НЕ могу настроить данную связку 7I92+7I77.
заранее спасибо
Kernel
cnc@lathe:~$ uname -a
Linux lathe 3.2.0-6-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.102-1 i686 GNU/Linux
cnc@lathe:~$ mesaflash --device 7i92 --verbose
ETH device 7I92 at ip=192.168.1.121
Communication:
transport layer: ethernet IPv4 UDP
ip address: 192.168.1.121
mac address: 00:60:1B:13:04:01
protocol: LBP16 version 3
Board info:
Flash size: 16Mb (id: 0x14)
Connectors count: 2
Pins per connector: 17
Connectors names: P2 P1
FPGA type: xc6slx9
Number of leds: 4
Board firmware info:
memory spaces:
0: HostMot2 (registers, RW, 32-bit) [size=64K]
1: KSZ8851 (registers, RW, 16-bit)
2: EtherEEP (EEPROM, RW, 16-bit) , page size: 1, erase size: 1
3: FPGAFlsh (flash, RW, 32-bit) [size=16M], page size: 256, erase size: 65536
4: Timers (memory, RW, 16-bit)
6: LBP16RW (memory, RW, 16-bit)
7: LBP16RO (memory, RO, 16-bit)
[space 0] HostMot2
[space 2] Ethernet eeprom:
ip address: 10.10.10.10
board name: 7I92
user leds: eth debug
[space 3] FPGA flash eeprom:
flash size: 16Mb (id: 0x14)
[space 4] timers:
uSTimeStampReg: 0xC7AB
WaituSReg: 0x0000
HM2Timeout: 0x0000
[space 6] LBP16 control/status:
packets received: all 311, UDP 49, bad 0
packets sended: all 52, UDP 49, bad 0
parse errors: 0, mem errors 0, write errors 0
error flags: 0x0000
debug LED ptr: 0x0008
scratch: 0x0000
[space 7] LBP16 info:
board name: 7I92
LBP16 protocol version 3
board firmware version 15
IP address jumpers at boot: fixed 192.168.1.121
Linux Cnc errors
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/cnc/linuxcnc/configs/4'
Machine configuration file is '4.ini'
INIFILE=/home/cnc/linuxcnc/configs/4/4.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./4.hal
hm2: loading Mesa HostMot2 driver version 0.15
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:13:04:01
hm2_eth: discovered 7I92
board fails HM2 registration
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=3960
hm2: unloading
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
Note: Using POSIX realtime
iptables: No chain/target/match by that name.
hm2/hm2_7i92.0: error reading Module Descriptor 3 (at 0x0464)
hm2_eth: rtapi_app_main: Input/output error (-5)
./4.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./4.hal:8: /usr/bin/rtapi_app exited without becoming ready
./4.hal:8: insmod for hm2_eth failed, returned -1
3960
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-6-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 4.9.2 (Debian 4.9.2-10+deb7u1) ) #1 SMP PREEMPT RT Debian 3.2.102-1
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f790000 (usable)
[ 0.000000] BIOS-e820: 000000003f790000 - 000000003f79e000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f79e000 - 000000003f7e0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f7e0000 - 000000003f800000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: ASUSTek Computer INC. P5GZ-MX/P5GZ-MX, BIOS 0707 07/09/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3f790 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 03F800000 mask FFF800000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01a00000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037800000 page 2M
[ 0.000000] 0037800000 - 00379fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000
[ 0.000000] RAMDISK: 365ac000 - 372ce000
[ 0.000000] ACPI: RSDP 0x00000000000FAFE0 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 0x000000003F790000 00038 (v01 A_M_I_ OEMRSDT 07000709 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x000000003F790200 00081 (v01 A_M_I_ OEMFACP 07000709 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x000000003F790590 0574C (v01 A0643 A0643000 00000000 INTL 20060113)
[ 0.000000] ACPI: FACS 0x000000003F79E000 00040
[ 0.000000] ACPI: APIC 0x000000003F790390 00080 (v01 A_M_I_ OEMAPIC 07000709 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x000000003F79E040 00066 (v01 A_M_I_ AMI_OEM 07000709 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x000000003F795CE0 00038 (v01 A_M_I_ OEMHPET 07000709 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x000000003F795D20 0003C (v01 A_M_I_ OEMMCFG 07000709 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 125MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000379fe
[ 0.000000] HighMem 0x000379fe -> 0x0003f790
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003f790
[ 0.000000] On node 0 totalpages: 259871
