(P_CONTOUR4.TAP)
(06-MAR-2017)
#12=1 (задание кол-ва повторов по X)
#13=0 (задание смещения по X мм)
#14=1 (задание кол-ва повторов по Y)
#15=0 (задание смещения по Y мм)
G90 G21 G49 G0 ( ABS mm clr_Z_offset rapid_motion )
(MSG, Установи T2.
M9 (turn all coolant off)
o100 call (o100 - первый замер, o101 - следующий замер.)
o106 repeat [#14] (Повтор ... раз по Y)
o105 repeat [#12] (Повтор ... раз по X)
S3500 M3
G0 X30.062 Y16.659 Z120.
(P-CONTOUR4 - POCKET)
X30.062 Y16.659 Z25.
Z2.
G1 X27.987 Y12.209 Z1.833 F300
X30.062 Y16.659 Z1.667
X27.987 Y12.209 Z1.5
X30.062 Y16.659 Z1.333
X27.987 Y12.209 Z1.167
X30.062 Y16.659 Z1.
X27.987 Y12.209 Z0.833
X30.062 Y16.659 Z0.667
X27.987 Y12.209 Z0.5
X30.062 Y16.659 Z0.333
X27.987 Y12.209 Z0.167
X30.062 Y16.659 Z0.
X27.987 Y12.209 Z-0.167
X30.062 Y16.659 Z-0.333
X27.987 Y12.209 Z-0.5
X30.062 Y16.659 F1000
G2 X34.083 Y19.081 R6.7
G1 X28.898 Y35.405
X24.896
G2 X27.035 Y34.111 R11.069
X27.044 Y34.104 R1.9
X28.341 Y32.902 R10.513
X28.344 Y32.899 R1.9
X30.304 Y29.852 R11.019
X31.131 Y27.226 R13.034
X31.461 Y24.544 R16.629
X31.483 Y23.58 R20.751
X31.277 Y20.639 R20.556
X31.275 Y20.63 R1.9
X30.578 Y17.848 R14.526
X30.573 Y17.836 R1.9
X30.062 Y16.659 R11.033
X29.348 Y15.446 R11.033
X29.343 Y15.438 R1.9
X26.086 Y12.469 R9.616
X23.561 Y11.427 R11.357
X21.002 Y10.936 R14.777
X18.781 Y10.821 R19.799
G1 X14.031
G2 X12.131 Y12.721 R1.9
G1 Y34.695
G2 X12.269 Y35.405 R1.9
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G2 X14.031 Y36.595 R1.9
G1 X18.835
G2 X21.599 Y36.384 R17.764
X21.609 Y36.382 R1.9
X24.114 Y35.729 R13.533
X24.122 Y35.726 R1.9
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G2 X17.999 Y10.366 R5.1
G3 X19.386 Y10.395 R32.359
G2 X19.403 Y10.395 R5.1
G3 X22.276 Y10.67 R25.663
G2 X22.292 Y10.672 R5.1
G3 X24.845 Y11.235 R19.011
G2 X24.866 Y11.241 R5.1
G3 X27.21 Y12.153 R14.099
G2 X27.229 Y12.163 R5.1
G3 X29.602 Y13.728 R11.244
X31.146 Y15.438 R9.683
G2 X36.263 Y17.505 R5.1
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G3 X14.031 Y10.821 R1.9
G1 X18.781
G3 X21.002 Y10.936 R19.799
X23.561 Y11.427 R14.777
X26.086 Y12.469 R11.357
X29.343 Y15.438 R9.616
X29.348 Y15.446 R1.9
X30.573 Y17.836 R11.033
X30.578 Y17.848 R1.9
X31.275 Y20.63 R14.526
X31.277 Y20.639 R1.9
X31.483 Y23.58 R20.556
X31.461 Y24.544 R20.751
X31.424 Y25.167 R16.629
G1 X36.531 Y27.23
X40.571 Y14.514
G3 X44.191 Y14.51 R1.9
G1 X49.997 Y32.67
X55.783 Y35.008
G2 X56.643 Y35.357 R3.5
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G2 X59.318 Y32.572 R1.9
G1 X63.745 Y19.364
G2 X62.677 Y17.008 R1.9
G1 X64.374
G2 X66.208 Y16.667 R5.1
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G2 X50.447 Y17.008 R5.1
G1 X52.251
G2 X51.187 Y19.377 R1.9
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G2 X61.944 Y16.861 R1.9
