Интересные примеры Gcode и OCode
Темка про интересные GCode / OCode.
Нарезание на токарном накатки через G33.
Код взят здесь: http://forum.linuxcnc.org/forum/show-yo ... -emco-120p
[spoiler=]G8
G53 G0 X0
G53 G0 Z0
M6 T3 G43
#<workpieceDia> = 0.700
#<workpieceRad> = [#<workpieceDia>/2]
#<safeXOffset> = 0.025
#<safeX> = [#<workpieceRad> + #<safeXOffset>]
#<knurlStartZ> = 0.000
#<knurlLen> = 0.25
#<knurlLeadIn> = 0.010
#<knurlDepth> = 0.002
#<knurlPerDia> = 28
#<knurlAngle> = 30
#<knurlEndZ> = [#<knurlStartZ> - #<knurlLen>]
#<rpm> = 100
#<pi> = 3.142
; The surface is the circumference of the workpiece
#<workSurface> = [#<pi> * #<workpieceDia>]
; Given a knurl angle, calculate Z feed given <workSurface>
#<feedPerRev> = [TAN[#<knurlAngle>] * #<workSurface>]
#<feedPerMin> = [#<feedPerRev> * #<rpm>]
(debug, feed per revolution: #<feedPerRev>; per min: #<feedPerMin>)
; thread _width_ is equal to distance traveled in one rev, i.e. <feedPerRev>
#<threadWidth> = #<feedPerRev>
; Thus, TPI will be 1/<threadWidth>
#<tpi> = [1/#<threadWidth>]
; To do a n-start thread, we need to start each thread
; <threadWidth>/n further back (Z+) than the prior thread
#<nStartZOffset> = [#<threadWidth>/#<knurlPerDia>]
M3 S#<rpm>
#100 = #<knurlPerDia>
#110 = [[#<knurlPerDia> * #<nStartZOffset>] + #<knurlStartZ> + #<knurlLeadIn>]
(debug, knurl lead in: #110)
G0 Z#110
G0 X[#<workpieceRad> - #<knurlDepth>]
O100 WHILE [#100 GT 0]
(debug, start Z: #110; feed: #<feedPerRev>)
(calculate the lead in for the knurl AFTER this one)
#105 = #110
#110 = [#110 - #<nStartZOffset>]
;G33 Z#110 K#<feedPerRev>
;G1 Z#<knurlEndZ> F#<feedPerMin>
;G1 Z#105 F#<feedPerMin>
G33 Z#<knurlEndZ> K#<feedPerRev>
G33 Z#105 K#<feedPerRev>
;G0 X#<safeX>
G0 Z#110
;G0 X[#<workpieceRad> - #<knurlDepth>]
#100 = [#100 - 1]
O100 ENDWHILE[/spoiler]
https://www.youtube.com/watch?v=zdCQ0X7b2uo
Re: Интересные примеры Gcode и OCode
Нарезание конусной резьбы:
Взято от сюды http://www.cnc-club.ru/wiki/index.php/% ... 0%BE%D0%B4.
[spoiler=]Taper Thread Subroutine for LinuxCNC)
(Latest source can be found at:)
(http://www.cnc-club.ru/wiki/index.php/Taper_thread_Gcode)
O<taper-thread> SUB
	#<Dst>	= #1
	#<Dend>	= #2
	#<l>	= #3
	#<dx> = [#<Dst>-#<Dend>]
	#<p> 	= SQRT[#4*#4 + #<dx>*#<dx>/4]
	#<step> = [#5/#6]
	#<steps> = #6
	(penetrate agle)
	#<pa> = 30
	#<px> = [#<step>*2]
	#<pz> = [ TAN[#<pa>] * #<px> ]
	#<x> = #<_x>
	#<z> = #<_z>
	#<safe_dist> = 10
	#<i> = #<steps>
	O<taper-thread0> REPEAT [#<steps>]
		G0 X[#<x>+#<safe_dist>]
		G0 Z[#<z> + #<pz>]
		G0 X[#<x>]
		#<i> = [#<i>-1]
		G1 X[#<Dst> + #<i>*#<step> + #<px>]
		G1 X[#<Dst> + #<i>*#<step>] Z[#<z>]
		G33 X[#<Dend> + #<i>*#<step>] Z[#<z>-#<l>] K[#<p>]
	O<taper-thread0> ENDREPEAT
O<taper-thread> ENDSUB
(Параметры)
(1 - начальный диаметр)
(2 - конечный диаметр)
(3 - длинна резьбы)
(4 - шаг резьбы)
(5 - глубина резьбы)
(6 - количество проходов)
(Parameters)
