Страница 1 из 42
Latency-test показания на разных материнских платах
Добавлено: 10 авг 2011, 14:03
Предлагаю в эту тему складывать результаты latency-test на различных компьютерах.
Формат:
Краткая характеристика: ASUS AT5NM10-I, Intel Atom D510 1.66GHz, N10 Family Integrated Graphics Controller
Latency:
  • Max jitter Base thread: 10 506 ns
  • Max jitter Servo thread: 13 346 ns
Полная характеристика:
sudo dmidecode | grep "Base Board Information" -A20
sudo lshw -sanitize
sudo lshw -sanitize -short
Base Board Information (Эта вовод от другой платы, для примера)
	Manufacturer: ASUSTeK Computer INC.
	Product Name: P8H67-M PRO
	Version: Rev 1.xx
	Serial Number: MF70ABG03801281
	Asset Tag: To be filled by O.E.M.
	Features:
		Board is a hosting board
		Board is replaceable
	Location In Chassis: To be filled by O.E.M.
	Chassis Handle: 0x0003
	Type: Motherboard
	Contained Object Handles: 0
computer
    description: Computer
    width: 32 bits
  *-core
       description: Motherboard
       physical id: 0
     *-memory
          description: System memory
          physical id: 0
     *-cpu
          product: Intel(R) Atom(TM) CPU D510   @ 1.66GHz
          vendor: Intel Corp.
          physical id: 1
          bus info: cpu@0
          version: 6.12.10
          serial: [REMOVED]
          width: 64 bits
          capabilities: fpu fpu_exception wp vme de tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx x86-64 constant_tsc arch_perfmon pebs bts aperfmperf pni dtes64 monitor ds_cpl tm2 ssse3 cx16 xtpr pdcm movbe lahf_lm pse
          configuration: id=1
        *-logicalcpu:0
             description: Logical CPU
             physical id: 1.1
             width: 64 bits
             capabilities: logical
        *-logicalcpu:1
             physical id: 1.2
             width: 64 bits
        *-logicalcpu:2
             physical id: 1.3
             width: 64 bits
        *-logicalcpu:3
             physical id: 1.4
             width: 64 bits
     *-pci
          description: Host bridge
          product: N10 Family DMI Bridge
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 02
          width: 32 bits
          clock: 33MHz
          configuration: driver=agpgart-intel
          resources: irq:0
        *-display:0
             description: VGA compatible controller
             product: N10 Family Integrated Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:27 memory:fbd80000-fbdfffff ioport:d400(size=8) memory:d0000000-dfffffff(prefetchable) memory:fbc00000-fbcfffff
        *-display:1 UNCLAIMED
             description: Display controller
             physical id: 2.1
             bus info: pci@0000:00:02.1
             version: 02
             width: 32 bits
             clock: 33MHz
             configuration: latency=0
             resources: memory:fbe00000-fbe7ffff
        *-multimedia
             description: Audio device
             product: N10/ICH 7 Family High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 02
             width: 64 bits
             clock: 33MHz
             configuration: driver=HDA Intel latency=0
             resources: irq:16 memory:fbef8000-fbefbfff
        *-pci:0
             description: PCI bridge
             product: N10/ICH 7 Family PCI Express Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: pci bus_master cap_list
             configuration: driver=pcieport
             resources: irq:24 ioport:1000(size=4096) memory:40000000-401fffff memory:40200000-403fffff(prefetchable)
        *-pci:1
             product: N10/ICH 7 Family PCI Express Port 2
             physical id: 1c.1
             bus info: pci@0000:00:1c.1
             version: 02
             width: 32 bits
             clock: 33MHz
             resources: irq:25 ioport:e000(size=4096) memory:fbf00000-fbffffff ioport:faf00000(size=1048576)
           *-network
                description: Ethernet interface
                product: RTL8111/8168B PCI Express Gigabit Ethernet controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth0
                version: 03
                serial: [REMOVED]
                width: 64 bits
                clock: 33MHz
                capabilities: bus_master cap_list rom ethernet physical
                configuration: broadcast=yes driver=r8169 driverversion=2.3LK-NAPI ip=[REMOVED] latency=0 multicast=yes
                resources: irq:26 ioport:e800(size=256) memory:fafff000-faffffff(prefetchable) memory:faff8000-faffbfff(prefetchable) memory:faf00000-faf0ffff(prefetchable)