[ 0.000000] free_area_init_node: node 0, pgdat c1423940, node_mem_map f5dbc200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1748 pages used for memmap
[ 0.000000] Normal zone: 221994 pages, LIFO batch:31
[ 0.000000] HighMem zone: 252 pages used for memmap
[ 0.000000] HighMem zone: 31894 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 3f800000 (gap: 3f800000:c0380000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 94 pages/cpu @f7879000 s362240 r0 d22784 u385024
[ 0.000000] pcpu-alloc: s362240 r0 d22784 u385024 alloc=94*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257839
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-6-rt-686-pae root=UUID=e5f40a2f-78fc-44f0-93c2-9b1445a1d70f ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:0003f790)
[ 0.000000] Memory: 1009400k/1039936k available (2875k kernel code, 30084k reserved, 1395k data, 744k init, 128584k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
[ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
[ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
[ 0.000000] .init : 0xc142c000 - 0xc14e6000 ( 744 kB)
[ 0.000000] .data : 0xc12cefb0 - 0xc142bc80 (1395 kB)
[ 0.000000] .text : 0xc1000000 - 0xc12cefb0 (2875 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f580a000 soft=f580c000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3466.628 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 6933.25 BogoMIPS (lpj=13866512)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004074] Security Framework initialized
[ 0.004081] AppArmor: AppArmor disabled by boot time parameter
[ 0.004106] Mount-cache hash table entries: 512
[ 0.004286] Initializing cgroup subsys cpuacct
[ 0.004292] Initializing cgroup subsys memory
[ 0.004306] Initializing cgroup subsys devices
[ 0.004309] Initializing cgroup subsys freezer
[ 0.004311] Initializing cgroup subsys net_cls
[ 0.004313] Initializing cgroup subsys blkio
[ 0.004322] Initializing cgroup subsys perf_event
[ 0.004372] CPU0: Hyper-Threading is disabled
[ 0.004376] mce: CPU supports 4 MCE banks
[ 0.004389] CPU0: Thermal monitoring enabled (TM1)
[ 0.004396] using mwait in idle threads.
[ 0.004408] Spectre V2 : Mitigation: Full generic retpoline
[ 0.004411] Spectre V2 : Filling RSB on context switch
[ 0.008465] ACPI: Core revision 20110623
[ 0.012086] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.012475] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.055446] CPU0: Intel(R) Celeron(R) D CPU 3.46GHz stepping 05
[ 0.056003] APIC calibration not consistent with PM-Timer: 115ms instead of 100ms
[ 0.056003] APIC delta adjusted to PM-Timer: 833304 (966622)
[ 0.056003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.056003] ... version: 0
[ 0.056003] ... bit width: 40
[ 0.056003] ... generic registers: 18
[ 0.056003] ... value mask: 000000ffffffffff
[ 0.056003] ... max period: 0000007fffffffff
[ 0.056003] ... fixed-purpose events: 0
[ 0.056003] ... event mask: 000000000003ffff
[ 0.072259] NMI watchdog enabled, takes one hw-pmu counter.
[ 0.076023] Brought up 1 CPUs
[ 0.076029] Total of 1 processors activated (6933.25 BogoMIPS).
[ 0.076805] devtmpfs: initialized
[ 0.077181] PM: Registering ACPI NVS region at 3f79e000 (270336 bytes)
[ 0.077529] print_constraints: dummy:
[ 0.077646] NET: Registered protocol family 16
[ 0.077892] ACPI: bus type pci registered
[ 0.078019] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[ 0.078023] PCI: not using MMCONFIG
[ 0.078225] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[ 0.078469] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=2
[ 0.078472] PCI: Using configuration type 1 for base access
[ 0.079871] bio: create slab <bio-0> at 0
[ 0.080103] ACPI: Added _OSI(Module Device)
[ 0.080108] ACPI: Added _OSI(Processor Device)
[ 0.080113] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.080117] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.081578] ACPI: EC: Look up EC in DSDT
[ 0.083656] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.090035] ACPI: Interpreter enabled
[ 0.090054] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.090110] ACPI: Using IOAPIC for interrupt routing
[ 0.090163] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xf0000000-0xffffffff] (base 0xf0000000)
[ 0.097103] PCI: MMCONFIG at [mem 0xf0000000-0xffffffff] reserved in ACPI motherboard resources
[ 0.097110] PCI: MMCONFIG for 0000 [bus00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000) (size reduced!)
