Inkscape Gcodetools plug-in English support forum
What function should we develope next?
Результаты голосования
Generated Gcode in EMC2 (1318845 просмотров) <a class='original' href='./download/file.php?id=508&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (21.99 КБ)</a>
TypeExtension of vector
graphics editor Inkscape
DeveloperGcodetools develop team
Written inPython
OSCross-Platform (Windows, Linux, MacOS)
Version1.6.03
LicenseGNU GPL
Downloads7800+
Gcodetools
Gcodetools is a plug-in for Inkscape. It prepares and converts paths from Inkscape to Gcode, using biarc interpolation.
This article is unfinished. You can help cnc-club expanding it.
Screenshots and photos are needed. Please post them at this thread.
Features (для просмотра содержимого нажмите на ссылку)
Features
Preview of the generated Gcode in EMC (1321769 просмотров) <a class='original' href='./download/file.php?id=130&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (154.76 КБ)</a>
Gcodetools area pocketing (1307872 просмотра) <a class='original' href='./download/file.php?id=772&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (147.75 КБ)</a>
Gcodetools lathe (1314193 просмотра) <a class='original' href='./download/file.php?id=642&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (21.98 КБ)</a>
Gcodetools lathe
Gcodetools engraving by Rene (1314358 просмотров) <a class='original' href='./download/file.php?id=631&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (233.84 КБ)</a>
Bears by Durachko (1249816 просмотров) <a class='original' href='./download/file.php?id=5429&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (89.93 КБ)</a>
Bears by Durachko
Export to Gcode
  • Export paths to Gcode
  • Using circular (biarc approximation) or straight line interpolation
  • Automatic path subdivision to reach defined tolerance
  • Multiply tool processing
  • Export Gcode in parametric of flat form
  • Including personal headers and footers
  • Choosing units
  • Multi-pass processing
  • Numeric suffix is added to generated files to avoid overwriting
Lathe Gcode
  • Compute trajectories for lathe
  • Fine cut
  • Define fine cut's depth
  • Define fine rounds
  • Two different computation functions for fine cut
  • Standard axis remapping
Path's area processing
  • Building area paths
  • Area paths could be modified
Engraving
  • Building trajectory according to the cutter's shape
  • Defining different cutter's shapes
Tool's library
  • Defining different tool's parameters (diameter, feed, depth step, penetration feed, personal Gcode before/after each path, cutters shape, personal tool's changing Gcode)
  • Tools can be managed by Inkscape's standard procedures (copy, delete, assigned to different layer)
  • Multiply tools processing
Orientation system
  • Applying scale along any axis
  • Apply rotate in the ХY plane
  • Apply translation along any axis
  • Apply transforms according to arbitrary points
Post-processor
  • You can create custom post-processor by writing down the commands or choose from the list of default post-processors
  • Scale and offset Gcode
  • Gcode commands remapping
  • Parameterize Gcode
  • Round floating point values to specified precision
Verifying tools for the scene
  • Select and remove small paths (area artefacts)
  • Tool's alignment check
  • Cutting order check
Plotter cutting
  • Export to Gcode for plotter with tangential knife. Forth axis A is knife's rotation.
Install (для просмотра содержимого нажмите на ссылку)
Install
Windows
Unpack and copy all the files to the following directory Program Files\Inkscape\share\extensions\ and restart inkscape
Linux
Unpack and copy all the files to the following directory /usr/share/inkscape/extensions/ and restart inkscape
Screenshots (для просмотра содержимого нажмите на ссылку)
Screenshots
Gcodetools plug-in tutorial (2600*1300 px png ~ 700Kb) (1321772 просмотра) <a class='original' href='./download/file.php?id=127&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (752.7 КБ)</a>
Curve to Gcode result (1321778 просмотров) <a class='original' href='./download/file.php?id=103&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (1023.52 КБ)</a>
Get latest version (для просмотра содержимого нажмите на ссылку)
Get latest versions
Latest stable version Gcodetools 1.7
gcodetools.tar.gz
Gcodetools 1.7
(75.25 КБ) 102173 скачивания
Older versions(ver 1.5)
gcodetools-1.6.tar.gz
Gcodetools 1.6
(56.6 КБ) 14986 скачиваний
(ver 1.5)
gcodetools.tar.gz
Gcodetools 1.5
(21.32 КБ) 10567 скачиваний
(ver 1.4)
gcodetools.tar.gz
(14.72 КБ) 27117 скачиваний
(ver 1.2)
extensions.tar.gz
(9.01 КБ) 10343 скачивания
Dev-version
You can try the newest development version by getting it from github repository https://github.com/cnc-club/gcodetools via web interface or using git clone git@github.com:cnc-club/gcodetools.git .