        *-usb:0
             description: USB Controller
             product: N10/ICH7 Family USB UHCI Controller #1
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 02
             width: 32 bits
             clock: 33MHz
             configuration: driver=uhci_hcd latency=0
             resources: irq:23 ioport:d480(size=32)
        *-usb:1
             product: N10/ICH 7 Family USB UHCI Controller #2
             physical id: 1d.1
             bus info: pci@0000:00:1d.1
             version: 02
             width: 32 bits
             clock: 33MHz
             resources: irq:19 ioport:d800(size=32)
        *-usb:2
             product: N10/ICH 7 Family USB UHCI Controller #3
             physical id: 1d.2
             bus info: pci@0000:00:1d.2
             version: 02
             width: 32 bits
             clock: 33MHz
             resources: irq:18 ioport:d880(size=32)
        *-usb:3
             product: N10/ICH 7 Family USB UHCI Controller #4
             physical id: 1d.3
             bus info: pci@0000:00:1d.3
             version: 02
             width: 32 bits
             clock: 33MHz
             resources: irq:16 ioport:dc00(size=32)
        *-usb:4
             product: N10/ICH 7 Family USB2 EHCI Controller
             physical id: 1d.7
             bus info: pci@0000:00:1d.7
             version: 02
             width: 32 bits
             clock: 33MHz
             configuration: driver=ehci_hcd latency=0
             resources: irq:23 memory:fbeffc00-fbefffff
        *-pci:2
             product: 82801 Mobile PCI Bridge
             physical id: 1e
             bus info: pci@0000:00:1e.0
             version: e2
             width: 32 bits
             clock: 33MHz
        *-isa
             description: ISA bridge
             product: NM10 Family LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 02
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
        *-ide
             description: IDE interface
             product: N10/ICH7 Family SATA IDE Controller
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 02
             width: 32 bits
             clock: 66MHz
             capabilities: ide bus_master cap_list
             configuration: driver=ata_piix latency=0
             resources: irq:19 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff90(size=16) memory:40400000-404003ff
        *-serial UNCLAIMED
             description: SMBus
             product: N10/ICH 7 Family SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 02
             width: 32 bits
             clock: 33MHz
             resources: ioport:400(size=32)
  *-scsi
       physical id: 1
       bus info: scsi@2
       logical name: scsi2
       capabilities: scsi-host
       configuration: driver=usb-storage
00:00.0 Host bridge: Intel Corporation N10 Family DMI Bridge (rev 02)
00:02.0 VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:02.1 Display controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 02)
00:1d.0 USB Controller: Intel Corporation N10/ICH7 Family USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation NM10 Family LPC Controller (rev 02)
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA IDE Controller (rev 02)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 02)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
Скориншот (опционально):
Screenshot-1.png (27574 просмотра) <a class='original' href='./download/file.php?id=1930&sid=8028c266ff7607c4a0899c3ffee8d869&mode=view' target=_blank>Загрузить оригинал (739.15 КБ)</a>
Шаблон для создания сообщений
[b]Краткая характеристика:[/b]
[b]Latency:[/b][list][*][b]Max jitter Base thread:[/b]      ns
[*][b]Max jitter Servo thread:[/b]      ns[/list][b]Полная характеристика:[/b]
[code]
sudo lshw -sanitize
[/code]
Re: latency-tests results
Добавлено: 15 авг 2011, 06:45
намбаван
Краткая характеристика: P4S5A/DX+,celeron 2000,GeForce4 MX 440
Latency:
  • Max jitter Base thread: 22303 ns
  • Max jitter Servo thread: 21954 ns
computer
    description: Desktop Computer
    product: P4S5A/DX+
    vendor: ECS
    version: 1.0
    serial: [REMOVED]
    width: 32 bits
    capabilities: smbios-2.3 dmi-2.3
    configuration: chassis=desktop
  *-core
       product: P4S5A/DX+
       vendor: ECS
       physical id: 0
       version: 1.0
       serial: [REMOVED]
     *-firmware
          description: BIOS
          vendor: American Megatrends Inc.
