Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/nkp/emc2/configs/demo_sim_cl'
Machine configuration file is 'demo_sim_cl.ini'
INIFILE=/home/nkp/emc2/configs/demo_sim_cl/demo_sim_cl.ini
PARAMETER_FILE=demo_sim_cl.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1575
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1575
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   NSC Geode by NSC
[    0.000000]   Cyrix CyrixInstead
[    0.000000]   Centaur CentaurHauls
[    0.000000]   Transmeta GenuineTMx86
[    0.000000]   Transmeta TransmetaCPU
[    0.000000]   UMC UMC UMC UMC
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[    0.000000]  BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 0000000017ff0000 (usable)
[    0.000000]  BIOS-e820: 0000000017ff0000 - 0000000017ff3000 (ACPI NVS)
[    0.000000]  BIOS-e820: 0000000017ff3000 - 0000000018000000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[    0.000000] DMI 2.3 present.
[    0.000000] last_pfn = 0x17ff0 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-C7FFF write-protect
[    0.000000]   C8000-FFFFF uncachable
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FF0000000 write-back
[    0.000000]   1 base 010000000 mask FF8000000 write-back
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 base 0D0000000 mask FFC000000 write-combining
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] modified physical RAM map:
[    0.000000]  modified: 0000000000000000 - 0000000000002000 (usable)
[    0.000000]  modified: 0000000000002000 - 0000000000006000 (reserved)
[    0.000000]  modified: 0000000000006000 - 000000000009fc00 (usable)
[    0.000000]  modified: 000000000009fc00 - 00000000000a0000 (reserved)
[    0.000000]  modified: 00000000000f0000 - 0000000000100000 (reserved)
[    0.000000]  modified: 0000000000100000 - 0000000017ff0000 (usable)
[    0.000000]  modified: 0000000017ff0000 - 0000000017ff3000 (ACPI NVS)
[    0.000000]  modified: 0000000017ff3000 - 0000000018000000 (ACPI data)
[    0.000000]  modified: 00000000ffff0000 - 0000000100000000 (reserved)
[    0.000000] initial memory mapped : 0 - 00c00000
[    0.000000] init_memory_mapping: 0000000000000000-0000000017ff0000
[    0.000000] Using x86 segment limits to approximate NX protection
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0017c00000 page 2M
[    0.000000]  0017c00000 - 0017ff0000 page 4k
[    0.000000] kernel direct mapping tables up to 17ff0000 @ 7000-c000
[    0.000000] RAMDISK: 113b6000 - 120330e0
[    0.000000] ACPI: RSDP 000f7a70 00014 (v00 VIA694)
[    0.000000] ACPI: RSDT 17ff3000 00028 (v01 VIA694 AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: FACP 17ff3040 00074 (v01 VIA694 AWRDACPI 42302E31 AWRD 00000000)
[    0.000000] ACPI: DSDT 17ff30c0 02529 (v01 VIA694 AWRDACPI 00001000 MSFT 0100000C)
[    0.000000] ACPI: FACS 17ff0000 00040
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 383MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 17ff0000
[    0.000000]   low ram: 0 - 17ff0000
[    0.000000]   node 0 low ram: 00000000 - 17ff0000
[    0.000000]   node 0 bootmap 00008000 - 0000b000
[    0.000000] (9 early reservations) ==> bootmem [0000000000 - 0017ff0000]
[    0.000000]   #0 [0000000000 - 0000001000]   BIOS data page ==> [0000000000 - 0000001000]
[    0.000000]   #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
[    0.000000]   #2 [0000006000 - 0000007000]       TRAMPOLINE ==> [0000006000 - 0000007000]
[    0.000000]   #3 [0000100000 - 00008b0db8]    TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[    0.000000]   #4 [00113b6000 - 00120330e0]          RAMDISK ==> [00113b6000 - 00120330e0]
[    0.000000]   #5 [000009fc00 - 0000100000]    BIOS reserved ==> [000009fc00 - 0000100000]
[    0.000000]   #6 [00008b1000 - 00008b40be]              BRK ==> [00008b1000 - 00008b40be]
[    0.000000]   #7 [0000007000 - 0000008000]          PGTABLE ==> [0000007000 - 0000008000]
[    0.000000]   #8 [0000008000 - 000000b000]          BOOTMAP ==> [0000008000 - 000000b000]
