#!/usr/bin/python
# This is a component of AXIS, a front-end for LinuxCNC
# Copyright 2004, 2005, 2006, 2007, 2008, 2009
# Jeff Epler <jepler@unpythonic.net> and Chris Radek <chris@timeguy.com>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
# import pdb
import sys, os
import string
BASE = os.path.abspath(os.path.join(os.path.dirname(sys.argv[0]), ".."))
sys.path.insert(0, os.path.join(BASE, "lib", "python"))
# otherwise, on hardy the user is shown spurious "[application] closed
# unexpectedly" messages but denied the ability to actually "report [the]
# problem"
sys.excepthook = sys.__excepthook__
import gettext;
gettext.install("linuxcnc", localedir=os.path.join(BASE, "share", "locale"), unicode=True)
import array, time, atexit, tempfile, shutil, errno, thread, select, re, getopt
import traceback
# Print Tk errors to stdout. python.org/sf/639266
import Tkinter
OldTk = Tkinter.Tk
class Tk(OldTk):
def __init__(self, *args, **kw):
OldTk.__init__(self, *args, **kw)
self.tk.createcommand('tkerror', self.tkerror)
def tkerror(self, arg):
print "TCL error in asynchronous code:"
print self.tk.call("set", "errorInfo")
Tkinter.Tk = Tk
from Tkinter import *
from minigl import *
RTLD_NOW, RTLD_GLOBAL = 0x1, 0x100 # XXX portable?
old_flags = sys.getdlopenflags()
sys.setdlopenflags(RTLD_NOW | RTLD_GLOBAL);
import gcode
sys.setdlopenflags(old_flags)
from rs274.OpenGLTk import *
from rs274.interpret import StatMixin
from rs274.glcanon import GLCanon, GlCanonDraw
from hershey import Hershey
from propertywindow import properties
import rs274.options
import nf
import locale
import bwidget
from math import hypot, atan2, sin, cos, pi, sqrt
import linuxcnc
from glnav import *
if os.environ.has_key("AXIS_NO_HAL"):
hal_present = 0;
else:
hal_present = 1;
if hal_present == 1 :
import hal
import ConfigParser
cp = ConfigParser.ConfigParser
class AxisPreferences(cp):
types = {
bool: cp.getboolean,
float: cp.getfloat,
int: cp.getint,
str: cp.get,
repr: lambda self,section,option: eval(cp.get(self,section,option)),
def __init__(self):
cp.__init__(self)
self.fn = os.path.expanduser("~/.axis_preferences")
self.read(self.fn)
def getpref(self, option, default=False, type=bool):
m = self.types.get(type)
try:
o = m(self, "DEFAULT", option)
except Exception, detail:
print detail
self.set("DEFAULT", option, default)
self.write(open(self.fn, "w"))
o = default
return o
def putpref(self, option, value, type=bool):
self.set("DEFAULT", option, type(value))
if sys.argv[1] != "-ini":
raise SystemExit, "-ini must be first argument"
inifile = linuxcnc.ini(sys.argv[2])
ap = AxisPreferences()
os.system("xhost -SI:localuser:gdm -SI:localuser:root > /dev/null 2>&1")
root_window = Tkinter.Tk(className="Axis")
root_window.iconify()
nf.start(root_window)
nf.makecommand(root_window, "_", _)
rs274.options.install(root_window)
root_window.tk.call("set", "version", linuxcnc.version)
try:
nf.source_lib_tcl(root_window,"axis.tcl")
except TclError:
print root_window.tk.call("set", "errorInfo")
raise
def General_Halt():
text = "Do you really want to close linuxcnc?"
if not root_window.tk.call("nf_dialog", ".error", "Confirm Close", text, "warning", 1, "Yes", "No"):
root_window.destroy()
root_window.protocol("WM_DELETE_WINDOW", General_Halt)
program_start_line = 0
program_start_line_last = -1
lathe = 0
mdi_history_max_entries = 1000
mdi_history_save_filename =\
inifile.find('DISPLAY', 'MDI_HISTORY_FILE') or "~/.axis_mdi_history"
feedrate_blackout = 0
rapidrate_blackout = 0
spindlerate_blackout = 0
maxvel_blackout = 0
jogincr_index_last = 1
mdi_history_index= -1
resume_inhibit = 0
help1 = [
("F1", _("Emergency stop")),
("F2", _("Turn machine on")),
("X, `", _("Activate first axis")),
("Y, 1", _("Activate second axis")),
("Z, 2", _("Activate third axis")),
("A, 3", _("Activate fourth axis")),
("4..8", _("Activate fifth through ninth axis")),
("`, 1..9, 0", _("Set Feed Override from 0% to 100%")),
(_(", and ."), _("Select jog speed")),
(_("< and >"), _("Select angular jog speed")),
(_("I, Shift-I"), _("Select jog increment")),
("C", _("Continuous jog")),
(_("Home"), _("Send active axis home")),
(_("Ctrl-Home"), _("Home all axes")),
(_("Shift-Home"), _("Zero G54 offset for active axis")),
(_("End"), _("Set G54 offset for active axis")),
(_("Ctrl-End"), _("Set tool offset for loaded tool")),
("-, =", _("Jog active axis")),
(_("Left, Right"), _("Jog first axis")),
(_("Up, Down"), _("Jog second axis")),
(_("Pg Up, Pg Dn"), _("Jog third axis")),
(_("Shift+above jogs"), _("Jog at traverse speed")),
("[, ]", _("Jog fourth axis")),
("D", _("Toggle between Drag and Rotate mode")),
(_("Left Button"), _("Pan, rotate or select line")),
(_("Shift+Left Button"), _("Rotate or pan")),
(_("Right Button"), _("Zoom view")),
(_("Wheel Button"), _("Rotate view")),
(_("Rotate Wheel"), _("Zoom view")),
(_("Control+Left Button"), _("Zoom view")),
help2 = [
("F3", _("Manual control")),
("F5", _("Code entry (MDI)")),
(_("Control-M"), _("Clear MDI history")),
(_("Control-H"), _("Copy selected MDI history elements")),
("", _("to clipboard")),
(_("Control-Shift-H"), _("Paste clipboard to MDI history")),
("L", _("Override Limits")),
("O", _("Open program")),
(_("Control-R"), _("Reload program")),
(_("Control-S"), _("Save g-code as")),
("R", _("Run program")),
("T", _("Step program")),
("P", _("Pause program")),
("S", _("Resume program")),
("ESC", _("Stop running program, or")),
("", _("stop loading program preview")),
("F7", _("Toggle mist")),
("F8", _("Toggle flood")),
("B", _("Spindle brake off")),
(_("Shift-B"), _("Spindle brake on")),
("F9", _("Turn spindle clockwise")),
("F10", _("Turn spindle counterclockwise")),
("F11", _("Turn spindle more slowly")),
("F12", _("Turn spindle more quickly")),
(_("Control-K"), _("Clear live plot")),
("V", _("Cycle among preset views")),
("F4", _("Cycle among preview, DRO, and user tabs")),
("@", _("toggle Actual/Commanded")),
("#", _("toggle Relative/Machine")),
(_("Ctrl-Space"), _("Clear notifications")),
def install_help(app):
keys = nf.makewidget(app, Frame, '.keys.text')
fixed = app.tk.call("linuxcnc::standard_fixed_font")
for i in range(len(help1)):
a, b = help1[i]
Label(keys, text=a, font=fixed, padx=4, pady=0, highlightthickness=0).grid(row=i, column=0, sticky="w")
Label(keys, text=b, padx=4, pady=0, highlightthickness=0).grid(row=i, column=1, sticky="w")
for i in range(len(help2)):
a, b = help2[i]
Label(keys, text=a, font=fixed, padx=4, pady=0, highlightthickness=0).grid(row=i, column=3, sticky="w")
Label(keys, text=b, padx=4, pady=0, highlightthickness=0).grid(row=i, column=4, sticky="w")
Label(keys, text=" ").grid(row=0, column=2)
def joints_mode():
return s.motion_mode == linuxcnc.TRAJ_MODE_FREE and s.kinematics_type != linuxcnc.KINEMATICS_IDENTITY
def parse_color(c):
if c == "": return (1,0,0)
return tuple([i/65535. for i in root_window.winfo_rgb(c)])
def to_internal_units(pos, unit=None):
if unit is None:
unit = s.linear_units
lu = (unit or 1) * 25.4
lus = [lu, lu, lu, 1, 1, 1, lu, lu, lu]
return [a/b for a, b in zip(pos, lus)]
def to_internal_linear_unit(v, unit=None):
if unit is None:
return v/lu
def from_internal_units(pos, unit=None):
if unit is None:
return [a*b for a, b in zip(pos, lus)]
def from_internal_linear_unit(v, unit=None):
if unit is None:
return v*lu
class Notification(Tkinter.Frame):
def __init__(self, master):
self.widgets = []
self.cache = []
Tkinter.Frame.__init__(self, master)
def clear(self,iconname=None):
if iconname:
cpy = self.widgets[:]
for i, item in enumerate(cpy):
frame,icon,text,button,iname = item
if iname == "icon_std_" + iconname:
self.remove(cpy[i])
else:
while self.widgets:
self.remove(self.widgets[0])
def clear_one(self):
if self.widgets:
def add(self, iconname, message):
self.place(relx=1, rely=1, y=-20, anchor="se")
iconname = self.tk.call("load_image", "std_" + iconname)
close = self.tk.call("load_image", "close", "notification-close")
if len(self.widgets) > 10:
if self.cache:
frame, icon, text, button, discard = self.cache.pop()
icon.configure(image=iconname)
text.configure(text=message)
widgets = frame, icon, text, button, iconname
else:
frame = Tkinter.Frame(self)
icon = Tkinter.Label(frame, image=iconname)
text = Tkinter.Label(frame, text=message, wraplength=300, justify="left")
button = Tkinter.Button(frame, image=close)
text.pack(side="left")
icon.pack(side="left")
button.pack(side="left")
button.configure(command=lambda: self.remove(widgets))
frame.pack(side="top", anchor="e")
self.widgets.append(widgets)
def remove(self, widgets):
self.widgets.remove(widgets)
if len(self.cache) < 10:
widgets[0].pack_forget()
self.cache.append(widgets)
else:
widgets[0].destroy()
if len(self.widgets) == 0:
self.place_forget()
def soft_limits():
def fudge(x):
if abs(x) > 1e30: return 0
return x
ax = s.axis
return (
to_internal_units([fudge(ax[i]['min_position_limit']) for i in range(3)]),
to_internal_units([fudge(ax[i]['max_position_limit']) for i in range(3)]))
class MyOpengl(GlCanonDraw, Opengl):
self.after_id = None
self.motion_after = None
self.perspective = False
Opengl.__init__(self, *args, **kw)
GlCanonDraw.__init__(self, s, None)
self.bind('<Button-1>', self.select_prime, add=True)
self.bind('<ButtonRelease-1>', self.select_fire, add=True)
self.bind('<Button1-Motion>', self.select_cancel, add=True)
self.highlight_line = None
self.select_event = None
self.select_buffer_size = 100
self.select_primed = None
self.last_position = None
self.last_homed = None
self.last_origin = None
self.last_rotation_xy = None
self.last_tool = None
self.last_limits = None
self.set_eyepoint(5.)
self.get_resources()
self.realize()
def getRotateMode(self):
return vars.rotate_mode.get()
def get_font_info(self):
return coordinate_charwidth, coordinate_linespace, fontbase
def get_resources(self):
self.colors = dict(GlCanonDraw.colors)
for c in self.colors.keys():
if isinstance(c, tuple):
c, d = c
elif c.endswith("_alpha"):
d = "Alpha"
else:
d = "Foreground"
option_value = self.option_get(c, d)
if option_value:
if d == "Alpha":
self.colors[c] = float(option_value)
else:
self.colors[c] = parse_color(option_value)
x = float(self.option_get("tool_light_x", "Float"))
y = float(self.option_get("tool_light_y", "Float"))
z = float(self.option_get("tool_light_z", "Float"))
dist = (x**2 + y**2 + z**2) ** .5
self.light_position = (x/dist, y/dist, z/dist, 0)
def select_prime(self, event):
self.select_primed = event
def select_cancel(self, event):
if self.select_primed and (event.x != self.select_primed.x or event.y != self.select_primed.y):
def select_fire(self, event):
if self.select_primed: self.queue_select(event)
def queue_select(self, event):
self.select_event = event
self.tkRedraw()
def deselect(self, event):
self.set_highlight_line(None)
def select(self, event):
GlCanonDraw.select(self, event.x, event.y)
def get_joints_mode(self): return joints_mode()
def get_current_tool(self): return current_tool
def is_lathe(self): return lathe
def get_show_commanded(self): return vars.display_type.get()
def get_show_rapids(self): return vars.show_rapids.get()
def get_geometry(self): return geometry
def is_foam(self): return foam
def get_num_joints(self): return num_joints
def get_program_alpha(self): return vars.program_alpha.get()
def get_a_axis_wrapped(self): return a_axis_wrapped
def get_b_axis_wrapped(self): return b_axis_wrapped
def get_c_axis_wrapped(self): return c_axis_wrapped
def set_current_line(self, line):
if line == vars.running_line.get(): return
t.tag_remove("executing", "0.0", "end")
if line is not None and line > 0:
vupdate(vars.running_line, line)
if vars.highlight_line.get() <= 0:
t.see("%d.0" % (line+2))
t.see("%d.0" % line)
t.tag_add("executing", "%d.0" % line, "%d.end" % line)
else:
vupdate(vars.running_line, 0)
def get_highlight_line(self):
return vars.highlight_line.get()
def set_highlight_line(self, line):
if line == self.get_highlight_line(): return
GlCanonDraw.set_highlight_line(self, line)
t.tag_remove("sel", "0.0", "end")
t.tag_add("sel", "%d.0" % line, "%d.end" % line)
vupdate(vars.highlight_line, line)
else:
vupdate(vars.highlight_line, -1)
def tkRedraw(self, *dummy):
if self.after_id:
# May need to upgrade to an instant redraw
self.after_cancel(self.after_id)
self.after_id = self.after_idle(self.actual_tkRedraw)
def redraw_soon(self, *dummy):
if self.after_id: return
self.after_id = self.after(50, self.actual_tkRedraw)
def tkRedraw_perspective(self, *dummy):
"""Cause the opengl widget to redraw itself."""