          physical id: 0
          version: 07.00T (04/02/01)
          capacity: 192KiB
          capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int17printer int10video acpi usb agp ls120boot zipboot biosbootspecification
     *-cpu
          description: CPU
          product: Intel(R) Celeron(R) CPU 2.00GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: 15.2.7
          slot: Slot-1
          width: 32 bits
          clock: 100MHz
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe up pebs bts cid
          configuration: id=0
        *-cache:0
             description: L1 cache
             physical id: 5
             slot: Internal Cache
             capacity: 1MiB
             clock: 25MHz (40.0ns)
             capabilities: pipeline-burst synchronous internal write-back data
        *-cache:1
             description: L2 cache
             physical id: 6
             capacity: 1MiB
             capabilities: synchronous internal write-back unified
     *-memory
          physical id: 1
     *-pci
          product: SiS645DX Host & Memory & AGP Controller
          vendor: Silicon Integrated Systems [SiS]
          physical id: 100
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=agpgart-sis latency=32
          resources: irq:0 memory:e0000000-e3ffffff
        *-pci
             product: Virtual PCI-to-PCI bridge (AGP)
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: memory:ddd00000-dfefffff memory:cd900000-ddbfffff(prefetchable)
           *-display
                product: NV17 [GeForce4 MX 440]
                vendor: nVidia Corporation
                physical id: 0
                bus info: pci@0000:01:00.0
                version: a3
                width: 32 bits
                clock: 66MHz
                capabilities: pm agp agp-2.0 bus_master cap_list rom
                configuration: driver=nouveau latency=64 maxlatency=1 mingnt=5
                resources: irq:5 memory:de000000-deffffff memory:d0000000-d7ffffff(prefetchable) memory:ddb80000-ddbfffff(prefetchable) memory:dfee0000-dfefffff(prefetchable)
        *-isa
             product: SiS962 [MuTIOL Media IO]
             physical id: 2
             version: 04
             width: 32 bits
             clock: 33MHz
        *-serial UNCLAIMED
             description: SMBus
             product: SiS961/2 SMBus Controller
             physical id: 2.1
             version: 00
             width: 32 bits
             clock: 33MHz
             resources: ioport:c00(size=32)
        *-ide
             product: 5513 [IDE]
             physical id: 2.5
             bus info: pci@0000:00:02.5
             logical name: scsi0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: ide bus_master emulated
             configuration: driver=pata_sis latency=128
             resources: irq:0 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff00(size=16)
           *-cdrom
                description: DVD writer
                product: DVD_RW ND-3550A
                vendor: _NEC
                physical id: 0.0.0
                bus info: scsi@0:0.0.0
                logical name: /dev/cdrom
                logical name: /dev/cdrw
                logical name: /dev/dvd
                logical name: /dev/dvdrw
                logical name: /dev/scd0
                logical name: /dev/sr0
                version: 1.05
                serial: [REMOVED]
                capabilities: removable audio cd-r cd-rw dvd dvd-r
                configuration: ansiversion=5 status=nodisc
           *-disk
                description: ATA Disk
                product: ST340014A
                vendor: Seagate
                physical id: 0.1.0
                bus info: scsi@0:0.1.0
                logical name: /dev/sda
                version: 3.54
                serial: [REMOVED]
                capabilities: partitioned partitioned:dos
                configuration: ansiversion=5 signature=0af80af8
              *-volume:0
                   description: Windows NTFS volume
                   physical id: 1
                   bus info: scsi@0:0.1.0,1
                   logical name: /dev/sda1
                   logical name: /host
                   version: 3.1
                   serial: [REMOVED]
                   capacity: 10001MiB
                   capabilities: primary bootable ntfs initialized
                   configuration: clustersize=4096 created=2002-12-11 12:32:19 filesystem=ntfs mount.fstype=fuseblk mount.options=rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096 state=mounted
              *-volume:1
                   description: Extended partition
                   physical id: 2
                   bus info: scsi@0:0.1.0,2
                   logical name: /dev/sda2
                   capacity: 27GiB
                   capabilities: primary extended partitioned partitioned:extended
                 *-logicalvolume
                      description: HPFS/NTFS partition
                      physical id: 5
                      logical name: /dev/sda5
                      capacity: 27GiB
        *-multimedia
             description: Multimedia audio controller
