] ACPI: RSDT 1fff3000 00028 (v01 VIA694 AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 1fff3040 00074 (v01 VIA694 AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 1fff30c0 033FC (v01 VIA694 AWRDACPI 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 1fff0000 00040
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 511MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1fff0000
[ 0.000000] low ram: 0 - 1fff0000
[ 0.000000] node 0 low ram: 00000000 - 1fff0000
[ 0.000000] node 0 bootmap 00011000 - 00015000
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001fff0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00173b4000 - 001803341c] RAMDISK ==> [00173b4000 - 001803341c]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b408a] BRK ==> [00008b1000 - 00008b408a]
[ 0.000000] #7 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #8 [0000011000 - 0000015000] BOOTMAP ==> [0000011000 - 0000015000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001fff0
[ 0.000000] HighMem 0x0001fff0 -> 0x0001fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001fff0
[ 0.000000] On node 0 totalpages: 130943
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 125968 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 20000000:dfff0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1800000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129919
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=e964bb4d-dcf3-45b4-8076-81d34648cef6 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2620800 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 495588k/524224k available (4539k kernel code, 27864k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07f0000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfff0000 ( 511 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1677.656 MHz processor.
[ 0.008006] Calibrating delay loop (skipped), value calculated using timer frequency.. 3355.31 BogoMIPS (lpj=6710624)
[ 0.008035] Security Framework initialized
[ 0.008074] AppArmor: AppArmor initialized
[ 0.008086] Mount-cache hash table entries: 512
[ 0.008277] Initializing cgroup subsys ns
[ 0.008283] Initializing cgroup subsys cpuacct
[ 0.008289] Initializing cgroup subsys memory
[ 0.008303] Initializing cgroup subsys devices
[ 0.008307] Initializing cgroup subsys freezer
[ 0.008310] Initializing cgroup subsys net_cls
[ 0.008335] CPU: CLK_CTL MSR was 60031223. Reprogramming to 20031223
[ 0.008341] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.008344] CPU: L2 Cache: 256K (64 bytes/line)
[ 0.008350] mce: CPU supports 4 MCE banks
[ 0.008377] Performance Events: AMD PMU driver.
[ 0.008394] ... version: 0
[ 0.008396] ... bit width: 48
[ 0.008399] ... generic registers: 4
[ 0.008402] ... value mask: 0000ffffffffffff
[ 0.008405] ... max period: 00007fffffffffff
[ 0.008408] ... fixed-purpose events: 0
[ 0.008410] ... event mask: 000000000000000f
[ 0.008416] Checking 'hlt' instruction... OK.
[ 0.024720] SMP alternatives: switching to UP code
[ 0.031835] Freeing SMP alternatives: 31k freed
[ 0.031880] ACPI: Core revision 20090903
[ 0.039115] ACPI: setting ELCR to 0200 (from 0a20)
[ 0.040108] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.040127] ftrace: allocating 21003 entries in 42 pages
[ 0.050731] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.050739] weird, boot CPU (#0) not listed by the BIOS.
[ 0.050742] SMP motherboard not detected.
[ 0.050746] Local APIC not detected. Using dummy APIC emulation.
[ 0.050749] SMP disabled
[ 0.051124] Brought up 1 CPUs
[ 0.051128] Total of 1 processors activated (3355.31 BogoMIPS).
[ 0.051476] CPU0 attaching NULL sched-domain.
[ 0.051748] devtmpfs: initialized
[ 0.052234] regulator: core version 0.5
[ 0.052310] NET: Registered protocol family 16
[ 0.052495] EISA bus registered
[ 0.052508] ACPI: bus type pci registered
[ 0.054412] PCI: PCI BIOS revision 2.10 entry at 0xfb200, last bus=1
[ 0.054416] PCI: Using configuration type 1 for base access
[ 0.055527] bio: create slab <bio-0> at 0
[ 0.056161] ACPI: EC: Look up EC in DSDT
[ 0.062045] ACPI: Interpreter enabled
[ 0.062049] ACPI: (supports S0 S5)
[ 0.062065] ACPI: Using PIC for interrupt routing
[ 0.067906] ACPI: No dock devices found.