[ 0.097113] PCI: Using MMCONFIG for extended config space
[ 0.109816] ACPI: No dock devices found.
[ 0.109821] HEST: Table not found.
[ 0.109829] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.109957] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.110221] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.110227] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.110231] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.110235] pci_root PNP0A08:00: host bridge window [mem 0x3f810000-0xffffffff] (ignored)
[ 0.110259] pci 0000:00:00.0: [8086:2770] type 0 class 0x000600
[ 0.110331] pci 0000:00:02.0: [8086:2772] type 0 class 0x000300
[ 0.110349] pci 0000:00:02.0: reg 10: [mem 0xdfe00000-0xdfe7ffff]
[ 0.110358] pci 0000:00:02.0: reg 14: [io 0x9800-0x9807]
[ 0.110368] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff pref]
[ 0.110377] pci 0000:00:02.0: reg 1c: [mem 0xdfe80000-0xdfebffff]
[ 0.110476] pci 0000:00:1b.0: [8086:27d8] type 0 class 0x000403
[ 0.110498] pci 0000:00:1b.0: reg 10: [mem 0xdfef8000-0xdfefbfff 64bit]
[ 0.110586] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.110618] pci 0000:00:1c.0: [8086:27d0] type 1 class 0x000604
[ 0.110710] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.110749] pci 0000:00:1d.0: [8086:27c8] type 0 class 0x000c03
[ 0.110801] pci 0000:00:1d.0: reg 20: [io 0xa000-0xa01f]
[ 0.110844] pci 0000:00:1d.1: [8086:27c9] type 0 class 0x000c03
[ 0.110895] pci 0000:00:1d.1: reg 20: [io 0xa400-0xa41f]
[ 0.110940] pci 0000:00:1d.2: [8086:27ca] type 0 class 0x000c03
[ 0.110992] pci 0000:00:1d.2: reg 20: [io 0xa800-0xa81f]
[ 0.111034] pci 0000:00:1d.3: [8086:27cb] type 0 class 0x000c03
[ 0.111086] pci 0000:00:1d.3: reg 20: [io 0xb000-0xb01f]
[ 0.111142] pci 0000:00:1d.7: [8086:27cc] type 0 class 0x000c03
[ 0.111167] pci 0000:00:1d.7: reg 10: [mem 0xdfeffc00-0xdfefffff]
[ 0.111269] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.111296] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604
[ 0.111385] pci 0000:00:1f.0: [8086:27b8] type 0 class 0x000601
[ 0.111489] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 0007)
[ 0.111542] pci 0000:00:1f.1: [8086:27df] type 0 class 0x000101
[ 0.111560] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.111572] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.111584] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.111596] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.111609] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.111658] pci 0000:00:1f.2: [8086:27c0] type 0 class 0x000101
[ 0.111678] pci 0000:00:1f.2: reg 10: [io 0xc800-0xc807]
[ 0.111689] pci 0000:00:1f.2: reg 14: [io 0xc400-0xc403]
[ 0.111700] pci 0000:00:1f.2: reg 18: [io 0xc000-0xc007]
[ 0.111711] pci 0000:00:1f.2: reg 1c: [io 0xb800-0xb803]
[ 0.111722] pci 0000:00:1f.2: reg 20: [io 0xb400-0xb40f]
[ 0.111769] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.111790] pci 0000:00:1f.3: [8086:27da] type 0 class 0x000c05
[ 0.111852] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.111945] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.111951] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.112051] pci 0000:01:04.0: [11ab:4320] type 0 class 0x000200
[ 0.112078] pci 0000:01:04.0: reg 10: [mem 0xdfffc000-0xdfffffff]
[ 0.112091] pci 0000:01:04.0: reg 14: [io 0xd800-0xd8ff]
[ 0.112143] pci 0000:01:04.0: reg 30: [mem 0xdffc0000-0xdffdffff pref]
[ 0.112191] pci 0000:01:04.0: supports D1 D2
[ 0.112194] pci 0000:01:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.112248] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.112254] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.112260] pci 0000:00:1e.0: bridge window [mem 0xdff00000-0xdfffffff]
[ 0.112271] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.112275] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xfffffffff] (subtractive decode)
[ 0.112291] pci_bus 0000:00: on NUMA node 0
[ 0.112298] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.112656] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[ 0.112849] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.113041] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.113047] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d
[ 0.113050] ACPI _OSC control for PCIe not granted, disabling ASPM
[ 0.120841] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.120957] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.121069] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.121179] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.121290] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.121401] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.121515] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.121627] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.121823] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.121845] vgaarb: loaded
[ 0.121848] vgaarb: bridge control possible 0000:00:02.0
[ 0.121941] PCI: Using ACPI for IRQ routing
[ 0.121947] PCI: pci_cache_line_size set to 64 bytes
[ 0.122039] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.122044] reserve RAM buffer: 000000003f790000 - 000000003fffffff
[ 0.122262] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.122270] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.122278] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.132052] AMD NB: Cannot enumerate AMD northbridges.