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000000 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x00017ff0
[    0.000000]   HighMem  0x00017ff0 -> 0x00017ff0
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[3] active PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00000002
[    0.000000]     0: 0x00000006 -> 0x0000009f
[    0.000000]     0: 0x00000100 -> 0x00017ff0
[    0.000000] On node 0 totalpages: 98187
[    0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3963 pages, LIFO batch:0
[    0.000000]   Normal zone: 736 pages used for memmap
[    0.000000]   Normal zone: 93456 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x4008
[    0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[    0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[    0.000000] APIC: disable apic facility
[    0.000000] nr_irqs_gsi: 16
[    0.000000] Allocating PCI resources starting at 18000000 (gap: 18000000:e7ff0000)
[    0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[    0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[    0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97419
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=f4a67649-de32-468d-bf8c-819c587c79ef ro quiet splash
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Enabling fast FPU save and restore... done.
[    0.000000] Initializing CPU#0
[    0.000000] allocated 1965760 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 366216k/393152k available (4539k kernel code, 26200k reserved, 1928k data, 620k init, 0k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff1e000 - 0xfffff000   ( 900 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xd87f0000 - 0xff7fe000   ( 624 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd7ff0000   ( 383 MB)
[    0.000000]       .init : 0xc0751000 - 0xc07ec000   ( 620 kB)
[    0.000000]       .data : 0xc056ecbc - 0xc0750e68   (1928 kB)
[    0.000000]       .text : 0xc0100000 - 0xc056ecbc   (4539 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:2304 nr_irqs:256
[    0.000000] I-pipe 2.6-03: pipeline enabled.
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 901.640 MHz processor.
[    0.004011] Calibrating delay loop (skipped), value calculated using timer frequency.. 1803.28 BogoMIPS (lpj=3606560)
[    0.004068] Security Framework initialized
[    0.004154] AppArmor: AppArmor initialized
[    0.004178] Mount-cache hash table entries: 512
[    0.004533] Initializing cgroup subsys ns
[    0.004546] Initializing cgroup subsys cpuacct
[    0.004557] Initializing cgroup subsys memory
[    0.004583] Initializing cgroup subsys devices
[    0.004591] Initializing cgroup subsys freezer
[    0.004598] Initializing cgroup subsys net_cls
[    0.004650] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[    0.004658] CPU: L2 Cache: 256K (64 bytes/line)
[    0.004670] mce: CPU supports 4 MCE banks
[    0.004720] Performance Events: AMD PMU driver.
[    0.004757] ... version:                0
[    0.004762] ... bit width:              48
[    0.004766] ... generic registers:      4
[    0.008011] ... value mask:             0000ffffffffffff
[    0.008017] ... max period:             00007fffffffffff
[    0.008023] ... fixed-purpose events:   0
[    0.008028] ... event mask:             000000000000000f
[    0.008041] Checking 'hlt' instruction... OK.
[    0.024200] SMP alternatives: switching to UP code
[    0.037704] Freeing SMP alternatives: 31k freed
[    0.037799] ACPI: Core revision 20090903
[    0.046601] ACPI: setting ELCR to 0200 (from 0e20)
[    0.048111] ftrace: converting mcount calls to 0f 1f 44 00 00
[    0.048141] ftrace: allocating 21003 entries in 42 pages
[    0.063066] Enabling APIC mode:  Flat.  Using 0 I/O APICs
[    0.063082] weird, boot CPU (#0) not listed by the BIOS.
[    0.063087] SMP motherboard not detected.
[    0.063096] Local APIC not detected. Using dummy APIC emulation.
[    0.063101] SMP disabled
[    0.064054] Brought up 1 CPUs
[    0.064062] Total of 1 processors activated (1803.28 BogoMIPS).