self.redraw_perspective()
def tkRedraw_ortho(self, *dummy):
self.redraw_ortho()
def startRotate(self, event):
if lathe: return
return Opengl.startRotate(self, event)
def tkAutoSpin(self, event):
if lathe: return
return Opengl.tkAutoSpin(self, event)
def tkRotate(self, event):
if lathe: return
Opengl.tkRotate(self, event)
self.perspective = True
widgets.view_z.configure(relief="link")
widgets.view_z2.configure(relief="link")
widgets.view_x.configure(relief="link")
widgets.view_y.configure(relief="link")
widgets.view_p.configure(relief="link")
vars.view_type.set(0)
def tkTranslateOrRotate(self, event):
if self.getRotateMode():
self.tkRotate(event)
else:
self.tkTranslate(event)
def tkRotateOrTranslate(self, event):
else:
def actual_tkRedraw(self, *dummy):
if self.perspective:
self.tkRedraw_perspective()
else:
self.tkRedraw_ortho()
def get_show_program(self): return vars.show_program.get()
def get_show_offsets(self): return vars.show_offsets.get()
def get_show_extents(self): return vars.show_extents.get()
def get_grid_size(self): return vars.grid_size.get()
def get_show_metric(self): return vars.metric.get()
def get_show_live_plot(self): return vars.show_live_plot.get()
def get_show_machine_speed(self): return vars.show_machine_speed.get()
def get_show_distance_to_go(self): return vars.show_distance_to_go.get()
def get_view(self):
x,y,z,p = 0,1,2,3
if str(widgets.view_x['relief']) == "sunken":
view = x
elif str(widgets.view_y['relief']) == "sunken":
view = y
elif (str(widgets.view_z['relief']) == "sunken" or
str(widgets.view_z2['relief']) == "sunken"):
view = z
else:
view = p
return view
def get_show_relative(self): return vars.coord_type.get()
def get_show_limits(self): return vars.show_machine_limits.get()
def get_show_tool(self): return vars.show_tool.get()
def redraw(self):
if not self.winfo_viewable():
return self.redraw_dro()
if self.select_event:
self.select(self.select_event)
GlCanonDraw.redraw(self)
def redraw_dro(self):
self.stat.poll()
limit, homed, posstrs, droposstrs = self.posstrs()
text = widgets.numbers_text
font = "Courier 10 pitch"
if not hasattr(self, 'font_width'):
self.font_width = text.tk.call(
"font", "measure", (font, -100, "bold"), "0")
self.font_vertspace = text.tk.call(
"font", "metrics", (font, -100, "bold"), "-linespace") - 100
self.last_font = None
font_width = self.font_width
font_vertspace = self.font_vertspace
text.delete("0.0", "end")
t = droposstrs[:]
i = 0
for ts in t:
if i < len(homed) and homed[i]:
t[i] += "*"
else:
t[i] += " "
if i < len(homed) and limit[i]:
t[i] += "!" # !!!1!
else:
t[i] += " "
i+=1
text.insert("end", "\n".join(t))
window_height = text.winfo_height()
window_width = text.winfo_width()
dro_lines = len(droposstrs)
dro_width = len(droposstrs[0]) + 3
# pixels of height required, for "100 pixel" font
req_height = dro_lines * 100 + (dro_lines + 1) * font_vertspace
# pixels of width required, for "100 pixel" font
req_width = dro_width * font_width
height_ratio = float(window_height) / req_height
width_ratio = float(window_width) / req_width
ratio = min(height_ratio, width_ratio)
new_font = -int(100*ratio)
if new_font != self.last_font:
text.configure(font=(font, new_font, "bold"))
self.last_font = new_font
def init():
glDrawBuffer(GL_BACK)
glDisable(GL_CULL_FACE)
glLineStipple(2, 0x5555)
glDisable(GL_LIGHTING)
glClearColor(0,0,0,0)
glPixelStorei(GL_UNPACK_ALIGNMENT, 1)
def toggle_perspective(e):
o.perspective = not o.perspective
o.tkRedraw()
def select_line(event):
i = t.index("@%d,%d" % (event.x, event.y))
i = int(i.split('.')[0])
o.set_highlight_line(i)
o.tkRedraw()
return "break"
def select_prev(event):
if o.highlight_line is None:
i = o.last_line
else:
i = max(1, o.highlight_line - 1)
o.tkRedraw()
def select_next(event):
i = 1
else:
i = min(o.last_line, o.highlight_line + 1)
o.tkRedraw()
def scroll_up(event):
t.yview_scroll(-2, "units")
def scroll_down(event):
t.yview_scroll(2, "units")
current_tool = None
def vupdate(var, val):
try:
if var.get() == val: return
except ValueError:
pass
var.set(val)
class LivePlotter:
def __init__(self, window):
self.win = window
window.live_plot_size = 0
self.after = None
self.error_after = None
self.running = BooleanVar(window)
self.running.set(False)
self.lastpts = -1
self.last_speed = -1
self.last_limit = None
self.last_motion_mode = None
self.last_joint_position = None
self.notifications_clear = False
self.notifications_clear_info = False
self.notifications_clear_error = False
def start(self):
if self.running.get(): return
if not os.path.exists(linuxcnc.nmlfile):
return False
try:
self.stat = linuxcnc.stat()
except linuxcnc.error:
return False
self.current_task_mode = self.stat.task_mode
def C(s):
a = o.colors[s + "_alpha"]
s = o.colors[s]
return [int(x * 255) for x in s + (a,)]
self.logger = linuxcnc.positionlogger(linuxcnc.stat(),
C('backplotjog'),
C('backplottraverse'),
C('backplotfeed'),
C('backplotarc'),
C('backplottoolchange'),
C('backplotprobing'),
geometry, foam
o.after_idle(lambda: thread.start_new_thread(self.logger.start, (.01,)))
global feedrate_blackout, rapidrate_blackout, spindlerate_blackout, maxvel_blackout
feedrate_blackout=rapidrate_blackout=spindlerate_blackout=maxvel_blackout=time.time()+1
self.running.set(True)
def stop(self):
if not self.running.get(): return
if hasattr(self, 'stat'): del self.stat
if self.after is not None:
self.win.after_cancel(self.after)
self.after = None
if self.error_after is not None:
self.win.after_cancel(self.error_after)
self.logger.stop()
def error_task(self):
error = e.poll()
while error:
kind, text = error
if kind in (linuxcnc.NML_ERROR, linuxcnc.OPERATOR_ERROR):
icon = "error"
else:
icon = "info"
notifications.add(icon, text)
error = e.poll()
self.error_after = self.win.after(200, self.error_task)
def update(self):
return
try:
self.stat.poll()
except linuxcnc.error, detail:
print "error", detail
del self.stat
return
if (self.stat.task_mode != self.current_task_mode):
if (self.current_task_mode == linuxcnc.MODE_MANUAL):
root_window.tk.eval(pane_top + ".tabs raise manual")
if (self.current_task_mode == linuxcnc.MODE_MDI):
root_window.tk.eval(pane_top + ".tabs raise mdi")
if (self.current_task_mode == linuxcnc.MODE_AUTO):
# not sure if anything needs to be done for this
pass
self.after = self.win.after(update_ms, self.update)
self.win.set_current_line(self.stat.id or self.stat.motion_line)
speed = self.stat.current_vel
limits = soft_limits()
if (self.logger.npts != self.lastpts
or limits != o.last_limits
or self.stat.actual_position != o.last_position
or self.stat.joint_actual_position != o.last_joint_position
or self.stat.homed != o.last_homed
or self.stat.g5x_offset != o.last_g5x_offset
or self.stat.g92_offset != o.last_g92_offset
or self.stat.g5x_index != o.last_g5x_index
or self.stat.rotation_xy != o.last_rotation_xy
or self.stat.limit != o.last_limit
or self.stat.tool_table[0] != o.last_tool
or self.stat.motion_mode != o.last_motion_mode
or abs(speed - self.last_speed) > .01):
o.redraw_soon()
o.last_limits = limits
o.last_limit = self.stat.limit
o.last_homed = self.stat.homed
o.last_position = self.stat.actual_position
o.last_g5x_offset = self.stat.g5x_offset
o.last_g92_offset = self.stat.g92_offset
o.last_g5x_index = self.stat.g5x_index
o.last_rotation_xy = self.stat.rotation_xy
o.last_motion_mode = self.stat.motion_mode
o.last_tool = self.stat.tool_table[0]
o.last_joint_position = self.stat.joint_actual_position
self.last_speed = speed
self.lastpts = self.logger.npts
root_window.update_idletasks()
vupdate(vars.exec_state, self.stat.exec_state)
vupdate(vars.interp_state, self.stat.interp_state)
vupdate(vars.queued_mdi_commands, self.stat.queued_mdi_commands)
notifications_clear = comp["notifications-clear"]
if self.notifications_clear != notifications_clear:
self.notifications_clear = notifications_clear
if self.notifications_clear:
notifications.clear()
notifications_clear_info = comp["notifications-clear-info"]
if self.notifications_clear_info != notifications_clear_info:
self.notifications_clear_info = notifications_clear_info
if self.notifications_clear_info:
notifications.clear("info")
notifications_clear_error = comp["notifications-clear-error"]
if self.notifications_clear_error != notifications_clear_error:
self.notifications_clear_error = notifications_clear_error
if self.notifications_clear_error:
notifications.clear("error")
now_resume_inhibit = comp["resume-inhibit"]
global resume_inhibit
if resume_inhibit != now_resume_inhibit:
resume_inhibit = now_resume_inhibit
if resume_inhibit:
root_window.tk.call("pause_image_override")
else:
root_window.tk.call("pause_image_normal")
vupdate(vars.task_mode, self.stat.task_mode)
vupdate(vars.task_state, self.stat.task_state)
vupdate(vars.task_paused, self.stat.task_paused)
vupdate(vars.taskfile, self.stat.file)
vupdate(vars.interp_pause, self.stat.paused)
vupdate(vars.mist, self.stat.mist)
vupdate(vars.flood, self.stat.flood)
vupdate(vars.brake, self.stat.spindle_brake)
vupdate(vars.spindledir, self.stat.spindle_direction)
vupdate(vars.motion_mode, self.stat.motion_mode)
vupdate(vars.optional_stop, self.stat.optional_stop)
vupdate(vars.block_delete, self.stat.block_delete)
if time.time() > spindlerate_blackout:
vupdate(vars.spindlerate, int(100 * self.stat.spindlerate + .5))
if time.time() > feedrate_blackout:
vupdate(vars.feedrate, int(100 * self.stat.feedrate + .5))
if time.time() > rapidrate_blackout:
vupdate(vars.rapidrate, int(100 * self.stat.rapidrate + .5))
if time.time() > maxvel_blackout:
m = to_internal_linear_unit(self.stat.max_velocity)
if vars.metric.get(): m = m * 25.4
vupdate(vars.maxvel_speed, float(int(600 * m)/10.0))
root_window.tk.call("update_maxvel_slider")
vupdate(vars.override_limits, self.stat.axis[0]['override_limits'])
on_any_limit = 0
for i, l in enumerate(self.stat.limit):
if self.stat.axis_mask & (1<<i) and l:
on_any_limit = True
vupdate(vars.on_any_limit, on_any_limit)
global current_tool
current_tool = self.stat.tool_table[0]
if current_tool:
tool_data = {'tool': current_tool[0], 'zo': current_tool[3], 'xo': current_tool[1], 'dia': current_tool[10]}
if current_tool is None:
vupdate(vars.tool, _("Unknown tool %d") % self.stat.tool_in_spindle)
elif tool_data['tool'] == 0 or tool_data['tool'] == -1:
vupdate(vars.tool, _("No tool"))
elif current_tool.xoffset == 0 and not lathe:
vupdate(vars.tool, _("Tool %(tool)d, offset %(zo)g, diameter %(dia)g") % tool_data)
else:
vupdate(vars.tool, _("Tool %(tool)d, zo %(zo)g, xo %(xo)g, dia %(dia)g") % tool_data)
active_codes = []
for i in self.stat.gcodes[1:]:
if i == -1: continue
if i % 10 == 0:
active_codes.append("G%d" % (i/10))
else:
active_codes.append("G%(ones)d.%(tenths)d" % {'ones': i/10, 'tenths': i%10})
for i in self.stat.mcodes[1:]:
active_codes.append("M%d" % i)
feed_str = "F%.1f" % self.stat.settings[1]
if feed_str.endswith(".0"): feed_str = feed_str[:-2]
active_codes.append(feed_str)
active_codes.append("S%.0f" % self.stat.settings[2])
codes = " ".join(active_codes)
widgets.code_text.configure(state="normal")
widgets.code_text.delete("0.0", "end")
widgets.code_text.insert("end", codes)
widgets.code_text.configure(state="disabled")
user_live_update()
def clear(self):
self.logger.clear()
o.redraw_soon()
def running(do_poll=True):
if do_poll: s.poll()
return s.task_mode == linuxcnc.MODE_AUTO and s.interp_state != linuxcnc.INTERP_IDLE
def manual_tab_visible():
page = root_window.tk.call(widgets.tabs, "raise")
return page == "manual"
def manual_ok(do_poll=True):
"""warning: deceptive function name.
This function returns TRUE when not running a program, i.e., when a user-
initiated action (whether an MDI command or a jog) is acceptable.