(1 - start dia)
(2 - end dia)
(3 - thread length)
(4 - pitch)
(5 - depth of thread)
(6 - number of passes)
G0 X80
G0 Z50
M3 S150
F100
O<taper-thread> CALL [46] [58] [100] [5] [2.5] [5]
M2[/spoiler]
Нарезание NTP резьбы
(info: NTP Male Threads)
; Assumptions
; Z0 is the end of the pipe
o<ntp>sub
#<tool-taper>      =  #1 (=1 Tool, Taper Cut)
#<max-rpm-taper>   =  #2 (Max RPM, Taper Cut)
#<sfm-taper>       =  #3 (SFM, Taper Cut)
#<ipm-taper>       =  #4 (IPM, Taper Cut)
#<coolant>         =  #5 (=8 Coolant)
#<small-diameter>  =  #6 (Small End Diameter)
#<pipe-OD>         =  #7 (Pipe OD)
#<tool-thread>     =  #8 (=7 Tool, Threading)
#<rpm-threading>   =  #9 (RPM Threading)
#<pitch>           = #10 (Thread Pitch)
#<minor-dia>       = #11 (Z0 Minor Diameter)
#<cut-lenght>      = #12 (Thread Length)
#<cut-depth>       = #13 (Depth of Cut)
G7 G18 G40 G54 (Dia, XZ, Comp Off, CS1)
; Calculate start and end X positions for taper cut
; for 0.1 before and after overlap
#<start-X-taper> = [#<small-diameter> - 0.00625]
#<end-X-taper> = [#<pipe-OD> + 0.00625]
; Calculate end Z position
#<end-Z-taper> = -[[[[#<end-X-taper>-#<small-diameter>]/2] * TAN[88.2101]]+0.1]
; Cut Taper
G96 D#<max-rpm-taper> S#<sfm-taper> (Constance Surface Speed)
T#<tool-taper> M6 G43
G42 (start cutter comp)
M3 M#<coolant>
G0 X#<start-X-taper> Z0.100
F#<ipm-taper>
G1 X#<end-X-taper> Z#<end-Z-taper>
M5 M9
G40 G97
G53 G0 X0 Z0
;Threading
#<X-start-thread> = #<start-X-taper>
#<X-end-thread> = [#<pipe-OD> + 0.00625]
#<Z-end-thread> = -#<cut-lenght>
T#<tool-thread> M6 G43
M3 S#<rpm-threading> M#<coolant>
o100 do
  G0 X#<X-start-thread> Z0.100
  ;#<Z-end-thread> = -[[[[#<X-end-thread>-#<X-start-thread>]/2] * TAN[88.2101]]+0.1]
  G33 X#<X-end-thread> Z#<Z-end-thread> K#<pitch>
  G0 X[#<X-end-thread>+.05]
  Z0.100
  o110 if [[#<X-start-thread> - #<cut-depth>] GT #<minor-dia>]
    ; make sure start value minus decrement will not go beyond end value
    #<X-start-thread> = [#<X-start-thread> - #<cut-depth>]
    #<X-end-thread>   = [#<X-end-thread> - #<cut-depth>]
  o110 else
    ; last pass for odd number of divisions
    #<last-cut> = [#<X-start-thread> - #<minor-dia>]
    #<X-start-thread> = [#<X-start-thread> - #<minor-dia>]
    #<X-end-thread>   = [#<X-end-thread> - #<minor-dia>]
  o110 endif
o100 while [#<X-start-thread> ge #<minor-dia>]
M5 M9
Z0.100
G53 X0 Z0
o<ntp>endsub
Вариант 2
(Pipe 3-4 male.ngc 12/13/2012 Joe Kline)
(TOOL: 7  60 DEG THREAD)
G0 G20 G90
G8 (rad)
G28 (Set tool chg pos with G28.1)
T7 M6 G43
F.006
S300         ( SPINDLE SPEED)
M3 M8        ( SPINDLE FWD Cool on)
G4P1         (PAUSE)
F5
#<X_Start>=.507     ( X START POINT )
#<Z_Start>=.2       ( Z Start Point )
#<Pitch>1=.07143   ( PITCH)
#<X_Depth>=-.057    ( X DEPTH, INCR)
#<Z_Depth>=-.0357   ( Z DEPTH, INCR  FOR COMPOUND, 0 PLUNGE)
#<X_End>=.535     ( X END OF THREAD)
#<Z_End>=-.646    ( Z END OF THREAD)
#<X_Pullout>=.05      ( X PULL OUT, +/- INCR)
#<Z_Pullout>=-.1357   ( Z PULL OUT, +/- INCR)
#<First_Cut>=.015     ( 1st CUT SIZE)
#<Remaining_Cuts>=.005     ( CUT SIZE)
#<Spring_Cuts>8=1        ( SPRING CUTS )
/g0 x[#<X_Start>+#<X_Depth>] z.25
/g1z.075 (temp mark OD)
/x#<X_Start>
/z.25   (temp mark minor)
G0 X#<X_Start> Z#<Z_Start>     (Start point)
#<Compound_Dist>=SQRT[[#<X_Depth>*#<X_Depth>]+[#<Z_Depth>*#<Z_Depth>]]  (calc compound dist)
#<kx>=[#<X_Depth>/#<Compound_Dist>] (kx)
#<kz>=[#<Z_Depth>/#<Compound_Dist>] (kz)
#<Spring_Cuts>9=[[#<First_Cut>-#<Remaining_Cuts>] * #<kx>] (1st cut size X)
#<First_Z_Cut>=[[#<First_Cut>-#<Remaining_Cuts>] * #<kz>] (1st cut size Z)
o100 do
  #<Spring_Cuts>9=[#<Spring_Cuts>9+[#<Remaining_Cuts> * #<kx>]] (X)
  #<First_Z_Cut>=[#<First_Z_Cut>+[#<Remaining_Cuts> * #<kz>]] (Z)
  o110 if [#<Spring_Cuts>9 GT ABS[#<X_Depth>]] (don't go too far)
    #<Spring_Cuts>9 = #<X_Depth>
    #<First_Z_Cut> = #<Z_Depth>
  o110 endif
  G1X[#<X_Start>+#<Spring_Cuts>9] Z[#<Z_Start>+#<First_Z_Cut>]            (start point - cut size)
  G33 X[#<X_End>+#<Spring_Cuts>9] Z[#<Z_End>+#<First_Z_Cut>] K#<Pitch>1     (cut thread)
  G33 X#<X_End> Z[#<Z_End>+#<First_Z_Cut>+#<Z_Pullout>] K#<Pitch>1 (pull out)
  G0 X[#<X_End>+#<X_Pullout>]
  G0 Z#<Z_Start>
  G0 X#<X_Start>
  o120 if [ABS[[#<Spring_Cuts>9] +.0001] GT ABS[#<X_Depth>]]
    o121 if [#<Spring_Cuts>8 GT 0]
      #<Spring_Cuts>9=[#<Spring_Cuts>9-[#<Remaining_Cuts> * #<kx>]] (back off X)
      #<First_Z_Cut>=[#<First_Z_Cut>-[#<Remaining_Cuts> * #<kz>]] (Z)
    o121 endif
    #<Spring_Cuts>8=[[#<Spring_Cuts>8]-1.] (decr spring passes)
  o120 endif
o100 while [[#<Spring_Cuts>8] GT -1.0]
M5M9
G28
M30
Где то скачал с инета архивчик под разные резьбы наруж/внутр.
PipeThreads.zip
(9.54 КБ) 763 скачивания
Написал программку для точения 3х зонного шнека. Зона 1 - цилиндрическая, зона 2 - конус, зона 3 - цилиндрическая.
На чертеже красным показан профиль шнека. Чертеж взял с Алиэкспресса.
Шнек.png (9533 просмотра) <a class='original' href='./download/file.php?id=199454&mode=view' target=_blank>Загрузить оригинал (347.79 КБ)</a>
На фото средний шнек выточен с переменным шагом.
IMG_1471 (Копировать).JPG (9533 просмотра) <a class='original' href='./download/file.php?id=199452&mode=view' target=_blank>Загрузить оригинал (250.04 КБ)</a>
Программка
SHNEK Ver4 .rar
(674 байт) 338 скачиваний
Y13Lab
Сообщение Y13Lab »
Немного подредактировали программу для проточки шнека.
Shnek Lathe.zip
(824 байт) 179 скачиваний
Траектории строились не совсем правильно.
Добавили расчёт оборотов шпинделя
исходя из заданной подачи.
Добавили одну зону для плавного выхода резца.
Полученый результат, фрезеровка в токарном.
IMG_20250130_170416~5.jpg (6986 просмотров) <a class='original' href='./download/file.php?id=213328&mode=view' target=_blank>Загрузить оригинал (347.51 КБ)</a>
Автору программы Огромная благодарность!