You'll need to run python create_inx.py to create inx files. After that install procedure is the same with the stable version.
Translations
Gcodetools is included into Inkscape v 0.49 so it will have native translations as other Inkscape's extensions. Until it is released you can use some self made translation packs:
Credits (для просмотра содержимого нажмите на ссылку)
Credits
Developers:
  • Nick Drobchenko (Nick)
  • Vladimir Kalyaev (Dormouse)
  • Henry Nicolas (Alfcnc)
Translators:
  • John Brooker (greybeard from cnczone.com)
Develop (для просмотра содержимого нажмите на ссылку)
Develop
At the moment following features are being developed:
  • Plasma cutter extension
  • Turning lathe extension
  • Plotter extension
You can help us improve Gcodetools in several ways
  • Writing a report / bug report
  • Improve help and manuals
  • Publish G-codes / SVGs / other code
  • Publish photos / videos
  • Make a bug report
  • Help develop new features
  • Suggest a new feature
Tested on (для просмотра содержимого нажмите на ссылку)
Tested on
Linux
Ubuntu 9.10 14.04 + inkscape 0.48 (older Gcodetools versions also work with 0.46, 0.47)
Windows
Windows XP, Windows Vista, Windows 7 + inkscape 0.46, inkscape 0.47
MacOS
There are some reports on successful work on MacOs.
avex
Настоящее имя: avex
Re: Inkscape Gcodetools plug-in English support forum
Сообщение avex »
I have a problem. When I click 'apply' in 'Path to Ccode' a window appears with next text - 'Path to Ccode' working, please wait - and than nothing happens. So problem with Measure extension: 'Measure Path' working, please wait.
What should I do to fix it?
Win 7, Inkscape 0.92
KubaAseph
Сообщение KubaAseph »
Hi!
I'm trying to make a file for pen plotter using gcodetools.
Most of images are pretty complicated, so let's say it's just a simple shape with a wide contour and some small details inside.
Is there any way to draw it whole (ie. "what is black will be black on print")? Cutrently I'm getting only countours of the shapes, without infill.
I tried area, but 1. It takes lots of time to convert (for some reason Inkscape uses only 1 core) and 2. It breaks some inner details (expansion needed to completely fill bigget countour will turn small details into shapeless blobs).
What I'd like to achieve is 3D-printer-like style, ie. contours of filled contour drawn first, then: a) infill at constant angle or b) concentric infill (similar to area but only between previously drawn contours).
What I usually get vs what I want to achieve but more efficient and repeatable way. (46858 просмотров) <a class='original' href='./download/file.php?id=133236&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (3.3 МБ)</a>
tcom4
Настоящее имя: parinya
Сообщение tcom4 »
HealeyV3
Настоящее имя: HealeyV3
Сообщение HealeyV3 »
Hi All,
I'm trying to use the AREA FILL functionality of this plug-in to create G-Code.
However, when I go to use this, I don't get the back and fourth pattern like the images in the instructions have.... I don't believe it's working properly.
Is there any updated tutorial on how to do this using 1.7?
The process I used was I made a simple rectangle, added some text, did a difference. Made sure object was path -- Then I used "Fill Area" tab in GCode Extension... No matter what parameters I put in, nothing seems to happen when I click Apply.
I get the errors:
Orientation points have not been defined! A default set of orientation points has been automatically added.
Cutting tool has not been defined! A default tool has been automatically added.
Then, my image has some simple spiral or zig zag pattern that isn't one that goes back and fourth like I would need.
$100 via PayPal to anyone that can help me figure this out and get multiple layer CNC going.
please contact me at healeyv3 at gmail.com if you think you can TeamViewer in and help me get this going.
Thanks!
test.png (45589 просмотров) <a class='original' href='./download/file.php?id=138379&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (113.43 КБ)</a>
test.svg
(9.34 КБ) 1153 скачивания
al_us
Сообщение al_us »
Good job, friend!
Ohmarinus
Настоящее имя: Marinus
Сообщение Ohmarinus »
Hi all, I wanted to say that I think this extension is still a very popular one and should be continued! I'm noticing an increase in people trying to use pen plotters nowadays and this extension is having it's own issues.