This means this function returns True when the mdi tab is visible."""
if s.task_state != linuxcnc.STATE_ON: return False
return s.interp_state == linuxcnc.INTERP_IDLE or (s.task_mode == linuxcnc.MODE_MDI and s.queued_mdi_commands < vars.max_queued_mdi_commands.get())
# If LinuxCNC is not already in one of the modes given, switch it to the
# first mode
def ensure_mode(m, *p):
s.poll()
if s.task_mode == m or s.task_mode in p: return True
if running(do_poll=False): return False
c.mode(m)
c.wait_complete()
return True
class DummyProgress:
def update(self, count): pass
def nextphase(self, count): pass
def done(self): pass
class Progress:
def __init__(self, phases, total):
self.num_phases = phases
self.phase = 0
self.total = total or 1
self.lastcount = 0
self.text = None
self.old_focus = root_window.tk.call("focus", "-lastfor", ".")
root_window.tk.call("canvas", ".info.progress",
"-width", 1, "-height", 1,
"-highlightthickness", 0,
"-borderwidth", 2, "-relief", "sunken",
"-cursor", "watch")
root_window.configure(cursor="watch")
root_window.tk.call(".menu", "configure", "-cursor", "watch")
t.configure(cursor="watch")
root_window.tk.call("bind", ".info.progress", "<Key>", "break")
root_window.tk.call("pack", ".info.progress", "-side", "left",
"-fill", "both", "-expand", "1")
root_window.tk.call(".info.progress", "create", "rectangle",
(-10, -10, -10, -10),
"-fill", "blue", "-outline", "blue")
root_window.tk.call("focus", "-force", ".info.progress")
root_window.tk.call("patient_grab", ".info.progress")
def update(self, count, force=0):
if force or count - self.lastcount > 400:
fraction = (self.phase + count * 1. / self.total) / self.num_phases
self.lastcount = count
try:
width = int(t.tk.call("winfo", "width", ".info.progress"))
except Tkinter.TclError, detail:
print detail
return
height = int(t.tk.call("winfo", "height", ".info.progress"))
t.tk.call(".info.progress", "coords", "1",
(0, 0, int(fraction * width), height))
t.tk.call("update", "idletasks")
def nextphase(self, total):
self.phase += 1
self.lastcount = -100
self.update(0, True)
def done(self):
root_window.tk.call("destroy", ".info.progress")
root_window.tk.call("grab", "release", ".info.progress")
root_window.tk.call("focus", self.old_focus)
root_window.configure(cursor="")
root_window.tk.call(".menu", "configure", "-cursor", "")
t.configure(cursor="xterm")
def __del__(self):
if root_window.tk.call("winfo", "exists", ".info.progress"):
self.done()
def set_text(self, text):
if self.text is None:
self.text = root_window.tk.call(".info.progress", "create", "text",
(1, 1), "-text", text, "-anchor", "nw")
else:
root_window.tk.call(".info.progress", "itemconfigure", text,
"-text", text)
class AxisCanon(GLCanon, StatMixin):
def __init__(self, widget, text, linecount, progress, arcdivision):
GLCanon.__init__(self, widget.colors, geometry, foam)
StatMixin.__init__(self, s, random_toolchanger)
self.text = text
self.linecount = linecount
self.progress = progress
self.aborted = False
self.arcdivision = arcdivision
def change_tool(self, pocket):
GLCanon.change_tool(self, pocket)
StatMixin.change_tool(self, pocket)
def do_cancel(self, event):
self.aborted = True
def check_abort(self):
root_window.update()
if self.aborted: raise KeyboardInterrupt
def next_line(self, st):
GLCanon.next_line(self, st)
self.progress.update(self.lineno)
if self.notify:
notifications.add("info",self.notify_message)
self.notify = 0
progress_re = re.compile("^FILTER_PROGRESS=(\\d*)$")
def filter_program(program_filter, infilename, outfilename):
import subprocess
outfile = open(outfilename, "w")
infilename_q = infilename.replace("'", "'\\''")
env = dict(os.environ)
env['AXIS_PROGRESS_BAR'] = '1'
p = subprocess.Popen(["sh", "-c", "%s '%s'" % (program_filter, infilename_q)],
stdin=subprocess.PIPE,
stdout=outfile,
stderr=subprocess.PIPE,
env=env)
p.stdin.close() # No input for you
progress = Progress(1, 100)
progress.set_text(_("Filtering..."))
stderr_text = []
try:
while p.poll() is None: # XXX add checking for abort
t.update()
r,w,x = select.select([p.stderr], [], [], 0.100)
if r:
stderr_line = p.stderr.readline()
m = progress_re.match(stderr_line)
if m:
progress.update(int(m.group(1)), 1)
else:
stderr_text.append(stderr_line)
sys.stderr.write(stderr_line)
# .. might be something left on stderr
for line in p.stderr:
m = progress_re.match(line)
if not m:
stderr_text.append(line)
sys.stderr.write(line)
return p.returncode, "".join(stderr_text)
finally:
progress.done()
def get_filter(filename):
ext = os.path.splitext(filename)[1]
if ext:
return inifile.find("FILTER", ext[1:])
else:
return None
def update_recent_menu():
recent = ap.getpref('recentfiles', [], repr)
root_window.tk.call("update_recent", *recent)
def add_recent_file(f):
if f in recent: recent.remove(f)
recent.insert(0, f)
recent = recent[:10]
ap.putpref('recentfiles', recent, repr)
def cancel_open(event=None):
if o.canon is not None:
o.canon.aborted = True
loaded_file = None
def open_file_guts(f, filtered=False, addrecent=True):
if addrecent:
add_recent_file(f)
if not filtered:
global loaded_file
loaded_file = f
program_filter = get_filter(f)
if program_filter:
tempfile = os.path.join(tempdir, os.path.basename(f))
exitcode, stderr = filter_program(program_filter, f, tempfile)
if exitcode:
root_window.tk.call("nf_dialog", (".error", "-ext", stderr),
_("Filter failed"),
_("The program %(program)r exited with code %(code)d. "
"Any error messages it produced are shown below:")
% {'program': program_filter, 'code': exitcode},
"error",0,_("OK"))
return
return open_file_guts(tempfile, True, False)
set_first_line(0)
t0 = time.time()
canon = None
o.deselect(None) # remove highlight line from last program
try:
# be sure to switch modes to cause an interp synch, which
# writes out the var file. there was a reset here, and that
# causes a var file write, but nukes important settings like
# TLO.
ensure_mode(linuxcnc.MODE_MDI)
c.wait_complete()
ensure_mode(linuxcnc.MODE_AUTO)
c.wait_complete()
c.program_open(f)
lines = open(f).readlines()
progress = Progress(2, len(lines))
t.tk.call("delete_all", t)
code = []
i = 0
for i, l in enumerate(lines):
l = l.expandtabs().replace("\r", "")
#t.insert("end", "%6d: " % (i+1), "lineno", l)
code.extend(["%6d: " % (i+1), "lineno", l, ""])
if i % 1000 == 0:
t.insert("end", *code)
del code[:]
progress.update(i)
if code:
progress.nextphase(len(lines))
f = os.path.abspath(f)
o.canon = canon = AxisCanon(o, widgets.text, i, progress, arcdivision)
root_window.bind_class(".info.progress", "<Escape>", cancel_open)
parameter = inifile.find("RS274NGC", "PARAMETER_FILE")
temp_parameter = os.path.join(tempdir, os.path.basename(parameter))
if os.path.exists(parameter):
shutil.copy(parameter, temp_parameter)
canon.parameter_file = temp_parameter
initcode = inifile.find("EMC", "RS274NGC_STARTUP_CODE") or ""
if initcode == "":
initcode = inifile.find("RS274NGC", "RS274NGC_STARTUP_CODE") or ""
if not interpname:
unitcode = "G%d" % (20 + (s.linear_units == 1))
else:
unitcode = ''
try:
result, seq = o.load_preview(f, canon, unitcode, initcode, interpname)
except KeyboardInterrupt:
result, seq = 0, 0
# According to the documentation, MIN_ERROR is the largest value that is
# not an error. Crazy though that sounds...
if result > gcode.MIN_ERROR:
error_str = _(gcode.strerror(result))
_("G-Code error in %s") % os.path.basename(f),
_("Near line %(seq)d of %(f)s:\n%(error_str)s") % {'seq': seq, 'f': f, 'error_str': error_str},
"error",0,_("OK"))
o.lp.set_depth(from_internal_linear_unit(o.get_foam_z()),
from_internal_linear_unit(o.get_foam_w()))
except Exception, e:
notifications.add("error", str(e))
finally:
# Before unbusying, I update again, so that any keystroke events
# that reached the program while it was busy are sent to the
# label, not to another window in the application. If this
# update call is removed, the events are only handled after that
# widget is destroyed and focus has passed to some other widget,
# which will handle the keystrokes instead, leading to the
# R-while-loading bug.
#print "load_time", time.time() - t0
if canon:
canon.progress = DummyProgress()
try:
progress.done()
except UnboundLocalError:
pass
o.tkRedraw()
root_window.tk.call("set_mode_from_tab")
tabs_mdi = str(root_window.tk.call("set", "_tabs_mdi"))
tabs_manual = str(root_window.tk.call("set", "_tabs_manual"))
tabs_preview = str(root_window.tk.call("set", "_tabs_preview"))
tabs_numbers = str(root_window.tk.call("set", "_tabs_numbers"))
pane_top = str(root_window.tk.call("set", "pane_top"))
pane_bottom = str(root_window.tk.call("set", "pane_bottom"))
widgets = nf.Widgets(root_window,
("help_window", Toplevel, ".keys"),
("about_window", Toplevel, ".about"),
("text", Text, pane_bottom + ".t.text"),
("preview_frame", Frame, tabs_preview),
("numbers_text", Text, tabs_numbers + ".text"),
("tabs", bwidget.NoteBook, pane_top + ".tabs"),
("right", bwidget.NoteBook, pane_top + ".right"),
("mdi_history", Listbox, tabs_mdi + ".history"),
("mdi_command", Entry, tabs_mdi + ".command"),
("code_text", Text, tabs_mdi + ".gcodes"),
("axes", Radiobutton, tabs_manual + ".axes"),
("axis_x", Radiobutton, tabs_manual + ".axes.axisx"),
("axis_y", Radiobutton, tabs_manual + ".axes.axisy"),
("axis_z", Radiobutton, tabs_manual + ".axes.axisz"),
("axis_a", Radiobutton, tabs_manual + ".axes.axisa"),
("axis_b", Radiobutton, tabs_manual + ".axes.axisb"),
("axis_c", Radiobutton, tabs_manual + ".axes.axisc"),
("axis_u", Radiobutton, tabs_manual + ".axes.axisu"),
("axis_v", Radiobutton, tabs_manual + ".axes.axisv"),
("axis_w", Radiobutton, tabs_manual + ".axes.axisw"),
("joints", Radiobutton, tabs_manual + ".joints"),
("joint_0", Radiobutton, tabs_manual + ".joints.joint0"),
("joint_1", Radiobutton, tabs_manual + ".joints.joint1"),
("joint_2", Radiobutton, tabs_manual + ".joints.joint2"),
("joint_3", Radiobutton, tabs_manual + ".joints.joint3"),
("joint_4", Radiobutton, tabs_manual + ".joints.joint4"),
("joint_5", Radiobutton, tabs_manual + ".joints.joint5"),
("joint_6", Radiobutton, tabs_manual + ".joints.joint6"),
("joint_7", Radiobutton, tabs_manual + ".joints.joint7"),
("joint_8", Radiobutton, tabs_manual + ".joints.joint8"),
("joint_9", Radiobutton, tabs_manual + ".joints.joint9"),
("jogincr", Entry, tabs_manual + ".jogf.jog.jogincr"),
("override", Checkbutton, tabs_manual + ".jogf.override"),
("ajogspeed", Entry, pane_top + ".ajogspeed"),
("lubel", Label, tabs_manual + ".coolant"),
("flood", Checkbutton, tabs_manual + ".flood"),
("mist", Checkbutton, tabs_manual + ".mist"),
("brake", Checkbutton, tabs_manual + ".spindlef.brake"),
("spindlel", Label, tabs_manual + ".spindlel"),
("spindlef", Frame, tabs_manual + ".spindlef"),
("spindle_ccw", Radiobutton, tabs_manual + ".spindlef.ccw"),
("spindle_stop", Radiobutton, tabs_manual + ".spindlef.stop"),
("spindle_cw", Radiobutton, tabs_manual + ".spindlef.cw"),
("spindle_minus", Button, tabs_manual + ".spindlef.spindleminus"),
("spindle_plus", Button, tabs_manual + ".spindlef.spindleplus"),
("view_z", Button, ".toolbar.view_z"),
("view_z2", Button, ".toolbar.view_z2"),
("view_x", Button, ".toolbar.view_x"),
("view_y", Button, ".toolbar.view_y"),
("view_p", Button, ".toolbar.view_p"),
("rotate", Button, ".toolbar.rotate"),
("feedoverride", Scale, pane_top + ".feedoverride.foscale"),
("rapidoverride", Scale, pane_top + ".rapidoverride.foscale"),
("spinoverride", Scale, pane_top + ".spinoverride.foscale"),
("spinoverridef", Scale, pane_top + ".spinoverride"),
("menu_view", Menu, ".menu.view"),
("menu_grid", Menu, ".menu.view.grid"),
("menu_file", Menu, ".menu.file"),
("menu_machine", Menu, ".menu.machine"),
("menu_touchoff", Menu, ".menu.machine.touchoff"),
("homebutton", Button, tabs_manual + ".jogf.zerohome.home"),
("homemenu", Menu, ".menu.machine.home"),
("unhomemenu", Menu, ".menu.machine.unhome")
def activate_axis(i, force=0):
if not force and not manual_ok(): return
if joints_mode():
if i >= num_joints: return
axis = getattr(widgets, "joint_%d" % i)
else:
if not s.axis_mask & (1<<i): return
axis = getattr(widgets, "axis_%s" % "xyzabcuvw"[i])
axis.focus()
axis.invoke()
def set_first_line(lineno):
global program_start_line
program_start_line = lineno
t.tag_remove("ignored", "0.0", "end")
if lineno > 0:
t.tag_add("ignored", "0.0", "%d.end" % (lineno-1))
def parse_increment(jogincr):
if jogincr.endswith("mm"):
scale = from_internal_linear_unit(1/25.4)
elif jogincr.endswith("cm"):
scale = from_internal_linear_unit(10/25.4)
elif jogincr.endswith("um"):
scale = from_internal_linear_unit(.001/25.4)
elif jogincr.endswith("in") or jogincr.endswith("inch"):
scale = from_internal_linear_unit(1.)