[ 0.132057] Switching to clocksource hpet
[ 0.135828] pnp: PnP ACPI init
[ 0.135863] ACPI: bus type pnp registered
[ 0.136069] pnp 00:00: [bus 00-ff]
[ 0.136074] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.136078] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.136082] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.136086] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.136090] pnp 00:00: [mem 0x3f810000-0xffffffff window]
[ 0.136194] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.136218] pnp 00:01: [mem 0xfed13000-0xfed19fff]
[ 0.136305] system 00:01: [mem 0xfed13000-0xfed19fff] has been reserved
[ 0.136312] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.136370] pnp 00:02: [dma 4]
[ 0.136374] pnp 00:02: [io 0x0000-0x000f]
[ 0.136378] pnp 00:02: [io 0x0081-0x0083]
[ 0.136381] pnp 00:02: [io 0x0087]
[ 0.136384] pnp 00:02: [io 0x0089-0x008b]
[ 0.136387] pnp 00:02: [io 0x008f]
[ 0.136390] pnp 00:02: [io 0x00c0-0x00df]
[ 0.136445] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.136473] pnp 00:03: [io 0x0070-0x0071]
[ 0.136488] pnp 00:03: [irq 8]
[ 0.136542] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.136562] pnp 00:04: [io 0x0061]
[ 0.136617] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.136642] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.136650] pnp 00:05: [irq 13]
[ 0.136706] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.137501] pnp 00:06: [irq 6]
[ 0.137506] pnp 00:06: [dma 2]
[ 0.137510] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.137513] pnp 00:06: [io 0x03f7]
[ 0.137626] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.138610] pnp 00:07: [irq 7]
[ 0.138614] pnp 00:07: [dma 3]
[ 0.138618] pnp 00:07: [io 0x0378-0x037f]
[ 0.138621] pnp 00:07: [io 0x0778-0x077f]
[ 0.138971] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.139042] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
[ 0.139047] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
[ 0.139051] pnp 00:08: [io 0x0290-0x0297]
[ 0.139141] system 00:08: [io 0x0290-0x0297] has been reserved
[ 0.139147] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.139333] pnp 00:09: [io 0x0010-0x001f]
[ 0.139338] pnp 00:09: [io 0x0022-0x003f]
[ 0.139341] pnp 00:09: [io 0x0044-0x005f]
[ 0.139344] pnp 00:09: [io 0x0062-0x0063]
[ 0.139347] pnp 00:09: [io 0x0065-0x006f]
[ 0.139350] pnp 00:09: [io 0x0072-0x007f]
[ 0.139354] pnp 00:09: [io 0x0080]
[ 0.139357] pnp 00:09: [io 0x0084-0x0086]
[ 0.139360] pnp 00:09: [io 0x0088]
[ 0.139363] pnp 00:09: [io 0x008c-0x008e]
[ 0.139366] pnp 00:09: [io 0x0090-0x009f]
[ 0.139369] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.139372] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.139376] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.139379] pnp 00:09: [io 0x0800-0x087f]
[ 0.139382] pnp 00:09: [io 0x0000-0xffffffffffffffff disabled]
[ 0.139386] pnp 00:09: [io 0x0480-0x04bf]
[ 0.139389] pnp 00:09: [io 0x0400-0x041f]
[ 0.139393] pnp 00:09: [mem 0xfed1c000-0xfed1ffff]
[ 0.139396] pnp 00:09: [mem 0xfed20000-0xfed8ffff]
[ 0.139400] pnp 00:09: [mem 0xffb00000-0xffbfffff]
[ 0.139403] pnp 00:09: [mem 0xfff00000-0xfffffffe]
[ 0.139510] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.139516] system 00:09: [io 0x0800-0x087f] could not be reserved
[ 0.139520] system 00:09: [io 0x0480-0x04bf] has been reserved
[ 0.139525] system 00:09: [io 0x0400-0x041f] has been reserved
[ 0.139530] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.139535] system 00:09: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.139543] system 00:09: [mem 0xffb00000-0xffbfffff] could not be reserved
[ 0.139548] system 00:09: [mem 0xfff00000-0xfffffffe] has been reserved
[ 0.139554] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.139710] pnp 00:0a: [mem 0xfed00000-0xfed003ff]
[ 0.139770] pnp 00:0a: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.139976] pnp 00:0b: [mem 0xfec00000-0xfec00fff]