[    0.064851] CPU0 attaching NULL sched-domain.
[    0.065373] devtmpfs: initialized
[    0.066226] regulator: core version 0.5
[    0.066374] NET: Registered protocol family 16
[    0.066714] EISA bus registered
[    0.066738] ACPI: bus type pci registered
[    0.099948] PCI: PCI BIOS revision 2.10 entry at 0xfb220, last bus=1
[    0.099955] PCI: Using configuration type 1 for base access
[    0.101912] bio: create slab <bio-0> at 0
[    0.102883] ACPI: EC: Look up EC in DSDT
[    0.109566] ACPI: Interpreter enabled
[    0.109572] ACPI: (supports S0 S5)
[    0.109602] ACPI: Using PIC for interrupt routing
[    0.117969] ACPI: No dock devices found.
[    0.118206] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.118316] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xd0000000-0xd3ffffff]
[    0.118430] pci 0000:00:01.0: supports D1
[    0.118565] pci 0000:00:07.1: reg 20 io port: [0xd000-0xd00f]
[    0.118653] pci 0000:00:07.2: reg 20 io port: [0xd400-0xd41f]
[    0.118732] pci 0000:00:07.3: reg 20 io port: [0xd800-0xd81f]
[    0.118833] pci 0000:00:07.4: quirk: region 6000-607f claimed by vt82c686 HW-mon
[    0.118842] pci 0000:00:07.4: quirk: region 5000-500f claimed by vt82c686 SMB
[    0.118915] pci 0000:00:13.0: reg 10 io port: [0xec00-0xecff]
[    0.118963] pci 0000:00:13.0: supports D1 D2
[    0.119030] pci 0000:01:00.0: reg 10 32bit mmio: [0xd8000000-0xd8ffffff]
[    0.119042] pci 0000:01:00.0: reg 14 32bit mmio pref: [0xd4000000-0xd7ffffff]
[    0.119068] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[    0.119136] pci 0000:00:01.0: bridge 32bit mmio: [0xd8000000-0xd9ffffff]
[    0.119146] pci 0000:00:01.0: bridge 32bit mmio pref: [0xd4000000-0xd7ffffff]
[    0.119159] pci_bus 0000:00: on NUMA node 0
[    0.119171] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.145425] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
[    0.145738] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[    0.146120] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 *10 11 12 14 15)
[    0.146495] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 *5 6 7 10 11 12 14 15)
[    0.146803] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.146812] vgaarb: loaded
[    0.147203] SCSI subsystem initialized
[    0.147500] libata version 3.00 loaded.
[    0.147729] usbcore: registered new interface driver usbfs
[    0.147762] usbcore: registered new interface driver hub
[    0.147848] usbcore: registered new device driver usb
[    0.148247] ACPI: WMI: Mapper loaded
[    0.148254] PCI: Using ACPI for IRQ routing
[    0.148594] NetLabel: Initializing
[    0.148600] NetLabel:  domain hash size = 128
[    0.148605] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.148647] NetLabel:  unlabeled traffic allowed by default
[    0.148745] Switching to clocksource tsc
[    0.153973] AppArmor: AppArmor Filesystem Enabled
[    0.154043] pnp: PnP ACPI init
[    0.154118] ACPI: bus type pnp registered
[    0.160725] pnp: PnP ACPI: found 13 devices
[    0.160731] ACPI: ACPI bus type pnp unregistered
[    0.160745] PnPBIOS: Disabled by ACPI PNP
[    0.160780] system 00:00: iomem range 0xcf000-0xcffff has been reserved
[    0.160789] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[    0.160798] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[    0.160806] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[    0.160815] system 00:00: iomem range 0x17ff0000-0x17ffffff could not be reserved
[    0.160824] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[    0.160833] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[    0.160841] system 00:00: iomem range 0x100000-0x17feffff could not be reserved
[    0.160850] system 00:00: iomem range 0xfec00000-0xfec00fff has been reserved
[    0.160858] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[    0.160877] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[    0.195961] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[    0.195968] pci 0000:00:01.0:   IO window: disabled
[    0.195980] pci 0000:00:01.0:   MEM window: 0xd8000000-0xd9ffffff
[    0.195990] pci 0000:00:01.0:   PREFETCH window: 0xd4000000-0xd7ffffff
[    0.196021] pci 0000:00:01.0: setting latency timer to 64
[    0.196035] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
[    0.196042] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[    0.196051] pci_bus 0000:01: resource 1 mem: [0xd8000000-0xd9ffffff]
[    0.196058] pci_bus 0000:01: resource 2 pref mem [0xd4000000-0xd7ffffff]
[    0.196163] NET: Registered protocol family 2