elif jogincr.endswith("mil"):
scale = from_internal_linear_unit(.001)
else:
scale = 1
jogincr = jogincr.rstrip(" inchmuil")
if "/" in jogincr:
p, q = jogincr.split("/")
jogincr = float(p) / float(q)
else:
jogincr = float(jogincr)
return jogincr * scale
def set_hal_jogincrement():
if not 'comp' in globals(): return # this is called once during startup before comp exists
jogincr = widgets.jogincr.get()
if jogincr == _("Continuous"):
distance = 0
else:
distance = parse_increment(jogincr)
comp['jog.increment'] = distance
def jogspeed_listbox_change(dummy, value):
global jogincr_index_last
# pdb.set_trace()
# FJ: curselection is not always up to date here, so
# do a linear search by hand
iterator = iter(root_window.call(widgets.jogincr._w, "list", "get", "0", "end"))
idx = 0
cursel = -1
for i in iterator:
if i == unicode(value, 'utf-8'):
cursel= idx
break
idx += 1
if cursel > 0:
jogincr_index_last= cursel
def jogspeed_continuous():
root_window.call(widgets.jogincr._w, "select", 0)
def jogspeed_incremental(dir=1):
jogincr_size = int(root_window.call(widgets.jogincr._w, "list", "size"))
# pdb.set_trace()
cursel = root_window.call(widgets.jogincr._w, "curselection")
if cursel == "":
cursel = 0
else:
cursel = int(cursel)
if dir == 1:
if cursel > 0:
# If it was "Continous" just before, then don't change last jog increment!
jogincr_index_last += 1
if jogincr_index_last >= jogincr_size:
jogincr_index_last = jogincr_size - 1
else:
if cursel > 0:
jogincr_index_last -= 1
if jogincr_index_last < 1:
root_window.call(widgets.jogincr._w, "select", jogincr_index_last)
class SelectionHandler:
def __init__(self, win, **kw):
self.kw = kw
self.win = win
self.win.selection_handle(self.handler, *kw)
self.value = ""
def set_value(self, value):
self.win.selection_own(**self.kw)
self.value = value
def handler(self, offset, maxchars):
offset = int(offset)
maxchars = int(maxchars)
return self.value[offset:offset+maxchars]
selection = SelectionHandler(root_window)
class DummyCanon:
def comment(*args): pass
def next_line(*args): pass
def set_g5x_offset(*args): pass
def set_g92_offset(*args): pass
def set_xy_rotation(*args): pass
def get_external_angular_units(self): return 1.0
def get_external_length_units(self): return 1.0
def set_plane(*args): pass
def get_axis_mask(self): return 7
def get_tool(self, tool):
return tool, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0
def set_feed_rate(self, rate): pass
def user_defined_function(self, m, p, q):
self.number = p
def parse_gcode_expression(e):
f = os.path.devnull
canon = DummyCanon()
result, seq = gcode.parse("", canon, "M199 P["+e+"]", "M2")
if result > gcode.MIN_ERROR: return False, gcode.strerror(result)
return True, canon.number
class _prompt_areyousure:
""" Prompt for a question, user can enter yes or no """
def __init__(self, title, text):
t = self.t = Toplevel(root_window, padx=7, pady=7)
t.wm_title(title)
t.wm_transient(root_window)
t.wm_resizable(0, 0)
self.status=False
m = Message(t, text=text, aspect=500, anchor="w", justify="left")
self.w = w = StringVar(t)
l = Tkinter.Message(t, textvariable=w, justify="left", anchor="w",
aspect=500)
self.buttons = f = Tkinter.Frame(t)
self.ok = Tkinter.Button(f, text=_("Ok"), command=self.do_ok, width=10,height=1,padx=0,pady=.25, default="active")
self.cancel = Tkinter.Button(f, text=_("Cancel"), command=self.do_cancel, width=10,height=1,padx=0,pady=.25, default="normal")
t.wm_protocol("WM_DELETE_WINDOW", self.cancel.invoke)
t.bind("<Return>", lambda event: (self.ok.flash(), self.ok.invoke()))
t.bind("<KP_Enter>", lambda event: (self.ok.flash(), self.ok.invoke()))
t.bind("<space>", lambda event: (self.ok.flash(), self.ok.invoke()))
t.bind("<Escape>", lambda event: (self.cancel.flash(), self.cancel.invoke()))
m.pack(side="top", anchor="w")
l.pack(side="top", anchor="w", fill="x", expand=1)
f.pack(side="bottom", anchor="e")
self.ok.pack(side="left", padx=3, pady=3)
self.cancel.pack(side="left", padx=3, pady=3)
def do_ok(self):
self.status=True
self.t.destroy()
def do_cancel(self):
self.status=False
self.t.destroy()
def result(self):
return self.status
def run(self):
self.t.grab_set()
self.t.wait_window()
try:
self.t.destroy()
except Tkinter.TclError:
pass
return self.result()
def prompt_areyousure(title, text):
t = _prompt_areyousure(title, text)
return t.run()
class _prompt_float:
""" Prompt for a g-code floating point expression """
def __init__(self, title, text, default, unit_str=''):
self.unit_str = unit_str
t.wm_title(title)
self.m = m = Message(t, text=text, aspect=500, anchor="w", justify="left")
self.v = v = StringVar(t)
self.vv = vv = DoubleVar(t)
self.u = u = BooleanVar(t)
aspect=500)
v.set(default)
self.e = e = Entry(t, textvariable=v)
self.ok = Tkinter.Button(f, text=_("OK"), command=self.do_ok, width=10,height=1,padx=0,pady=.25, default="active")
v.trace("w", self.check_valid)
self.m.configure(text=text)
def do_ok(self):
self.u.set(True)
self.t.destroy()
self.u.set(False)
self.t.destroy()
def check_valid(self, *args):
v = self.v.get()
st = 0
ok = 1
if "#" in v:
ok = 0
self.w.set("Variables may not be used here")
if ok:
for ch in v:
if ch == "[": st += 1
elif ch == "]": st -= 1
if st < 0:
ok = 0
self.w.set("Right bracket without matching left bracket")
break
if st != 0:
self.w.set("Left bracket without matching right bracket")
ok = 0
if ok:
ok, value = parse_gcode_expression(v)
if ok:
self.w.set("= %f%s" % (value, self.unit_str))
self.vv.set(value)
else:
self.w.set(value)
if ok:
self.ok.configure(state="normal")
else:
self.ok.configure(state="disabled")
def do_focus(self):
if not self.e.winfo_viewable():
self._after = self.t.after(10, self.do_focus)
else:
self.e.focus()
self.e.selection_range(0, "end")
self._after = None
def result(self):
if self.u.get(): return self.vv.get()
return None
def run(self):
self.t.grab_set()
self._after = self.t.after_idle(self.do_focus)
if self._after is not None:
self.t.after_cancel(self._after)
try:
self.t.destroy()
pass
def prompt_float(title, text, default, unit_str):
t = _prompt_float(title, text, default, unit_str)
return t.run()
all_systems = ['P1 G54', 'P2 G55', 'P3 G56', 'P4 G57', 'P5 G58',
'P6 G59', 'P7 G59.1', 'P8 G59.2', 'P9 G59.3',
_('T Tool Table')]
class _prompt_touchoff(_prompt_float):
def __init__(self, title, text_pattern, default, tool_only, defaultsystem):
systems = all_systems[:]
if not tool_only:
del systems[-1]
linear_axis = vars.current_axis.get() in "xyzuvw"
if linear_axis:
if vars.metric.get(): unit_str = " " + _("mm")
else: unit_str = " " + _("in")
if lathe and vars.current_axis.get() == "x":
if 80 in s.gcodes:
unit_str += _(" radius")
else:
unit_str += _(" diameter")
else: unit_str = _(u"\xb0")
self.text_pattern = text_pattern
text = text_pattern % self.workpiece_or_fixture(defaultsystem)
_prompt_float.__init__(self, title, text, default, unit_str)
t = self.t
f = Frame(t)
self.c = c = StringVar(t)
c.set(defaultsystem)
c.trace_variable("w", self.change_system)
if not tool_only:
l = Label(f, text=_("Coordinate System:"))
mb = OptionMenu(f, c, *systems)
mb.tk.call("size_menubutton_to_entries", mb)
mb.configure(takefocus=1)
l.pack(side="left")
mb.pack(side="left")
f.pack(side="top")
self.buttons.tkraise()
if not tool_only:
for i in [1,2,3,4,5,6,7,8,9]:
t.bind("<Alt-KeyPress-%s>" % i, lambda event, system=systems[i-1]: c.set(system))
if tool_only:
if current_tool.id > 0:
t.bind("<Alt-t>", lambda event: c.set(systems[9]))
t.bind("<Alt-0>", lambda event: c.set(systems[9]))
def workpiece_or_fixture(self, s):
if s.startswith('T') and vars.tto_g11.get():
return _("fixture")
return _("workpiece")
def change_system(self, *args):
system = self.c.get()
text = self.text_pattern % self.workpiece_or_fixture(system)
self.set_text(text)
def result(self):
if self.u.get(): return self.v.get(), self.c.get()
return None, None
def prompt_touchoff(title, text, default, tool_only, system=None):
t = _prompt_touchoff(title=title,
text_pattern=text,
default=default,
tool_only=tool_only,
defaultsystem=system
return t.run()
property_names = [
('name', _("Name:")), ('size', _("Size:")),
('tools', _("Tool order:")), ('g0', _("Rapid distance:")),
('g1', _("Feed distance:")), ('g', _("Total distance:")),
('run', _("Run time:")), ('x', _("X bounds:")),
('y', _("Y bounds:")), ('z', _("Z bounds:")),
('a', _("A bounds:")), ('b', _("B bounds:")),
('c', _("C bounds:"))
def dist((x,y,z),(p,q,r)):
return ((x-p)**2 + (y-q)**2 + (z-r)**2) ** .5
# returns units/sec
def get_jog_speed(a):
if vars.teleop_mode.get():
if a in (0,1,2,6,7,8):
return vars.jog_speed.get()/60.
else:
return vars.jog_aspeed.get()/60.
else:
if joint_type[a] == 'LINEAR':
else:
def get_max_jog_speed(a):
max_linear_speed = vars.max_speed.get()
max_linear_speed = to_internal_linear_unit(max_linear_speed)
if vars.metric.get(): max_linear_speed = max_linear_speed * 25.4
return max_linear_speed
else:
return vars.max_aspeed.get()
else:
else:
def run_warn():
warnings = []
if o.canon:
machine_limit_min, machine_limit_max = soft_limits()
for i in range(3): # Does not enforce angle limits
if not(s.axis_mask & (1<<i)): continue
if o.canon.min_extents_notool[i] < machine_limit_min[i]:
warnings.append(_("Program exceeds machine minimum on axis %s")
% "XYZABCUVW"[i])
if o.canon.max_extents_notool[i] > machine_limit_max[i]:
warnings.append(_("Program exceeds machine maximum on axis %s")
% "XYZABCUVW"[i])
if warnings:
text = "\n".join(warnings)
return int(root_window.tk.call("nf_dialog", ".error",
_("Program exceeds machine limits"),
text,
"warning",
1, _("Run Anyway"), _("Cancel")))
return 0
def reload_file(refilter=True):
if running(): return
s.poll()
if not loaded_file:
return
line = vars.highlight_line.get()
o.set_highlight_line(None)
if refilter or not get_filter(loaded_file):
open_file_guts(loaded_file, False, False)
else:
tempfile = os.path.join(tempdir, os.path.basename(loaded_file))
if line:
o.set_highlight_line(line)
class TclCommands(nf.TclCommands):
def next_tab(event=None):
current = widgets.right.raise_page()
pages = widgets.right.pages()
try:
idx = pages.index(current)
except ValueError:
idx = -1
newidx = (idx + 1) % len(pages)
widgets.right.raise_page(pages[newidx])
root_window.focus_force()
def redraw_soon(event=None):
o.redraw_soon()
def to_internal_linear_unit(a, b=None):
if b is not None: b = float(b)
return to_internal_linear_unit(float(a), b)
def from_internal_linear_unit(a, b=None):
return from_internal_linear_unit(float(a), b)
def toggle_tto_g11(event=None):
ap.putpref("tto_g11", vars.tto_g11.get())
def toggle_optional_stop(event=None):
c.set_optional_stop(vars.optional_stop.get())
ap.putpref("optional_stop", vars.optional_stop.get())
def toggle_block_delete(event=None):
c.set_block_delete(vars.block_delete.get())
ap.putpref("block_delete", vars.block_delete.get())
c.wait_complete()
ensure_mode(linuxcnc.MODE_MANUAL)
s.poll()
o.tkRedraw()
reload_file(False)
def gcode_properties(event=None):
props = {}
if not loaded_file:
props['name'] = _("No file loaded")
else:
ext = os.path.splitext(loaded_file)[1]
program_filter = None
if ext:
program_filter = inifile.find("FILTER", ext[1:])
name = os.path.basename(loaded_file)
if program_filter:
props['name'] = _("generated from %s") % name
else:
props['name'] = name
size = os.stat(loaded_file).st_size
lines = int(widgets.text.index("end").split(".")[0])-2
props['size'] = _("%(size)s bytes\n%(lines)s gcode lines") % {'size': size, 'lines': lines}
conv = 1
units = _("mm")
fmt = "%.3f"
else:
conv = 1/25.4
units = _("in")
fmt = "%.4f"
mf = vars.max_speed.get()
#print o.canon.traverse[0]
g0 = sum(dist(l[1][:3], l[2][:3]) for l in o.canon.traverse)
g1 = (sum(dist(l[1][:3], l[2][:3]) for l in o.canon.feed) +
sum(dist(l[1][:3], l[2][:3]) for l in o.canon.arcfeed))
gt = (sum(dist(l[1][:3], l[2][:3])/min(mf, l[3]) for l in o.canon.feed) +
sum(dist(l[1][:3], l[2][:3])/min(mf, l[3]) for l in o.canon.arcfeed) +
sum(dist(l[1][:3], l[2][:3])/mf for l in o.canon.traverse) +
o.canon.dwell_time
props['g0'] = "%f %s".replace("%f", fmt) % (from_internal_linear_unit(g0, conv), units)
props['g1'] = "%f %s".replace("%f", fmt) % (from_internal_linear_unit(g1, conv), units)
if gt > 120:
props['run'] = _("%.1f minutes") % (gt/60)
else:
props['run'] = _("%d seconds") % (int(gt))
min_extents = from_internal_units(o.canon.min_extents, conv)
max_extents = from_internal_units(o.canon.max_extents, conv)
for (i, c) in enumerate("xyz"):
a = min_extents[i]
b = max_extents[i]
if a != b:
props[c] = _("%(a)f to %(b)f = %(diff)f %(units)s").replace("%f", fmt) % {'a': a, 'b': b, 'diff': b-a, 'units': units}
properties(root_window, _("G-Code Properties"), property_names, props)
def launch_website(event=None):
import webbrowser
webbrowser.open("http://www.linuxcnc.org/")
def set_spindlerate(newval):
global spindlerate_blackout
try:
value = int(newval)
except ValueError: return
value = value / 100.