G1 X52.984
G1 X55.72 Y32.584
G2 X56.576 Y33.618 R1.9
G1 X56.571 Y33.627
X56.342 Y33.473
G3 X55.818 Y32.841 R1.91
G1 X44.384 Y10.398
G2 X44.306 Y10.366 R5.1
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G2 X39.046 Y14.029 R3.5
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G2 X17.998 Y8.766 R3.5
G3 X19.453 Y8.796 R33.959
G2 X19.465 Y8.797 R3.5
G3 X22.517 Y9.088 R27.263
G2 X22.528 Y9.09 R3.5
G3 X25.296 Y9.7 R20.611
G2 X25.31 Y9.704 R3.5
G3 X27.921 Y10.72 R15.699
G2 X27.934 Y10.726 R3.5
G3 X30.649 Y12.518 R12.844
X32.452 Y14.514 R11.283
G2 X38.605 Y13.678 R3.5
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G2 X50.447 Y15.408 R3.5
G1 X64.374
G2 X67.653 Y13.132 R3.5
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G2 X43.756 Y11.87 R3.5
G1 X43.127 Y13.341
G2 X40.571 Y14.514 R1.9
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G3 X19.521 Y7.198 R35.559
G2 X19.527 Y7.198 R1.9
G3 X22.759 Y7.506 R28.863
G2 X22.764 Y7.506 R1.9
G3 X25.748 Y8.165 R22.211
G2 X25.755 Y8.168 R1.9
G3 X28.631 Y9.286 R17.299
G2 X28.638 Y9.29 R1.9
G3 X31.696 Y11.308 R14.444
X33.759 Y13.591 R12.883
G2 X37.099 Y13.137 R1.9
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G2 X50.447 Y13.808 R1.9
G1 X64.374
G2 X66.154 Y12.572 R1.9
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G2 X43.127 Y13.341 R1.9
G1 X43.01 Y13.617
G2 X40.857 Y14.604 R1.6
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G3 X19.534 Y6.898 R35.859
G2 X19.539 Y6.898 R1.6
G3 X22.804 Y7.21 R29.163
G2 X22.809 Y7.21 R1.6
G3 X25.832 Y7.877 R22.511
G2 X25.839 Y7.879 R1.6
G3 X28.765 Y9.018 R17.599
G2 X28.771 Y9.021 R1.6
G3 X31.893 Y11.081 R14.744
X34.004 Y13.418 R13.183
G2 X36.817 Y13.036 R1.6
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G2 X50.447 Y13.508 R1.6
G1 X64.374
G2 X65.873 Y12.467 R1.6
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G2 X43.01 Y13.617 R1.6
G3 X43.216 Y13.724 R1.6
G1 X51.562 Y18.027
G2 X51.471 Y19.28 R1.6
G1 X56.003 Y32.487
G2 X59.034 Y32.476 R1.6
G1 X63.461 Y19.269
G2 X61.944 Y17.161 R1.6
G1 X52.984
G2 X51.562 Y18.027 R1.6
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
G2 X30.98 Y20.682 R20.256
X30.98 Y20.674 R1.6
X30.296 Y17.95 R14.226
X30.292 Y17.939 R1.6
X29.1 Y15.614 R10.733
X29.096 Y15.608 R1.6
X25.94 Y12.731 R9.316
X23.479 Y11.716 R11.057
X20.971 Y11.235 R14.477
X18.781 Y11.121 R19.499
G1 X14.031
G2 X12.431 Y12.721 R1.6
G1 Y34.695
G2 X14.031 Y36.295 R1.6
G1 X18.835
G2 X21.553 Y36.087 R17.464
X21.561 Y36.086 R1.6
X24.011 Y35.447 R13.233
X24.018 Y35.445 R1.6
X26.852 Y33.874 R10.769
X26.86 Y33.868 R1.6
X28.12 Y32.7 R10.213
X28.122 Y32.697 R1.6
X30.029 Y29.733 R10.719
X30.837 Y27.166 R12.734
X31.161 Y24.531 R16.329
X31.183 Y23.58 R20.451
X30.999 Y20.819 R20.256
G3 X31.389 Y19.339 R2.
G1 X32.981 Y20.55
G0 Z25.
X30.062 Y16.659
Z1.5
G1 X27.987 Y12.209 Z1.333 F300
X30.062 Y16.659 Z1.167
X27.987 Y12.209 Z1.
X30.062 Y16.659 Z0.833
X27.987 Y12.209 Z0.667
X30.062 Y16.659 Z0.5
X27.987 Y12.209 Z0.333
X30.062 Y16.659 Z0.167
X27.987 Y12.209 Z0.
X30.062 Y16.659 Z-0.167
X27.987 Y12.209 Z-0.333
X30.062 Y16.659 Z-0.5
X27.987 Y12.209 Z-0.667
X30.062 Y16.659 Z-0.833
X27.987 Y12.209 Z-1.
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X30.062 Y16.659
Z1.
G1 X27.987 Y12.209 Z0.833 F300
X30.062 Y16.659 Z0.
X30.062 Y16.659 Z-0.667
X27.987 Y12.209 Z-0.833
X30.062 Y16.659 Z-1.
X27.987 Y12.209 Z-1.167
X30.062 Y16.659 Z-1.333
X27.987 Y12.209 Z-1.5
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X30.062 Y16.659
Z0.5
G1 X27.987 Y12.209 Z0.333 F300
X27.987 Y12.209 Z0.
X30.062 Y16.659 Z-1.167
X27.987 Y12.209 Z-1.333
X30.062 Y16.659 Z-1.5
X27.987 Y12.209 Z-1.667
X30.062 Y16.659 Z-1.833
X27.987 Y12.209 Z-2.
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X30.062 Y16.659
Z0.
G1 X27.987 Y12.209 Z-0.167 F300
X30.062 Y16.659 Z-1.667
X27.987 Y12.209 Z-1.833
X30.062 Y16.659 Z-2.
X27.987 Y12.209 Z-2.167
X30.062 Y16.659 Z-2.333
X27.987 Y12.209 Z-2.5
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X27.987 Y12.209
Z-0.5
G1 X30.062 Y16.659 Z-0.668 F300
X27.987 Y12.209 Z-0.836
X30.062 Y16.659 Z-1.004
X27.987 Y12.209 Z-1.171
X30.062 Y16.659 Z-1.339
X27.987 Y12.209 Z-1.507
X30.062 Y16.659 Z-1.675
X27.987 Y12.209 Z-1.843
X30.062 Y16.659 Z-2.011
X27.987 Y12.209 Z-2.179
X30.062 Y16.659 Z-2.346
X27.987 Y12.209 Z-2.514
X30.062 Y16.659 Z-2.682
X27.987 Y12.209 Z-2.85
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X30.062 Y16.659
Z-0.85
G1 X27.987 Y12.209 Z-1.015 F300
X30.062 Y16.659 Z-1.181
X27.987 Y12.209 Z-1.346
X30.062 Y16.659 Z-1.512
X27.987 Y12.209 Z-1.677
X30.062 Y16.659 Z-1.842
X27.987 Y12.209 Z-2.008
X30.062 Y16.659 Z-2.173
X27.987 Y12.209 Z-2.338
X30.062 Y16.659 Z-2.504
X27.987 Y12.209 Z-2.669
X30.062 Y16.659 Z-2.835
X27.987 Y12.209 Z-3.