I have fixed a lot of things myself, such as changing the str(s) to s.encode and('utf8') etc etc etc.
Besides fixes I have added support for multiple pens with tool changing scripts and other additional features (extra parameters etc). But I am running into a problem with the tool changes and I hope someone can help me with this problem.
I'm using Inkscape 92.2 on a Max OSX computer with the 1.7 gcodetools extension.
What happens:
Tool change script gets applied on every path instead of on every layer.
This causes the tool change to run a lot when you have a drawing with a lot of detailed lines.. This causes wear on the machine and makes print time unnecessarily long.
If anyone knows how to fix this? Spasiba. I would be grateful.
Ohmarinus
Because I can't edit my previous post, I wanted to say that I fixed the errors I've come across in the gcodetools script. The pen plotter I've built now works flawlessly with the tool changing and rounded numbers. I might post my own edit some time somewhere on the web. I'll post an update if the new edited script becomes available. I will also correct all grammar and language errors and have added support for pen plotters in the script where you can choose for example 'Pen 1', 'Pen 2' and 'Pen 3'. Also, I will include a small tutorial file or maybe a video on how to set up the layers and how to edit the extension files to include your own settings in the extension because I think that copying in your custom gcode each time into the Inkscape file is tedious to say the least.
happy
Настоящее имя: happy
Сообщение happy »
Hello. I Make very sample sketch on Inkscape and use Gcode tools extension and got the following error as you can see in attachment please guide me
error.jpg (39261 просмотр) <a class='original' href='./download/file.php?id=167836&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (237.09 КБ)</a>
zhichao
Настоящее имя: zhichao
Сообщение zhichao »
Hi nick, I really want to know how to use him in the Linux command line?
alienkidmj12
Настоящее имя: david sives-rutherford
Сообщение alienkidmj12 »
where do i find the latest gcodetools plugin files ?
qulet
Настоящее имя: Marek
Сообщение qulet »
Ohmarinus !
Вы делитесь своими модификациями в плагине для рисования где-нибудь на машинах?
Я хотел бы проверить.
kuleta@wtvk.pl
мой "Drawbot"
https://drive.google.com/open?id=18Ra-S ... uatF6OMq16
Firelogic
Настоящее имя: Peter
Сообщение Firelogic »
Hi All!
Is it possible in gcodeTools to set inner or outer engraving for an object?
For example I draw a circle shape in Inkscape, and I would like to engrave it, but it's important to set where should the machine cut it with the tool.
How can I adjust it?
Thanks in advance.
Attila1000
Сообщение Attila1000 »
Hello,
i have a LinuxCNC controlled styrofoam hot wire cutter machine. And i try to use gCodeTool integrated in inkscape v1.0.2.
I have project drawed in CorelDraw saved in format *.CRD.
The path cutted with hot wire is continously, but the direction of cutting is important.
Cutting is must to go from top to bottom. But when i generate g code with gcodetool, i dont know how to change the direction of cutting. Because the
default direction is opposite. I try to change in corel the zero point of project, put orientation point, and in-out point in gcodetool, but without result.
Can someone help me how to change the direction of cutting please?
Thanks Attila.
gcodepath.png (12263 просмотра) <a class='original' href='./download/file.php?id=192717&sid=3964509edbd423a8783a1c57b7d1315c&mode=view' target=_blank>Загрузить оригинал (34.74 КБ)</a>
MarcWeber
Настоящее имя: Marc Weber
Сообщение MarcWeber »
Where is current documentation ?
There are some problems with Inkscape:
- python2 eventually should still be used ? Didn''t test all versions yet.
I am looking for most basic documentation like when using a cone cutter what does it mean?
Why does documentation talk about height/diameter ratio but the tool options only have diameter?
The angle option (default tool) what does that actually mean?
It's said that you can add depth function yourself (?) But I somehow don't get it where to put such formular.
Babken
Сообщение Babken »
Hello,
Can anyone tell me how to use in and out trajectory option in default tool? I want to cut outside of the path and get exactly the shape I have.
artix
Настоящее имя: Luca
Сообщение artix »
Hi please come one can help me if know some tutorial in how use grey scale with ink?
THANKS!
PS: I have a cnc 3020 for wood etc doing all patch vector etc produce the gcode but give me other result in z deep axis like for example want cut 20mm deep and give me all strings -1 so just cut 1mm
Вернуться в «English forum»