             product: AC'97 Sound Controller
             physical id: 2.7
             bus info: pci@0000:00:02.7
             version: a0
             width: 32 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=Intel ICH latency=64 maxlatency=11 mingnt=52
             resources: irq:11 ioport:dc00(size=256) ioport:d800(size=128)
        *-usb:0
             product: USB 1.1 Controller
             physical id: 3
             bus info: pci@0000:00:03.0
             version: 0f
             width: 32 bits
             clock: 33MHz
             configuration: driver=ohci_hcd latency=64 maxlatency=80
             resources: irq:11 memory:dfffd000-dfffdfff
        *-usb:1
             physical id: 3.1
             bus info: pci@0000:00:03.1
             version: 0f
             width: 32 bits
             clock: 33MHz
             resources: irq:11 memory:dfffe000-dfffefff
        *-usb:2
             physical id: 3.2
             bus info: pci@0000:00:03.2
             version: 0f
             width: 32 bits
             clock: 33MHz
             resources: irq:5 memory:dffff000-dfffffff
        *-usb:3
             product: USB 2.0 Controller
             physical id: 3.3
             bus info: pci@0000:00:03.3
             version: 00
             width: 32 bits
             clock: 33MHz
             configuration: driver=ehci_hcd latency=64 maxlatency=80
             resources: irq:11 memory:dffdf000-dffdffff
        *-network
             product: RTL-8139/8139C/8139C+
             physical id: 9
             bus info: pci@0000:00:09.0
             logical name: eth0
             version: 10
             serial: [REMOVED]
             capacity: 100MB/s
             width: 32 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
             configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=64 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10MB/s
             resources: irq:11 ioport:d400(size=256) memory:dfffcf00-dfffcfff
     *-scsi
          physical id: 2
          bus info: usb@1:1
          logical name: scsi2
          capabilities: emulated scsi-host
        *-disk
             description: Windows FAT volume
             vendor: MSDOS5.0
             physical id: 0.0.0
             bus info: scsi@2:0.0.0
             logical name: /dev/sdb
             logical name: /media/4C36-4760
             version: FAT32
             serial: [REMOVED]
             capacity: 15GiB
             capabilities: fat initialized
             configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0077,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,flush,errors=remount-ro signature=6f20736b state=mounted
21975191ce7a.png (27544 просмотра) <a class='original' href='./download/file.php?id=1952&sid=8028c266ff7607c4a0899c3ffee8d869&mode=view' target=_blank>Загрузить оригинал (288.13 КБ)</a>
Добавлено: 15 авг 2011, 13:48
woody
Результаты лучше хранить в виде таблички, причем она уже успешно ведется
http://wiki.linuxcnc.org/emcinfo.pl?Latency-Test
Только обновляется не очень часто.
Погонял домашние компы... самый лучший результат был на ZOTAC GF9300-A-E + Q8400
Следом идет ноутбук на Centrino 1,73 ГГц
А Atom 330 (Intel D945GCLF2)на третьем месте. В 10000 джиттер укладывается.
Пара компов, причем довольно крутых, показали ужасный результат.
Добавлено: 15 авг 2011, 16:33
Табличку я потом сведу, если будет надо.
На linuxCNC табличка не самая удобная - нет сортировки и не совсем понятно каких годов тесты/платы. Иногда по одним только буквам в названии сложно это определить. А когда собираешься выбирать компьютер для EMC2 лучше смотреть тесты на современных моделях, которые можно найти в магазинах.
Добавлено: 20 сен 2011, 13:43
jo_key
Вставлю и свои 5 копеек.
Вчера тестировал плату Asus AT5NM10T-I (Intel Atom D525, Intel NM10, Intel GMA 3150) +2 GB RAM So-Dimm + HDD 80GВ
Значения получил следующие 6346 и 7257. При включенном НТ данные значения выше на 100-120 пунктов
ЕМС2 был обновлен до 2.4.6
Вставить скриншот не могу, но тестировал мин 15
Добавлено: 20 сен 2011, 15:46
PKM
jo_key писал(а):следующие 6346 и 7257
это при запуске нескольких копий glxgears?
jo_key писал(а):тестировал мин 15
надо подольше, часик хотя бы
Добавлено: 20 сен 2011, 16:04
Да, результаты просто отличные. Странно, что у меня на примерно такой же матери они были на уровне 10000-13000.
Добавлено: 21 сен 2011, 12:19
jo_key
Нет, только запущена Лиса с 11 вкладками, да gedit
Давайте отдадим должное, что ЕМС - это стойка, коотрая выполняет ж-код и поэтому что-то запускать неразумно , особенно для данной матери. Хочеться подправить код, пожалуйста на рабочей машине, но не на стойке..
Может я что-то и не так понимаю - поджправьте меняю. Я новичок в этом деле
Добавлено: 21 сен 2011, 12:25
Лучше нагрузить по полной, тогда мы обезопасимся от аварийных ситуаций. Вообще все дополнительный приложения не должны сильно влиять на работу EMC2 - у нее приоритет очень высокий. Но вот некоторые девайсы с хитрыми драйверами могут наговнякать. Например, тот же AXIS пользуется OpenGL для отрисовки траектории инструмента. Поэтому лучше нагрузить компьютер по полной.