G1 X28.898 Y35.405
X24.896
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y34.695
G1 X11.965
Y11.966
X12.288
G1 Y34.695
G1 X18.835
X31.275 Y20.63 R1.9
G1 X14.031
G1 Y16.659
X10.365
Y10.366
X17.996
G1 X30.069 Y37.005
X10.365
Y16.659
X12.131 Y17.372
Y12.721
G1 X18.781
G1 X36.531 Y27.23
X40.571 Y14.514
G1 X49.997 Y32.67
X55.783 Y35.008
G1 X56.623 Y35.405
X55.91
X55.783 Y35.008
X56.576 Y33.618
G1 X63.745 Y19.364
G1 X64.374
G1 X57.687 Y37.005
X54.742
X48.179 Y16.476
G1 X52.251
G1 X55.72 Y32.584
G1 X63.745 Y19.364
G1 X52.984
G1 X55.72 Y32.584
G1 X56.571 Y33.627
X56.342 Y33.473
G1 X44.384 Y10.398
G1 X44.371
X44.384 Y10.398
X43.756 Y11.87
G1 X31.239 Y38.605
X8.765
Y8.766
X17.996
G1 X40.37 Y8.766
X45.465
X47.186 Y13.18
G1 X64.374
G1 X69.283 Y8.766
X71.253
X58.752 Y38.605
X53.574
X45.715 Y14.023
G1 X43.127 Y13.341
G1 X32.41 Y40.205
X7.165
Y7.166
X17.996
G1 X39.244 Y7.166
X46.558
X48.677 Y12.598
G1 X64.374
G1 X68.172 Y7.166
X73.658
X59.816 Y40.205
X52.405
X44.191 Y14.51
G1 X43.01 Y13.617
G1 X32.629 Y40.505
X6.865
Y6.866
X17.996
G1 X39.033 Y6.866
X46.763
X48.957 Y12.489
G1 X64.374
G1 X67.964 Y6.866
X74.109
X60.016 Y40.505
X52.186
X43.905 Y14.602
G1 X51.562 Y18.027
G1 X56.003 Y32.487
G1 X63.461 Y19.269
G1 X52.984
G1 X45.274 Y18.881
X43.905 Y14.602
G1 X39.238 Y19.701
X30.999 Y20.819
X30.98 Y20.674 R1.6
G1 X14.031
G1 Y34.695
G1 X18.835
X26.86 Y33.868 R1.6
G1 X32.981 Y20.55
G0 Z25.
X90.117 Y23.929
Z2.
G1 X85.244 Y24.527 Z1.833 F300
X90.117 Y23.929 Z1.667
X85.244 Y24.527 Z1.5
X90.117 Y23.929 Z1.333
X85.244 Y24.527 Z1.167
X90.117 Y23.929 Z1.
X85.244 Y24.527 Z0.833
X90.117 Y23.929 Z0.667
X85.244 Y24.527 Z0.5
X90.117 Y23.929 Z0.333
X85.244 Y24.527 Z0.167
X90.117 Y23.929 Z0.
X85.244 Y24.527 Z-0.167
X90.117 Y23.929 Z-0.333
X85.244 Y24.527 Z-0.5
X90.117 Y23.929 F1000
X92.837
Y24.64
X87.398
G2 X85.498 Y26.54 R1.9
G1 Y31.598
X84.536
Y26.54
G2 X82.636 Y24.64 R1.9
G1 X77.198
Y23.929
X82.636
G2 X84.536 Y22.029 R1.9
G1 Y16.975
X85.498
Y22.029
G2 X87.398 Y23.929 R1.9
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G2 X85.798 Y26.54 R1.6
G1 Y31.898
X84.236
Y26.54
G2 X82.636 Y24.94 R1.6
G1 X76.898
Y23.629
X82.636
G2 X84.236 Y22.029 R1.6
G1 Y16.675
X85.798
Y22.029
G2 X87.398 Y23.629 R1.6
G1 X90.117
G3 X90.825 Y23.922 R1.
G1 X90.117 Y24.629
G0 Z25.
Y23.929
Z1.5
G1 X85.244 Y24.527 Z1.333 F300
X90.117 Y23.929 Z1.167
X85.244 Y24.527 Z1.