[    0.196421] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.197149] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.197751] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.198368] TCP: Hash tables configured (established 16384 bind 16384)
[    0.198376] TCP reno registered
[    0.198640] NET: Registered protocol family 1
[    0.198699] pci 0000:00:00.0: Applying VIA southbridge workaround
[    0.198712] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[    0.198724] pci 0000:00:07.0: Disabling VIA external APIC routing
[    0.198786] pci 0000:01:00.0: Boot video device
[    0.199684] Scanning for low memory corruption every 60 seconds
[    0.200043] audit: initializing netlink socket (disabled)
[    0.200081] type=2000 audit(1309085465.199:1): initialized
[    0.220191] Trying to unpack rootfs image as initramfs...
[    0.244029] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.251263] VFS: Disk quotas dquot_6.5.2
[    0.251545] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.253230] fuse init (API version 7.13)
[    0.253468] msgmni has been set to 715
[    0.260081] alg: No test for stdrng (krng)
[    0.260312] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.260323] io scheduler noop registered
[    0.260328] io scheduler anticipatory registered
[    0.260334] io scheduler deadline registered
[    0.260465] io scheduler cfq registered (default)
[    0.260767] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.260829] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.261044] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.261059] ACPI: Power Button [PWRB]
[    0.261187] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[    0.261205] ACPI: Sleep Button [SLPB]
[    0.261374] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.261382] ACPI: Power Button [PWRF]
[    0.264868] isapnp: Scanning for PnP cards...
[    0.270953] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.271177] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.271373] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.271974] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.272208] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.275086] brd: module loaded
[    0.325354] loop: module loaded
[    0.325760] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[    0.332272] Fixed MDIO Bus: probed
[    0.332380] PPP generic driver version 2.4.2
[    0.332612] tun: Universal TUN/TAP device driver, 1.6
[    0.332618] tun: (C) 1999-2004 Max Krasnyansky <
maxk@qualcomm.com>
[    0.332941] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.333043] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.333080] uhci_hcd: USB Universal Host Controller Interface driver
[    0.334160] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[    0.334171] PCI: setting IRQ 5 as level-triggered
[    0.334184] uhci_hcd 0000:00:07.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[    0.334211] uhci_hcd 0000:00:07.2: UHCI Host Controller
[    0.334331] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
[    0.334392] uhci_hcd 0000:00:07.2: irq 5, io base 0x0000d400
[    0.334726] usb usb1: configuration #1 chosen from 1 choice
[    0.334808] hub 1-0:1.0: USB hub found
[    0.334843] hub 1-0:1.0: 2 ports detected
[    0.334981] uhci_hcd 0000:00:07.3: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[    0.334996] uhci_hcd 0000:00:07.3: UHCI Host Controller
[    0.335094] uhci_hcd 0000:00:07.3: new USB bus registered, assigned bus number 2
[    0.339418] uhci_hcd 0000:00:07.3: irq 5, io base 0x0000d800
[    0.339933] usb usb2: configuration #1 chosen from 1 choice
[    0.340043] hub 2-0:1.0: USB hub found
[    0.340083] hub 2-0:1.0: 2 ports detected
[    0.340366] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.340832] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.340865] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.341259] mice: PS/2 mouse device common for all mice
[    0.341798] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[    0.341834] rtc0: alarms up to one year, y3k, 242 bytes nvram
[    0.342110] device-mapper: uevent: version 1.0.3
[    0.344984] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised:
dm-devel@redhat.com
[    0.345227] device-mapper: multipath: version 1.1.0 loaded
[    0.345236] device-mapper: multipath round-robin: version 1.0.0 loaded
[    0.346859] EISA: Probing bus 0 at eisa.0
[    0.346896] Cannot allocate resource for EISA slot 4
[    0.346902] Cannot allocate resource for EISA slot 5
[    0.346908] Cannot allocate resource for EISA slot 6
[    0.346924] EISA: Detected 0 cards.