c.spindleoverride(value)
spindlerate_blackout = time.time() + 1
def set_feedrate(newval):
try:
value = int(newval)
c.feedrate(value)
feedrate_blackout = time.time() + 1
def set_rapidrate(newval):
global rapidrate_blackout
try:
value = int(newval)
c.rapidrate(value)
rapidrate_blackout = time.time() + 1
def set_maxvel(newval):
newval = float(newval)
if vars.metric.get(): newval = newval / 25.4
newval = from_internal_linear_unit(newval)
global maxvel_blackout
c.maxvel(newval / 60.)
maxvel_blackout = time.time() + 1
def copy_line(*args):
line = -1
if vars.running_line.get() != -1: line = vars.running_line.get()
if vars.highlight_line.get() != -1: line = vars.highlight_line.get()
if line == -1: return
selection.set_value(t.get("%d.8" % line, "%d.end" % line))
def task_run_line(*args):
if line != -1: set_first_line(line)
commands.task_run()
def reload_tool_table(*args):
c.load_tool_table()
def program_verify(*args):
set_first_line(-1)
commands.task_run()
def zoomin(event=None):
o.zoomin()
def zoomout(event=None):
o.zoomout()
def set_view_x(event=None):
widgets.view_x.configure(relief="sunken")
vars.view_type.set(3)
o.set_view_x()
def set_view_y(event=None):
widgets.view_y.configure(relief="sunken")
vars.view_type.set(4)
o.set_view_y()
def set_view_z(event=None):
widgets.view_z.configure(relief="sunken")
vars.view_type.set(1)
o.set_view_z()
def set_view_z2(event=None):
widgets.view_z2.configure(relief="sunken")
vars.view_type.set(2)
o.set_view_z2()
def set_view_p(event=None):
widgets.view_p.configure(relief="sunken")
vars.view_type.set(5)
o.set_view_p()
def estop_clicked(event=None):
s.poll()
if s.task_state == linuxcnc.STATE_ESTOP:
c.state(linuxcnc.STATE_ESTOP_RESET)
else:
c.state(linuxcnc.STATE_ESTOP)
def onoff_clicked(event=None):
s.poll()
if s.task_state == linuxcnc.STATE_ESTOP_RESET:
c.state(linuxcnc.STATE_ON)
else:
c.state(linuxcnc.STATE_OFF)
def open_file(*event):
global open_directory
all_extensions = tuple([".ngc"])
for e in extensions:
all_extensions = all_extensions + tuple(e[1])
types = (
(_("All machinable files"), all_extensions),
(_("rs274ngc files"), ".ngc")) + extensions + \
((_("All files"), "*"),)
f = root_window.tk.call("tk_getOpenFile", "-initialdir", open_directory,
"-filetypes", types)
if not f: return
f = str(f)
open_directory = os.path.dirname(f)
commands.open_file_name(f)
def remote (cmd,arg=""):
if cmd == "clear_live_plot":
commands.clear_live_plot()
return ""
if running():
return _("axis cannot accept remote command while running")
if cmd == "open_file_name":
commands.open_file_name(arg)
elif cmd == "send_mdi_command":
commands.send_mdi_command(arg)
elif cmd == "reload_file":
commands.reload_file()
elif cmd == "destroy":
root_window.tk.call("destroy", ".")
return ""
def open_file_name(f):
open_file_guts(f)
commands.set_view_x()
commands.set_view_y()
elif str(widgets.view_z['relief']) == "sunken":
commands.set_view_z()
elif str(widgets.view_z2['relief']) == "sunken":
commands.set_view_z2()
else:
commands.set_view_p()
x = (o.canon.min_extents[0] + o.canon.max_extents[0])/2
y = (o.canon.min_extents[1] + o.canon.max_extents[1])/2
z = (o.canon.min_extents[2] + o.canon.max_extents[2])/2
o.set_centerpoint(x, y, z)
def open_pipe(f, c):
try:
os.makedirs(os.path.join(tempdir, "pipe"))
except os.error:
pass
f = os.path.join(tempdir, "pipe", os.path.basename(f))
fi = open(f, "w")
fi.write(c)
fi.close()
def reload_file(*event):
reload_file()
def edit_program(*event):
if loaded_file is None:
pass
else:
omode = 0
showname = os.path.basename(loaded_file)
if not os.access(loaded_file,os.W_OK):
omode = root_window.tk.call(
"nf_dialog",
".filenotwritable",
_("File not Writable:") + showname,
_("This file is not writable\n"
"You can Edit-readonly\n\n"
"or\n\n"
"Save it to your own directory\n"
"then open that saved, writable file"),
"warning",
0,
_("Edit-readonly"),
_("Save"),
_("Cancel")
if omode == 1:
root_window.tk.call("save_gcode",
"my_" + showname)
return
elif omode == 2: return
e = string.split(editor)
if os.path.splitext(loaded_file)[1] == '.dxf':
fs=os.path.join(open_directory, 'edit_dxf.ngc')
e.append(fs)
else:
e.append(loaded_file)
e.append("&")
root_window.tk.call("exec", *e)
def edit_tooltable(*event):
if tooltable is None:
pass
else:
e = string.split(tooleditor)
e.append(tooltable)
e.append("&")
def task_run(*event):
if run_warn(): return
global program_start_line, program_start_line_last
program_start_line_last = program_start_line;
c.auto(linuxcnc.AUTO_RUN, program_start_line)
def task_step(*event):
if s.task_mode != linuxcnc.MODE_AUTO or s.interp_state != linuxcnc.INTERP_IDLE:
c.auto(linuxcnc.AUTO_STEP)
def task_pause(*event):
if s.task_mode != linuxcnc.MODE_AUTO or s.interp_state not in (linuxcnc.INTERP_READING, linuxcnc.INTERP_WAITING):
return
c.auto(linuxcnc.AUTO_PAUSE)
def task_resume(*event):
s.poll()
if not s.paused:
return
if s.task_mode not in (linuxcnc.MODE_AUTO, linuxcnc.MODE_MDI):
return
ensure_mode(linuxcnc.MODE_AUTO, linuxcnc.MODE_MDI)
c.auto(linuxcnc.AUTO_RESUME)
def task_pauseresume(*event):
return
s.poll()
if s.paused:
if resume_inhibit: return
elif s.interp_state != linuxcnc.INTERP_IDLE:
def task_stop(*event):
if s.task_mode == linuxcnc.MODE_AUTO and vars.running_line.get() != 0:
o.set_highlight_line(vars.running_line.get())
c.abort()
c.wait_complete()
def mdi_up_cmd(*args):
if args and args[0].char: return # e.g., for KP_Up with numlock on
global mdi_history_index
if widgets.mdi_command.cget("state") == "disabled":
return
if mdi_history_index != -1:
if mdi_history_index > 0:
mdi_history_index -= 1
else:
mdi_history_index = widgets.mdi_history.size() - 1
widgets.mdi_history.selection_clear(0, "end")
widgets.mdi_history.see(mdi_history_index)
if mdi_history_index != (widgets.mdi_history.size() - 1):
widgets.mdi_history.selection_set(mdi_history_index, mdi_history_index)
vars.mdi_command.set(widgets.mdi_history.get(mdi_history_index))
widgets.mdi_command.selection_range(0, "end")
def mdi_down_cmd(*args):
return
history_size = widgets.mdi_history.size()
if mdi_history_index < (history_size - 1):
mdi_history_index += 1
else:
mdi_history_index = 0
def send_mdi(*event):
if not manual_ok(): return "break"
command = vars.mdi_command.get()
commands.send_mdi_command(command)
return "break"
def send_mdi_command(command):
global mdi_history_index, mdi_history_save_filename
if command != "":
command= command.lstrip().rstrip()
vars.mdi_command.set("")
## check if input is already in list. If so, then delete old element
#idx = 0
#for ele in widgets.mdi_history.get(0, "end"):
# if ele == command:
# widgets.mdi_history.delete(idx)
# break
# idx += 1
new_entry = 1
if history_size > 1 and widgets.mdi_history.get(history_size - 2) == command:
new_entry = 0
if new_entry != 0:
# if command is already at end of list, don't add it again
widgets.mdi_history.insert(history_size - 1, "%s" % command)
history_size += 1
widgets.mdi_history.see(history_size - 1)
if history_size > (mdi_history_max_entries + 1):
widgets.mdi_history.delete(0, 0)
history_size= (mdi_history_max_entries + 1)
# pdb.set_trace()
mdi_history_index = widgets.mdi_history.index("end") - 1
c.mdi(command)
o.tkRedraw()
commands.mdi_history_write_to_file(mdi_history_save_filename, history_size)
# write out mdi history file (history_size equal to -1 will delete history)
def mdi_history_write_to_file(file_name, history_size):
# print "mdi_history_write: %s : %d" % (file_name, history_size)
if history_size > 1 or history_size == -1:
file_name = os.path.expanduser(file_name)
try:
f = open(file_name, "w")
try:
if history_size != -1:
for idx in range(history_size - 1):
f.write("%s\n" % widgets.mdi_history.get(idx, idx))
finally:
f.close()
except IOError:
print >>sys.stderr, "Can't open MDI history file [%s] for writing" % file_name
def mdi_history_hist2clip(*event):
cursel = widgets.mdi_history.curselection()
root_window.clipboard_clear()
selection = ""
count = 0
if cursel != "":
for data in cursel:
selection += "%s\n" % widgets.mdi_history.get(data)
count += 1
if selection != "":
root_window.clipboard_append(selection, type = "STRING")
def mdi_history_clip2hist(*event):
try:
count = 0
for data in root_window.selection_get(selection="CLIPBOARD").split("\n"):
if data != "":
new_entry = 1
if history_size > 1 and widgets.mdi_history.get(history_size - 2) == data:
new_entry = 0
if new_entry != 0:
widgets.mdi_history.insert(history_size - 1, "%s" % data)
history_size += 1
count += 1
return
print "DBG: Sorry, but the clipboard is empty ..."
def mdi_history_double_butt_1(event):
return
cursel= widgets.mdi_history.index("active")
if cursel < (widgets.mdi_history.size() - 1):
commands.send_mdi(event)
def mdi_history_butt_1(event):
if len(widgets.mdi_history.curselection()) > 1:
# multiple selection: clear mdi entry field and return
return
cursel = widgets.mdi_history.index('@' + str(event.x) + ',' + str(event.y))
bbox = widgets.mdi_history.bbox(cursel)
if bbox and (event.y <= (bbox[1] + bbox[3])) and (cursel < widgets.mdi_history.size() - 1):
mdi_history_index = cursel
vars.mdi_command.set(widgets.mdi_history.get(cursel))
else:
widgets.mdi_history.see("end")
def clear_mdi_history(*ignored):
widgets.mdi_history.delete(0, "end")
widgets.mdi_history.insert(0, "")
widgets.mdi_history.see(0)
widgets.mdi_history.selection_clear(0, 0)
commands.mdi_history_write_to_file(mdi_history_save_filename, -1)
def ensure_manual(*event):
commands.set_teleop_mode()
def ensure_mdi(*event):
def redraw(*ignored):
o.tkRedraw()
def toggle_show_rapids(*event):
ap.putpref("show_rapids", vars.show_rapids.get())
o.tkRedraw()
def toggle_show_program(*event):
ap.putpref("show_program", vars.show_program.get())
o.tkRedraw()
def toggle_program_alpha(*event):
ap.putpref("program_alpha", vars.program_alpha.get())
o.tkRedraw()
def toggle_show_live_plot(*event):
ap.putpref("show_live_plot", vars.show_live_plot.get())
o.tkRedraw()
def toggle_show_tool(*event):
ap.putpref("show_tool", vars.show_tool.get())
o.tkRedraw()
def toggle_show_extents(*event):
ap.putpref("show_extents", vars.show_extents.get())
o.tkRedraw()
def toggle_show_offsets(*event):
ap.putpref("show_offsets", vars.show_offsets.get())
o.tkRedraw()
def set_grid_size(*event):
ap.putpref("grid_size", vars.grid_size.get(), type=float)
o.tkRedraw()
def set_grid_size_custom(*event):
v = prompt_float("Custom Grid", "Enter grid size",
"", unit_str) or 0
if v <= 0: return
if vars.metric.get(): v /= 25.4
match_grid_size(v)
def toggle_show_machine_limits(*event):
ap.putpref("show_machine_limits", vars.show_machine_limits.get())
o.tkRedraw()
def toggle_show_machine_speed(*event):
ap.putpref("show_machine_speed", vars.show_machine_speed.get())
o.tkRedraw()
def toggle_show_distance_to_go(*event):
ap.putpref("show_distance_to_go", vars.show_distance_to_go.get())
o.tkRedraw()
def toggle_dro_large_font(*event):
ap.putpref("dro_large_font", vars.dro_large_font.get())
get_coordinate_font(vars.dro_large_font.get())
o.tkRedraw()
def clear_live_plot(*ignored):
live_plotter.clear()
# The next three don't have 'manual_ok' because that's done in jog_on /
# jog_off
def jog_plus(incr=False):
a = vars.current_axis.get()
if isinstance(a, (str, unicode)):
a = "xyzabcuvw".index(a)
speed = get_jog_speed(a)
jog_on(a, speed)
def jog_minus(incr=False):
jog_on(a, -speed)
def jog_stop(event=None):
jog_off(vars.current_axis.get())
def home_all_axes(event=None):
isHomed=True
for i,h in enumerate(s.homed):
if s.axis_mask & (1<<i):
isHomed=isHomed and h
doHoming=True
if isHomed:
doHoming=prompt_areyousure(_("Warning"),_("Axis is already homed, are you sure you want to re-home?"))