[ 0.068048] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.068113] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xe9ffffff]
[ 0.068206] pci 0000:00:01.0: supports D1
[ 0.068237] pci 0000:00:0a.0: reg 10 io port: [0xd000-0xd01f]
[ 0.068264] pci 0000:00:0a.0: reg 30 32bit mmio pref: [0x000000-0x007fff]
[ 0.068388] pci 0000:00:11.1: reg 20 io port: [0xd400-0xd40f]
[ 0.068461] pci 0000:00:11.2: reg 20 io port: [0xd800-0xd81f]
[ 0.068529] pci 0000:00:11.3: reg 20 io port: [0xdc00-0xdc1f]
[ 0.068583] pci 0000:00:11.5: reg 10 io port: [0xe000-0xe0ff]
[ 0.068675] pci 0000:01:00.0: reg 10 32bit mmio: [0xea000000-0xeaffffff]
[ 0.068682] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.068701] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x00ffff]
[ 0.068750] pci 0000:00:01.0: bridge 32bit mmio: [0xea000000-0xebffffff]
[ 0.068756] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.068765] pci_bus 0000:00: on NUMA node 0
[ 0.068771] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.086663] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
[ 0.086849] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.087080] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
[ 0.087300] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
[ 0.087473] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.087478] vgaarb: loaded
[ 0.087679] SCSI subsystem initialized
[ 0.087821] libata version 3.00 loaded.
[ 0.087938] usbcore: registered new interface driver usbfs
[ 0.087956] usbcore: registered new interface driver hub
[ 0.088023] usbcore: registered new device driver usb
[ 0.088230] ACPI: WMI: Mapper loaded
[ 0.088233] PCI: Using ACPI for IRQ routing
[ 0.088397] NetLabel: Initializing
[ 0.088400] NetLabel: domain hash size = 128
[ 0.088403] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.088426] NetLabel: unlabeled traffic allowed by default
[ 0.088479] Switching to clocksource tsc
[ 0.091636] AppArmor: AppArmor Filesystem Enabled
[ 0.091666] pnp: PnP ACPI init
[ 0.091699] ACPI: bus type pnp registered
[ 0.096101] pnp: PnP ACPI: found 16 devices
[ 0.096104] ACPI: ACPI bus type pnp unregistered
[ 0.096110] PnPBIOS: Disabled by ACPI PNP
[ 0.096131] system 00:02: ioport range 0x4000-0x407f has been reserved
[ 0.096136] system 00:02: ioport range 0x5000-0x500f has been reserved
[ 0.096144] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.096148] system 00:03: ioport range 0x800-0x805 has been reserved
[ 0.096153] system 00:03: ioport range 0x290-0x297 has been reserved
[ 0.130945] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.130949] pci 0000:00:01.0: IO window: disabled
[ 0.130957] pci 0000:00:01.0: MEM window: 0xea000000-0xebffffff
[ 0.130962] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xe7ffffff
[ 0.130981] pci 0000:00:01.0: setting latency timer to 64
[ 0.130989] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.130993] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.130997] pci_bus 0000:01: resource 1 mem: [0xea000000-0xebffffff]
[ 0.131001] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[ 0.131055] NET: Registered protocol family 2
[ 0.131183] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.131576] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.131800] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.132021] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.132025] TCP reno registered
[ 0.132149] NET: Registered protocol family 1
[ 0.132175] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.132222] pci 0000:01:00.0: Boot video device
[ 0.132575] Scanning for low memory corruption every 60 seconds
[ 0.132706] audit: initializing netlink socket (disabled)
[ 0.132724] type=2000 audit(1364470258.131:1): initialized
[ 0.142784] Trying to unpack rootfs image as initramfs...
