Страница 1 из 1
gcodetool crashes
Добавлено: 16 май 2012, 11:41
nicocnc
I have installed gcodetools 1.7 on ubuntu precise.
When I try to create a new tool in the tool library. I have a message "Tools library working, please wait" and just after inkscape crashes with messages "Inkscape encountered an internal error and will close now".
I had the same error whan I tried to creat gcode using the defaul tool.
Any tips ? Thanks.
Re: gcodetool crashes
Добавлено: 16 май 2012, 12:01
Hmmm... attach your svg please. What inkscape version is there in precise?
Добавлено: 16 май 2012, 12:23
nicocnc
Thanks for your fast answer
Version is Inkscape 0.48.3.1 r9886
attached is the file
Добавлено: 16 май 2012, 12:27
It seems like the document is imported from somewhere outside of inkscape, is'n it? :)
Thus it does not have a lot of inkscape's definitions, for example there's no layers in the document.
The best way is to open such document, select all the paths and copy them to a new document created in inkscape (File-New, Paste). After that you should have all the paths in native inkscape's svg.
Добавлено: 16 май 2012, 13:06
nicocnc
You were right on all points. Thanks