if doHoming:
c.home(-1)
def unhome_all_axes(event=None):
c.unhome(-1)
def home_axis(event=None):
doHoming=True
if s.homed["xyzabcuvw".index(vars.current_axis.get())]:
doHoming=prompt_areyousure(_("Warning"),_("This axis is already homed, are you sure you want to re-home?"))
if doHoming:
c.home("xyzabcuvw".index(vars.current_axis.get()))
def unhome_axis(event=None):
c.unhome("xyzabcuvw".index(vars.current_axis.get()))
def home_axis_number(num):
c.home(num)
def unhome_axis_number(num):
c.unhome(num)
def clear_offset(num):
s.poll()
if num == "G92":
clear_command = "G92.1"
else:
clear_command = "G10 L2 P%c R0" % num
for i, a in enumerate("XYZABCUVW"):
if s.axis_mask & (1<<i): clear_command += " %c0" % a
c.mdi(clear_command)
c.wait_complete()
s.poll()
o.tkRedraw()
reload_file(False)
def touch_off_system(event=None, new_axis_value = None):
global system
if joints_mode(): return
offset_axis = "xyzabcuvw".index(vars.current_axis.get())
if new_axis_value is None:
new_axis_value, system = prompt_touchoff(
title=_("Touch Off (system)"),
text=_("Enter %s coordinate relative to %%s:") % vars.current_axis.get().upper(),
default=0.0,
tool_only=False,
system=vars.touch_off_system.get()
else:
system = vars.touch_off_system.get()
if new_axis_value is None: return
vars.touch_off_system.set(system)
s.poll()
if linear_axis and vars.metric.get(): scale = 1/25.4
else: scale = 1
if linear_axis and 210 in s.gcodes:
scale *= 25.4
offset_command = "G10 L20 %s %c[%s*%.12f]" % (system.split()[0], vars.current_axis.get(), new_axis_value, scale)
c.mdi(offset_command)
c.wait_complete()
s.poll()
o.tkRedraw()
reload_file(False)
def touch_off_tool(event=None, new_axis_value = None):
global system
s.poll()
# in case we get here via the keyboard shortcut, when the widget is disabled:
if s.tool_in_spindle == 0: return
title=_("Tool Touch Off (Tool No:%s)"%s.tool_in_spindle),
default=0.0,
tool_only=True,
else:
s.poll()
else: scale = 1
scale *= 25.4
lnum = 10 + vars.tto_g11.get()
offset_command = "G10 L%d P%d %c[%s*%.12f]" % (lnum, s.tool_in_spindle, vars.current_axis.get(), new_axis_value, scale)
c.wait_complete()
c.mdi("G43")
c.wait_complete()
s.poll()
o.tkRedraw()
reload_file(False)
def set_axis_offset(event=None):
commands.touch_off_system(new_axis_value=0.)
def brake(event=None):
c.brake(vars.brake.get())
def flood(event=None):
c.flood(vars.flood.get())
def mist(event=None):
c.mist(vars.mist.get())
def spindle(event=None):
c.spindle(vars.spindledir.get(),default_spindle_speed)
def spindle_increase(event=None):
c.spindle(linuxcnc.SPINDLE_INCREASE)
def spindle_decrease(event=None):
c.spindle(linuxcnc.SPINDLE_DECREASE)
def spindle_constant(event=None):
c.spindle(linuxcnc.SPINDLE_CONSTANT)
def mist_toggle(*args):
s.poll()
c.mist(not s.mist)
def flood_toggle(*args):
s.poll()
c.flood(not s.flood)
def spindle_forward_toggle(*args):
s.poll()
if s.spindle_direction == 0:
c.spindle(linuxcnc.SPINDLE_FORWARD,default_spindle_speed)
else:
c.spindle(linuxcnc.SPINDLE_OFF)
def spindle_backward_toggle(*args):
s.poll()
c.spindle(linuxcnc.SPINDLE_REVERSE,default_spindle_speed)
else:
return "break" # bound to F10, don't activate menu
def brake_on(*args):
c.brake(1)
def brake_off(*args):
c.brake(0)
def toggle_display_type(*args):
vars.display_type.set(not vars.display_type.get())
o.tkRedraw()
def toggle_teleop_mode(*args):
vars.teleop_mode.set(not vars.teleop_mode.get())
def toggle_coord_type(*args):
vars.coord_type.set(not vars.coord_type.get())
o.tkRedraw()
def toggle_override_limits(*args):
s.poll()
if s.interp_state != linuxcnc.INTERP_IDLE: return
if s.axis[0]['override_limits']:
else:
c.override_limits()
def cycle_view(*args):
else:
def axis_activated(*args):
if not hal_present: return # this only makes sense if HAL is present on this machine
comp['jog.x'] = vars.current_axis.get() == "x"
comp['jog.y'] = vars.current_axis.get() == "y"
comp['jog.z'] = vars.current_axis.get() == "z"
comp['jog.a'] = vars.current_axis.get() == "a"
comp['jog.b'] = vars.current_axis.get() == "b"
comp['jog.c'] = vars.current_axis.get() == "c"
comp['jog.u'] = vars.current_axis.get() == "u"
comp['jog.v'] = vars.current_axis.get() == "v"
comp['jog.w'] = vars.current_axis.get() == "w"
def set_teleop_mode(*args):
teleop_mode = vars.teleop_mode.get()
c.teleop_enable(teleop_mode)
c.wait_complete()
def save_gcode(*args):
if not loaded_file: return
initialfile = ''
if len(args):
initialfile = args[0]
f = root_window.tk.call("tk_getSaveFile", "-initialdir", open_directory,
"-initialfile", initialfile,
"-filetypes",
((_("rs274ngc files"), ".ngc"),))
if not f: return
f = unicode(f)
if get_filter(loaded_file):
srcfile = os.path.join(tempdir, os.path.basename(loaded_file))
else:
srcfile = loaded_file
try:
shutil.copyfile(srcfile, f)
except (shutil.Error, os.error, IOError), detail:
tb = traceback.format_exc()
root_window.tk.call("nf_dialog", ".error", _("Error saving file"),
str(detail), "error", 0, _("OK"))
else:
add_recent_file(f)
def goto_sensible_line():
line = o.get_highlight_line()
if not line: line = vars.running_line.get()
def dynamic_tab(name, text):
return _dynamic_tab(name,text) # caller: make a frame and pack
def inifindall(section, item):
items = tuple(inifile.findall(section, item))
return root_window.tk.merge(*items)
commands = TclCommands(root_window)
vars = nf.Variables(root_window,
("linuxcnctop_command", StringVar),
("emcini", StringVar),
("mdi_command", StringVar),
("taskfile", StringVar),
("interp_pause", IntVar),
("exec_state", IntVar),
("task_state", IntVar),
("task_paused", IntVar),
("interp_state", IntVar),
("task_mode", IntVar),
("has_ladder", IntVar),
("has_editor", IntVar),
("current_axis", StringVar),
("tto_g11", BooleanVar),
("mist", BooleanVar),
("flood", BooleanVar),
("brake", BooleanVar),
("spindledir", IntVar),
("running_line", IntVar),
("highlight_line", IntVar),
("show_program", IntVar),
("program_alpha", IntVar),
("show_live_plot", IntVar),
("show_tool", IntVar),
("show_extents", IntVar),
("show_offsets", IntVar),
("grid_size", DoubleVar),
("show_machine_limits", IntVar),
("show_machine_speed", IntVar),
("show_distance_to_go", IntVar),
("dro_large_font", IntVar),
("show_rapids", IntVar),
("feedrate", IntVar),
("rapidrate", IntVar),
("spindlerate", IntVar),
("tool", StringVar),
("active_codes", StringVar),
("metric", IntVar),
("coord_type", IntVar),
("display_type", IntVar),
("override_limits", BooleanVar),
("view_type", IntVar),
("jog_speed", DoubleVar),
("jog_aspeed", DoubleVar),
("max_speed", DoubleVar),
("max_aspeed", DoubleVar),
("maxvel_speed", DoubleVar),
("max_maxvel", DoubleVar),
("teleop_mode", IntVar),
("motion_mode", IntVar),
("kinematics_type", IntVar),
("optional_stop", BooleanVar),
("block_delete", BooleanVar),
("rotate_mode", BooleanVar),
("touch_off_system", StringVar),
("machine", StringVar),
("on_any_limit", BooleanVar),
("queued_mdi_commands", IntVar),
("max_queued_mdi_commands", IntVar),
vars.linuxcnctop_command.set(os.path.join(os.path.dirname(sys.argv[0]), "linuxcnctop"))
vars.highlight_line.set(-1)
vars.running_line.set(-1)
vars.tto_g11.set(ap.getpref("tto_g11", False))
vars.show_program.set(ap.getpref("show_program", True))
vars.show_rapids.set(ap.getpref("show_rapids", True))
vars.program_alpha.set(ap.getpref("program_alpha", False))
vars.show_live_plot.set(ap.getpref("show_live_plot", True))
vars.show_tool.set(ap.getpref("show_tool", True))
vars.show_extents.set(ap.getpref("show_extents", True))
vars.show_offsets.set(ap.getpref("show_offsets", True))
vars.grid_size.set(ap.getpref("grid_size", 0.0, type=float))
vars.show_machine_limits.set(ap.getpref("show_machine_limits", True))
vars.show_machine_speed.set(ap.getpref("show_machine_speed", True))
vars.show_distance_to_go.set(ap.getpref("show_distance_to_go", False))
vars.dro_large_font.set(ap.getpref("dro_large_font", False))
vars.block_delete.set(ap.getpref("block_delete", True))
vars.optional_stop.set(ap.getpref("optional_stop", True))
# placeholder function for LivePlotter.update():
def user_live_update():
pass
vars.touch_off_system.set("P1 G54")
def set_feedrate(n):
widgets.feedoverride.set(n)
def set_rapidrate(n):
widgets.rapidoverride.set(n)
def activate_axis_or_set_feedrate(n):
# XXX: axis_mask does not apply if in joint mode
if manual_ok() and s.axis_mask & (1<<n):
activate_axis(n)
else:
set_feedrate(10*n)
def nomodifier(f):
def g(event):
if event.state & (1|4|8|32|64|128): return ""
return f(event)
return g
def kp_wrap(f,g):
return nomodifier(f)
root_window.bind("<Escape>", commands.task_stop)
root_window.bind("l", commands.toggle_override_limits)
root_window.bind("o", commands.open_file)
root_window.bind("s", commands.task_resume)
root_window.bind("t", commands.task_step)
root_window.bind("p", commands.task_pause)
root_window.bind("v", commands.cycle_view)
root_window.bind("<Alt-p>", "#nothing")
root_window.bind("r", commands.task_run)
root_window.bind("<Control-r>", commands.reload_file)
root_window.bind("<Control-s>", commands.save_gcode)
root_window.bind_class("all", "<Key-F1>", commands.estop_clicked)
root_window.bind("<Key-F2>", commands.onoff_clicked)
root_window.bind("<Key-F7>", commands.mist_toggle)
root_window.bind("<Key-F8>", commands.flood_toggle)
root_window.bind("<Key-F9>", commands.spindle_forward_toggle)
root_window.bind("<Key-F10>", commands.spindle_backward_toggle)
root_window.bind("<Key-F11>", commands.spindle_decrease)
root_window.bind("<Key-F12>", commands.spindle_increase)
root_window.bind("B", commands.brake_on)
root_window.bind("b", commands.brake_off)
root_window.bind("<Control-k>", commands.clear_live_plot)
root_window.bind("x", lambda event: activate_axis(0))
root_window.bind("y", lambda event: activate_axis(1))
root_window.bind("z", lambda event: activate_axis(2))
root_window.bind("a", lambda event: activate_axis(3))