[ 0.139980] pnp 00:0b: [mem 0xfee00000-0xfee00fff]
[ 0.140123] system 00:0b: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.140128] system 00:0b: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.140134] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.140825] pnp 00:0c: [irq 4]
[ 0.140830] pnp 00:0c: [dma 0 disabled]
[ 0.140834] pnp 00:0c: [io 0x03f8-0x03ff]
[ 0.140977] pnp 00:0c: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.141103] pnp 00:0d: [mem 0xffb80000-0xffbfffff]
[ 0.141108] pnp 00:0d: [mem 0xfff80000-0xffffffff]
[ 0.141167] pnp 00:0d: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.141272] pnp 00:0e: [mem 0xffc00000-0xfff7ffff]
[ 0.141369] system 00:0e: [mem 0xffc00000-0xfff7ffff] could not be reserved
[ 0.141375] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.141457] pnp 00:0f: [mem 0xf0000000-0xf3ffffff]
[ 0.141548] system 00:0f: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.141554] system 00:0f: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.141921] pnp 00:10: [mem 0x00000000-0x0009ffff]
[ 0.141926] pnp 00:10: [mem 0x000c0000-0x000dffff]
[ 0.141929] pnp 00:10: [mem 0x000e0000-0x000fffff]
[ 0.141933] pnp 00:10: [mem 0x00100000-0x3f7fffff]
[ 0.141937] pnp 00:10: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.142041] system 00:10: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.142047] system 00:10: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.142052] system 00:10: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.142057] system 00:10: [mem 0x00100000-0x3f7fffff] could not be reserved
[ 0.142062] system 00:10: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.142385] pnp: PnP ACPI: found 17 devices
[ 0.142389] ACPI: ACPI bus type pnp unregistered
[ 0.142394] PnPBIOS: Disabled by ACPI PNP
[ 0.181055] PCI: max bus depth: 1 pci_try_num: 2
[ 0.181096] pci 0000:00:1c.0: BAR 14: assigned [mem 0x40000000-0x401fffff]
[ 0.181104] pci 0000:00:1c.0: BAR 15: assigned [mem 0x40200000-0x403fffff 64bit pref]
[ 0.181109] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.181114] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.181121] pci 0000:00:1c.0: bridge window [mem 0x40000000-0x401fffff]
[ 0.181127] pci 0000:00:1c.0: bridge window [mem 0x40200000-0x403fffff 64bit pref]
[ 0.181136] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.181140] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.181147] pci 0000:00:1e.0: bridge window [mem 0xdff00000-0xdfffffff]
[ 0.181189] pci 0000:00:1c.0: setting latency timer to 64
[ 0.181201] pci 0000:00:1e.0: setting latency timer to 64
[ 0.181206] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.181210] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff]
[ 0.181214] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.181217] pci_bus 0000:02: resource 1 [mem 0x40000000-0x401fffff]
[ 0.181221] pci_bus 0000:02: resource 2 [mem 0x40200000-0x403fffff 64bit pref]
[ 0.181224] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.181228] pci_bus 0000:01: resource 1 [mem 0xdff00000-0xdfffffff]
[ 0.181231] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.181234] pci_bus 0000:01: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.181345] NET: Registered protocol family 2
[ 0.183922] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.184515] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.185185] TCP bind hash table entries: 65536 (order: 8, 1835008 bytes)
[ 0.186377] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.186385] TCP reno registered
[ 0.186398] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.186424] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.186637] NET: Registered protocol family 1
[ 0.186669] pci 0000:00:02.0: Boot video device
[ 0.186896] PCI: CLS 16 bytes, default 64
[ 0.187011] Unpacking initramfs...