[    0.346933] cpuidle: using governor ladder
[    0.346939] cpuidle: using governor menu
[    0.348069] TCP cubic registered
[    0.348472] NET: Registered protocol family 10
[    0.349589] lo: Disabled Privacy Extensions
[    0.350317] NET: Registered protocol family 17
[    0.350422] Using IPI No-Shortcut mode
[    0.350739] registered taskstats version 1
[    0.351178] rtc_cmos 00:04: setting system clock to 2011-06-26 10:51:05 UTC (1309085465)
[    0.351188] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.351194] EDD information not available.
[    0.362708] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    0.951439] isapnp: No Plug & Play device found
[    1.526169] Freeing initrd memory: 12788k freed
[    1.582300] Freeing unused kernel memory: 620k freed
[    1.585369] Write protecting the kernel text: 4540k
[    1.585429] Write protecting the kernel read-only data: 1668k
[    1.661098] udev: starting version 151
[    2.118495] Floppy drive(s): fd0 is 1.44M
[    2.136166] FDC 0 is a post-1991 82077
[    2.187240] Linux agpgart interface v0.103
[    2.207810] pata_via 0000:00:07.1: version 0.3.4
[    2.212773] scsi0 : pata_via
[    2.269964] scsi1 : pata_via
[    2.270313] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xd000 irq 14
[    2.270323] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xd008 irq 15
[    2.281437] [drm] Initialized drm 1.1.0 20060810
[    2.281829] agpgart: Detected VIA Twister-K/KT133x/KM133 chipset
[    2.289524] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xd0000000
[    2.432633] ata1.00: ATA-6: Maxtor 2B020H1, WAH21PB0, max UDMA/100
[    2.432643] ata1.00: 40020624 sectors, multi 16: LBA
[    2.432696] ata1.00: limited to UDMA/33 due to 40-wire cable
[    2.448616] ata1.00: configured for UDMA/33
[    2.449037] scsi 0:0:0:0: Direct-Access     ATA      Maxtor 2B020H1   WAH2 PQ: 0 ANSI: 5
[    2.449557] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    2.450489] sd 0:0:0:0: [sda] 40020624 512-byte logical blocks: (20.4 GB/19.0 GiB)
[    2.450634] sd 0:0:0:0: [sda] Write Protect is off
[    2.450644] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.450717] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.451165]  sda:
[    2.604645] ata2.00: ATAPI: HL-DT-ST RW/DVD GCC-4521B, 1.05, max UDMA/33
[    2.620447] ata2.00: configured for UDMA/33
[    2.621467] scsi 1:0:0:0: CD-ROM            HL-DT-ST RW/DVD GCC-4521B 1.05 PQ: 0 ANSI: 5
[    2.624860] sr0: scsi3-mmc drive: 52x/52x writer cd/rw xa/form2 cdda tray
[    2.624873] Uniform CD-ROM driver Revision: 3.20
[    2.625675] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.626035] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    3.806167]  sda1 sda2 < sda5 >
[    3.832711] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.963804] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[    3.963818] PCI: setting IRQ 11 as level-triggered
[    3.963832] nouveau 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[    3.980210] [drm] nouveau 0000:01:00.0: Detected an NV10 generation card (0x018100a2)
[    3.980608] [drm] nouveau 0000:01:00.0: Attempting to load BIOS image from PROM
[    4.302838] [drm] nouveau 0000:01:00.0: ... appears to be valid
[    4.303371] [drm] nouveau 0000:01:00.0: BMP BIOS found
[    4.303379] [drm] nouveau 0000:01:00.0: BMP version 5.36
[    4.303389] [drm] nouveau 0000:01:00.0: Bios version 04.18.20.13
[    4.303400] [drm] nouveau 0000:01:00.0: Found Display Configuration Block version 2.1
[    4.303413] [drm] nouveau 0000:01:00.0: Raw DCB entry 0: 01000300 000088b8
[    4.303424] [drm] nouveau 0000:01:00.0: Raw DCB entry 1: 02020311 00008803
[    4.303859] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode
[    4.303869] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xC7A4
[    4.303938] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xCB52
[    4.360784] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xC8BF
[    4.380097] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xD033
[    4.380133] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xD04F
[    4.380145] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0xCAB9
[    4.380164] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0xCAED
[    4.401517] [TTM] Zone  kernel: Available graphics memory: 189994 kiB.