Опять же разница между 7000-8000 и 11000-13000 не сильно велика, но она гарантирует нормальную работу станка ;).
Добавлено: 21 сен 2011, 12:26
jo_key
Да , при запуски ролика на ютубе - МаксДжитер вырос до значений 9870\13487
Завтра проверю на ноутбуке HP nx9420 (Core2Duo 1,86 + 2GB)
Подскажите плз методику тестирования: Просто мои понимания - ЕМС - это стойка и она выполняет ж-код. Никакие КАД и КАМ системы не должны стоять в Линухах., ну, может ПДФ запущен должне быть. как шпаргалки ). Т.о. запустить те программы которые будут использованы в работе и запустить тест? я правильно понял? ()
Добавлено: 21 сен 2011, 12:32
Не совсем, лучше загрузить систему по полной, запустить кучу приложений, начать копировать большое количество файлов в несколько потоков, поставить пару-тройку фильмов, и наблюдать за этим :hehehe: как минимум минут 10-15. И вот это значение брать за основу. Оно не должно сильно отличаться от полученного, если не используются новые устройства. Например, если ты запустишь 5 ютубов вместо одного latency не должен сильно возрасти.
Добавлено: 21 сен 2011, 12:43
jo_key
Ну что же, буду тестировать дальше )) хотя атом был тестовый, и его только что забрали ((((( есть желание прикупить данную мамку, ввиду отсутствия вентилятора. в закрытом большом корпусе его температура составила 54*С. что есть нормально )
Спасибо за совет, будем дальше работать над собой
Добавлено: 21 сен 2011, 15:16
Atom - отличная штука, показывает очень хорошие результаты. Для emc2 это лучшее из того, что я видел.
Добавлено: 22 сен 2011, 12:29
jo_key
Было бы классно, если бы были решения на FreandlyARM )
Добавлено: 25 сен 2011, 21:38
jo_key
Так на NX9420 не запустился ЕМС2((( (очень досадно за свой ноут)
тестировалось мин 15 (больше не было времени)
Acer eMachine E642g (Athlon X2 + 4gB + RadeonHD4250) (проигрывылось видео и копировалось файлы в 2 потока, запущенный Firefox и ролик в YouTube) 15412\18591
Lenovo IdeaPad g-550 (Celeron N3100 + 3gB + intel HD4500) (проигрывылось видео и копировалось файлы в 2 потока, запущенный Firefox и ролик в YouTube) 24181\26434
Или в данном случае методика тестирования тоже некорректная
Добавлено: 25 сен 2011, 23:59
PKM
Не пойму, какой смысл ЕМС2 на ноутах запускать? Разве что как симулятор. LPT вряд ли где есть. Но результаты на удивление неплохие.
Добавлено: 26 сен 2011, 00:11
Тут все норм :). А почему не запустился на NX9420, что сказал?
jo_key писал(а):Было бы классно, если бы были решения на FreandlyARM )
Вроде как были потуги и даже есть видео рабочего чуда от украинского магазина. Но нигде не продается http://www.youtube.com/watch?v=_Ti7yJoLla4 ...
Запускал на нетбуке именно как симулятор. Дальше смысла не было, т.к. нет даже express pci
Добавлено: 26 сен 2011, 08:05
jo_key
А ничего не сказала, просто повисла и все, даже на клаву не раеагировала (. Устанавливать не стал
А по поводу Украинского магазина - это http://777.lg.ua , но там как в танке, многие недовольны ими, как и Вантой )))), Лично я не дозвонился им, да и цены у них запредельные (
Добавлено: 26 сен 2011, 08:23
Да-да он самый. Но все таки сделали же, почему не продают :roll:?
Добавлено: 26 сен 2011, 09:30
jo_key
PKM писал(а):Не пойму, какой смысл ЕМС2 на ноутах запускать? Разве что как симулятор. LPT вряд ли где есть. Но результаты на удивление неплохие.
но есть же решения дескотпные на данной логике и там присутствует ЛПТ
Самое интересное, был запушел тест на машине (DualCore E8500 + 4G + Крутая видяха, не посмотрел какая). ТАк вот уже при запуске теста значения джитера были порядка 11000, так это без дополнительных загрузок