[ 0.590550] Freeing initrd memory: 13448k freed
[ 0.601612] audit: initializing netlink socket (disabled)
[ 0.601637] type=2000 audit(1551044415.596:1): initialized
[ 0.619956] highmem bounce pool size: 64 pages
[ 0.619965] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.620267] VFS: Disk quotas dquot_6.5.2
[ 0.620330] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.620452] msgmni has been set to 1746
[ 0.620778] alg: No test for stdrng (krng)
[ 0.620840] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.620846] io scheduler noop registered
[ 0.620848] io scheduler deadline registered
[ 0.620874] io scheduler cfq registered (default)
[ 0.621023] pcieport 0000:00:1c.0: setting latency timer to 64
[ 0.621082] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[ 0.621247] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.621295] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.621298] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.621843] ERST: Table is not found!
[ 0.621846] GHES: HEST is not enabled!
[ 0.621875] isapnp: Scanning for PnP cards...
[ 0.975174] isapnp: No Plug & Play device found
[ 0.975301] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.995719] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.060636] 00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.072377] Linux agpgart interface v0.103
[ 1.072575] agpgart-intel 0000:00:00.0: Intel 945G Chipset
[ 1.072657] agpgart-intel 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 1.072782] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.072958] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 1.073206] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.075778] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.075790] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.076091] mousedev: PS/2 mouse device common for all mice
[ 1.076162] rtc_cmos 00:03: RTC can wake from S4
[ 1.076351] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.076433] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 1.076464] cpuidle: using governor ladder
[ 1.076467] cpuidle: using governor menu
[ 1.076983] TCP cubic registered
[ 1.077057] NET: Registered protocol family 10
[ 1.078308] Mobile IPv6
[ 1.078314] NET: Registered protocol family 17
[ 1.078323] Registering the dns_resolver key type
[ 1.078364] Using IPI No-Shortcut mode
[ 1.078575] PM: Hibernation image not present or could not be loaded.
[ 1.078596] registered taskstats version 1
[ 1.078986] rtc_cmos 00:03: setting system clock to 2019-02-24 21:40:16 UTC (1551044416)
[ 1.079051] Initializing network drop monitor service
[ 1.079277] Freeing unused kernel memory: 744k freed
[ 1.079868] Write protecting the kernel text: 2876k
[ 1.079921] Write protecting the kernel read-only data: 1100k
[ 1.079924] NX-protecting the kernel data: 3268k
[ 1.108420] udevd[57]: starting version 175
[ 1.221946] usbcore: registered new interface driver usbfs
[ 1.221993] usbcore: registered new interface driver hub
[ 1.252838] usbcore: registered new device driver usb
[ 1.270308] SCSI subsystem initialized
[ 1.275351] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.275428] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.275434] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.275484] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.275519] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.275533] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.279420] ehci_hcd 0000:00:1d.7: cache line size of 16 is not supported
[ 1.282178] skge: 1.14 addr 0xdfffc000 irq 20 chip Yukon-Lite rev 9
[ 1.283243] skge 0000:01:04.0: eth0: addr 00:18:f3:0d:58:a5
[ 1.289334] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.300461] ehci_hcd 0000:00:1d.7: irq 20, io mem 0xdfeffc00
[ 1.332137] libata version 3.00 loaded.