[ 0.155977] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.158228] VFS: Disk quotas dquot_6.5.2
[ 0.158319] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.164037] fuse init (API version 7.13)
[ 0.164238] msgmni has been set to 968
[ 0.164629] alg: No test for stdrng (krng)
[ 0.164679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.164684] io scheduler noop registered
[ 0.164687] io scheduler anticipatory registered
[ 0.164690] io scheduler deadline registered
[ 0.164744] io scheduler cfq registered (default)
[ 0.164889] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.164922] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.165037] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.165044] ACPI: Power Button [PWRB]
[ 0.165112] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.165121] ACPI: Sleep Button [SLPB]
[ 0.165214] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.165218] ACPI: Power Button [PWRF]
[ 0.167309] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.167433] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.167568] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.167921] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.168055] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.169600] brd: module loaded
[ 0.170295] loop: module loaded
[ 0.170459] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.171193] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
[ 0.171198] PCI: setting IRQ 5 as level-triggered
[ 0.171206] pata_acpi 0000:00:11.1: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 0.171213] pata_acpi 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 5
[ 0.171328] pata_acpi 0000:00:11.1: PCI INT A disabled
[ 0.171580] isapnp: Scanning for PnP cards...
[ 0.184096] Fixed MDIO Bus: probed
[ 0.184152] PPP generic driver version 2.4.2
[ 0.184245] tun: Universal TUN/TAP device driver, 1.6
[ 0.184249] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.184402] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.184445] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.184463] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.185123] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.185128] PCI: setting IRQ 11 as level-triggered
[ 0.185136] uhci_hcd 0000:00:11.2: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.185152] uhci_hcd 0000:00:11.2: UHCI Host Controller
[ 0.185222] uhci_hcd 0000:00:11.2: new USB bus registered, assigned bus number 1
[ 0.185258] uhci_hcd 0000:00:11.2: irq 11, io base 0x0000d800
[ 0.185432] usb usb1: configuration #1 chosen from 1 choice
[ 0.185476] hub 1-0:1.0: USB hub found
[ 0.185493] hub 1-0:1.0: 2 ports detected
[ 0.185571] uhci_hcd 0000:00:11.3: PCI INT D -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.185581] uhci_hcd 0000:00:11.3: UHCI Host Controller
[ 0.185635] uhci_hcd 0000:00:11.3: new USB bus registered, assigned bus number 2
[ 0.185658] uhci_hcd 0000:00:11.3: irq 11, io base 0x0000dc00
[ 0.185790] usb usb2: configuration #1 chosen from 1 choice
[ 0.185834] hub 2-0:1.0: USB hub found
[ 0.185847] hub 2-0:1.0: 2 ports detected
[ 0.185969] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.229857] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.229872] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.230064] mice: PS/2 mouse device common for all mice
[ 0.230275] rtc_cmos 00:05: RTC can wake from S4
[ 0.230351] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.230377] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.230511] device-mapper: uevent: version 1.0.3
[ 0.233501] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.233810] device-mapper: multipath: version 1.1.0 loaded
[ 0.233816] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.235063] EISA: Probing bus 0 at eisa.0
[ 0.235085] Cannot allocate resource for EISA slot 4
[ 0.235088] Cannot allocate resource for EISA slot 5
[ 0.235102] EISA: Detected 0 cards.
[ 0.235106] cpuidle: using governor ladder
[ 0.235110] cpuidle: using governor menu
[ 0.235701] TCP cubic registered
[ 0.235919] NET: Registered protocol family 10
[ 0.236467] lo: Disabled Privacy Extensions
[ 0.236849] NET: Registered protocol family 17
[ 0.236899] Using IPI No-Shortcut mode
[ 0.237064] registered taskstats version 1
[ 0.237303] rtc_cmos 00:05: setting system clock to 2013-03-28 11:30:58 UTC (1364470258)
[ 0.237308] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.237311] EDD information not available.