[    4.401562] [drm] nouveau 0000:01:00.0: 64 MiB VRAM
[    4.401707] agpgart-via 0000:00:00.0: AGP 2.0 bridge
[    4.401741] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[    4.401795] nouveau 0000:01:00.0: putting AGP V2 device into 4x mode
[    4.401804] [drm] nouveau 0000:01:00.0: 64 MiB GART (aperture)
[    4.402352] [drm] nouveau 0000:01:00.0: Allocating FIFO number 0
[    4.405024] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 0
[    4.405057] [drm] nouveau 0000:01:00.0: Initial CRTC_OWNER is 0
[    4.405071] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[    4.455556] [drm] nouveau 0000:01:00.0: Detected a VGA connector
[    4.456238] [drm] nouveau 0000:01:00.0: Detected a TV connector
[    4.457938] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on vga encoder (output 0)
[    4.457949] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[    4.608064] [drm] nouveau 0000:01:00.0: Load detected on output B
[    4.608784] [drm] nouveau 0000:01:00.0: allocated 1024x768 fb: 0x49000, bo d195b200
[    4.609334] fb0: nouveaufb frame buffer device
[    4.609340] registered panic notifier
[    4.609360] [drm] Initialized nouveau 0.0.15 20090420 for 0000:01:00.0 on minor 0
[    4.618896] vga16fb: initializing
[    4.618918] vga16fb: mapped to 0xc00a0000
[    4.618936] vga16fb: not registering due to another framebuffer present
[    5.314722] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on vga encoder (output 0)
[    5.314737] [drm] nouveau 0000:01:00.0: Output VGA-1 is running on CRTC 0 using output A
[    5.334984] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on TV encoder (output 1)
[    5.335004] [drm] nouveau 0000:01:00.0: Output TV-1 is running on CRTC 1 using output B
[    5.336998] Console: switching to colour frame buffer device 90x36
[    5.953186] xor: measuring software checksum speed
[    5.972026]    8regs     :  1287.000 MB/sec
[    5.992024]    8regs_prefetch:  1154.000 MB/sec
[    6.012024]    32regs    :   605.000 MB/sec
[    6.032027]    32regs_prefetch:   678.000 MB/sec
[    6.052023]    pII_mmx   :  2497.000 MB/sec
[    6.072023]    p5_mmx    :  3255.000 MB/sec
[    6.072030] xor: using function: p5_mmx (3255.000 MB/sec)
[    6.081850] device-mapper: dm-raid45: initialized v0.2594b
[    6.326758] EXT4-fs (sda1): mounted filesystem with ordered data mode
[   20.210849] Adding 877560k swap on /dev/sda5.  Priority:-1 extents:1 across:877560k
[   20.348809] udev: starting version 151
[   20.630767] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   20.999122] parport_pc: VIA 686A/8231 detected
[   20.999134] parport_pc: probing current configuration
[   20.999158] parport_pc: Current parallel port base: 0x378
[   20.999219] parport0: PC-style at 0x378, irq 7 [PCSPP,EPP]
[   21.088357] parport_pc: VIA parallel port: io=0x378, irq=7
[   21.204855] lp0: using parport0 (interrupt-driven).