[ 1.340185] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.340308] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.340313] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.340317] usb usb1: Product: EHCI Host Controller
[ 1.340320] usb usb1: Manufacturer: Linux 3.2.0-6-rt-686-pae ehci_hcd
[ 1.340323] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.340625] hub 1-0:1.0: USB hub found
[ 1.340645] hub 1-0:1.0: 8 ports detected
[ 1.340895] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.340901] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.340921] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.366292] uhci_hcd 0000:00:1d.0: irq 20, io base 0x0000a000
[ 1.366375] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.366380] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.366384] usb usb2: Product: UHCI Host Controller
[ 1.366386] usb usb2: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[ 1.366389] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.366640] hub 2-0:1.0: USB hub found
[ 1.366650] hub 2-0:1.0: 2 ports detected
[ 1.366822] ata_piix 0000:00:1f.1: version 2.13
[ 1.366920] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.387325] Floppy drive(s): fd0 is 1.44M
[ 1.406123] scsi0 : ata_piix
[ 1.411247] scsi1 : ata_piix
[ 1.415777] FDC 0 is a post-1991 82077
[ 1.418665] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.418671] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.419809] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.419816] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.419839] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.423865] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000a400
[ 1.423947] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.423952] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.423955] usb usb3: Product: UHCI Host Controller
[ 1.423958] usb usb3: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[ 1.423961] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.424309] hub 3-0:1.0: USB hub found
[ 1.424321] hub 3-0:1.0: 2 ports detected
[ 1.424566] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.424639] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.434605] scsi2 : ata_piix
[ 1.439553] scsi3 : ata_piix
[ 1.443442] ata3: SATA max UDMA/133 cmd 0xc800 ctl 0xc400 bmdma 0xb400 irq 23
[ 1.443448] ata4: SATA max UDMA/133 cmd 0xc000 ctl 0xb800 bmdma 0xb408 irq 23
[ 1.445761] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.445769] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.445792] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.450351] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000a800
[ 1.450427] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.450432] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.450436] usb usb4: Product: UHCI Host Controller
[ 1.450439] usb usb4: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[ 1.450442] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.450687] hub 4-0:1.0: USB hub found
[ 1.450698] hub 4-0:1.0: 2 ports detected
[ 1.450883] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.450888] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.450906] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.456294] uhci_hcd 0000:00:1d.3: irq 19, io base 0x0000b000
[ 1.456378] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.456382] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.456386] usb usb5: Product: UHCI Host Controller
[ 1.456389] usb usb5: Manufacturer: Linux 3.2.0-6-rt-686-pae uhci_hcd
[ 1.456392] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.456644] hub 5-0:1.0: USB hub found
[ 1.456655] hub 5-0:1.0: 2 ports detected
[ 1.600022] Refined TSC clocksource calibration: 3466.554 MHz.
[ 1.600032] Switching to clocksource tsc
[ 1.623227] ata3.00: ATA-7: Hitachi HDS721680PLA380, P21OAB3A, max UDMA/133
[ 1.623233] ata3.00: 160836480 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.636341] ata3.00: configured for UDMA/133
[ 1.636521] scsi 2:0:0:0: Direct-Access ATA Hitachi HDS72168 P21O PQ: 0 ANSI: 5
[ 1.654721] sd 2:0:0:0: [sda] 160836480 512-byte logical blocks: (82.3 GB/76.6 GiB)
[ 1.654839] sd 2:0:0:0: [sda] Write Protect is off
[ 1.654844] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.654893] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.689097] sda: sda1 sda2 < sda5 >
[ 1.690003] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.693966] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.764034] usb 1-3: new high-speed USB device number 4 using ehci_hcd
[ 1.896928] usb 1-3: New USB device found, idVendor=2a45, idProduct=2004
[ 1.896934] usb 1-3: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1.896938] usb 1-3: Product: M5c
[ 1.896940] usb 1-3: Manufacturer: Meizu
[ 1.896943] usb 1-3: SerialNumber: 710HVBR523L8L
[ 2.136079] usb 2-1: new low-speed USB device number 2 using uhci_hcd
[ 2.304393] usb 2-1: New USB device found, idVendor=1bcf, idProduct=0005
[ 2.304398] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.304402] usb 2-1: Product: USB Optical Mouse
[ 2.332862] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input0
[ 2.333154] generic-usb 0003:1BCF:0005.0001: input,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-0000:00:1d.0-1/input0
[ 2.333502] usbcore: registered new interface driver usbhid
[ 2.333506] usbhid: USB HID core driver
[ 2.548022] usb 2-2: new low-speed USB device number 3 using uhci_hcd
[ 2.715406] usb 2-2: New USB device found, idVendor=2a7a, idProduct=6a08
[ 2.715411] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.715415] usb 2-2: Product: U
[ 2.738791] input: U as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input1
[ 2.739004] generic-usb 0003:2A7A:6A08.0002: input,hidraw1: USB HID v1.10 Keyboard [U] on usb-0000:00:1d.0-2/input0
[ 2.770620] input: U as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/input/input2
[ 2.770794] generic-usb 0003:2A7A:6A08.0003: input,hidraw2: USB HID v1.10 Device [U] on usb-0000:00:1d.0-2/input1
[ 6.951705] microcode: CPU0 sig=0xf65, pf=0x4, revision=0x9
[ 6.958786] platform microcode: firmware: agent loaded intel-ucode/0f-06-05 into memory
[ 6.959146] microcode: CPU0 updated to revision 0xb, date = 2007-05-10
[ 6.959876] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 6.980707] PM: Starting manual resume from disk
[ 6.980714] PM: Hibernation image partition 8:5 present
[ 6.980716] PM: Looking for hibernation image.