[ 0.249536] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.843286] isapnp: No Plug & Play device found
[ 0.974380] Freeing initrd memory: 12797k freed
[ 0.996109] Freeing unused kernel memory: 620k freed
[ 0.997221] Write protecting the kernel text: 4540k
[ 0.997254] Write protecting the kernel read-only data: 1668k
[ 1.035916] udev: starting version 151
[ 1.316883] pata_via 0000:00:11.1: version 0.3.4
[ 1.316911] pata_via 0000:00:11.1: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 1.316918] pata_via 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 5
[ 1.334431] scsi0 : pata_via
[ 1.341393] scsi1 : pata_via
[ 1.349273] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xd400 irq 14
[ 1.349280] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xd408 irq 15
[ 1.356980] ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
[ 1.357585] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 1.357592] ne2k-pci 0000:00:0a.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 1.358442] eth0: RealTek RTL-8029 found at 0xd000, IRQ 11, 00:c0:df:f4:18:75.
[ 1.359193] Linux agpgart interface v0.103
[ 1.376094] FDC 0 is a post-1991 82077
[ 1.512397] ata1.00: ATAPI: ASUS DRW-1612BL, 1.06, max UDMA/66
[ 1.512426] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 1.528263] ata1.00: configured for UDMA/33
[ 1.529119] scsi 0:0:0:0: CD-ROM ASUS DRW-1612BL 1.06 PQ: 0 ANSI: 5
[ 1.532815] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.532823] Uniform CD-ROM driver Revision: 3.20
[ 1.533020] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 1.533144] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 1.696518] ata2.00: ATA-6: SAMSUNG SP8004H, QW100-60, max UDMA/100
[ 1.696525] ata2.00: 156368016 sectors, multi 16: LBA
[ 1.704376] ata2.00: configured for UDMA/100
[ 1.704569] scsi 1:0:0:0: Direct-Access ATA SAMSUNG SP8004H QW10 PQ: 0 ANSI: 5
[ 1.704833] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.704958] sd 1:0:0:0: [sda] 156368016 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 1.705036] sd 1:0:0:0: [sda] Write Protect is off
[ 1.705041] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.705082] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.705326] sda: sda1 sda2 < sda5 >
[ 1.735393] sd 1:0:0:0: [sda] Attached SCSI disk
[ 1.773596] agpgart: Detected VIA KT266/KY266x/KT333 chipset
[ 1.776782] [drm] Initialized drm 1.1.0 20060810
[ 1.786580] agpgart-via 0000:00:00.0: AGP aperture is 32M @ 0xe8000000
[ 1.840877] nouveau 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 1.847187] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x011000b2)
[ 1.847346] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[ 1.981017] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 1.981336] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 1.981340] [drm] nouveau 0000:01:00.0: BMP version 5.17
[ 1.981345] [drm] nouveau 0000:01:00.0: Bios version 03.11.00.18
[ 1.981351] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 1.2
[ 1.981355] [drm] nouveau 0000:01:00.0: No useful information in BIOS output table; adding all possible outputs
[ 1.981359] [drm] nouveau 0000:01:00.0: Probing TV encoders on I2C bus: 1
[ 1.985888] [drm] nouveau 0000:01:00.0: No TV encoders found.
[ 1.986167] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x07FE
[ 1.986184] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x0EA7
[ 1.986192] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0x0819
[ 1.986210] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0x0E4E
[ 1.986220] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0x08AC
[ 1.986225] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0x09BB
[ 1.986246] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0x08DA
[ 1.986264] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 7 at offset 0x0956
[ 1.997362] [TTM] Zone kernel: Available graphics memory: 254680 kiB.
[ 1.997383] [drm] nouveau 0000:01:00.0: 32 MiB VRAM
[ 1.997462] agpgart-via 0000:00:00.0: AGP 2.0 bridge
[ 1.997483] agpgart-via 0000:00:00.0: putting AGP V2 device into 2x mode
[ 1.997522] nouveau 0000:01:00.0: putting AGP V2 device into 2x mode
[ 1.997526] [drm] nouveau 0000:01:00.0: 32 MiB GART (aperture)
[ 1.997795] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[ 1.999174] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[ 1.999195] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[ 1.999206] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 2.034454] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[ 2.034738] [drm] nouveau 0000:01:00.0: Detected a DVI-D connector
[ 2.035655] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[ 2.035661] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on tmds encoder (output 1)
[ 2.174407] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo d7a5a400
[ 2.174693] fb0: nouveaufb frame buffer device
[ 2.174696] registered panic notifier
[ 2.174706] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[ 2.179242] vga16fb: initializing
[ 2.179252] vga16fb: mapped to 0xc00a0000
[ 2.179262] vga16fb: not registering due to another framebuffer present
[ 2.205298] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[ 2.205307] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output @
[ 2.212034] Console: switching to colour frame buffer device 160x64
[ 2.640155] xor: automatically using best checksumming function: pIII_sse
[ 2.660019] pIII_sse : 4567.000 MB/sec
[ 2.660023] xor: using function: pIII_sse (4567.000 MB/sec)
[ 2.667591] device-mapper: dm-raid45: initialized v0.2594b
[ 2.846977] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 2.846988] EXT4-fs (sda1): write access will be enabled during recovery
[ 2.982217] EXT4-fs (sda1): recovery complete
[ 2.983328] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 12.461682] udev: starting version 151
[ 12.503886] Adding 1489912k swap on /dev/sda5. Priority:-1 extents:1 across:1489912k
[ 12.697430] lp: driver loaded but no devices found
[ 12.714459] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 13.154835] type=1505 audit(1364470271.414:2): operation="profile_load" pid=491 name="/sbin/dhclient3"
[ 13.155244] type=1505 audit(1364470271.414:3): operation="profile_load" pid=491 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.155475] type=1505 audit(1364470271.414:4): operation="profile_load" pid=491 name="/usr/lib/connman/scripts/dhclient-script"
[ 13.205781] irda_init()
[ 13.205813] NET: Registered protocol family 23
[ 13.222702] parport_pc 00:0b: reported by Plug and Play ACPI
[ 13.222749] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 13.310212] lp0: using parport0 (interrupt-driven).
[ 13.358974] ppdev: user-space parallel port driver
[ 13.463473] gameport: NS558 PnP Gameport is pnp00:0f/gameport0, io 0x201, speed 994kHz
[ 13.501232] psmouse serio1: ID: 10 00 64
[ 13.917595] VIA 82xx Audio 0000:00:11.5: PCI INT C -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 13.917738] VIA 82xx Audio 0000:00:11.5: setting latency timer to 64
[ 14.082913] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input5
[ 14.236273] type=1505 audit(1364470272.498:5): operation="profile_load" pid=690 name="/usr/share/gdm/guest-session/Xsession"
[ 14.255051] type=1505 audit(1364470272.514:6): operation="profile_replace" pid=692 name="/sbin/dhclient3"
[ 14.255495] type=1505 audit(1364470272.514:7): operation="profile_replace" pid=692 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 14.255738] type=1505 audit(1364470272.514:8): operation="profile_replace" pid=692 name="/usr/lib/connman/scripts/dhclient-script"
[ 14.307991] type=1505 audit(1364470272.566:9): operation="profile_load" pid=694 name="/usr/bin/evince"
[ 14.328876] type=1505 audit(1364470272.590:10): operation="profile_load" pid=694 name="/usr/bin/evince-previewer"
[ 14.355168] type=1505 audit(1364470272.614:11): operation="profile_load" pid=694 name="/usr/bin/evince-thumbnailer"
[ 15.217467] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[ 15.219466] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 24.452059] eth0: no IPv6 routers present
[ 83.870137] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 149.812076] usb 1-2: new full speed USB device using uhci_hcd and address 2
[ 149.986866] usb 1-2: configuration #1 chosen from 1 choice
[ 150.086132] Initializing USB Mass Storage driver...
[ 150.088352] scsi2 : SCSI emulation for USB Mass Storage devices
[ 150.092453] usbcore: registered new interface driver usb-storage
[ 150.092461] USB Mass Storage support registered.
[ 150.101533] usb-storage: device found at 2
[ 150.101540] usb-storage: waiting for device to settle before scanning
[ 155.104228] usb-storage: device scan complete
[ 155.447721] scsi 2:0:0:0: Direct-Access JetFlash Transcend 16GB 1100 PQ: 0 ANSI: 4
[ 155.452120] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 155.471521] sd 2:0:0:0: [sdb] 31678464 512-byte logical blocks: (16.2 GB/15.1 GiB)
[ 155.474669] sd 2:0:0:0: [sdb] Write Protect is off
[ 155.474680] sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00
[ 155.474684] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 155.491668] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 155.491686] sdb: sdb4
[ 155.508660] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 155.508674] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 157.972101] usb 1-2: reset full speed USB device using uhci_hcd and address 2
[ 173.088120] usb 1-2: device descriptor read/64, error -110
[ 188.304095] usb 1-2: device descriptor read/64, error -110
[ 188.520103] usb 1-2: reset full speed USB device using uhci_hcd and address 2
[ 203.632207] usb 1-2: device descriptor read/64, error -110
[ 218.848115] usb 1-2: device descriptor read/64, error -110
[ 219.064090] usb 1-2: reset full speed USB device using uhci_hcd and address 2
[ 229.472068] usb 1-2: device not accepting address 2, error -110
[ 229.584090] usb 1-2: reset full speed USB device using uhci_hcd and address 2
[ 239.992073] usb 1-2: device not accepting address 2, error -110
[ 239.992139] usb 1-2: USB disconnect, address 2
[ 239.992665] sd 2:0:0:0: Device offlined - not ready after error recovery
[ 239.992983] sd 2:0:0:0: [sdb] Unhandled error code
[ 239.992988] sd 2:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 239.992994] sd 2:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 67 00 00 80 00
[ 239.993007] end_request: I/O error, dev sdb, sector 2151
[ 239.993162] sd 2:0:0:0: [sdb] Unhandled error code
[ 239.993166] sd 2:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 239.993170] sd 2:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 08 e7 00 00 7e 00
[ 239.993181] end_request: I/O error, dev sdb, sector 2279
[ 239.997662] FAT: FAT read failed (blocknr 2088)
[ 240.132086] usb 1-2: new full speed USB device using uhci_hcd and address 3
[ 241.195564] FAT: Directory bread(block 30944) failed
[ 241.195628] FAT: Directory bread(block 30945) failed
[ 241.195644] FAT: Directory bread(block 30946) failed
[ 241.195658] FAT: Directory bread(block 30947) failed
[ 241.195672] FAT: Directory bread(block 30948) failed
[ 241.195686] FAT: Directory bread(block 30949) failed
[ 241.195699] FAT: Directory bread(block 30950) failed
[ 241.195713] FAT: Directory bread(block 30951) failed
[ 241.195727] FAT: Directory bread(block 30952) failed
[ 241.195741] FAT: Directory bread(block 30953) failed
[ 241.195755] FAT: Directory bread(block 30954) failed
[ 241.195768] FAT: Directory bread(block 30955) failed
[ 241.195782] FAT: Directory bread(block 30956) failed
[ 241.195796] FAT: Directory bread(block 30957) failed
[ 241.195810] FAT: Directory bread(block 30958) failed
[ 241.195824] FAT: Directory bread(block 30959) failed