[   21.364795] psmouse serio1: ID: 10 00 64
[   21.947425] ppdev: user-space parallel port driver
[   21.965758] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[   22.402735] type=1505 audit(1309074687.548:2):  operation="profile_load" pid=535 name="/sbin/dhclient3"
[   22.403539] type=1505 audit(1309074687.548:3):  operation="profile_load" pid=535 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   22.403986] type=1505 audit(1309074687.548:4):  operation="profile_load" pid=535 name="/usr/lib/connman/scripts/dhclient-script"
[   22.923763] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[   22.923777] PCI: setting IRQ 10 as level-triggered
[   22.923791] C-Media PCI 0000:00:13.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[   23.505801] type=1505 audit(1309074688.652:5):  operation="profile_load" pid=642 name="/usr/share/gdm/guest-session/Xsession"
[   23.527291] type=1505 audit(1309074688.672:6):  operation="profile_replace" pid=643 name="/sbin/dhclient3"
[   23.541338] type=1505 audit(1309074688.688:7):  operation="profile_replace" pid=643 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   23.541909] type=1505 audit(1309074688.688:8):  operation="profile_replace" pid=643 name="/usr/lib/connman/scripts/dhclient-script"
[   23.653651] type=1505 audit(1309074688.800:9):  operation="profile_load" pid=645 name="/usr/bin/evince"
[   23.731721] type=1505 audit(1309074688.876:10):  operation="profile_load" pid=645 name="/usr/bin/evince-previewer"
[   23.755402] type=1505 audit(1309074688.900:11):  operation="profile_load" pid=645 name="/usr/bin/evince-thumbnailer"
[   24.676204] [drm] nouveau 0000:01:00.0: Load detected on output B
[   24.816368] [drm] nouveau 0000:01:00.0: Load detected on output B
[   24.831700] [drm] nouveau 0000:01:00.0: Allocating FIFO number 1
[   24.839608] [drm] nouveau 0000:01:00.0: nouveau_channel_alloc: initialised FIFO 1
[   25.390068] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 1)
[   25.416871] [drm] nouveau 0000:01:00.0: Setting dpms mode 0 on TV encoder (output 1)
[   25.416883] [drm] nouveau 0000:01:00.0: Output TV-1 is running on CRTC 1 using output B
[   27.680064] [drm] nouveau 0000:01:00.0: Load detected on output B
[   27.924063] [drm] nouveau 0000:01:00.0: Load detected on output B
[   28.168063] [drm] nouveau 0000:01:00.0: Load detected on output B
[   35.368085] [drm] nouveau 0000:01:00.0: Load detected on output B
[  109.423957] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[  678.168069] usb 2-1: new full speed USB device using uhci_hcd and address 2
[  678.569186] usb 2-1: configuration #1 chosen from 1 choice
[  678.674311] Initializing USB Mass Storage driver...
[  678.674698] scsi2 : SCSI emulation for USB Mass Storage devices
[  678.675262] usbcore: registered new interface driver usb-storage
[  678.675271] USB Mass Storage support registered.
[  678.691259] usb-storage: device found at 2
[  678.691271] usb-storage: waiting for device to settle before scanning
[  683.689958] usb-storage: device scan complete
[  683.692922] scsi 2:0:0:0: Direct-Access     Generic  USB Flash Disk   7.76 PQ: 0 ANSI: 2
[  683.701284] sd 2:0:0:0: Attached scsi generic sg2 type 0
[  683.721905] sd 2:0:0:0: [sdb] 16353280 512-byte logical blocks: (8.37 GB/7.79 GiB)
[  683.724897] sd 2:0:0:0: [sdb] Write Protect is off
[  683.724916] sd 2:0:0:0: [sdb] Mode Sense: 03 00 00 00
[  683.724925] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[  683.740146] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[  683.740176]  sdb: sdb1
[  684.219694] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[  684.219720] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[  771.590353] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
