UAVpilot писал(а):Уже в PCI конфликты исправных устройств невозможны, а в PCI-Е и неисправных тоже.
И тем не менее:
С Мезой
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
Subsystem: ASUSTeK Computer Inc. P8P67 Deluxe Motherboard
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fa000000-fb0fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff
Capabilities: [88] Subsystem: ASUSTeK Computer Inc. Device 844d
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Kernel driver in use: pcieport
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 3
Memory at fb307000 (64-bit, non-prefetchable) [size=16]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable- Count=1/1 Maskable- 64bit+
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at fb306000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci_hcd
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
Subsystem: ASUSTeK Computer Inc. Device 8445
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at fb300000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 844d
Capabilities: [a0] Power Management version 2
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=04, sec-latency=0
Memory behind bridge: fb200000-fb2fffff
00:1c.2 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Prefetchable memory behind bridge: 00000000d2100000-00000000d21fffff
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
00:1c.4 PCI bridge: Intel Corporation 82801 PCI Bridge (rev b5) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: fb100000-fb1fffff
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Memory at fb305000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation H61 Express Chipset Family LPC Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 20
I/O ports at f0d0 [size=8]
I/O ports at f0c0 [size=4]
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=16]
I/O ports at f080 [size=16]
Capabilities: [70] Power Management version 3
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
Flags: medium devsel, IRQ 18
Memory at fb304000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel driver in use: i801_smbus
00:1f.5 IDE interface: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller (rev 05) (prog-if 85 [Master SecO PriO])
I/O ports at f070 [size=8]
I/O ports at f060 [size=4]
I/O ports at f050 [size=8]
I/O ports at f040 [size=4]
I/O ports at f030 [size=16]
I/O ports at f020 [size=16]
01:00.0 VGA compatible controller: NVIDIA Corporation GF108 [GeForce GT 440] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at fb000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nouveau
01:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
03:00.0 PCI bridge: Texas Instruments XIO2001 PCI Express-to-PCI Bridge (prog-if 00 [Normal decode])
Bus: primary=03, secondary=04, subordinate=04, sec-latency=32
Capabilities: [40] Subsystem: Device 0000:0000
Capabilities: [48] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/16 Maskable- 64bit+
Capabilities: [70] Express PCI/PCI-X Bridge, MSI 00
Capabilities: [100] Advanced Error Reporting
04:00.0 DPIO module: Device 2718:5125
Subsystem: Device 2718:5125
Flags: fast devsel, IRQ 10
Memory at fb200000 (32-bit, non-prefetchable) [size=64K]
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
Subsystem: ASUSTeK Computer Inc. P8P67 and other motherboards
Flags: bus master, fast devsel, latency 0, IRQ 18
I/O ports at d000 [size=256]
Memory at d2104000 (64-bit, prefetchable) [size=4K]
Memory at d2100000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: r8169
07:00.0 Serial controller: NetMos Technology PCIe 9922 Multi-I/O Controller (prog-if 02 [16550])
Subsystem: Device a000:1000
Flags: fast devsel, IRQ 16
I/O ports at c010 [disabled] [size=8]
[virtual] Memory at fb103000 (32-bit, non-prefetchable) [size=4K]
[virtual] Memory at fb102000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Legacy Endpoint, MSI 00
Capabilities: [800] Advanced Error Reporting
Kernel driver in use: serial
07:00.1 Serial controller: NetMos Technology PCIe 9922 Multi-I/O Controller (prog-if 02 [16550])
Flags: fast devsel, IRQ 17
I/O ports at c000 [disabled] [size=8]
[virtual] Memory at fb101000 (32-bit, non-prefetchable) [size=4K]
[virtual] Memory at fb100000 (32-bit, non-prefetchable) [size=4K]
Без Мезы
Memory at fb207000 (64-bit, non-prefetchable) [size=16]
Memory at fb206000 (32-bit, non-prefetchable) [size=1K]
Memory at fb200000 (64-bit, non-prefetchable) [size=16K]
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory at fb205000 (32-bit, non-prefetchable) [size=1K]
Memory at fb204000 (64-bit, non-prefetchable) [size=256]
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
06:00.0 Serial controller: NetMos Technology PCIe 9922 Multi-I/O Controller (prog-if 02 [16550])
I/O ports at c010 [size=8]
06:00.1 Serial controller: NetMos Technology PCIe 9922 Multi-I/O Controller (prog-if 02 [16550])
I/O ports at c000 [size=8]
И, что любопытно, команда
cnc2@debian-cnc:~/linuxcnc/SERPORT$ sudo sh -c "echo 1 >/sys/bus/pci/devices/0000:07:00.0/enable"
sh: 1: cannot create /sys/bus/pci/devices/0000:07:00.0/enable: Directory nonexistent
без Мезы вот так ругается. А с Мезой - выполняется молча. Но без результата.
PS: всё это для меня представляет пока что академический интерес, т.к. использовать одновременно Mesa и COM-порты не планирую. Но на будущее хотелось бы разобраться.