[ 241.245391] FAT: Directory bread(block 30944) failed
[ 241.245412] FAT: Directory bread(block 30945) failed
[ 241.245427] FAT: Directory bread(block 30946) failed
[ 241.245441] FAT: Directory bread(block 30947) failed
[ 241.245456] FAT: Directory bread(block 30948) failed
[ 241.245470] FAT: Directory bread(block 30949) failed
[ 241.245484] FAT: Directory bread(block 30950) failed
[ 241.245499] FAT: Directory bread(block 30951) failed
[ 241.245513] FAT: Directory bread(block 30952) failed
[ 241.245527] FAT: Directory bread(block 30953) failed
[ 241.245541] FAT: Directory bread(block 30954) failed
[ 241.245555] FAT: Directory bread(block 30955) failed
[ 241.245569] FAT: Directory bread(block 30956) failed
[ 241.245583] FAT: Directory bread(block 30957) failed
[ 241.245598] FAT: Directory bread(block 30958) failed
[ 241.245612] FAT: Directory bread(block 30959) failed
[ 241.245741] FAT: Directory bread(block 30944) failed
[ 241.245757] FAT: Directory bread(block 30945) failed
[ 241.245772] FAT: Directory bread(block 30946) failed
[ 241.245786] FAT: Directory bread(block 30947) failed
[ 241.245800] FAT: Directory bread(block 30948) failed
[ 241.245815] FAT: Directory bread(block 30949) failed
[ 241.245829] FAT: Directory bread(block 30950) failed
[ 241.245844] FAT: Directory bread(block 30951) failed
[ 241.245858] FAT: Directory bread(block 30952) failed
[ 241.245872] FAT: Directory bread(block 30953) failed
[ 241.245887] FAT: Directory bread(block 30954) failed
[ 241.245901] FAT: Directory bread(block 30955) failed
[ 241.245915] FAT: Directory bread(block 30956) failed
[ 241.245930] FAT: Directory bread(block 30957) failed
[ 241.245944] FAT: Directory bread(block 30958) failed
[ 241.245958] FAT: Directory bread(block 30959) failed
[ 241.246035] FAT: Directory bread(block 30944) failed
[ 241.246049] FAT: Directory bread(block 30945) failed
[ 241.246064] FAT: Directory bread(block 30946) failed
[ 241.246078] FAT: Directory bread(block 30947) failed
[ 241.246092] FAT: Directory bread(block 30948) failed
[ 241.246106] FAT: Directory bread(block 30949) failed
[ 241.246120] FAT: Directory bread(block 30950) failed
[ 241.246135] FAT: Directory bread(block 30951) failed
[ 241.246149] FAT: Directory bread(block 30952) failed
[ 241.246163] FAT: Directory bread(block 30953) failed
[ 241.246177] FAT: Directory bread(block 30954) failed
[ 241.246191] FAT: Directory bread(block 30955) failed
[ 241.246206] FAT: Directory bread(block 30956) failed
[ 241.246220] FAT: Directory bread(block 30957) failed
[ 241.246234] FAT: Directory bread(block 30958) failed
[ 241.246248] FAT: Directory bread(block 30959) failed
[ 255.244064] usb 1-2: device descriptor read/64, error -110
[ 270.464088] usb 1-2: device descriptor read/64, error -110
[ 270.680120] usb 1-2: new full speed USB device using uhci_hcd and address 4
[ 285.792091] usb 1-2: device descriptor read/64, error -110
[ 301.008068] usb 1-2: device descriptor read/64, error -110
[ 301.224098] usb 1-2: new full speed USB device using uhci_hcd and address 5
[ 311.632213] usb 1-2: device not accepting address 5, error -110
[ 311.744098] usb 1-2: new full speed USB device using uhci_hcd and address 6
[ 322.152080] usb 1-2: device not accepting address 6, error -110
[ 322.152114] hub 1-0:1.0: unable to enumerate USB device on port 2
[ 417.896741] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
