Вот такой вывод в терминале после ввода команды python flatcam.py
________________________
alexander@alexander-ubuntu:~/flatcam$ python flatcam
[INFO][MainThread] FlatCAM Starting...
[DEBUG][MainThread] Application path is /home/alexander/flatcam
[DEBUG][MainThread] Started in /home/alexander/flatcam
[DEBUG][Dummy-1] CanvasCache Thread Started!
[DEBUG][MainThread] Radio toggled
[DEBUG][MainThread] propagate_defaults()
[DEBUG][MainThread] gerber_use_buffer_for_union OK!
[DEBUG][MainThread] cncjob_coordinate_format OK!
[DEBUG][MainThread] zdownrate OK
[DEBUG][MainThread] excellon_zeros OK!
[DEBUG][MainThread] options_write_form_field(): No field for: verbose_error_level
[DEBUG][MainThread] options_write_form_field(): No field for: background_timeout
[DEBUG][MainThread] options_write_form_field(): No field for: cncjob_dwell
[DEBUG][MainThread] options_write_form_field(): No field for: cncjob_coordinate_format
[DEBUG][MainThread] options_write_form_field(): No field for: zoom_ratio
[DEBUG][MainThread] options_write_form_field(): No field for: shell_at_startup
[DEBUG][MainThread] options_write_form_field(): No field for: defaults_save_period_ms
[DEBUG][MainThread] options_write_form_field(): No field for: geometry_paintcontour
[DEBUG][MainThread] options_write_form_field(): No field for: excellon_zeros
[DEBUG][MainThread] options_write_form_field(): No field for: geometry_pathconnect
[DEBUG][MainThread] options_write_form_field(): No field for: zdownrate
[DEBUG][MainThread] options_write_form_field(): No field for: def_win_x
[DEBUG][MainThread] options_write_form_field(): No field for: point_clipboard_format
[DEBUG][MainThread] options_write_form_field(): No field for: cncjob_dwelltime
[DEBUG][MainThread] options_write_form_field(): No field for: gerber_use_buffer_for_union
[DEBUG][MainThread] options_write_form_field(): No field for: def_win_h
[DEBUG][MainThread] options_write_form_field(): No field for: def_win_w
[DEBUG][MainThread] options_write_form_field(): No field for: serial
[DEBUG][MainThread] options_write_form_field(): No field for: shell_shape
[DEBUG][MainThread] options_write_form_field(): No field for: zoom_in_key
[DEBUG][MainThread] options_write_form_field(): No field for: def_win_y
[DEBUG][MainThread] options_write_form_field(): No field for: stats
[DEBUG][MainThread] options_write_form_field(): No field for: recent_limit
[DEBUG][MainThread] options_write_form_field(): No field for: last_folder
[DEBUG][MainThread] options_write_form_field(): No field for: zoom_out_key
[DEBUG][MainThread] options_write_form_field(): No field for: fit_key
[DEBUG][MainThread] Options --> 0
[INFO][MainThread] Starting Worker...
[INFO][MainThread] Checking for updates in backgroud (this is version 8.5).
[DEBUG][MainThread] setup_recent_items()
[DEBUG][Dummy-2] Worker Started!
[DEBUG][Dummy-3] Worker Started!
[DEBUG][MainThread] setup_shell()
[DEBUG][MainThread] END of constructor. Releasing control.
[DEBUG][Dummy-2] Running task: {'worker_name': 'worker2', 'params': [], 'fcn': <bound method App.version_check of <FlatCAMApp.App object at 0xb52f9f5c>>}
[DEBUG][Dummy-2] version_check()
[DEBUG][Dummy-2] Checking for updates @
http://flatcam.org/version?s=33os1s61wn ... defaults=1
[DEBUG][Dummy-3] Running task: {'worker_name': 'worker2', 'params': [], 'fcn': <bound method App.version_check of <FlatCAMApp.App object at 0xb52f9f5c>>}
[DEBUG][Dummy-3] Task ignored.
__________________________________
Что могут значить строки типа:
Надеюсь на помощь Убунту-Гуру. Куда копать?