root_window.bind("`", lambda event: activate_axis_or_set_feedrate(0))
root_window.bind("1", lambda event: activate_axis_or_set_feedrate(1))
root_window.bind("2", lambda event: activate_axis_or_set_feedrate(2))
root_window.bind("3", lambda event: activate_axis_or_set_feedrate(3))
root_window.bind("4", lambda event: activate_axis_or_set_feedrate(4))
root_window.bind("5", lambda event: activate_axis_or_set_feedrate(5))
root_window.bind("6", lambda event: activate_axis_or_set_feedrate(6))
root_window.bind("7", lambda event: activate_axis_or_set_feedrate(7))
root_window.bind("8", lambda event: activate_axis_or_set_feedrate(8))
root_window.bind("9", lambda event: set_feedrate(90))
root_window.bind("0", lambda event: set_feedrate(100))
root_window.bind("c", lambda event: jogspeed_continuous())
root_window.bind("d", lambda event: widgets.rotate.invoke())
root_window.bind("i", lambda event: jogspeed_incremental())
root_window.bind("I", lambda event: jogspeed_incremental(-1))
root_window.bind("!", "set metric [expr {!$metric}]; redraw")
root_window.bind("@", commands.toggle_display_type)
root_window.bind("#", commands.toggle_coord_type)
root_window.bind("$", commands.toggle_teleop_mode)
root_window.bind("<Home>", commands.home_axis)
root_window.bind("<KP_Home>", kp_wrap(commands.home_axis, "KeyPress"))
root_window.bind("<Control-Home>", commands.home_all_axes)
root_window.bind("<Shift-Home>", commands.set_axis_offset)
root_window.bind("<End>", commands.touch_off_system)
root_window.bind("<Control-End>", commands.touch_off_tool)
root_window.bind("<Control-KP_Home>", kp_wrap(commands.home_all_axes, "KeyPress"))
root_window.bind("<Shift-KP_Home>", kp_wrap(commands.set_axis_offset, "KeyPress"))
root_window.bind("<KP_End>", kp_wrap(commands.touch_off_system, "KeyPress"))
widgets.mdi_history.bind("<Configure>", "%W see end" )
widgets.mdi_history.bind("<ButtonRelease-1>", commands.mdi_history_butt_1)
widgets.mdi_history.bind("<Double-Button-1>", commands.mdi_history_double_butt_1)
widgets.mdi_command.unbind("<Control-h>")
widgets.mdi_command.bind("<Control-m>", commands.clear_mdi_history)
widgets.mdi_command.bind("<Control-h>", commands.mdi_history_hist2clip)
widgets.mdi_command.bind("<Control-Shift-H>", commands.mdi_history_clip2hist)
widgets.mdi_command.bind("<Key-Return>", commands.send_mdi)
widgets.mdi_command.bind("<Up>", commands.mdi_up_cmd)
widgets.mdi_command.bind("<Down>", commands.mdi_down_cmd)
widgets.mdi_command.bind("<Key-KP_Enter>", commands.send_mdi)
widgets.mdi_command.bind("<KP_Up>", commands.mdi_up_cmd)
widgets.mdi_command.bind("<KP_Down>", commands.mdi_down_cmd)
widgets.mdi_command.bind("<KeyRelease-minus>", "break")
widgets.mdi_command.bind("<KeyRelease-equal>", "break")
# try to read back previously saved mdi history data
mdi_hist_file = os.path.expanduser(mdi_history_save_filename)
try:
line_cnt = 0
f = open(mdi_hist_file, "r")
try:
for line in f:
line_cnt += 1
finally:
f.seek(0)
skip = line_cnt - mdi_history_max_entries
history_size = 1
try:
for line in f:
if skip <= 0:
widgets.mdi_history.insert(history_size - 1, "%s" % line.rstrip("\r\n"))
mdi_history_index = history_size
history_size += 1
else:
skip -= 1
finally:
f.close()
except IOError:
pass
def jog(*args):
if not manual_tab_visible(): return
c.jog(*args)
# XXX correct for machines with more than six axes
jog_after = [None] * 9
jog_cont = [False] * 9
jogging = [0] * 9
def jog_on(a, b):
if a < 3 or a > 5:
if vars.metric.get(): b = b / 25.4
b = from_internal_linear_unit(b)
if jog_after[a]:
root_window.after_cancel(jog_after[a])
jog_after[a] = None
return
if s.motion_mode == linuxcnc.TRAJ_MODE_TELEOP:
jogging[a] = b
jog_cont[a] = False
cartesian_only=jogging[:6]
c.teleop_vector(*cartesian_only)
else:
if jogincr != _("Continuous"):
s.poll()
if s.state != 1: return
jog(linuxcnc.JOG_INCREMENT, a, b, distance)
jog_cont[a] = False
else:
jog(linuxcnc.JOG_CONTINUOUS, a, b)
jog_cont[a] = True
jogging[a] = b
def jog_off(a):
if jog_after[a]: return
jog_after[a] = root_window.after_idle(lambda: jog_off_actual(a))
def jog_off_actual(a):
activate_axis(a)
jog_after[a] = None
jogging[a] = 0
else:
if jog_cont[a]:
jog(linuxcnc.JOG_STOP, a)
def jog_off_all():
for i in range(6):
if jogging[i]:
jog_off_actual(i)
def bind_axis(a, b, d):
root_window.bind("<KeyPress-%s>" % a, kp_wrap(lambda e: jog_on(d, -get_jog_speed(d)), "KeyPress"))
root_window.bind("<KeyPress-%s>" % b, kp_wrap(lambda e: jog_on(d, get_jog_speed(d)), "KeyPress"))
root_window.bind("<Shift-KeyPress-%s>" % a, lambda e: jog_on(d, -get_max_jog_speed(d)))
root_window.bind("<Shift-KeyPress-%s>" % b, lambda e: jog_on(d, get_max_jog_speed(d)))
root_window.bind("<KeyRelease-%s>" % a, lambda e: jog_off(d))
root_window.bind("<KeyRelease-%s>" % b, lambda e: jog_off(d))
root_window.bind("<FocusOut>", lambda e: str(e.widget) == "." and jog_off_all())
open_directory = "programs"
unit_values = {'inch': 1/25.4, 'mm': 1}
def units(s, d=1.0):
try:
return float(s)
except ValueError:
return unit_values.get(s, d)
random_toolchanger = int(inifile.find("EMCIO", "RANDOM_TOOLCHANGER") or 0)
vars.emcini.set(sys.argv[2])
open_directory = inifile.find("DISPLAY", "PROGRAM_PREFIX")
vars.machine.set(inifile.find("EMC", "MACHINE"))
extensions = inifile.findall("FILTER", "PROGRAM_EXTENSION")
extensions = [e.split(None, 1) for e in extensions]
extensions = tuple([(v, tuple(k.split(","))) for k, v in extensions])
postgui_halfile = inifile.find("HAL", "POSTGUI_HALFILE")
max_feed_override = float(inifile.find("DISPLAY", "MAX_FEED_OVERRIDE"))
max_spindle_override = float(inifile.find("DISPLAY", "MAX_SPINDLE_OVERRIDE") or max_feed_override)
max_feed_override = int(max_feed_override * 100 + 0.5)
max_spindle_override = int(max_spindle_override * 100 + 0.5)
default_spindle_speed = int(inifile.find("DISPLAY", "DEFAULT_SPINDLE_SPEED") or 1)
geometry = inifile.find("DISPLAY", "GEOMETRY") or "XYZBCUVW"
geometry = re.split(" *(-?[XYZABCUVW])", geometry.upper())
geometry = "".join(reversed(geometry))
jog_speed = (
inifile.find("DISPLAY", "DEFAULT_LINEAR_VELOCITY")
or inifile.find("TRAJ", "DEFAULT_LINEAR_VELOCITY")
or inifile.find("TRAJ", "DEFAULT_VELOCITY")
or 1.0)
vars.jog_speed.set(float(jog_speed)*60)
jog_speed = (
inifile.find("DISPLAY", "DEFAULT_ANGULAR_VELOCITY")
or inifile.find("TRAJ", "DEFAULT_ANGULAR_VELOCITY")
or jog_speed)
vars.jog_aspeed.set(float(jog_speed)*60)
mlv = (
inifile.find("DISPLAY","MAX_LINEAR_VELOCITY")
or inifile.find("TRAJ","MAX_LINEAR_VELOCITY")
or inifile.find("TRAJ","MAX_VELOCITY")
or 1.0)
vars.max_speed.set(float(mlv))
mav = (
inifile.find("DISPLAY","MAX_ANGULAR_VELOCITY")
or inifile.find("TRAJ","MAX_ANGULAR_VELOCITY")
or mlv)
vars.max_aspeed.set(float(mav))
mv = inifile.find("DISPLAY","MAX_LINEAR_VELOCITY") or inifile.find("TRAJ","MAX_LINEAR_VELOCITY") or inifile.find("TRAJ","MAX_VELOCITY") or inifile.find("AXIS_0","MAX_VELOCITY") or 1.0
vars.maxvel_speed.set(float(mv)*60)
vars.max_maxvel.set(float(mv))
root_window.tk.eval("${pane_top}.jogspeed.s set [setval $jog_speed $max_speed]")
root_window.tk.eval("${pane_top}.ajogspeed.s set [setval $jog_aspeed $max_aspeed]")
root_window.tk.eval("${pane_top}.maxvel.s set [setval $maxvel_speed $max_maxvel]")
widgets.feedoverride.configure(to=max_feed_override)
widgets.rapidoverride.configure(to=100)
widgets.spinoverride.configure(to=max_spindle_override)
nmlfile = inifile.find("EMC", "NML_FILE")
if nmlfile:
linuxcnc.nmlfile = os.path.join(os.path.dirname(sys.argv[2]), nmlfile)
vars.coord_type.set(inifile.find("DISPLAY", "POSITION_OFFSET") == "RELATIVE")
vars.display_type.set(inifile.find("DISPLAY", "POSITION_FEEDBACK") == "COMMANDED")
coordinate_display = inifile.find("DISPLAY", "POSITION_UNITS")
lathe = bool(inifile.find("DISPLAY", "LATHE"))
foam = bool(inifile.find("DISPLAY", "FOAM"))
editor = inifile.find("DISPLAY", "EDITOR")
vars.has_editor.set(editor is not None)
tooleditor = inifile.find("DISPLAY", "TOOL_EDITOR") or "tooledit"
tooltable = inifile.find("EMCIO", "TOOL_TABLE")
lu = units(inifile.find("TRAJ", "LINEAR_UNITS"))
a_axis_wrapped = inifile.find("AXIS_3", "WRAPPED_ROTARY")
b_axis_wrapped = inifile.find("AXIS_4", "WRAPPED_ROTARY")
c_axis_wrapped = inifile.find("AXIS_5", "WRAPPED_ROTARY")
if coordinate_display:
if coordinate_display.lower() in ("mm", "metric"): vars.metric.set(1)
else: vars.metric.set(0)
else:
if lu in [.001, .01, .1, 1, 10]: vars.metric.set(1)
if lu == 1:
root_window.tk.eval("${pane_top}.jogspeed.l1 configure -text mm/min")
root_window.tk.eval("${pane_top}.maxvel.l1 configure -text mm/min")
else:
root_window.tk.eval("${pane_top}.jogspeed.l1 configure -text in/min")
root_window.tk.eval("${pane_top}.maxvel.l1 configure -text in/min")
root_window.tk.eval(u"${pane_top}.ajogspeed.l1 configure -text deg/min")
homing_order_defined = inifile.find("AXIS_0", "HOME_SEQUENCE") is not None
if homing_order_defined:
widgets.homebutton.configure(text=_("Home All"), command="home_all_axes")
root_window.tk.call("DynamicHelp::add", widgets.homebutton,
"-text", _("Home all axes [Ctrl-Home]"))
widgets.homemenu.add_command(command=commands.home_all_axes)
root_window.tk.call("setup_menu_accel", widgets.homemenu, "end",
_("Home All Axes"))
update_ms = int(1000 * float(inifile.find("DISPLAY","CYCLE_TIME") or 0.020))
interpname = inifile.find("TASK", "INTERPRETER") or ""
widgets.unhomemenu.add_command(command=commands.unhome_all_axes)
root_window.tk.call("setup_menu_accel", widgets.unhomemenu, "end", _("Unhome All Axes"))
s = linuxcnc.stat();
s.poll()
statfail=0
statwait=.01
while s.axes == 0:
print "waiting for s.axes"
time.sleep(statwait)
statfail+=1
statwait *= 2
if statfail > 8:
raise SystemExit, (
"A configuration error is preventing LinuxCNC from starting.\n"
"More information may be available when running from a terminal.")