[ 6.981009] PM: Image not found (code -22)
[ 6.981012] PM: Hibernation image not present or could not be loaded.
[ 7.038887] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.730403] udevd[355]: starting version 175
[ 8.996958] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 8.996969] ACPI: Power Button [PWRB]
[ 8.997073] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.997080] ACPI: Power Button [PWRF]
[ 9.175520] intel_rng: FWH not detected
[ 9.349122] udevd[405]: renamed network interface eth0 to eth1
[ 9.437025] [drm] Initialized drm 1.1.0 20060810
[ 9.587464] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 9.621521] parport_pc 00:07: reported by Plug and Play ACPI
[ 9.621646] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 9.710497] iTCO_vendor_support: vendor-support=0
[ 9.735365] snd_hda_intel 0000:00:1b.0: irq 41 for MSI/MSI-X
[ 9.735931] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 9.744528] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 9.744676] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 9.746256] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.851064] leds_ss4200: no LED devices found
[ 9.917587] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 9.930916] i915 0000:00:02.0: setting latency timer to 64
[ 9.969570] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.969575] [drm] Driver supports precise vblank timestamp query.
[ 9.970227] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.007656] [drm] initialized overlay support
[ 10.014673] usbcore: registered new interface driver cdc_ether
[ 10.022682] rndis_host 1-3:1.0: usb0: register 'rndis_host' at usb-0000:00:1d.7-3, RNDIS device, b2:bc:32:04:cc:84
[ 10.022731] usbcore: registered new interface driver rndis_host
[ 10.071713] fbcon: inteldrmfb (fb0) is primary device
[ 10.122922] Console: switching to colour frame buffer device 240x67
[ 10.142848] fb0: inteldrmfb frame buffer device
[ 10.142853] drm: registered panic notifier
[ 10.142867] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 11.963895] Adding 3302396k swap on /dev/sda5. Priority:-1 extents:1 across:3302396k
[ 11.991728] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.216521] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.458388] loop: module loaded
[ 14.492715] RPC: Registered named UNIX socket transport module.
[ 14.492720] RPC: Registered udp transport module.
[ 14.492723] RPC: Registered tcp transport module.
[ 14.492726] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.544066] FS-Cache: Loaded
[ 14.591769] FS-Cache: Netfs 'nfs' registered for caching
[ 14.626669] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.101620] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input7
[ 18.159099] Bluetooth: Core ver 2.16
[ 18.159556] NET: Registered protocol family 31
[ 18.159561] Bluetooth: HCI device and connection manager initialized
[ 18.159566] Bluetooth: HCI socket layer initialized
[ 18.159570] Bluetooth: L2CAP socket layer initialized
[ 18.159584] Bluetooth: SCO socket layer initialized
[ 18.195354] Bluetooth: RFCOMM TTY layer initialized
[ 18.195364] Bluetooth: RFCOMM socket layer initialized
[ 18.195367] Bluetooth: RFCOMM ver 1.11
[ 18.270067] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.270073] Bluetooth: BNEP filters: protocol multicast
[ 18.326067] lp0: using parport0 (interrupt-driven).
[ 18.338301] ppdev: user-space parallel port driver
[ 21.175314] skge 0000:01:04.0: eth1: enabling interface
[ 22.863115] skge 0000:01:04.0: eth1: Link is up at 100 Mbps, full duplex, flow control both
[ 31.776018] eth1: no IPv6 routers present
[ 32.440016] usb0: no IPv6 routers present
[ 254.068941] ip_tables: (C) 2000-2006 Netfilter Core Team