X90.117 Y23.929 Z0.833
X85.244 Y24.527 Z0.667
X90.117 Y23.929 Z0.5
X85.244 Y24.527 Z0.333
X90.117 Y23.929 Z0.167
X85.244 Y24.527 Z0.
X90.117 Y23.929 Z-0.167
X85.244 Y24.527 Z-0.333
X90.117 Y23.929 Z-0.5
X85.244 Y24.527 Z-0.667
X90.117 Y23.929 Z-0.833
X85.244 Y24.527 Z-1.
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
Y23.929
Z1.
G1 X85.244 Y24.527 Z0.833 F300
X90.117 Y23.929 Z0.
X90.117 Y23.929 Z-0.667
X85.244 Y24.527 Z-0.833
X90.117 Y23.929 Z-1.
X85.244 Y24.527 Z-1.167
X90.117 Y23.929 Z-1.333
X85.244 Y24.527 Z-1.5
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
Y23.929
Z0.5
G1 X85.244 Y24.527 Z0.333 F300
X85.244 Y24.527 Z0.
X90.117 Y23.929 Z-1.167
X85.244 Y24.527 Z-1.333
X90.117 Y23.929 Z-1.5
X85.244 Y24.527 Z-1.667
X90.117 Y23.929 Z-1.833
X85.244 Y24.527 Z-2.
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
Y23.929
Z0.
G1 X85.244 Y24.527 Z-0.167 F300
X90.117 Y23.929 Z-1.667
X85.244 Y24.527 Z-1.833
X90.117 Y23.929 Z-2.
X85.244 Y24.527 Z-2.167
X90.117 Y23.929 Z-2.333
X85.244 Y24.527 Z-2.5
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
X85.244 Y24.527
Z-0.5
G1 X90.117 Y23.929 Z-0.668 F300
X85.244 Y24.527 Z-0.836
X90.117 Y23.929 Z-1.004
X85.244 Y24.527 Z-1.171
X90.117 Y23.929 Z-1.339
X85.244 Y24.527 Z-1.507
X90.117 Y23.929 Z-1.675
X85.244 Y24.527 Z-1.843
X90.117 Y23.929 Z-2.011
X85.244 Y24.527 Z-2.179
X90.117 Y23.929 Z-2.346
X85.244 Y24.527 Z-2.514
X90.117 Y23.929 Z-2.682
X85.244 Y24.527 Z-2.85
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
Y23.929
Z-0.85
G1 X85.244 Y24.527 Z-1.015 F300
X90.117 Y23.929 Z-1.181
X85.244 Y24.527 Z-1.346
X90.117 Y23.929 Z-1.512
X85.244 Y24.527 Z-1.677
X90.117 Y23.929 Z-1.842
X85.244 Y24.527 Z-2.008
X90.117 Y23.929 Z-2.173
X85.244 Y24.527 Z-2.338
X90.117 Y23.929 Z-2.504
X85.244 Y24.527 Z-2.669
X90.117 Y23.929 Z-2.835
X85.244 Y24.527 Z-3.
X92.837
Y24.64
X87.398
G1 Y31.598
X84.536
Y26.54
G1 X77.198
Y23.929
X82.636
G1 Y16.975
X85.498
Y22.029
G1 X90.117
Y23.629
X93.137
Y24.94
X87.398
G1 Y31.898
X84.236
Y26.54
G1 X76.898
Y23.629
X82.636
G1 Y16.675
X85.798
Y22.029
G1 X90.117
G1 X90.117 Y24.629
G0 Z25.
g0 x0 y0 (В конце программы повтора на 0 координат!)
g92 x-#13 (Сдвиг по X)
o105 endrepeat
g92.1 (Отмена офсетов по G92)
g90
g92 y-#15 (Сдвиг по Y)
o106 endrepeat
g90
M30
( ИНСТРУМЕНТОВ 1 шт. )
( T2.
( Processed by postprocessor v.1.03 )
( ©GSElabs, 2013 )
https://github.com/G-S-E )