s.poll()
live_axis_count = 0
for i,j in enumerate("XYZABCUVW"):
if s.axis_mask & (1<<i) == 0: continue
live_axis_count += 1
widgets.homemenu.add_command(command=lambda i=i: commands.home_axis_number(i))
widgets.unhomemenu.add_command(command=lambda i=i: commands.unhome_axis_number(i))
_("Home Axis _%s") % j)
_("Unhome Axis _%s") % j)
num_joints = int(inifile.find("TRAJ", "JOINTS") or live_axis_count)
astep_size = step_size = 1
for a in range(9):
if s.axis_mask & (1<<a) == 0: continue
section = "AXIS_%d" % a
unit = inifile.find(section, "UNITS") or lu
unit = units(unit) * 25.4
f = inifile.find(section, "SCALE") or inifile.find(section, "INPUT_SCALE") or "8000"
try:
f = abs(float(f.split()[0]))
except ValueError:
pass
else:
if f != 0:
step_size_tmp = min(step_size, 1. / f)
if a < 3: step_size = astep_size = step_size_tmp
else: astep_size = step_size_tmp
joint_type = [None] * 9
for j in range(9):
if s.axis_mask & (1<<j) == 0: continue
section = "AXIS_%d" % j
joint_type[j] = inifile.find(section, "TYPE")
if inifile.find("DISPLAY", "MIN_LINEAR_VELOCITY"):
root_window.tk.call("set_slider_min", float(inifile.find("DISPLAY", "MIN_LINEAR_VELOCITY"))*60)
elif inifile.find("DISPLAY", "MIN_VELOCITY"):
root_window.tk.call("set_slider_min", float(inifile.find("DISPLAY", "MIN_VELOCITY"))*60)
elif step_size != 1:
root_window.tk.call("set_slider_min", step_size*30)
if inifile.find("DISPLAY", "MIN_ANGULAR_VELOCITY"):
root_window.tk.call("set_aslider_min", float(inifile.find("DISPLAY", "MIN_ANGULAR_VELOCITY"))*60)
root_window.tk.call("set_aslider_min", float(inifile.find("DISPLAY", "MIN_VELOCITY"))*60)
elif astep_size != 1:
root_window.tk.call("set_aslider_min", astep_size*30)
increments = inifile.find("DISPLAY", "INCREMENTS")
if increments:
if "," in increments:
increments = [i.strip() for i in increments.split(",")]
else:
increments = increments.split()
root_window.call(widgets.jogincr._w, "list", "delete", "1", "end")
root_window.call(widgets.jogincr._w, "list", "insert", "end", *increments)
widgets.jogincr.configure(command= jogspeed_listbox_change)
vcp = inifile.find("DISPLAY", "PYVCP")
arcdivision = int(inifile.find("DISPLAY", "ARCDIVISION") or 64)
del sys.argv[1:3]
root_window.bind("<KeyPress-KP_Begin>", kp_wrap(lambda e: None, "KeyPress"))
root_window.bind("<KeyPress-KP_Insert>", kp_wrap(lambda e: None, "KeyPress"))
if lathe:
bind_axis("Left", "Right", 2)
bind_axis("Up", "Down", 0)
bind_axis("KP_Left", "KP_Right", 2)
bind_axis("KP_Up", "KP_Down", 0)
bind_axis("KP_4", "KP_6", 2)
bind_axis("KP_8", "KP_2", 0)
root_window.bind("<KeyPress-KP_Next>", kp_wrap(lambda e: None, "KeyPress"))
root_window.bind("<KeyPress-KP_Prior>", kp_wrap(lambda e: None, "KeyPress"))
else:
bind_axis("Left", "Right", 0)
bind_axis("Down", "Up", 1)
bind_axis("Next", "Prior", 2)
bind_axis("KP_Left", "KP_Right", 0)
bind_axis("KP_Down", "KP_Up", 1)
bind_axis("KP_Next", "KP_Prior", 2)
bind_axis("KP_4", "KP_6", 0)
bind_axis("KP_2", "KP_8", 1)
bind_axis("KP_3", "KP_9", 2)
bind_axis("bracketleft", "bracketright", 3)
root_window.bind("<KeyPress-minus>", nomodifier(commands.jog_minus))
root_window.bind("<KeyPress-equal>", nomodifier(commands.jog_plus))
root_window.bind("<KeyRelease-minus>", commands.jog_stop)
root_window.bind("<KeyRelease-equal>", commands.jog_stop)
opts, args = getopt.getopt(sys.argv[1:], 'd:')
for i in range(9):
if s.axis_mask & (1<<i): continue
c = getattr(widgets, "axis_%s" % ("xyzabcuvw"[i]))
c.grid_forget()
for i in range(num_joints, 9):
c = getattr(widgets, "joint_%d" % i)
c.grid_forget()
if s.axis_mask & 56 == 0:
widgets.ajogspeed.grid_forget()
c = linuxcnc.command()
e = linuxcnc.error_channel()
c.wait_complete()
c.wait_complete()
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
o.last_line = 1
o.pack(fill="both", expand=1)
def match_grid_size(v):
for idx in range(3, widgets.menu_grid.index("end")+1):
gv = widgets.menu_grid.entrycget(idx, "value")
if abs(float(gv)-v) < 1e-5:
vars.grid_size.set(gv)
widgets.menu_grid.entryconfigure(2, value=-1)
break
else:
vars.grid_size.set(v)
widgets.menu_grid.entryconfigure(2, value=v)
commands.set_grid_size()
o.tkRedraw()
def setup_grid_menu(grids):
for i in grids.split():
v = to_internal_linear_unit(parse_increment(i))
widgets.menu_grid.add_radiobutton(value=v, label=i,
variable="grid_size", command="set_grid_size")
match_grid_size(vars.grid_size.get())
grids = inifile.find("DISPLAY", "GRIDS") \
or "10mm 20mm 50mm 100mm 1in 2in 5in 10in"
# Find font for coordinate readout and get metrics
font_cache = {}
def get_coordinate_font(large):
global coordinate_font
global coordinate_linespace
global coordinate_charwidth
global fontbase
if large:
coordinate_font = "courier bold 20"
else:
coordinate_font = "courier bold 11"
if coordinate_font not in font_cache:
font_cache[coordinate_font] = \
glnav.use_pango_font(coordinate_font, 0, 128)
fontbase, coordinate_charwidth, coordinate_linespace = \
root_window.bind("<Key-F3>", pane_top + ".tabs raise manual")
root_window.bind("<Key-F5>", pane_top + ".tabs raise mdi")
root_window.bind("<Key-F5>", "+" + tabs_mdi + ".command selection range 0 end")
root_window.bind("<Key-F4>", commands.next_tab)
init()
#right click menu for the program
def rClicker(e):
def select_run_from(e):
commands.task_run_line()
#if no line is selected drop out
if vars.highlight_line.get() == -1 :
return
nclst=[
(' ',None), #
(' ------ ',None), #
(_('Run from here'), lambda e=e: select_run_from(e)),
rmenu = Tkinter.Menu(None, tearoff=0, takefocus=0)
cas = {}
for (txt, cmd) in nclst:
if txt == ' ------ ':
rmenu.add_separator()
else: rmenu.add_command(label=txt, command=cmd)
rmenu.entryconfigure(0, label = "AXIS", state = 'disabled')
if not manual_ok():
rmenu.entryconfigure(2, state = 'disabled')
rmenu.tk_popup(e.x_root-3, e.y_root+3,entry="0")
return "break"
t = widgets.text
t.bind('<Button-3>', rClicker) #allow right-click to select start from line
t.tag_configure("ignored", background="#ffffff", foreground="#808080")
t.tag_configure("lineno", foreground="#808080")
t.tag_configure("executing", background="#804040", foreground="#ffffff")
t.bind("<Button-1>", select_line)
t.bind("<B1-Motion>", lambda e: "break")
t.bind("<B1-Leave>", lambda e: "break")
t.bind("<Button-4>", scroll_up)
t.bind("<Button-5>", scroll_down)
t.configure(state="disabled")
if hal_present == 1 :
comp = hal.component("axisui")
comp.newpin("jog.x", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.y", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.z", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.a", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.b", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.c", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.u", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.v", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.w", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.increment", hal.HAL_FLOAT, hal.HAL_OUT)
comp.newpin("notifications-clear",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("notifications-clear-info",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("notifications-clear-error",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("resume-inhibit",hal.HAL_BIT,hal.HAL_IN)
vars.has_ladder.set(hal.component_exists('classicladder_rt'))
if vcp:
import vcpparse
comp.setprefix("pyvcp")
f = Tkinter.Frame(root_window)
f.grid(row=0, column=4, rowspan=6, sticky="nw", padx=4, pady=4)
vcpparse.filename = vcp
vcpparse.create_vcp(f, comp)
comp.ready()
gladevcp = inifile.find("DISPLAY", "GLADEVCP")
if gladevcp:
f = Tkinter.Frame(root_window, container=1, borderwidth=0, highlightthickness=0)
f.grid(row=0, column=5, rowspan=6, sticky="nsew", padx=4, pady=4)
else:
f = None
gladevcp_frame = f
_dynamic_childs = {}
# Call this later
def load_gladevcp_panel():
if gladevcp:
from subprocess import Popen
xid = gladevcp_frame.winfo_id()
cmd = "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp".split()
cmd += ['-x', str(xid)] + gladevcp.split()
child = Popen(cmd)
_dynamic_childs['gladevcp'] = (child, cmd, True)
notifications = Notification(root_window)
root_window.bind("<Control-space>", lambda event: notifications.clear())
widgets.mdi_command.bind("<Control-space>", lambda event: notifications.clear())
live_plotter = LivePlotter(o)
live_plotter.start()
o.lp = live_plotter.logger
hershey = Hershey()
def remove_tempdir(t):
shutil.rmtree(t)
tempdir = tempfile.mkdtemp()
atexit.register(remove_tempdir, tempdir)
activate_axis(0, True)
code = []
addrecent = True
if args:
elif os.environ.has_key("AXIS_OPEN_FILE"):
initialfile = os.environ["AXIS_OPEN_FILE"]
elif inifile.find("DISPLAY", "OPEN_FILE"):
initialfile = inifile.find("DISPLAY", "OPEN_FILE")
elif lathe:
initialfile = os.path.join(BASE, "share", "axis", "images","axis-lathe.ngc")
addrecent = False
else:
initialfile = os.path.join(BASE, "share", "axis", "images", "axis.ngc")
addrecent = False
if os.path.exists(initialfile):
open_file_guts(initialfile, False, addrecent)
if lathe:
else:
if o.canon:
def destroy_splash():
try:
root_window.send("popimage", "destroy", ".")
pass
def _dynamic_tab(name, text):
tab = widgets.right.insert("end", name, text=text)
tab.configure(borderwidth=1, highlightthickness=0)
return tab
def _dynamic_tabs(inifile):
tab_names = inifile.findall("DISPLAY", "EMBED_TAB_NAME")
tab_cmd = inifile.findall("DISPLAY", "EMBED_TAB_COMMAND")
if len(tab_names) != len(tab_cmd):
print "Invalid tab configuration"
# Complain somehow
return
# XXX: Set our root window ID in environment so child GladeVcp processes
# may forward keyboard events to it
rxid = root_window.winfo_id()
os.environ['AXIS_FORWARD_EVENTS_TO'] = str(rxid)
for i,t,c in zip(range(len(tab_cmd)), tab_names, tab_cmd):
w = _dynamic_tab("user_" + str(i), t)
f = Tkinter.Frame(w, container=1, borderwidth=0, highlightthickness=0)
f.pack(fill="both", expand=1)
xid = f.winfo_id()
cmd = c.replace('{XID}', str(xid)).split()
child = Popen(cmd)
wait = cmd[:2] == ['halcmd', 'loadusr']
_dynamic_childs[str(w)] = (child, cmd, wait)
@atexit.register
def kill_dynamic_childs():
for c,_,w in _dynamic_childs.values():
if not w:
c.terminate()
def check_dynamic_tabs():
for c,cmd,w in _dynamic_childs.values():
if not w:
continue
r = c.poll()
if r == 0:
continue
if r is None:
break
print 'Embeded tab command "%s" exited with error: %s' %\
(" ".join(cmd), r)
raise SystemExit(r)
else:
if postgui_halfile:
if postgui_halfile.lower().endswith('.tcl'):
res = os.spawnvp(os.P_WAIT, "haltcl", ["haltcl", "-i", vars.emcini.get(), postgui_halfile])
else:
res = os.spawnvp(os.P_WAIT, "halcmd", ["halcmd", "-i", vars.emcini.get(), "-f", postgui_halfile])
if res: raise SystemExit, res
root_window.deiconify()
destroy_splash()
return
root_window.after(100, check_dynamic_tabs)
tkpkgs = inifile.findall("DISPLAY","TKPKG") or ""
for pkg in tkpkgs:
pkg=pkg.split()
root_window.tk.call("package","require",*pkg)
tkapps = inifile.findall("DISPLAY","TKAPP") or ""
for app in tkapps:
root_window.tk.call("source",app)
o.update_idletasks()
icons = (root_window.tk.call("load_image", "axis-48x48"),
root_window.tk.call("load_image", "axis-24x24"))
for win in root_window, widgets.about_window, widgets.help_window:
root_window.tk.call("wm", "iconphoto", win, *icons)
vars.kinematics_type.set(s.kinematics_type)
vars.max_queued_mdi_commands.set(int(inifile.find("TASK", "MDI_QUEUED_COMMANDS") or 10))
def balance_ja():
w = max(widgets.axes.winfo_reqwidth(), widgets.joints.winfo_reqwidth())
h = max(widgets.axes.winfo_reqheight(), widgets.joints.winfo_reqheight())
widgets.axes.configure(width=w, height=h)
widgets.joints.configure(width=w, height=h)
if s.kinematics_type != linuxcnc.KINEMATICS_IDENTITY:
c.teleop_enable(0)
c.wait_complete()
vars.teleop_mode.set(0)
widgets.joints.grid_propagate(0)
widgets.axes.grid_propagate(0)
root_window.after_idle(balance_ja)
else:
widgets.menu_view.delete("end")
root_window.bind("$", "")
if lathe:
root_window.after_idle(commands.set_view_y)
root_window.bind("v", commands.set_view_y)
root_window.bind("d", "")
widgets.view_z.pack_forget()
widgets.view_z2.pack_forget()
widgets.view_x.pack_forget()
widgets.view_y.pack_forget()
widgets.view_p.pack_forget()
widgets.rotate.pack_forget()
widgets.axis_y.grid_forget()
widgets.menu_view.delete(0, 5)
widgets.feedoverride.set(100)
commands.set_feedrate(100)
widgets.rapidoverride.set(100)
commands.set_rapidrate(100)
widgets.spinoverride.set(100)
commands.set_spindlerate(100)
def forget(widget, *pins):
if os.environ.has_key("AXIS_NO_AUTOCONFIGURE"): return
for p in pins:
if hal.pin_has_writer(p): return
m = widget.winfo_manager()
if m in ("grid", "pack"):
widget.tk.call(m, "forget", widget._w)
forget(widgets.brake, "motion.spindle-brake")
forget(widgets.spindle_cw, "motion.spindle-forward", "motion.spindle-on",
"motion.spindle-speed-out", "motion.spindle-speed-out-abs", "motion.spindle-speed-out-rps", "motion.spindle-speed-out-rps-abs")
forget(widgets.spindle_ccw, "motion.spindle-reverse",
forget(widgets.spindle_stop, "motion.spindle-forward", "motion.spindle-reverse", "motion.spindle-on",
forget(widgets.spindle_plus,
forget(widgets.spindle_minus,
forget(widgets.spindlef, "motion.spindle-forward", "motion.spindle-reverse", "motion.spindle-on", "motion.spindle-brake",
forget(widgets.spindlel, "motion.spindle-forward", "motion.spindle-reverse", "motion.spindle-on", "motion.spindle-brake",
forget(widgets.spinoverridef,
has_limit_switch = 0
for j in range(9):
try:
if hal.pin_has_writer("axis.%d.neg-lim-sw-in" % j):
has_limit_switch=1
break
if hal.pin_has_writer("axis.%d.pos-lim-sw-in" % j):
has_limit_switch=1
break
except NameError, detail:
break
if not has_limit_switch:
widgets.override.grid_forget()
forget(widgets.mist, "iocontrol.0.coolant-mist")
forget(widgets.flood, "iocontrol.0.coolant-flood")
forget(widgets.lubel, "iocontrol.0.coolant-flood", "iocontrol.0.coolant-mist")
rcfile = "~/.axisrc"
user_command_file = inifile.find("DISPLAY", "USER_COMMAND_FILE") or ""
if user_command_file:
rcfile = user_command_file
rcfile = os.path.expanduser(rcfile)
if os.path.exists(rcfile):
try:
execfile(rcfile)
except:
print >>sys.stderr, tb
root_window.tk.call("nf_dialog", ".error", _("Error in ~/.axisrc"),
tb, "error", 0, _("OK"))
if hal_present == 1:
else:
destroy_splash()
root_window.tk.call("trace", "variable", "metric", "w", "update_units")
install_help(root_window)
widgets.numbers_text.bind("<Configure>", commands.redraw_soon)
live_plotter.update()
live_plotter.error_task()
o.mainloop()
live_plotter.stop()
# vim:sw=4:sts=4:et:
